╚═══===═══[~]>> dmesg
[ 0.000000] Linux version 5.9.1-arch1-1 (linux@archlinux) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Sat, 17 Oct 2020 13:30:37 +0000
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=f3908a45-1f60-442a-b4d0-37f888b94027 rw quiet loglevel=3 systemd.show_status=false udev.log-priority=3 vt.global_cursor_default=0
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000000fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000001000-0x000000000008ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000090000-0x0000000000090fff] type 20
[ 0.000000] BIOS-e820: [mem 0x0000000000091000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009d01fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009d02000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20bfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a20c000-0x00000000d9338fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000d9339000-0x00000000d94fafff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000d94fb000-0x00000000d9683fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000d9684000-0x00000000d9783fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000d9784000-0x00000000da4b7fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000da4b8000-0x00000000da552fff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000da553000-0x00000000dcffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dd000000-0x00000000dfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000101f2fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0xd9620000 ACPI=0xd9620000 SMBIOS=0xda39d000 SMBIOS 3.0=0xda39c000 MEMATTR=0xd7bb8698 ESRT=0xd7e89c18
[ 0.000000] SMBIOS 3.2.0 present.
[ 0.000000] DMI: System manufacturer System Product Name/TUF GAMING X570-PLUS, BIOS 1407 04/01/2020
[ 0.000000] tsc: Fast TSC calibration failed
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] last_pfn = 0x101f300 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF write-through
[ 0.000000] C0000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 base 0000C0000000 mask FFFFE0000000 write-back
[ 0.000000] 3 base 0000D9B50000 mask FFFFFFFF0000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000001020000000 aka 66048M
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000000] total RAM covered: 3583M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 128M num_reg: 4 lose cover RAM: 0G
[ 0.000000] e820: update [mem 0xd9b50000-0xd9b5ffff] usable ==> reserved
[ 0.000000] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.000000] last_pfn = 0xdd000 max_arch_pfn = 0x400000000
[ 0.000000] esrt: Reserving ESRT space from 0x00000000d7e89c18 to 0x00000000d7e89c50.
[ 0.000000] e820: update [mem 0xd7e89000-0xd7e89fff] usable ==> reserved
[ 0.000000] check: Scanning 1 areas for low memory corruption
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] Secure boot could not be determined
[ 0.000000] RAMDISK: [mem 0x341cb000-0x360dcfff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000D9620000 000024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x00000000D96200A0 0000B4 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000D962BBE0 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 0x00000000D96201E8 00B9F3 (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.000000] ACPI: FACS 0x00000000D976CE00 000040
[ 0.000000] ACPI: APIC 0x00000000D962BCF8 00015E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000D962BE58 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FIDT 0x00000000D962BEA0 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x00000000D962BF40 000164 (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.000000] ACPI: WSMT 0x00000000D9641838 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x00000000D962C100 008C98 (v02 AMD AMD ALIB 00000002 MSFT 04000000)
[ 0.000000] ACPI: SSDT 0x00000000D9634D98 00368A (v01 AMD AMD AOD 00000001 INTL 20120913)
[ 0.000000] ACPI: MCFG 0x00000000D9638428 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.000000] ACPI: HPET 0x00000000D9638468 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.000000] ACPI: SSDT 0x00000000D96384A0 000024 (v01 AMD BIXBY 00001000 INTL 20120913)
[ 0.000000] ACPI: UEFI 0x00000000D96384C8 000042 (v01 ALASKA A M I 00000002 01000013)
[ 0.000000] ACPI: IVRS 0x00000000D9638510 0000D0 (v02 AMD AMD IVRS 00000001 AMD 00000000)
[ 0.000000] ACPI: PCCT 0x00000000D96385E0 00006E (v01 AMD AMD PCCT 00000001 AMD 00000000)
[ 0.000000] ACPI: SSDT 0x00000000D9638650 005E09 (v01 AMD AMD CPU 00000001 AMD 00000001)
[ 0.000000] ACPI: CRAT 0x00000000D963E460 001658 (v01 AMD AMD CRAT 00000001 AMD 00000001)
[ 0.000000] ACPI: CDIT 0x00000000D963FAB8 000029 (v01 AMD AMD CDIT 00000001 AMD 00000001)
[ 0.000000] ACPI: SSDT 0x00000000D963FAE8 001D4A (v01 AMD AmdTable 00000001 INTL 20120913)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000101f2fffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x101f2fc000-0x101f2fffff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000101f2fffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000008ffff]
[ 0.000000] node 0: [mem 0x0000000000091000-0x000000000009ffff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x0000000009d01fff]
[ 0.000000] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.000000] node 0: [mem 0x000000000a20c000-0x00000000d9338fff]
[ 0.000000] node 0: [mem 0x00000000da553000-0x00000000dcffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000101f2fffff]
[ 0.000000] Zeroed struct page in unavailable ranges: 21126 pages
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000101f2fffff]
[ 0.000000] On node 0 totalpages: 16756090
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 24 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 13996 pages used for memmap
[ 0.000000] DMA32 zone: 895708 pages, LIFO batch:63
[ 0.000000] Normal zone: 247756 pages used for memmap
[ 0.000000] Normal zone: 15856384 pages, LIFO batch:63
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 25, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 26, version 33, address 0xfec01000, GSI 24-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 32 CPUs, 8 hotplug CPUs
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x00090000-0x00090fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x09d02000-0x09ffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20bfff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xd7e89000-0xd7e89fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xd9339000-0xd94fafff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xd94fb000-0xd9683fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xd9684000-0xd9783fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xd9784000-0xda4b7fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xda4b8000-0xda552fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xdd000000-0xdfffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfcffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfd000000-0xffffffff]
[ 0.000000] [mem 0xe0000000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.000000] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:32 nr_node_ids:1
[ 0.000000] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[ 0.000000] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.000000] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16494250
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=f3908a45-1f60-442a-b4d0-37f888b94027 rw quiet loglevel=3 systemd.show_status=false udev.log-priority=3 vt.global_cursor_default=0
[ 0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[ 0.000000] printk: log_buf_len min size: 131072 bytes
[ 0.000000] printk: log_buf_len: 262144 bytes
[ 0.000000] printk: early log buf free: 118916(90%)
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.000000] Memory: 65620352K/67024360K available (14339K kernel code, 1524K rwdata, 7912K rodata, 1660K init, 2928K bss, 1403748K reserved, 0K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.000000] ftrace: allocating 40856 entries in 160 pages
[ 0.000000] ftrace: allocated 160 pages with 2 groups
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.000000] NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] printk: console [tty0] enabled
[ 0.000000] ACPI: Core revision 20200717
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.000000] APIC: Switch to symmetric I/O mode setup
[ 0.003333] Switched APIC routing to physical flat.
[ 0.006666] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.033333] tsc: Unable to calibrate against PIT
[ 0.033333] tsc: using HPET reference calibration
[ 0.033333] tsc: Detected 3792.825 MHz processor
[ 0.000002] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6d57be2a7b4, max_idle_ns: 881590759319 ns
[ 0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 7588.71 BogoMIPS (lpj=12642750)
[ 0.000004] pid_max: default: 32768 minimum: 301
[ 0.001621] efi: memattr: Entry attributes invalid: RO and XP bits both cleared
[ 0.001623] efi: memattr: ! 0x000000090000-0x000000090fff [Runtime Code |RUN| | | | | | | | | | | | ]
[ 0.002713] LSM: Security Framework initializing
[ 0.002715] Yama: becoming mindful.
[ 0.002792] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.002855] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003012] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.003061] LVT offset 1 assigned for vector 0xf9
[ 0.003173] LVT offset 2 assigned for vector 0xf4
[ 0.003203] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[ 0.003203] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.003205] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.003206] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.003206] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.003207] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.003207] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.003208] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.003423] Freeing SMP alternatives memory: 32K
[ 0.110828] smpboot: CPU0: AMD Ryzen 9 3900X 12-Core Processor (family: 0x17, model: 0x71, stepping: 0x0)
[ 0.110882] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.110884] ... version: 0
[ 0.110885] ... bit width: 48
[ 0.110885] ... generic registers: 6
[ 0.110885] ... value mask: 0000ffffffffffff
[ 0.110885] ... max period: 00007fffffffffff
[ 0.110886] ... fixed-purpose events: 0
[ 0.110886] ... event mask: 000000000000003f
[ 0.110906] rcu: Hierarchical SRCU implementation.
[ 0.111022] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.111157] smp: Bringing up secondary CPUs ...
[ 0.111220] x86: Booting SMP configuration:
[ 0.111221] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15 #16 #17 #18 #19 #20 #21 #22 #23
[ 0.163379] smp: Brought up 1 node, 24 CPUs
[ 0.163379] smpboot: Max logical packages: 2
[ 0.163379] smpboot: Total of 24 processors activated (182128.25 BogoMIPS)
[ 0.164696] devtmpfs: initialized
[ 0.164696] x86/mm: Memory block size: 2048MB
[ 0.164696] PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20bfff] (49152 bytes)
[ 0.164696] PM: Registering ACPI NVS region [mem 0xd9684000-0xd9783fff] (1048576 bytes)
[ 0.164696] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.164696] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.166690] pinctrl core: initialized pinctrl subsystem
[ 0.166690] PM: RTC time: 19:39:07, date: 2020-10-24
[ 0.166690] NET: Registered protocol family 16
[ 0.166690] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.166690] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.166690] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.166690] audit: initializing netlink subsys (disabled)
[ 0.166690] audit: type=2000 audit(1603568347.199:1): state=initialized audit_enabled=0 res=1
[ 0.166738] thermal_sys: Registered thermal governor 'fair_share'
[ 0.166738] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.166739] thermal_sys: Registered thermal governor 'step_wise'
[ 0.166739] thermal_sys: Registered thermal governor 'user_space'
[ 0.166739] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.166746] cpuidle: using governor ladder
[ 0.166746] cpuidle: using governor menu
[ 0.166746] Detected 1 PCC Subspaces
[ 0.166746] Registering PCC driver as Mailbox controller
[ 0.166746] ACPI: bus type PCI registered
[ 0.166746] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.166816] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.166819] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.166829] PCI: Using configuration type 1 for base access
[ 0.167806] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.167806] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.170123] ACPI: Added _OSI(Module Device)
[ 0.170123] ACPI: Added _OSI(Processor Device)
[ 0.170124] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.170124] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.170125] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.170126] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.170126] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.180692] ACPI: 7 ACPI AML tables successfully acquired and loaded
[ 0.182011] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.184547] ACPI: Interpreter enabled
[ 0.184558] ACPI: (supports S0 S3 S4 S5)
[ 0.184558] ACPI: Using IOAPIC for interrupt routing
[ 0.184822] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.185059] ACPI: Enabled 2 GPEs in block 00 to 1F
[ 0.191771] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.191775] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.191917] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME LTR DPC]
[ 0.192053] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[ 0.192061] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.192336] PCI host bridge to bus 0000:00
[ 0.192337] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.192338] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.192339] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.192339] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.192340] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.192341] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.192341] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfec02fff window]
[ 0.192342] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[ 0.192342] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.192352] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000
[ 0.192444] pci 0000:00:00.2: [1022:1481] type 00 class 0x080600
[ 0.192541] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000
[ 0.192614] pci 0000:00:01.1: [1022:1483] type 01 class 0x060400
[ 0.192640] pci 0000:00:01.1: enabling Extended Tags
[ 0.192683] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.192808] pci 0000:00:01.2: [1022:1483] type 01 class 0x060400
[ 0.192833] pci 0000:00:01.2: enabling Extended Tags
[ 0.192875] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.192972] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000
[ 0.193045] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000
[ 0.193122] pci 0000:00:03.1: [1022:1483] type 01 class 0x060400
[ 0.193197] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[ 0.193323] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000
[ 0.193398] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000
[ 0.193472] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000
[ 0.193543] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400
[ 0.193565] pci 0000:00:07.1: enabling Extended Tags
[ 0.193602] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.193698] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000
[ 0.193770] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400
[ 0.193794] pci 0000:00:08.1: enabling Extended Tags
[ 0.193833] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.193931] pci 0000:00:08.2: [1022:1484] type 01 class 0x060400
[ 0.193956] pci 0000:00:08.2: enabling Extended Tags
[ 0.193995] pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
[ 0.194095] pci 0000:00:08.3: [1022:1484] type 01 class 0x060400
[ 0.194120] pci 0000:00:08.3: enabling Extended Tags
[ 0.194159] pci 0000:00:08.3: PME# supported from D0 D3hot D3cold
[ 0.194270] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.194388] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.194510] pci 0000:00:18.0: [1022:1440] type 00 class 0x060000
[ 0.194557] pci 0000:00:18.1: [1022:1441] type 00 class 0x060000
[ 0.194602] pci 0000:00:18.2: [1022:1442] type 00 class 0x060000
[ 0.194647] pci 0000:00:18.3: [1022:1443] type 00 class 0x060000
[ 0.194691] pci 0000:00:18.4: [1022:1444] type 00 class 0x060000
[ 0.194740] pci 0000:00:18.5: [1022:1445] type 00 class 0x060000
[ 0.194788] pci 0000:00:18.6: [1022:1446] type 00 class 0x060000
[ 0.194834] pci 0000:00:18.7: [1022:1447] type 00 class 0x060000
[ 0.194934] pci 0000:01:00.0: [144d:a808] type 00 class 0x010802
[ 0.194952] pci 0000:01:00.0: reg 0x10: [mem 0xf7d00000-0xf7d03fff 64bit]
[ 0.195153] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.195157] pci 0000:00:01.1: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.195214] pci 0000:02:00.0: [1022:57ad] type 01 class 0x060400
[ 0.195268] pci 0000:02:00.0: enabling Extended Tags
[ 0.195349] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.195447] pci 0000:02:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 126.024 Gb/s with 16.0 GT/s PCIe x8 link)
[ 0.195513] pci 0000:00:01.2: PCI bridge to [bus 02-08]
[ 0.195516] pci 0000:00:01.2: bridge window [io 0xd000-0xefff]
[ 0.195518] pci 0000:00:01.2: bridge window [mem 0xf7200000-0xf77fffff]
[ 0.195790] pci 0000:03:04.0: [1022:57a3] type 01 class 0x060400
[ 0.195863] pci 0000:03:04.0: enabling Extended Tags
[ 0.196045] pci 0000:03:04.0: PME# supported from D0 D3hot D3cold
[ 0.196290] pci 0000:03:05.0: [1022:57a3] type 01 class 0x060400
[ 0.196363] pci 0000:03:05.0: enabling Extended Tags
[ 0.196545] pci 0000:03:05.0: PME# supported from D0 D3hot D3cold
[ 0.196797] pci 0000:03:08.0: [1022:57a4] type 01 class 0x060400
[ 0.196866] pci 0000:03:08.0: enabling Extended Tags
[ 0.197020] pci 0000:03:08.0: PME# supported from D0 D3hot D3cold
[ 0.197236] pci 0000:03:09.0: [1022:57a4] type 01 class 0x060400
[ 0.197305] pci 0000:03:09.0: enabling Extended Tags
[ 0.197458] pci 0000:03:09.0: PME# supported from D0 D3hot D3cold
[ 0.197647] pci 0000:03:0a.0: [1022:57a4] type 01 class 0x060400
[ 0.197716] pci 0000:03:0a.0: enabling Extended Tags
[ 0.197870] pci 0000:03:0a.0: PME# supported from D0 D3hot D3cold
[ 0.198088] pci 0000:02:00.0: PCI bridge to [bus 03-08]
[ 0.198094] pci 0000:02:00.0: bridge window [io 0xd000-0xefff]
[ 0.198097] pci 0000:02:00.0: bridge window [mem 0xf7200000-0xf77fffff]
[ 0.198218] pci 0000:04:00.0: [10ec:8178] type 00 class 0x028000
[ 0.198243] pci 0000:04:00.0: reg 0x10: [io 0xe000-0xe0ff]
[ 0.198275] pci 0000:04:00.0: reg 0x18: [mem 0xf7700000-0xf7703fff 64bit]
[ 0.198430] pci 0000:04:00.0: supports D1 D2
[ 0.198430] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.198623] pci 0000:03:04.0: PCI bridge to [bus 04]
[ 0.198629] pci 0000:03:04.0: bridge window [io 0xe000-0xefff]
[ 0.198633] pci 0000:03:04.0: bridge window [mem 0xf7700000-0xf77fffff]
[ 0.198755] pci 0000:05:00.0: [10ec:8168] type 00 class 0x020000
[ 0.198782] pci 0000:05:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.198819] pci 0000:05:00.0: reg 0x18: [mem 0xf7604000-0xf7604fff 64bit]
[ 0.198841] pci 0000:05:00.0: reg 0x20: [mem 0xf7600000-0xf7603fff 64bit]
[ 0.198984] pci 0000:05:00.0: supports D1 D2
[ 0.198984] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.199204] pci 0000:03:05.0: PCI bridge to [bus 05]
[ 0.199210] pci 0000:03:05.0: bridge window [io 0xd000-0xdfff]
[ 0.199213] pci 0000:03:05.0: bridge window [mem 0xf7600000-0xf76fffff]
[ 0.199339] pci 0000:06:00.0: [1022:1485] type 00 class 0x130000
[ 0.199405] pci 0000:06:00.0: enabling Extended Tags
[ 0.199559] pci 0000:06:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.199753] pci 0000:06:00.1: [1022:149c] type 00 class 0x0c0330
[ 0.200162] pci 0000:06:00.1: reg 0x10: [mem 0xf7300000-0xf73fffff 64bit]
[ 0.200890] pci 0000:06:00.1: enabling Extended Tags
[ 0.201432] pci 0000:06:00.1: PME# supported from D0 D3hot D3cold
[ 0.201739] pci 0000:06:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.201763] pci 0000:06:00.3: reg 0x10: [mem 0xf7200000-0xf72fffff 64bit]
[ 0.201822] pci 0000:06:00.3: enabling Extended Tags
[ 0.201897] pci 0000:06:00.3: PME# supported from D0 D3hot D3cold
[ 0.202068] pci 0000:03:08.0: PCI bridge to [bus 06]
[ 0.202076] pci 0000:03:08.0: bridge window [mem 0xf7200000-0xf73fffff]
[ 0.202181] pci 0000:07:00.0: [1022:7901] type 00 class 0x010601
[ 0.202250] pci 0000:07:00.0: reg 0x24: [mem 0xf7500000-0xf75007ff]
[ 0.202269] pci 0000:07:00.0: enabling Extended Tags
[ 0.202361] pci 0000:07:00.0: PME# supported from D3hot D3cold
[ 0.202441] pci 0000:07:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.202515] pci 0000:03:09.0: PCI bridge to [bus 07]
[ 0.202523] pci 0000:03:09.0: bridge window [mem 0xf7500000-0xf75fffff]
[ 0.202628] pci 0000:08:00.0: [1022:7901] type 00 class 0x010601
[ 0.202698] pci 0000:08:00.0: reg 0x24: [mem 0xf7400000-0xf74007ff]
[ 0.202716] pci 0000:08:00.0: enabling Extended Tags
[ 0.202809] pci 0000:08:00.0: PME# supported from D3hot D3cold
[ 0.202889] pci 0000:08:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.202960] pci 0000:03:0a.0: PCI bridge to [bus 08]
[ 0.202968] pci 0000:03:0a.0: bridge window [mem 0xf7400000-0xf74fffff]
[ 0.203062] pci 0000:09:00.0: [10de:1f06] type 00 class 0x030000
[ 0.203076] pci 0000:09:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[ 0.203088] pci 0000:09:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.203100] pci 0000:09:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.203108] pci 0000:09:00.0: reg 0x24: [io 0xf000-0xf07f]
[ 0.203115] pci 0000:09:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[ 0.203130] pci 0000:09:00.0: BAR 1: assigned to efifb
[ 0.203182] pci 0000:09:00.0: PME# supported from D0 D3hot D3cold
[ 0.203260] pci 0000:09:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:03.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.203296] pci 0000:09:00.1: [10de:10f9] type 00 class 0x040300
[ 0.203308] pci 0000:09:00.1: reg 0x10: [mem 0xf7080000-0xf7083fff]
[ 0.203447] pci 0000:09:00.2: [10de:1ada] type 00 class 0x0c0330
[ 0.203465] pci 0000:09:00.2: reg 0x10: [mem 0xf2000000-0xf203ffff 64bit pref]
[ 0.203484] pci 0000:09:00.2: reg 0x1c: [mem 0xf2040000-0xf204ffff 64bit pref]
[ 0.203545] pci 0000:09:00.2: PME# supported from D0 D3hot D3cold
[ 0.203597] pci 0000:09:00.3: [10de:1adb] type 00 class 0x0c8000
[ 0.203609] pci 0000:09:00.3: reg 0x10: [mem 0xf7084000-0xf7084fff]
[ 0.203685] pci 0000:09:00.3: PME# supported from D0 D3hot D3cold
[ 0.203780] pci 0000:00:03.1: PCI bridge to [bus 09]
[ 0.203783] pci 0000:00:03.1: bridge window [io 0xf000-0xffff]
[ 0.203785] pci 0000:00:03.1: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.203788] pci 0000:00:03.1: bridge window [mem 0xe0000000-0xf20fffff 64bit pref]
[ 0.203828] pci 0000:0a:00.0: [1022:148a] type 00 class 0x130000
[ 0.203855] pci 0000:0a:00.0: enabling Extended Tags
[ 0.203965] pci 0000:00:07.1: PCI bridge to [bus 0a]
[ 0.204021] pci 0000:0b:00.0: [1022:1485] type 00 class 0x130000
[ 0.204053] pci 0000:0b:00.0: enabling Extended Tags
[ 0.204163] pci 0000:0b:00.1: [1022:1486] type 00 class 0x108000
[ 0.204178] pci 0000:0b:00.1: reg 0x18: [mem 0xf7900000-0xf79fffff]
[ 0.204189] pci 0000:0b:00.1: reg 0x24: [mem 0xf7a08000-0xf7a09fff]
[ 0.204197] pci 0000:0b:00.1: enabling Extended Tags
[ 0.204297] pci 0000:0b:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.204310] pci 0000:0b:00.3: reg 0x10: [mem 0xf7800000-0xf78fffff 64bit]
[ 0.204339] pci 0000:0b:00.3: enabling Extended Tags
[ 0.204383] pci 0000:0b:00.3: PME# supported from D0 D3hot D3cold
[ 0.204452] pci 0000:0b:00.4: [1022:1487] type 00 class 0x040300
[ 0.204460] pci 0000:0b:00.4: reg 0x10: [mem 0xf7a00000-0xf7a07fff]
[ 0.204485] pci 0000:0b:00.4: enabling Extended Tags
[ 0.204526] pci 0000:0b:00.4: PME# supported from D0 D3hot D3cold
[ 0.204614] pci 0000:00:08.1: PCI bridge to [bus 0b]
[ 0.204618] pci 0000:00:08.1: bridge window [mem 0xf7800000-0xf7afffff]
[ 0.204664] pci 0000:0c:00.0: [1022:7901] type 00 class 0x010601
[ 0.204698] pci 0000:0c:00.0: reg 0x24: [mem 0xf7c00000-0xf7c007ff]
[ 0.204708] pci 0000:0c:00.0: enabling Extended Tags
[ 0.204761] pci 0000:0c:00.0: PME# supported from D3hot D3cold
[ 0.204853] pci 0000:00:08.2: PCI bridge to [bus 0c]
[ 0.204857] pci 0000:00:08.2: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.204902] pci 0000:0d:00.0: [1022:7901] type 00 class 0x010601
[ 0.204936] pci 0000:0d:00.0: reg 0x24: [mem 0xf7b00000-0xf7b007ff]
[ 0.204946] pci 0000:0d:00.0: enabling Extended Tags
[ 0.204998] pci 0000:0d:00.0: PME# supported from D3hot D3cold
[ 0.205089] pci 0000:00:08.3: PCI bridge to [bus 0d]
[ 0.205093] pci 0000:00:08.3: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.205438] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 11 14 15) *0
[ 0.205480] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 11 14 15) *0
[ 0.205516] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 11 14 15) *0
[ 0.205560] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 10 11 14 15) *0
[ 0.205600] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[ 0.205633] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[ 0.205666] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[ 0.205698] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[ 0.206671] iommu: Default domain type: Translated
[ 0.206693] pci 0000:09:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.206697] pci 0000:09:00.0: vgaarb: bridge control possible
[ 0.206698] pci 0000:09:00.0: vgaarb: setting as boot device
[ 0.206698] vgaarb: loaded
[ 0.206835] SCSI subsystem initialized
[ 0.206870] libata version 3.00 loaded.
[ 0.206870] ACPI: bus type USB registered
[ 0.206870] usbcore: registered new interface driver usbfs
[ 0.206870] usbcore: registered new interface driver hub
[ 0.206870] usbcore: registered new device driver usb
[ 0.206870] pps_core: LinuxPPS API ver. 1 registered
[ 0.206870] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.206870] PTP clock support registered
[ 0.206870] EDAC MC: Ver: 3.0.0
[ 0.206899] Registered efivars operations
[ 0.206899] NetLabel: Initializing
[ 0.206899] NetLabel: domain hash size = 128
[ 0.206899] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.206899] NetLabel: unlabeled traffic allowed by default
[ 0.206899] PCI: Using ACPI for IRQ routing
[ 0.207689] PCI: pci_cache_line_size set to 64 bytes
[ 0.207809] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.207810] e820: reserve RAM buffer [mem 0x09d02000-0x0bffffff]
[ 0.207811] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.207811] e820: reserve RAM buffer [mem 0xd7e89000-0xd7ffffff]
[ 0.207811] e820: reserve RAM buffer [mem 0xd9339000-0xdbffffff]
[ 0.207812] e820: reserve RAM buffer [mem 0xdd000000-0xdfffffff]
[ 0.207812] e820: reserve RAM buffer [mem 0x101f300000-0x101fffffff]
[ 0.207815] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.207815] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.210005] clocksource: Switched to clocksource tsc-early
[ 0.216884] VFS: Disk quotas dquot_6.6.0
[ 0.216895] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.216936] pnp: PnP ACPI init
[ 0.217033] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.217036] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.217105] system 00:01: [mem 0xfd000000-0xfd0fffff] has been reserved
[ 0.217106] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.217141] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.217243] system 00:03: [io 0x0290-0x029f] has been reserved
[ 0.217244] system 00:03: [io 0x0200-0x021f] has been reserved
[ 0.217245] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.217436] pnp 00:04: [dma 0 disabled]
[ 0.217456] pnp 00:04: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.217654] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.217655] system 00:05: [io 0x040b] has been reserved
[ 0.217655] system 00:05: [io 0x04d6] has been reserved
[ 0.217656] system 00:05: [io 0x0c00-0x0c01] has been reserved
[ 0.217656] system 00:05: [io 0x0c14] has been reserved
[ 0.217657] system 00:05: [io 0x0c50-0x0c51] has been reserved
[ 0.217658] system 00:05: [io 0x0c52] has been reserved
[ 0.217658] system 00:05: [io 0x0c6c] has been reserved
[ 0.217659] system 00:05: [io 0x0c6f] has been reserved
[ 0.217660] system 00:05: [io 0x0cd0-0x0cd1] has been reserved
[ 0.217660] system 00:05: [io 0x0cd2-0x0cd3] has been reserved
[ 0.217661] system 00:05: [io 0x0cd4-0x0cd5] has been reserved
[ 0.217661] system 00:05: [io 0x0cd6-0x0cd7] has been reserved
[ 0.217662] system 00:05: [io 0x0cd8-0x0cdf] has been reserved
[ 0.217663] system 00:05: [io 0x0800-0x089f] has been reserved
[ 0.217663] system 00:05: [io 0x0b00-0x0b0f] has been reserved
[ 0.217664] system 00:05: [io 0x0b20-0x0b3f] has been reserved
[ 0.217665] system 00:05: [io 0x0900-0x090f] has been reserved
[ 0.217665] system 00:05: [io 0x0910-0x091f] has been reserved
[ 0.217666] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.217667] system 00:05: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.217668] system 00:05: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.217668] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.217669] system 00:05: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.217670] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.217671] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.217672] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.218003] pnp: PnP ACPI: found 6 devices
[ 0.223232] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.223269] NET: Registered protocol family 2
[ 0.223478] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.223742] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.224166] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.224227] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.224388] MPTCP token hash table entries: 65536 (order: 8, 1572864 bytes, linear)
[ 0.224518] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.224637] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.224738] NET: Registered protocol family 1
[ 0.224740] NET: Registered protocol family 44
[ 0.224752] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.224756] pci 0000:00:01.1: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.224760] pci 0000:03:04.0: PCI bridge to [bus 04]
[ 0.224762] pci 0000:03:04.0: bridge window [io 0xe000-0xefff]
[ 0.224767] pci 0000:03:04.0: bridge window [mem 0xf7700000-0xf77fffff]
[ 0.224776] pci 0000:03:05.0: PCI bridge to [bus 05]
[ 0.224778] pci 0000:03:05.0: bridge window [io 0xd000-0xdfff]
[ 0.224783] pci 0000:03:05.0: bridge window [mem 0xf7600000-0xf76fffff]
[ 0.224792] pci 0000:03:08.0: PCI bridge to [bus 06]
[ 0.224797] pci 0000:03:08.0: bridge window [mem 0xf7200000-0xf73fffff]
[ 0.224806] pci 0000:03:09.0: PCI bridge to [bus 07]
[ 0.224810] pci 0000:03:09.0: bridge window [mem 0xf7500000-0xf75fffff]
[ 0.224819] pci 0000:03:0a.0: PCI bridge to [bus 08]
[ 0.224823] pci 0000:03:0a.0: bridge window [mem 0xf7400000-0xf74fffff]
[ 0.224832] pci 0000:02:00.0: PCI bridge to [bus 03-08]
[ 0.224834] pci 0000:02:00.0: bridge window [io 0xd000-0xefff]
[ 0.224838] pci 0000:02:00.0: bridge window [mem 0xf7200000-0xf77fffff]
[ 0.224847] pci 0000:00:01.2: PCI bridge to [bus 02-08]
[ 0.224848] pci 0000:00:01.2: bridge window [io 0xd000-0xefff]
[ 0.224850] pci 0000:00:01.2: bridge window [mem 0xf7200000-0xf77fffff]
[ 0.224855] pci 0000:00:03.1: PCI bridge to [bus 09]
[ 0.224856] pci 0000:00:03.1: bridge window [io 0xf000-0xffff]
[ 0.224858] pci 0000:00:03.1: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.224860] pci 0000:00:03.1: bridge window [mem 0xe0000000-0xf20fffff 64bit pref]
[ 0.224863] pci 0000:00:07.1: PCI bridge to [bus 0a]
[ 0.224869] pci 0000:00:08.1: PCI bridge to [bus 0b]
[ 0.224871] pci 0000:00:08.1: bridge window [mem 0xf7800000-0xf7afffff]
[ 0.224875] pci 0000:00:08.2: PCI bridge to [bus 0c]
[ 0.224878] pci 0000:00:08.2: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.224882] pci 0000:00:08.3: PCI bridge to [bus 0d]
[ 0.224884] pci 0000:00:08.3: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.224888] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.224889] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.224890] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.224891] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.224891] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.224892] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.224892] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xfec02fff window]
[ 0.224893] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[ 0.224894] pci_bus 0000:01: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.224894] pci_bus 0000:02: resource 0 [io 0xd000-0xefff]
[ 0.224895] pci_bus 0000:02: resource 1 [mem 0xf7200000-0xf77fffff]
[ 0.224895] pci_bus 0000:03: resource 0 [io 0xd000-0xefff]
[ 0.224896] pci_bus 0000:03: resource 1 [mem 0xf7200000-0xf77fffff]
[ 0.224897] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 0.224897] pci_bus 0000:04: resource 1 [mem 0xf7700000-0xf77fffff]
[ 0.224898] pci_bus 0000:05: resource 0 [io 0xd000-0xdfff]
[ 0.224898] pci_bus 0000:05: resource 1 [mem 0xf7600000-0xf76fffff]
[ 0.224899] pci_bus 0000:06: resource 1 [mem 0xf7200000-0xf73fffff]
[ 0.224900] pci_bus 0000:07: resource 1 [mem 0xf7500000-0xf75fffff]
[ 0.224900] pci_bus 0000:08: resource 1 [mem 0xf7400000-0xf74fffff]
[ 0.224901] pci_bus 0000:09: resource 0 [io 0xf000-0xffff]
[ 0.224902] pci_bus 0000:09: resource 1 [mem 0xf6000000-0xf70fffff]
[ 0.224902] pci_bus 0000:09: resource 2 [mem 0xe0000000-0xf20fffff 64bit pref]
[ 0.224903] pci_bus 0000:0b: resource 1 [mem 0xf7800000-0xf7afffff]
[ 0.224903] pci_bus 0000:0c: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.224904] pci_bus 0000:0d: resource 1 [mem 0xf7b00000-0xf7bfffff]
[ 0.225304] pci 0000:09:00.1: D0 power state depends on 0000:09:00.0
[ 0.225326] pci 0000:09:00.2: D0 power state depends on 0000:09:00.0
[ 0.225476] pci 0000:09:00.3: D0 power state depends on 0000:09:00.0
[ 0.225601] PCI: CLS 64 bytes, default 64
[ 0.225625] Trying to unpack rootfs image as initramfs...
[ 0.516198] Freeing initrd memory: 31816K
[ 0.516216] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.516267] pci 0000:00:01.0: Adding to iommu group 0
[ 0.516275] pci 0000:00:01.1: Adding to iommu group 1
[ 0.516282] pci 0000:00:01.2: Adding to iommu group 2
[ 0.516292] pci 0000:00:02.0: Adding to iommu group 3
[ 0.516302] pci 0000:00:03.0: Adding to iommu group 4
[ 0.516309] pci 0000:00:03.1: Adding to iommu group 5
[ 0.516318] pci 0000:00:04.0: Adding to iommu group 6
[ 0.516327] pci 0000:00:05.0: Adding to iommu group 7
[ 0.516337] pci 0000:00:07.0: Adding to iommu group 8
[ 0.516344] pci 0000:00:07.1: Adding to iommu group 9
[ 0.516356] pci 0000:00:08.0: Adding to iommu group 10
[ 0.516364] pci 0000:00:08.1: Adding to iommu group 11
[ 0.516371] pci 0000:00:08.2: Adding to iommu group 12
[ 0.516379] pci 0000:00:08.3: Adding to iommu group 13
[ 0.516390] pci 0000:00:14.0: Adding to iommu group 14
[ 0.516397] pci 0000:00:14.3: Adding to iommu group 14
[ 0.516426] pci 0000:00:18.0: Adding to iommu group 15
[ 0.516432] pci 0000:00:18.1: Adding to iommu group 15
[ 0.516439] pci 0000:00:18.2: Adding to iommu group 15
[ 0.516445] pci 0000:00:18.3: Adding to iommu group 15
[ 0.516451] pci 0000:00:18.4: Adding to iommu group 15
[ 0.516459] pci 0000:00:18.5: Adding to iommu group 15
[ 0.516468] pci 0000:00:18.6: Adding to iommu group 15
[ 0.516474] pci 0000:00:18.7: Adding to iommu group 15
[ 0.516482] pci 0000:01:00.0: Adding to iommu group 16
[ 0.516490] pci 0000:02:00.0: Adding to iommu group 17
[ 0.516521] pci 0000:03:04.0: Adding to iommu group 18
[ 0.516552] pci 0000:03:05.0: Adding to iommu group 19
[ 0.516563] pci 0000:03:08.0: Adding to iommu group 20
[ 0.516573] pci 0000:03:09.0: Adding to iommu group 21
[ 0.516583] pci 0000:03:0a.0: Adding to iommu group 22
[ 0.516615] pci 0000:04:00.0: Adding to iommu group 23
[ 0.516647] pci 0000:05:00.0: Adding to iommu group 24
[ 0.516650] pci 0000:06:00.0: Adding to iommu group 20
[ 0.516653] pci 0000:06:00.1: Adding to iommu group 20
[ 0.516656] pci 0000:06:00.3: Adding to iommu group 20
[ 0.516659] pci 0000:07:00.0: Adding to iommu group 21
[ 0.516663] pci 0000:08:00.0: Adding to iommu group 22
[ 0.516683] pci 0000:09:00.0: Adding to iommu group 25
[ 0.516695] pci 0000:09:00.1: Adding to iommu group 25
[ 0.516704] pci 0000:09:00.2: Adding to iommu group 25
[ 0.516713] pci 0000:09:00.3: Adding to iommu group 25
[ 0.516721] pci 0000:0a:00.0: Adding to iommu group 26
[ 0.516730] pci 0000:0b:00.0: Adding to iommu group 27
[ 0.516739] pci 0000:0b:00.1: Adding to iommu group 28
[ 0.516748] pci 0000:0b:00.3: Adding to iommu group 29
[ 0.516757] pci 0000:0b:00.4: Adding to iommu group 30
[ 0.516765] pci 0000:0c:00.0: Adding to iommu group 31
[ 0.516772] pci 0000:0d:00.0: Adding to iommu group 32
[ 0.520927] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.520928] pci 0000:00:00.2: AMD-Vi: Extended features (0x58f77ef22294ade):
[ 0.520928] PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.520930] AMD-Vi: Interrupt remapping enabled
[ 0.520930] AMD-Vi: Virtual APIC enabled
[ 0.520930] AMD-Vi: X2APIC enabled
[ 0.521043] AMD-Vi: Lazy IO/TLB flushing enabled
[ 0.521794] amd_uncore: AMD NB counters detected
[ 0.521797] amd_uncore: AMD LLC counters detected
[ 0.522247] LVT offset 0 assigned for vector 0x400
[ 0.522480] perf: AMD IBS detected (0x000003ff)
[ 0.522484] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.522519] check: Scanning for low memory corruption every 60 seconds
[ 0.522891] Initialise system trusted keyrings
[ 0.522904] Key type blacklist registered
[ 0.522951] workingset: timestamp_bits=41 max_order=24 bucket_order=0
[ 0.523564] zbud: loaded
[ 0.526009] Key type asymmetric registered
[ 0.526010] Asymmetric key parser 'x509' registered
[ 0.526015] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.526062] io scheduler mq-deadline registered
[ 0.526062] io scheduler kyber registered
[ 0.526074] io scheduler bfq registered
[ 0.526739] pcieport 0000:00:07.1: AER: enabled with IRQ 31
[ 0.526866] pcieport 0000:00:08.1: AER: enabled with IRQ 32
[ 0.527024] pcieport 0000:00:08.2: AER: enabled with IRQ 33
[ 0.527178] pcieport 0000:00:08.3: AER: enabled with IRQ 34
[ 0.528202] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.528243] efifb: probing for efifb
[ 0.528266] efifb: No BGRT, not showing boot graphics
[ 0.528266] efifb: framebuffer at 0xe0000000, using 3072k, total 3072k
[ 0.528267] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.528267] efifb: scrolling: redraw
[ 0.528268] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.528294] fbcon: Deferring console take-over
[ 0.528295] fb0: EFI VGA frame buffer device
[ 0.528344] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.528359] ACPI: Power Button [PWRB]
[ 0.528384] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.531215] ACPI: Power Button [PWRF]
[ 0.531301] Monitor-Mwait will be used to enter C-1 state
[ 0.531305] ACPI: \_PR_.C000: Found 2 idle states
[ 0.531416] ACPI: \_PR_.C002: Found 2 idle states
[ 0.531476] ACPI: \_PR_.C004: Found 2 idle states
[ 0.531604] ACPI: \_PR_.C006: Found 2 idle states
[ 0.531667] ACPI: \_PR_.C008: Found 2 idle states
[ 0.531738] ACPI: \_PR_.C00A: Found 2 idle states
[ 0.531861] ACPI: \_PR_.C00C: Found 2 idle states
[ 0.531922] ACPI: \_PR_.C00E: Found 2 idle states
[ 0.532014] ACPI: \_PR_.C010: Found 2 idle states
[ 0.532088] ACPI: \_PR_.C012: Found 2 idle states
[ 0.532180] ACPI: \_PR_.C014: Found 2 idle states
[ 0.532250] ACPI: \_PR_.C016: Found 2 idle states
[ 0.532306] ACPI: \_PR_.C001: Found 2 idle states
[ 0.532406] ACPI: \_PR_.C003: Found 2 idle states
[ 0.532507] ACPI: \_PR_.C005: Found 2 idle states
[ 0.532618] ACPI: \_PR_.C007: Found 2 idle states
[ 0.532732] ACPI: \_PR_.C009: Found 2 idle states
[ 0.532822] ACPI: \_PR_.C00B: Found 2 idle states
[ 0.532899] ACPI: \_PR_.C00D: Found 2 idle states
[ 0.532982] ACPI: \_PR_.C00F: Found 2 idle states
[ 0.533070] ACPI: \_PR_.C011: Found 2 idle states
[ 0.533145] ACPI: \_PR_.C013: Found 2 idle states
[ 0.533233] ACPI: \_PR_.C015: Found 2 idle states
[ 0.533360] ACPI: \_PR_.C017: Found 2 idle states
[ 0.533588] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.533723] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.534276] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.535544] nvme nvme0: pci function 0000:01:00.0
[ 0.535575] ahci 0000:07:00.0: version 3.0
[ 0.535762] ahci 0000:07:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.535763] ahci 0000:07:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.535907] scsi host0: ahci
[ 0.535944] ata1: SATA max UDMA/133 abar m2048@0xf7500000 port 0xf7500100 irq 44
[ 0.536065] ahci 0000:08:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.536066] ahci 0000:08:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.536204] scsi host1: ahci
[ 0.536227] ata2: SATA max UDMA/133 abar m2048@0xf7400000 port 0xf7400100 irq 45
[ 0.536323] ahci 0000:0c:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.536324] ahci 0000:0c:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.536412] scsi host2: ahci
[ 0.536432] ata3: SATA max UDMA/133 abar m2048@0xf7c00000 port 0xf7c00100 irq 47
[ 0.536522] ahci 0000:0d:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.536523] ahci 0000:0d:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.536630] scsi host3: ahci
[ 0.536651] ata4: SATA max UDMA/133 abar m2048@0xf7b00000 port 0xf7b00100 irq 49
[ 0.536674] usbcore: registered new interface driver usbserial_generic
[ 0.536676] usbserial: USB Serial support registered for generic
[ 0.536691] rtc_cmos 00:02: RTC can wake from S4
[ 0.536844] rtc_cmos 00:02: registered as rtc0
[ 0.536896] rtc_cmos 00:02: setting system clock to 2020-10-24T19:39:08 UTC (1603568348)
[ 0.536905] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.537216] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.537284] drop_monitor: Initializing network drop monitor service
[ 0.537376] NET: Registered protocol family 10
[ 0.540411] Segment Routing with IPv6
[ 0.540411] RPL Segment Routing with IPv6
[ 0.540421] NET: Registered protocol family 17
[ 0.541628] microcode: CPU0: patch_level=0x08701013
[ 0.541634] microcode: CPU1: patch_level=0x08701013
[ 0.541639] microcode: CPU2: patch_level=0x08701013
[ 0.541654] microcode: CPU3: patch_level=0x08701013
[ 0.541669] microcode: CPU4: patch_level=0x08701013
[ 0.541683] microcode: CPU5: patch_level=0x08701013
[ 0.541697] microcode: CPU6: patch_level=0x08701013
[ 0.541711] microcode: CPU7: patch_level=0x08701013
[ 0.541724] microcode: CPU8: patch_level=0x08701013
[ 0.541730] microcode: CPU9: patch_level=0x08701013
[ 0.541736] microcode: CPU10: patch_level=0x08701013
[ 0.541741] microcode: CPU11: patch_level=0x08701013
[ 0.541743] microcode: CPU12: patch_level=0x08701013
[ 0.541748] microcode: CPU13: patch_level=0x08701013
[ 0.541751] microcode: CPU14: patch_level=0x08701013
[ 0.541758] microcode: CPU15: patch_level=0x08701013
[ 0.541772] microcode: CPU16: patch_level=0x08701013
[ 0.541777] microcode: CPU17: patch_level=0x08701013
[ 0.541783] microcode: CPU18: patch_level=0x08701013
[ 0.541788] microcode: CPU19: patch_level=0x08701013
[ 0.541793] microcode: CPU20: patch_level=0x08701013
[ 0.541798] microcode: CPU21: patch_level=0x08701013
[ 0.541803] microcode: CPU22: patch_level=0x08701013
[ 0.541809] microcode: CPU23: patch_level=0x08701013
[ 0.541826] microcode: Microcode Update Driver: v2.2.
[ 0.541981] nvme nvme0: missing or invalid SUBNQN field.
[ 0.541992] nvme nvme0: Shutdown timeout set to 8 seconds
[ 0.542102] resctrl: L3 allocation detected
[ 0.542102] resctrl: L3DATA allocation detected
[ 0.542102] resctrl: L3CODE allocation detected
[ 0.542103] resctrl: MB allocation detected
[ 0.542103] resctrl: L3 monitoring detected
[ 0.542105] IPI shorthand broadcast: enabled
[ 0.542110] sched_clock: Marking stable (575427111, -33330377)->(544856806, -2760072)
[ 0.542239] registered taskstats version 1
[ 0.542242] Loading compiled-in X.509 certificates
[ 0.543679] Loaded X.509 cert 'Build time autogenerated kernel key: de2f2e3f73e7d58d4e970143d99b45ae56b47dc0'
[ 0.543810] zswap: loaded using pool lz4/z3fold
[ 0.543985] Key type ._fscrypt registered
[ 0.543985] Key type .fscrypt registered
[ 0.543985] Key type fscrypt-provisioning registered
[ 0.544276] PM: Magic number: 8:976:698
[ 0.544314] acpi LNXCPU:0c: hash matches
[ 0.544365] RAS: Correctable Errors collector initialized.
[ 0.569357] nvme nvme0: 32/0/0 default/read/poll queues
[ 0.574044] nvme0n1: p1 p2 p3 p4 p5 p6
[ 0.851278] ata3: SATA link down (SStatus 0 SControl 300)
[ 0.852528] ata1: SATA link down (SStatus 0 SControl 300)
[ 0.853675] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.013373] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.014537] ata2.00: ATAPI: HL-DT-ST DVDRAM GH24NSD5, LV00, max UDMA/133
[ 1.016019] ata2.00: configured for UDMA/133
[ 1.018411] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GH24NSD5 LV00 PQ: 0 ANSI: 5
[ 1.058611] Freeing unused decrypted memory: 2040K
[ 1.058853] Freeing unused kernel image (initmem) memory: 1660K
[ 1.083348] Write protecting the kernel read-only data: 24576k
[ 1.083835] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 1.083974] Freeing unused kernel image (rodata/data gap) memory: 280K
[ 1.105518] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.105521] Run /init as init process
[ 1.105522] with arguments:
[ 1.105522] /init
[ 1.105523] with environment:
[ 1.105523] HOME=/
[ 1.105523] TERM=linux
[ 1.105523] BOOT_IMAGE=/boot/vmlinuz-linux
[ 1.188284] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.188366] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.193710] xhci_hcd 0000:06:00.1: xHCI Host Controller
[ 1.193715] xhci_hcd 0000:06:00.1: new USB bus registered, assigned bus number 1
[ 1.193870] xhci_hcd 0000:06:00.1: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 1.194255] cryptd: max_cpu_qlen set to 1000
[ 1.194441] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.194443] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.194444] usb usb1: Product: xHCI Host Controller
[ 1.194445] usb usb1: Manufacturer: Linux 5.9.1-arch1-1 xhci-hcd
[ 1.194446] usb usb1: SerialNumber: 0000:06:00.1
[ 1.194528] hub 1-0:1.0: USB hub found
[ 1.194538] hub 1-0:1.0: 6 ports detected
[ 1.195213] xhci_hcd 0000:06:00.1: xHCI Host Controller
[ 1.195215] xhci_hcd 0000:06:00.1: new USB bus registered, assigned bus number 2
[ 1.195217] xhci_hcd 0000:06:00.1: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.195230] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.195246] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 1.195248] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.195249] usb usb2: Product: xHCI Host Controller
[ 1.195250] usb usb2: Manufacturer: Linux 5.9.1-arch1-1 xhci-hcd
[ 1.195251] usb usb2: SerialNumber: 0000:06:00.1
[ 1.195321] hub 2-0:1.0: USB hub found
[ 1.195331] hub 2-0:1.0: 4 ports detected
[ 1.195805] xhci_hcd 0000:06:00.3: xHCI Host Controller
[ 1.195808] xhci_hcd 0000:06:00.3: new USB bus registered, assigned bus number 3
[ 1.195968] xhci_hcd 0000:06:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 1.196305] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.196307] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.196308] usb usb3: Product: xHCI Host Controller
[ 1.196309] usb usb3: Manufacturer: Linux 5.9.1-arch1-1 xhci-hcd
[ 1.196310] usb usb3: SerialNumber: 0000:06:00.3
[ 1.196382] hub 3-0:1.0: USB hub found
[ 1.196394] hub 3-0:1.0: 6 ports detected
[ 1.197097] xhci_hcd 0000:06:00.3: xHCI Host Controller
[ 1.197099] xhci_hcd 0000:06:00.3: new USB bus registered, assigned bus number 4
[ 1.197110] xhci_hcd 0000:06:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.197128] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.197144] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 1.197145] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.197147] usb usb4: Product: xHCI Host Controller
[ 1.197148] usb usb4: Manufacturer: Linux 5.9.1-arch1-1 xhci-hcd
[ 1.197149] usb usb4: SerialNumber: 0000:06:00.3
[ 1.197319] hub 4-0:1.0: USB hub found
[ 1.197329] hub 4-0:1.0: 4 ports detected
[ 1.197617] AVX2 version of gcm_enc/dec engaged.
[ 1.197618] AES CTR mode by8 optimization enabled
[ 1.198570] xhci_hcd 0000:09:00.2: xHCI Host Controller
[ 1.198574] xhci_hcd 0000:09:00.2: new USB bus registered, assigned bus number 5
[ 1.199802] xhci_hcd 0000:09:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[ 1.199940] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.199942] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.199943] usb usb5: Product: xHCI Host Controller
[ 1.199945] usb usb5: Manufacturer: Linux 5.9.1-arch1-1 xhci-hcd
[ 1.199946] usb usb5: SerialNumber: 0000:09:00.2
[ 1.200203] hub 5-0:1.0: USB hub found
[ 1.200209] hub 5-0:1.0: 2 ports detected
[ 1.200305] xhci_hcd 0000:09:00.2: xHCI Host Controller
[ 1.200307] xhci_hcd 0000:09:00.2: new USB bus registered, assigned bus number 6
[ 1.200309] xhci_hcd 0000:09:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.200327] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.200341] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 1.200342] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.200342] usb usb6: Product: xHCI Host Controller
[ 1.200343] usb usb6: Manufacturer: Linux 5.9.1-arch1-1 xhci-hcd
[ 1.200344] usb usb6: SerialNumber: 0000:09:00.2
[ 1.200426] hub 6-0:1.0: USB hub found
[ 1.200434] hub 6-0:1.0: 4 ports detected
[ 1.200602] xhci_hcd 0000:0b:00.3: xHCI Host Controller
[ 1.200605] xhci_hcd 0000:0b:00.3: new USB bus registered, assigned bus number 7
[ 1.200716] xhci_hcd 0000:0b:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 1.200999] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[ 1.201000] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.201001] usb usb7: Product: xHCI Host Controller
[ 1.201002] usb usb7: Manufacturer: Linux 5.9.1-arch1-1 xhci-hcd
[ 1.201003] usb usb7: SerialNumber: 0000:0b:00.3
[ 1.201058] hub 7-0:1.0: USB hub found
[ 1.201064] hub 7-0:1.0: 4 ports detected
[ 1.201199] xhci_hcd 0000:0b:00.3: xHCI Host Controller
[ 1.201202] xhci_hcd 0000:0b:00.3: new USB bus registered, assigned bus number 8
[ 1.201204] xhci_hcd 0000:0b:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.201222] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.201237] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[ 1.201238] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.201239] usb usb8: Product: xHCI Host Controller
[ 1.201240] usb usb8: Manufacturer: Linux 5.9.1-arch1-1 xhci-hcd
[ 1.201241] usb usb8: SerialNumber: 0000:0b:00.3
[ 1.201299] hub 8-0:1.0: USB hub found
[ 1.201306] hub 8-0:1.0: 4 ports detected
[ 1.259682] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.259684] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.283601] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.530024] usb 3-6: new full-speed USB device number 2 using xhci_hcd
[ 1.530030] usb 7-2: new full-speed USB device number 2 using xhci_hcd
[ 1.536884] tsc: Refined TSC clocksource calibration: 3792.876 MHz
[ 1.536892] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d581b92771, max_idle_ns: 881590605997 ns
[ 1.536938] clocksource: Switched to clocksource tsc
[ 1.684169] usb 3-6: config 1 has an invalid interface number: 2 but max is 1
[ 1.684170] usb 3-6: config 1 has no interface number 1
[ 1.686239] usb 7-2: New USB device found, idVendor=e0ff, idProduct=0002, bcdDevice= 0.01
[ 1.686241] usb 7-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.686242] usb 7-2: Product: G3
[ 1.686242] usb 7-2: Manufacturer: A.....
[ 1.693155] random: fast init done
[ 1.695026] fbcon: Taking over console
[ 1.695072] Console: switching to colour frame buffer device 128x48
[ 1.695763] hid: raw HID events driver (C) Jiri Kosina
[ 1.696155] usb 3-6: New USB device found, idVendor=0b05, idProduct=18f3, bcdDevice= 1.00
[ 1.696157] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.696157] usb 3-6: Product: AURA LED Controller
[ 1.696158] usb 3-6: Manufacturer: AsusTek Computer Inc.
[ 1.696159] usb 3-6: SerialNumber: 9876543210
[ 1.705297] usbcore: registered new interface driver usbhid
[ 1.705297] usbhid: USB HID core driver
[ 1.706535] input: A..... G3 as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb7/7-2/7-2:1.0/0003:E0FF:0002.0001/input/input2
[ 1.706573] hid-generic 0003:E0FF:0002.0001: input,hidraw0: USB HID v1.00 Mouse [A..... G3] on usb-0000:0b:00.3-2/input0
[ 1.706660] input: A..... G3 as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb7/7-2/7-2:1.1/0003:E0FF:0002.0002/input/input3
[ 1.706677] input: A..... G3 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb7/7-2/7-2:1.1/0003:E0FF:0002.0002/input/input4
[ 1.714279] hid-generic 0003:0B05:18F3.0003: hiddev0,hidraw1: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:06:00.3-6/input2
[ 1.723229] EXT4-fs (nvme0n1p6): mounted filesystem with ordered data mode. Opts: (null)
[ 1.763394] input: A..... G3 Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb7/7-2/7-2:1.1/0003:E0FF:0002.0002/input/input5
[ 1.763440] hid-generic 0003:E0FF:0002.0002: input,hiddev1,hidraw2: USB HID v1.00 Keyboard [A..... G3] on usb-0000:0b:00.3-2/input1
[ 1.781229] systemd[1]: Configuration file /etc/systemd/system.conf.d/limits.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 1.781665] systemd[1]: systemd 246.6-1-arch running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 1.796710] systemd[1]: Detected architecture x86-64.
[ 1.813358] usb 7-3: new low-speed USB device number 3 using xhci_hcd
[ 1.830601] systemd[1]: Set hostname to <user-systemproductname>.
[ 1.902911] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.903547] systemd[1]: Created slice system-getty.slice.
[ 1.903675] systemd[1]: Created slice system-modprobe.slice.
[ 1.903828] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 1.903948] systemd[1]: Created slice User and Session Slice.
[ 1.903975] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 1.903993] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.904069] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.904087] systemd[1]: Reached target Login Prompts.
[ 1.904106] systemd[1]: Reached target Remote File Systems.
[ 1.904112] systemd[1]: Reached target Slices.
[ 1.904121] systemd[1]: Reached target Swap.
[ 1.904153] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.904556] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 1.904674] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.905528] systemd[1]: Listening on Process Core Dump Socket.
[ 1.905588] systemd[1]: Listening on Journal Audit Socket.
[ 1.905625] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.905666] systemd[1]: Listening on Journal Socket.
[ 1.905720] systemd[1]: Listening on Network Service Netlink Socket.
[ 1.905765] systemd[1]: Listening on udev Control Socket.
[ 1.905797] systemd[1]: Listening on udev Kernel Socket.
[ 1.906216] systemd[1]: Mounting Huge Pages File System...
[ 1.906684] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.907206] systemd[1]: Mounting Kernel Debug File System...
[ 1.907739] systemd[1]: Mounting Kernel Trace File System...
[ 1.908107] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
[ 1.908521] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 1.909094] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 1.909598] systemd[1]: Starting Load Kernel Module drm...
[ 1.909630] systemd[1]: Condition check resulted in Setup the console colors being skipped.
[ 1.910292] systemd[1]: Starting Set Up Additional Binary Formats...
[ 1.910324] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 1.911108] systemd[1]: Starting Load Kernel Modules...
[ 1.911580] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 1.911615] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 1.912101] systemd[1]: Starting Coldplug All udev Devices...
[ 1.912741] systemd[1]: Mounted Huge Pages File System.
[ 1.912799] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.912857] systemd[1]: Mounted Kernel Debug File System.
[ 1.912907] systemd[1]: Mounted Kernel Trace File System.
[ 1.912956] systemd[1]: Mounted Temporary Directory (/tmp).
[ 1.913170] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 1.913253] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 440 (systemd-binfmt)
[ 1.913693] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 1.913931] Linux agpgart interface v0.103
[ 1.914740] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 1.915408] EXT4-fs (nvme0n1p6): re-mounted. Opts: (null)
[ 1.915878] systemd[1]: Finished Set Up Additional Binary Formats.
[ 1.916099] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 1.916175] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 1.916400] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 1.916868] systemd[1]: Starting Load/Save Random Seed...
[ 1.916902] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 1.917243] Asymmetric key parser 'pkcs8' registered
[ 1.917380] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 1.917851] systemd[1]: Finished Load Kernel Modules.
[ 1.917952] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 1.918389] systemd[1]: Mounting Kernel Configuration File System...
[ 1.918865] systemd[1]: Starting Apply Kernel Variables...
[ 1.919486] systemd[1]: Mounted Kernel Configuration File System.
[ 1.923964] systemd[1]: Finished Apply Kernel Variables.
[ 1.928102] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 1.928717] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 1.929732] systemd[1]: Starting Journal Service...
[ 1.930479] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 1.933107] systemd[1]: modprobe@drm.service: Succeeded.
[ 1.933312] systemd[1]: Finished Load Kernel Module drm.
[ 1.949710] systemd[1]: Finished Coldplug All udev Devices.
[ 1.950193] systemd[1]: Starting Wait for udev To Complete Device Initialization...
[ 1.970314] usb 7-3: New USB device found, idVendor=145f, idProduct=01e5, bcdDevice= 1.10
[ 1.970316] usb 7-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.970317] usb 7-3: Product: USB Keyboard
[ 1.970317] usb 7-3: Manufacturer: SEMICO
[ 2.000443] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb7/7-3/7-3:1.0/0003:145F:01E5.0004/input/input6
[ 2.056724] hid-generic 0003:145F:01E5.0004: input,hidraw3: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:0b:00.3-3/input0
[ 2.061440] input: SEMICO USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb7/7-3/7-3:1.1/0003:145F:01E5.0005/input/input7
[ 2.116722] input: SEMICO USB Keyboard System Control as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb7/7-3/7-3:1.1/0003:145F:01E5.0005/input/input8
[ 2.116762] hid-generic 0003:145F:01E5.0005: input,hidraw4: USB HID v1.10 Device [SEMICO USB Keyboard] on usb-0000:0b:00.3-3/input1
[ 2.123149] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 2.123193] audit: type=1130 audit(1603568350.080:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.123996] systemd[1]: Starting Network Service...
[ 2.131155] systemd[1]: Started Journal Service.
[ 2.131211] audit: type=1130 audit(1603568350.090:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.136045] audit: type=1130 audit(1603568350.093:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.142803] acpi_cpufreq: overriding BIOS provided _PSD data
[ 2.181770] random: mktemp: uninitialized urandom read (6 bytes read)
[ 2.181771] random: mktemp: uninitialized urandom read (6 bytes read)
[ 2.181780] random: mktemp: uninitialized urandom read (6 bytes read)
[ 2.214364] nvidia-gpu 0000:09:00.3: enabling device (0000 -> 0002)
[ 2.233874] random: crng init done
[ 2.233875] random: 7 urandom warning(s) missed due to ratelimiting
[ 2.237576] audit: type=1130 audit(1603568350.196:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.240019] usb 7-4: new high-speed USB device number 4 using xhci_hcd
[ 2.244001] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 2.244005] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 2.244136] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 2.244252] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 2.244255] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 2.247655] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 2.247774] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ 2.247780] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 2.251395] libphy: Fixed MDIO Bus: probed
[ 2.255585] asus_wmi: ASUS WMI generic driver loaded
[ 2.255591] ccp 0000:0b:00.1: enabling device (0000 -> 0002)
[ 2.255839] ccp 0000:0b:00.1: ccp: unable to access the device: you might be running a broken BIOS.
[ 2.257912] asus_wmi: Initialization: 0x0
[ 2.257965] asus_wmi: BIOS WMI version: 0.9
[ 2.258324] asus_wmi: SFUN value: 0x0
[ 2.258328] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[ 2.259378] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input9
[ 2.282994] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.284284] libphy: r8169: probed
[ 2.284450] r8169 0000:05:00.0 eth0: RTL8168h/8111h, 04:d9:f5:d5:73:e7, XID 541, IRQ 107
[ 2.284452] r8169 0000:05:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 2.287967] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.316140] audit: type=1130 audit(1603568350.273:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.358620] kvm: disabled by bios
[ 2.359236] snd_hda_intel 0000:09:00.1: enabling device (0000 -> 0002)
[ 2.359311] snd_hda_intel 0000:09:00.1: Disabling MSI
[ 2.359320] snd_hda_intel 0000:09:00.1: Handle vga_switcheroo audio client
[ 2.359397] snd_hda_intel 0000:0b:00.4: enabling device (0000 -> 0002)
[ 2.377389] snd_hda_codec_realtek hdaudioC1D0: ALCS1200A: SKU not ready 0x00000000
[ 2.377847] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALCS1200A: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 2.377848] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.377848] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 2.377849] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 2.377850] snd_hda_codec_realtek hdaudioC1D0: dig-out=0x1e/0x0
[ 2.377850] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 2.377851] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 2.377852] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 2.377853] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 2.382618] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input10
[ 2.382646] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input11
[ 2.382668] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input12
[ 2.382689] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input13
[ 2.382718] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input14
[ 2.382740] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input15
[ 2.382760] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:03.1/0000:09:00.1/sound/card0/input16
[ 2.457297] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/sound/card1/input17
[ 2.457338] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/sound/card1/input18
[ 2.457370] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/sound/card1/input19
[ 2.457403] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/sound/card1/input20
[ 2.457435] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/sound/card1/input21
[ 2.457467] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/sound/card1/input22
[ 2.457499] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/sound/card1/input23
[ 2.457530] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/sound/card1/input24
[ 2.518465] kvm: disabled by bios
[ 2.522101] usb 7-4: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[ 2.522103] usb 7-4: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 2.522104] usb 7-4: Product: USB 3.0 Device
[ 2.522104] usb 7-4: Manufacturer: Intenso
[ 2.522105] usb 7-4: SerialNumber: 305000000000000022D9
[ 2.527310] MCE: In-kernel MCE decoding enabled.
[ 2.532360] EDAC amd64: F17h_M70h detected (node 0).
[ 2.532401] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.697441] EDAC amd64: F17h_M70h detected (node 0).
[ 2.697488] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.697988] kvm: disabled by bios
[ 2.713791] rtl8192ce 0000:04:00.0: enabling device (0000 -> 0003)
[ 2.713941] rtl8192ce: Chip Version ID: B_CHIP_92C
[ 2.725171] rtl8192ce: Using firmware rtlwifi/rtl8192cfw.bin
[ 2.727441] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 2.727780] rtlwifi: rtlwifi: wireless switch is on
[ 2.802201] r8169 0000:05:00.0 enp5s0: renamed from eth0
[ 2.884215] EDAC amd64: F17h_M70h detected (node 0).
[ 2.884264] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.886085] kvm: disabled by bios
[ 2.922975] wl: loading out-of-tree module taints kernel.
[ 2.922978] wl: module license 'MIXED/Proprietary' taints kernel.
[ 2.922979] Disabling lock debugging due to kernel taint
[ 2.973383] Generic FE-GE Realtek PHY r8169-500:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-500:00, irq=IGNORE)
[ 2.980109] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 3.084715] EDAC amd64: F17h_M70h detected (node 0).
[ 3.084769] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.085311] kvm: disabled by bios
[ 3.088841] audit: type=1130 audit(1603568351.046:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.113532] r8169 0000:05:00.0 enp5s0: Link is Down
[ 3.151413] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[ 3.151920] nvidia 0000:09:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 3.195202] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.28 Wed Sep 30 01:05:16 UTC 2020
[ 3.245671] EDAC amd64: F17h_M70h detected (node 0).
[ 3.245800] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.246515] kvm: disabled by bios
[ 3.377482] EDAC amd64: F17h_M70h detected (node 0).
[ 3.377583] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.378317] kvm: disabled by bios
[ 3.378703] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 455.28 Wed Sep 30 00:58:12 UTC 2020
[ 3.386087] [drm] [nvidia-drm] [GPU ID 0x00000900] Loading driver
[ 3.386089] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:09:00.0 on minor 0
[ 3.537359] kvm: disabled by bios
[ 3.537579] EDAC amd64: F17h_M70h detected (node 0).
[ 3.537629] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.711794] EDAC amd64: F17h_M70h detected (node 0).
[ 3.711857] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.712054] kvm: disabled by bios
[ 3.712170] mousedev: PS/2 mouse device common for all mice
[ 3.712693] usb-storage 7-4:1.0: USB Mass Storage device detected
[ 3.712836] usb-storage 7-4:1.0: Quirks match for vid 174c pid 55aa: 400000
[ 3.712868] scsi host4: usb-storage 7-4:1.0
[ 3.713018] usbcore: registered new interface driver usb-storage
[ 3.718807] usbcore: registered new interface driver uas
[ 3.893034] nvidia-gpu 0000:09:00.3: i2c timeout error e0000000
[ 3.893039] ucsi_ccg 0-0008: i2c_transfer failed -110
[ 3.893041] ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
[ 3.893047] ucsi_ccg: probe of 0-0008 failed with error -110
[ 3.924540] EDAC amd64: F17h_M70h detected (node 0).
[ 3.924595] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.925072] kvm: disabled by bios
[ 4.084669] EDAC amd64: F17h_M70h detected (node 0).
[ 4.084722] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.260954] EDAC amd64: F17h_M70h detected (node 0).
[ 4.261006] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.430267] EDAC amd64: F17h_M70h detected (node 0).
[ 4.430340] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.618415] EDAC amd64: F17h_M70h detected (node 0).
[ 4.618464] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.737745] scsi 4:0:0:0: Direct-Access Intenso USB 3.0 Device 0 PQ: 0 ANSI: 6
[ 4.791732] EDAC amd64: F17h_M70h detected (node 0).
[ 4.791782] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.937349] EDAC amd64: F17h_M70h detected (node 0).
[ 4.937392] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.084932] EDAC amd64: F17h_M70h detected (node 0).
[ 5.084985] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.258113] EDAC amd64: F17h_M70h detected (node 0).
[ 5.258163] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.421036] EDAC amd64: F17h_M70h detected (node 0).
[ 5.421091] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.537982] EDAC amd64: F17h_M70h detected (node 0).
[ 5.538032] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.657871] EDAC amd64: F17h_M70h detected (node 0).
[ 5.657921] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.754080] EDAC amd64: F17h_M70h detected (node 0).
[ 5.754131] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.844711] EDAC amd64: F17h_M70h detected (node 0).
[ 5.844760] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.954196] EDAC amd64: F17h_M70h detected (node 0).
[ 5.954247] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.030751] EDAC amd64: F17h_M70h detected (node 0).
[ 6.030800] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.098003] audit: type=1130 audit(1603568354.056:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-settle comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.191420] audit: type=1130 audit(1603568354.150:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-activation-early comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.191425] audit: type=1131 audit(1603568354.150:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-activation-early comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.271112] audit: type=1130 audit(1603568354.230:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-activation comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.271122] audit: type=1131 audit(1603568354.230:12): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-activation comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.331363] audit: type=1130 audit(1603568354.290:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.355580] audit: type=1130 audit(1603568354.313:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-6A2C\x2dF586 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.384755] audit: type=1130 audit(1603568354.343:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.390089] audit: type=1127 audit(1603568354.350:16): pid=874 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 6.392780] audit: type=1130 audit(1603568354.350:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.413012] NET: Registered protocol family 38
[ 7.597924] sd 4:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 7.597926] sd 4:0:0:0: [sda] 4096-byte physical blocks
[ 7.598396] sd 4:0:0:0: [sda] Write Protect is off
[ 7.598397] sd 4:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 7.598891] sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 7.641422] sda: sda1
[ 7.643291] sd 4:0:0:0: [sda] Attached SCSI disk
[ 9.681359] fuse: init (API version 7.31)
[ 13.361473] kauditd_printk_skb: 28 callbacks suppressed
[ 13.361476] audit: type=1130 audit(1603568361.320:46): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.262354] audit: type=1130 audit(1603568362.220:47): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pacman-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.978062] audit: type=1131 audit(1603568364.936:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.263284] audit: type=1100 audit(1603568365.220:49): pid=1103 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="user" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 17.264125] audit: type=1101 audit(1603568365.223:50): pid=1103 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="user" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 17.355561] audit: type=1106 audit(1603568365.313:51): pid=1046 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 17.355605] audit: type=1104 audit(1603568365.313:52): pid=1046 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 17.358286] audit: type=1103 audit(1603568365.316:53): pid=1103 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="user" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 17.358368] audit: type=1006 audit(1603568365.316:54): pid=1103 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 17.372089] audit: type=1130 audit(1603568365.330:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.105472] kauditd_printk_skb: 9 callbacks suppressed
[ 23.105473] audit: type=1130 audit(1603568371.063:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.122209] audit: type=1334 audit(1603568371.080:66): prog-id=13 op=LOAD
[ 23.122253] audit: type=1334 audit(1603568371.080:67): prog-id=14 op=LOAD
[ 23.139280] audit: type=1130 audit(1603568371.096:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.424931] audit: type=1130 audit(1603568371.383:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 24.074947] audit: type=1130 audit(1603568372.033:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.641165] audit: type=1131 audit(1603568375.600:71): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.649415] audit: type=1131 audit(1603568375.606:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 54.261260] audit: type=1131 audit(1603568402.220:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 54.390027] audit: type=1334 audit(1603568402.350:74): prog-id=10 op=UNLOAD
[ 54.390030] audit: type=1334 audit(1603568402.350:75): prog-id=9 op=UNLOAD
[ 81.820126] audit: type=1111 audit(1603568429.780:76): pid=877 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=2277 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 81.825283] audit: type=1130 audit(1603568429.783:77): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 86.834152] audit: type=1131 audit(1603568434.793:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 99.492680] audit: type=1334 audit(1603568447.450:79): prog-id=15 op=LOAD
[ 99.492769] audit: type=1334 audit(1603568447.450:80): prog-id=16 op=LOAD
[ 99.693132] audit: type=1130 audit(1603568447.650:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 122.448168] audit: type=1130 audit(1603568470.406:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 122.470598] audit: type=1130 audit(1603568470.430:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 122.685686] audit: type=1130 audit(1603568470.643:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 129.743135] audit: type=1131 audit(1603568477.703:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 129.870027] audit: type=1334 audit(1603568477.830:86): prog-id=16 op=UNLOAD
[ 129.870031] audit: type=1334 audit(1603568477.830:87): prog-id=15 op=UNLOAD
[ 132.695569] audit: type=1130 audit(1603568480.656:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 132.695573] audit: type=1131 audit(1603568480.656:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 132.936363] audit: type=1130 audit(1603568480.893:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 142.945727] audit: type=1130 audit(1603568490.906:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 142.945732] audit: type=1131 audit(1603568490.906:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 143.166507] audit: type=1130 audit(1603568491.123:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 153.195677] audit: type=1130 audit(1603568501.156:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 153.195681] audit: type=1131 audit(1603568501.156:95): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 153.421498] audit: type=1130 audit(1603568501.380:96): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=reflector comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
