XML-Dateien zusammenführen!?
heno
Feb. 2011
Hallo!
Wir haben ein kleines Problem: In Civ 5 können Mods nur noch Multiplayerfähig gemacht werden wenn man die XML-Dateien des Spieles nach dem Mod anpasst.
Der Mod liefert solche XML-Dateien:
Code:
<?xml version="1.0" encoding="utf-8"?>
<!-- Created by ModBuddy on 11/13/2012 3:20:04 PM -->
<GameData>
	<!-- Created by ModBuddy on 4/7/2011 11:51:39 PM -->
	<!-- Terrains.xml changes -->
	<!-- Desert -->
		<Terrain_Yields>
			<Row>
				<TerrainType>TERRAIN_OCEAN</TerrainType>
				<YieldType>YIELD_PRODUCTION</YieldType>
				<Yield>1</Yield>
			</Row>
			<Row>
				<YieldType>YIELD_GOLD</YieldType>
				<Yield>1</Yield>
			</Row>
			<Delete TerrainType="TERRAIN_OCEAN" YieldType="YIELD_FOOD"/>
		</Terrain_Yields>
		<Feature_YieldChanges>
			<Row>
				<FeatureType>FEATURE_LAKE</FeatureType>
				<Yield>1</Yield>
			</Row>
		</Feature_YieldChanges>
	<Terrain_HillsYieldChanges>
		<Update>
			<Where TerrainType="TERRAIN_DESERT" YieldType="YIELD_PRODUCTION"/>
			<Set Yield="1"/>
		</Update>
	</Terrain_HillsYieldChanges>
</GameData>
Diese Änderungen (ZB: <Yield>1</Yield>) müssen hier eingetragen werden:
Code:
<!-- edited with XMLSPY v2004 rel. 2 U (http://www.xmlspy.com) by Jon Shafer (Firaxis Games) -->
<GameData>
	<!-- Table definition -->
	<Table name="Terrains">
		<Column name="ID" type="integer" primarykey="true" autoincrement="true"/>
		<Column name="Type" type="text" notnull="true" unique="true"/>
		<Column name="Description" type="text"/>
		<Column name="Civilopedia" type="text"/>
		<Column name="ArtDefineTag" type="text"/>
		<Column name="Water" type="boolean" default="false"/>
		<Column name="Impassable" type="boolean" default="false"/>
		<Column name="Found" type="boolean" default="false"/>
		<Column name="FoundCoast" type="boolean" default="false"/>
		<Column name="FoundFreshWater" type="boolean" default="false"/>
		<Column name="Movement" type="integer" default="1"/>
		<Column name="SeeFrom" type="integer" default="1"/>
		<Column name="SeeThrough" type="integer" default="1"/>
		<Column name="BuildModifier" type="integer" default="0"/>
		<Column name="Defense" type="integer" default="0"/>
		<Column name="InfluenceCost" type="integer" default="0"/>
		<Column name="Button" type="text"/>
		<Column name="WorldSoundscapeAudioScript" type="text"/>
		<Column name="GraphicalOnly" type="boolean" default="false"/>
		<Column name="PortraitIndex" type="integer" default="-1"/>
		<Column name="EffectTypeTag" type="text"/>
		<Column name="IconAtlas" type="text" default="NULL" reference="IconTextureAtlases(Atlas)"/>
	</Table>
	<Table name="Terrain_Yields">
		<Column name="TerrainType" type="text" reference="Terrains(Type)"/>
		<Column name="YieldType" type="text" reference="Yields(Type)"/>
		<Column name="Yield" type="integer" default="0"/>
	</Table>
	<Table name="Terrain_RiverYieldChanges">
	</Table>
	<Table name="Terrain_HillsYieldChanges">
	</Table>
	<!-- Table data -->
	<Terrains>
		<Row>
			<ID>0</ID>
			<Type>TERRAIN_GRASS</Type>
			<Description>TXT_KEY_TERRAIN_GRASS</Description>
			<Civilopedia>TXT_KEY_CIV5_TERRAIN_GRASSLAND_TEXT</Civilopedia>
			<ArtDefineTag>ART_DEF_TERRAIN_GRASS</ArtDefineTag>
			<Found>true</Found>
			<InfluenceCost>1</InfluenceCost>
			<Button>Art/Interface\Buttons\WorldBuilder\Terrain_Grass.dds</Button>
			<WorldSoundscapeAudioScript>ASSS_AMBIENCE_GRASSLANDS</WorldSoundscapeAudioScript>
			<EffectTypeTag>DIRT</EffectTypeTag>
			<PortraitIndex>4</PortraitIndex>
			<IconAtlas>TERRAIN_ATLAS</IconAtlas>
		</Row>
		<Row>
			<Type>TERRAIN_PLAINS</Type>
			<Description>TXT_KEY_TERRAIN_PLAINS</Description>
			<Civilopedia>TXT_KEY_CIV5_TERRAIN_PLAINS_TEXT</Civilopedia>
			<ArtDefineTag>ART_DEF_TERRAIN_PLAINS</ArtDefineTag>
			<Found>true</Found>
			<Button>Art/Interface\Buttons\WorldBuilder\Terrain_Plains.dds</Button>
			<PortraitIndex>12</PortraitIndex>
		</Row>
		<Row>
			<Type>TERRAIN_DESERT</Type>
			<Description>TXT_KEY_TERRAIN_DESERT</Description>
			<Civilopedia>TXT_KEY_CIV5_TERRAIN_DESERT_TEXT</Civilopedia>
			<ArtDefineTag>ART_DEF_TERRAIN_DESERT</ArtDefineTag>
			<Found>true</Found>
			<InfluenceCost>2</InfluenceCost>
			<Button>Art/Interface\Buttons\WorldBuilder\Terrain_Desert.dds</Button>
			<WorldSoundscapeAudioScript>ASSS_AMBIENCE_DESERT</WorldSoundscapeAudioScript>
			<EffectTypeTag>SAND</EffectTypeTag>
			<PortraitIndex>1</PortraitIndex>
		</Row>
		<Row>
			<Type>TERRAIN_TUNDRA</Type>
			<Description>TXT_KEY_TERRAIN_TUNDRA</Description>
			<Civilopedia>TXT_KEY_CIV5_TERRAIN_TUNDRA_TEXT</Civilopedia>
			<ArtDefineTag>ART_DEF_TERRAIN_TUNDRA</ArtDefineTag>
			<Found>true</Found>
			<Button>Art/Interface\Buttons\WorldBuilder\Terrain_Tundra.dds</Button>
			<WorldSoundscapeAudioScript>ASSS_AMBIENCE_TUNDRA</WorldSoundscapeAudioScript>
			<PortraitIndex>16</PortraitIndex>
		</Row>
		<Row>
			<Type>TERRAIN_SNOW</Type>
			<Description>TXT_KEY_TERRAIN_SNOW</Description>
			<Civilopedia>TXT_KEY_CIV5_TERRAIN_SNOW_TEXT</Civilopedia>
			<ArtDefineTag>ART_DEF_TERRAIN_SNOW</ArtDefineTag>
			<Found>true</Found>
			<Button>Art/Interface\Buttons\WorldBuilder\Terrain_Ice.dds</Button>
			<EffectTypeTag>SNOW</EffectTypeTag>
			<PortraitIndex>15</PortraitIndex>
		</Row>
		<Row>
			<Type>TERRAIN_COAST</Type>
			<Description>TXT_KEY_TERRAIN_COAST</Description>
			<Civilopedia>TXT_KEY_CIV5_TERRAIN_COAST_TEXT</Civilopedia>
			<ArtDefineTag>ART_DEF_TERRAIN_COAST</ArtDefineTag>
			<Water>true</Water>
			<SeeFrom>0</SeeFrom>
			<SeeThrough>0</SeeThrough>
			<Button>Art/Interface\Buttons\WorldBuilder\Terrain_Coast.dds</Button>
			<WorldSoundscapeAudioScript>ASSS_AMBIENCE_COAST</WorldSoundscapeAudioScript>
			<EffectTypeTag>WATER</EffectTypeTag>
			<PortraitIndex>14</PortraitIndex>
		</Row>
		<Row>
			<Type>TERRAIN_OCEAN</Type>
			<Description>TXT_KEY_TERRAIN_OCEAN</Description>
			<Civilopedia>TXT_KEY_CIV5_TERRAIN_OCEAN_TEXT</Civilopedia>
			<ArtDefineTag>ART_DEF_TERRAIN_OCEAN</ArtDefineTag>
			<Water>true</Water>
			<InfluenceCost>3</InfluenceCost>
			<Button>Art/Interface\Buttons\WorldBuilder\Terrain_Ocean.dds</Button>
			<WorldSoundscapeAudioScript>ASSS_AMBIENCE_DEEP_OCEAN</WorldSoundscapeAudioScript>
			<PortraitIndex>11</PortraitIndex>
		</Row>
		<Row>
			<Type>TERRAIN_MOUNTAIN</Type>
			<Description>TXT_KEY_TERRAIN_MOUNTAIN</Description>
			<Civilopedia>TXT_KEY_CIV5_SPECIALTERRAIN_MOUNTAINS_TEXT</Civilopedia>
			<ArtDefineTag>ART_DEF_TERRAIN_MOUNTAIN</ArtDefineTag>
			<Water>true</Water>
			<InfluenceCost>0</InfluenceCost>
			<Button>Art/Interface\Buttons\WorldBuilder\Terrain_Mountain.dds</Button>
			<GraphicalOnly>true</GraphicalOnly>
			<PortraitIndex>9</PortraitIndex>
		</Row>
		<Row>
			<Type>TERRAIN_HILL</Type>
			<Description>TXT_KEY_TERRAIN_HILL</Description>
			<Civilopedia>TXT_KEY_CIV5_SPECIALTERRAIN_HILLS_TEXT</Civilopedia>
			<ArtDefineTag>ART_DEF_TERRAIN_HILL</ArtDefineTag>
			<Water>true</Water>
			<Button>Art/Interface\Buttons\WorldBuilder\Terrain_Hill.dds</Button>
			<PortraitIndex>5</PortraitIndex>
		</Row>
	</Terrains>
	<Terrain_Yields>
		<Row>
			<TerrainType>TERRAIN_GRASS</TerrainType>
			<YieldType>YIELD_FOOD</YieldType>
			<Yield>2</Yield>
		</Row>
		<Row>
			<TerrainType>TERRAIN_PLAINS</TerrainType>
			<Yield>1</Yield>
		</Row>
		<Row>
			<Yield>1</Yield>
		</Row>
		<Row>
			<TerrainType>TERRAIN_TUNDRA</TerrainType>
			<Yield>1</Yield>
		</Row>
		<Row>
			<TerrainType>TERRAIN_COAST</TerrainType>
			<Yield>1</Yield>
		</Row>
		<Row>
			<Yield>1</Yield>
		</Row>
		<Row>
			<Yield>1</Yield>
		</Row>
		<Row>
			<Yield>1</Yield>
		</Row>
	</Terrain_Yields>
	<Terrain_RiverYieldChanges>
		<Row>
			<Yield>1</Yield>
		</Row>
		<Row>
			<Yield>1</Yield>
		</Row>
		<Row>
			<TerrainType>TERRAIN_DESERT</TerrainType>
			<Yield>1</Yield>
		</Row>
		<Row>
			<Yield>1</Yield>
		</Row>
	</Terrain_RiverYieldChanges>
		<Row>
			<Yield>-2</Yield>
		</Row>
		<Row>
			<Yield>2</Yield>
		</Row>
		<Row>
			<Yield>-1</Yield>
		</Row>
		<Row>
			<Yield>1</Yield>
		</Row>
		<Row>
			<Yield>2</Yield>
		</Row>
		<Row>
			<Yield>-1</Yield>
		</Row>
		<Row>
			<Yield>2</Yield>
		</Row>
</GameData>
Da bei 500 Änderungen das ganze per Hand hühselig wird, dachte ich, es gäbe das auch automatisch als "Merge-Tool"? Kennt jemand da was?
LG hen0
Ein merge-tool wüsste ich jetzt nicht, aber kannst du nicht einiges davon schon mit Notepad++ und regulären Ausdrücken ersetzen oder durch einfaches Strg+h ?
Sicher geht das, aber bei 500 Änderungen wünsche ich mir eine Automation :D
Tools wie kDiff können zwar Dateien mergen, aber haben keine XML-spezifische Intelligenz. Wenn du eine Skriptsprache beherrscht, solltest du einfach ein kleines Progrämmchen schreiben, das beide Dokumente einliest, die XML-Bäume zusammenführt und dann das resultierende Dokument wieder ausspuckt. Mit einer Sprache wie Python, Perl, etc. sollte das relativ simpel sein. Du mußt natürlich dann in deinem Skript entscheiden, was zu tun ist, wenn z.B. ein Element nicht nur zusätzliche Unterelemente erhält sondern selbst verändert wird ... gewinnt dann File A oder File B?
Ist vielleicht etwas Aufwand, aber wenn du das ganze in Zukunft noch öfters tun möchtest, würde sich das schon lohnen.
