Feb 13 20:06:19 Thin-Client systemd[1]: Started Sleep-On-LAN daemon.
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO configuration.go:69 Configuration file found under [/home/applications/sleep-on-lan/sol.json], now reading content
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO configuration.go:143 Daemon will stop if any listener can't be started (per ExitIfAnyPortIsAlreadyUsed
configuration)
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO configuration.go:152 Avoid dual UDP sending not enabled
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO sol.go:107 Application [sleep-on-lan], version [1.1.0-RELEASE], compilation timestamp [2021-11-18T21:19:18+0100], git commit [d5e9ac204164e6adc9e>
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO sol.go:110 Now starting sleep-on-lan, hardware IP/mac addresses are :
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO sol.go:112 - local IP adress [10.125.0.6/32], mac [], reversed mac []
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO sol.go:112 - local IP adress [127.0.0.1/8], mac [], reversed mac []
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO sol.go:112 - local IP adress [192.168.1.41/24], mac [7c:d3:0a:37:xx:xx], reversed mac [xx:xx:37:0a:d3:7c]
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO sol.go:116 Available commands are :
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO sol.go:118 - operation [sleep], command [pm-suspend], default [true], type [external]
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO listener_http.go:162 HTTP starting on port [8009], without auth
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO listener_http.go:87 Registering route [/]
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 INFO listener_udp.go:15 Now listening UDP packets on port [7]
Feb 13 20:06:19 Thin-Client sol[8032]: 2022-02-13 19:06:19 ERROR listener_udp.go:24 Error while starting listening (will exit, per configuration) :%!(EXTRA string=listen udp :7: bind: address already in use)
Feb 13 20:06:19 Thin-Client systemd[1]: sleep-on-lan.service: Succeeded.
Feb 13 20:06:19 Thin-Client systemd[1]: sleep-on-lan.service: Scheduled restart job, restart counter is at 5.
Feb 13 20:06:19 Thin-Client systemd[1]: Stopped Sleep-On-LAN daemon.
Feb 13 20:06:19 Thin-Client systemd[1]: sleep-on-lan.service: Start request repeated too quickly.
Feb 13 20:06:19 Thin-Client systemd[1]: sleep-on-lan.service: Failed with result 'start-limit-hit'.
Feb 13 20:06:19 Thin-Client systemd[1]: Failed to start Sleep-On-LAN daemon.
