3 Bluscreens in 4 Tagen
Liturgis
Nov. 2007
Ich habe mir einen kleinen HTPC zusammengestellt und habe diverse Probleme angefangen damit das die Maus und die Tastatur einfach von jetzt auf gleich aus gehen und enden mit Bluescreens.
Ich Poste mal die Auswertungen der Crashdump in Spoilern vielleicht kann mir jemand helfen :
1
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\070311-9640-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17592.amd64fre.win7sp1_gdr.110408-1631
Machine Name:
Kernel base = 0xfffff800`02a4c000 PsLoadedModuleList = 0xfffff800`02c91650
Debug session time: Sun Jul 3 22:29:52.277 2011 (UTC + 2:00)
System Uptime: 0 days 1:03:02.589
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {fffff8804b3391b8, 5, 0, fffff8800103c002}
Unable to load image \SystemRoot\system32\DRIVERS\intelppm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for intelppm.sys
*** ERROR: Module load completed but symbols could not be loaded for intelppm.sys
Probably caused by : msahci.sys ( msahci!AhciHwInterrupt+466 )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: fffff8804b3391b8, memory referenced
Arg2: 0000000000000005, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8800103c002, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cfb100
fffff8804b3391b8
CURRENT_IRQL: 5
FAULTING_IP:
fffff880`0103c002 0f83b1000000 jae msahci!AhciHwInterrupt+0x51d (fffff880`0103c0b9)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
TRAP_FRAME: fffff8000405f880 -- (.trap 0xfffff8000405f880)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=fffff880033391b8
rdx=0000000080000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800103c002 rsp=fffff8000405fa10 rbp=fffffa8003afc6a8
r8=0000000000000029 r9=0000000000000000 r10=fffffa8003afc610
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po cy
msahci!AhciHwInterrupt+0x466:
fffff880`0103c002 0f83b1000000 jae msahci!AhciHwInterrupt+0x51d (fffff880`0103c0b9) [br=0]
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002acb2a9 to fffff80002acbd00
STACK_TEXT:
fffff800`0405f738 fffff800`02acb2a9 : 00000000`0000000a fffff880`4b3391b8 00000000`00000005 00000000`00000000 : nt!KeBugCheckEx
fffff800`0405f740 fffff800`02ac9f20 : fffffa80`05a08502 fffff880`011bf1db 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff800`0405f880 fffff880`0103c002 : 00000000`00000000 00000000`00000008 00000000`00000008 00000000`00000000 : nt!KiPageFault+0x260
fffff800`0405fa10 fffff800`02ac7939 : fffffa80`00000000 fffffa80`03b0be48 fffff800`0405fb40 fffff800`02a0d895 : msahci!AhciHwInterrupt+0x466
fffff800`0405fa70 fffff800`02ac7718 : 00000000`00000002 fffffa80`043835d0 fffffa80`04fdccf0 fffffa80`00000000 : nt!KiScanInterruptObjectList+0x69
fffff800`0405fac0 fffff880`03c6a9c2 : fffff800`02ad5509 00000000`0020b587 fffffa80`04c10308 fffff800`02c4ccc0 : nt!KiChainedDispatch+0x128
fffff800`0405fc58 fffff800`02ad5509 : 00000000`0020b587 fffffa80`04c10308 fffff800`02c4ccc0 00000000`00000001 : intelppm+0x39c2
fffff800`0405fc60 fffff800`02ac39fc : fffff800`02c3ee80 fffff800`00000000 00000000`00000000 fffff880`02d15588 : nt!PoIdle+0x52a
fffff800`0405fd40 00000000`00000000 : fffff800`04060000 fffff800`0405a000 fffff800`0405fd00 00000000`00000000 : nt!KiIdleLoop+0x2c
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: msahci!AhciHwInterrupt+466
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: msahci
IMAGE_NAME: msahci.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4ce7a416
FAILURE_BUCKET_ID: X64_0xD1_msahci!AhciHwInterrupt+466
2
Loading Dump File [C:\Windows\Minidump\070311-8970-01.dmp]
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`02a13000 PsLoadedModuleList = 0xfffff800`02c58e90
Debug session time: Sun Jul 3 01:52:01.521 2011 (UTC + 2:00)
System Uptime: 0 days 0:24:40.848
BugCheck A, {fffffa84802dfc68, 2, 1, fffff80002ab3881}
Probably caused by : memory_corruption ( nt!MiUnlinkFreeOrZeroedPage+181 )
0: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffa84802dfc68, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80002ab3881, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cc40e8
fffffa84802dfc68
CURRENT_IRQL: 2
FAULTING_IP:
fffff800`02ab3881 48893cc2 mov qword ptr [rdx+rax*8],rdi
BUGCHECK_STR: 0xA
PROCESS_NAME: svchost.exe
TRAP_FRAME: fffff88005b83760 -- (.trap 0xfffff88005b83760)
rax=000000009005bf8c rbx=0000000000000000 rcx=0000000000000006
rdx=fffffa8000000008 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002ab3881 rsp=fffff88005b838f0 rbp=0000000000000002
r8=0000000000000000 r9=0000000000000000 r10=fffffa8003012070
r11=fffff80002c05e80 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz na pe nc
nt!MiUnlinkFreeOrZeroedPage+0x181:
fffff800`02ab3881 48893cc2 mov qword ptr [rdx+rax*8],rdi ds:dbb0:fffffa84`802dfc68=????????????????
LAST_CONTROL_TRANSFER: from fffff80002a92be9 to fffff80002a93640
STACK_TEXT:
fffff880`05b83618 fffff800`02a92be9 : 00000000`0000000a fffffa84`802dfc68 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`05b83620 fffff800`02a91860 : fffff8a0`0af23140 00000000`00000000 fffffa80`00000002 fffffa80`00569460 : nt!KiBugCheckDispatch+0x69
fffff880`05b83760 fffff800`02ab3881 : 00000000`071edbc0 00000000`071edb00 00000000`00000003 00000000`00000001 : nt!KiPageFault+0x260
fffff880`05b838f0 fffff800`02ab80b8 : fffff880`05b839c0 00000000`0001cdc2 fffffa80`00569460 00000000`00000000 : nt!MiUnlinkFreeOrZeroedPage+0x181
fffff880`05b83960 fffff800`02aa1844 : 00000000`00000000 00000000`00000002 00000000`00000000 ffffffff`ffffffff : nt!MiRemoveAnyPage+0x1d8
fffff880`05b83a80 fffff800`02a9176e : 00000000`00000001 00000000`078a3000 00000000`00000001 00000000`078282d8 : nt!MmAccessFault+0x1224
fffff880`05b83be0 00000000`706b414d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
00000000`071ed648 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x706b414d
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_NAME: nt!MiUnlinkFreeOrZeroedPage+181
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4ce7951a
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0xA_nt!MiUnlinkFreeOrZeroedPage+181
0: kd> !analyze -v
Arguments:
Debugging Details:
WRITE_ADDRESS: fffffa84802dfc68
CURRENT_IRQL: 2
FAULTING_IP:
BUGCHECK_STR: 0xA
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
3
Loading Dump File [C:\Windows\Minidump\070711-8392-01.dmp]
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`00b9c4c0?
Machine Name:
Kernel base = 0xfffff800`02a54000 PsLoadedModuleList = 0xfffff800`02c99650
Debug session time: Thu Jul 7 03:54:48.896 2011 (UTC + 2:00)
System Uptime: 0 days 2:32:47.223
BugCheck 9F, {3, fffffa8004c9f060, fffff80000b9c4d8, fffffa8005ed50f0}
Probably caused by : usbhub.sys
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8004c9f060, Physical Device Object of the stack
Arg3: fffff80000b9c4d8, Functional Device Object of the stack
Arg4: fffffa8005ed50f0, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
DRIVER_OBJECT: fffffa80043f9ab0
IMAGE_NAME: usbhub.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4ce7a68e
MODULE_NAME: usbhub
FAULTING_MODULE: fffff880040dc000 usbhub
BUGCHECK_STR: 0x9F
CURRENT_IRQL: 2
STACK_TEXT:
fffff800`00b9c488 fffff800`02b409c2 : 00000000`0000009f 00000000`00000003 fffffa80`04c9f060 fffff800`00b9c4d8 : nt!KeBugCheckEx
fffff800`00b9c490 fffff800`02adf652 : fffff800`00b9c5c0 fffff800`00b9c5c0 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`00b9c530 fffff800`02adf4f6 : fffff800`02c7bf00 00000000`0008f776 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00b9c5a0 fffff800`02adf3de : 00000015`58174e26 fffff800`00b9cc18 00000000`0008f776 fffff800`02c4a148 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9cbf0 fffff800`02adf1c7 : 00000004`9350a7c1 00000004`0008f776 00000004`9350a788 00000000`00000076 : nt!KiTimerExpiration+0x1be
fffff800`00b9cc90 fffff800`02acba2a : fffff800`02c46e80 fffff800`02c54cc0 00000000`00000000 fffff880`03c02db0 : nt!KiRetireDpcList+0x277
fffff800`00b9cd40 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cd00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FAILURE_BUCKET_ID: X64_0x9F_3_IMAGE_usbhub.sys
Ich bitte um Entschuldigung falls ich mit meiner Frage vielleicht der 1000 bin.
Grüße Liturgis
Hallo
welche Hardware hast du denn verbaut?
Du hast da "(DRIVER_)IRQL_NOT_LESS_OR_EQUAL" (laut LogFile). Hast du mal den RAM überprüft (Memtest86 z.B.)?
Sind alle Treiber aktuell?
BIOS auch aktuell? Da wird v.a. bei neuen Boards oft Inkompatibilitäten v.a. mit RAM behoben.
verbaut ist folgende Hardware:
ASUS P8H61-I
G620T
2GB TEAM CL9 Value
OCZ Vertex 2 Extended 60GB
Western Digital Caviar Green 1,5 TB
Aktuelle treiber von der Asus-Seite das Bios ist das Auslieferungs-BIOS, es gibt leider bisher nur das eine, welches auch Probleme bereitet was die Temperatur und Spannungsauslesung angeht, aber das ist jetzt erst einmal zweitrangig hoffe ich.
CPU wurde mit Prime und da interne GPU auch mit Furmark auf Stabilität geprüft bisher keine Probleme der Ram durchlief 3 Durchgänge von Memtest ohne Fehlermeldung.
Grüße Liturgis
hm komisch, kann keine wirkliche Gemeinsamkeit zwischen den BlueScreens erkennen. Gibt es denn ein bestimmts Programm, was du öffnest, bevor der PC abstürzt? Oder geschieht es nach einer gewissen Zeit? Oder auch einfach wenn du 10Minuten lang nichts am PC machst?
Der erste Fehler deutet auf die SSD hin, der Zweite und Dritte allerdings auf Treiber bzw Services.
Läuft der abgesicherte Modus denn stabil? Notfalls einmal alle überflüssigen Komponenten abklemmen, incl der 2ten Festplatte. Welchen Controller verwendest du für die SSD?
Lass memtest86+ doch mal ne ganze Nacht lang laufen, die Fehler müssen nach 3 Durchgängen noch nicht auftreten. Wahrscheinlich schon, aber damit du den RAM sicher ausschließen kannst, lass es mal lange durchlaufen. Wenns mehrere Riegel sind auch mal beide einzeln lange testen.
Grad bei so wirrem Verhalten und scheinbar unzusammenhängenden Bluescreens ist es meist der Arbeitsspeicher.
nur mal so: die maus bzw. die tastatur gehen nicht aus, sondern der gesamte rechner friert ein
was hastn du für hardware?
Ich hatte ein ähnliches Problem (Klick) - ein Firmware-Update der SSD OCZ Solid3 hat es dann schließlich behoben.
Also ich habe mir den HTPC für XBMC zusammengestellt, bei der Wiedergabe von Videos über XBMC ist dann der erste Bluescreen aufgetreten der zweite kam unverhofft und der dritte gestern Nacht als ich den PC herunterfahren wollte erst stand minutenlang "Herunterfahren" und dann kam der Bluscreen "DRIVER POWER STATE FAILURE"
Das musst du mir erläutern ?
Grüße Liturgis
Edit: Habe gehört, dass die OCZ SSD's mit den neuen P67, H67 usw. -boards ab und zu Probleme haben, die sich in Bluescreens äußern können.
Krautmaster schrieb:
1 ram riegel? mal anderen ram testen. Meist isses ram.
Ja es ist ein Riegel, habe leider keinen weiteren DDR 3 Riegel hier zum Testen, könnte mir aber gleich einen besorgen, allerdings
kann es aber nochmal testen vielleicht ist jetzt etwas verkehrt.
Danke für den Tip werde es mal probieren.
