hmm laut release notes müsste es eigentlich gehen
Filename: SBXF_PCDRVBETA_US_2_18_0006.exe
This download is a beta driver providing Microsoft® Windows Vista® and Windows® XP support for Creative Sound Blaster® X-Fi™ series of audio devices. For more details, read the rest of this web release note.
Take note of the following:
* THIS IS AN UNSUPPORTED BETA DRIVER. There is no technical support for this driver.
* We recommend that only experienced users install this driver. Do not install this driver on a system used to perform critical tasks.
* Users who are looking for stable drivers should wait for the final release. When this happens, user should install the latest Sound Blaster X-Fi series driver available.
This download supports the following audio devices only:
* Creative Sound Blaster X-Fi XtremeGamer Fatal1ty® Professional Series
* Creative Sound Blaster X-Fi Platinum Fatal1ty Champion Series
* Creative Sound Blaster X-Fi XtremeMusic
* Creative Sound Blaster X-Fi Fatal1ty
* Creative Sound Blaster X-Fi Elite Pro
Added Features or Enhancements:
* Supports Dolby® Digital Live
* Supports DTS® Connect (For Windows Vista only)
Requires the latest Creative Console Launcher application. Click here to download.
To get the above mentioned features you will need to purchase the Dolby Digital Live and DTS Connect software pack.
For systems using Windows Vista
To find out the Product ID of your audio device and if it supports the following features in Windows XP, click here.
* Dolby Digital and DTS decode re-established for sound cards that included decoding in their Windows XP drivers (Not applicable for products that included a 3rd party software DVD player license in the package).
* DVD-Audio playback re-established for sound cards that included the application in their Windows XP software suite (For Windows Vista 32-bit only).
Requires the latest Creative MediaSource DVD-Audio Player software. Click here to download.
Fixes:
* Resolves issue of audio popping when playing AC-3 Wave files or using Dolby Digital Live via the digital output on Windows Vista.
* Resolves Audio Control Panel issue of incorrect X-Fi CMSS®-3D behavior while using Audio Creation Mode.
Requirements:
* Windows Vista 64-bit, Windows Vista 32-bit, Windows XP Professional x64 Edition, Windows XP Service Pack 2 (SP2), Windows XP Media Center Edition (MCE) 2005 or Windows XP MCE 2004
* Creative Sound Blaster X-Fi audio devices listed above
Notes:
* Do not install this driver for Sound Blaster X-Fi Xtreme Audio.
* To install this driver
1. Download the file onto your local hard disk.
2. Double-click the downloaded file.
3. Follow the instructions on the screen.
