Microsoft (R) Windows Debugger Version 10.0.22473.1005 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\knsna\Desktop\112621-8421-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 22000 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Edition build lab: 22000.1.amd64fre.co_release.210604-1628
Machine Name:
Kernel base = 0xfffff803`4c000000 PsLoadedModuleList = 0xfffff803`4cc29750
Debug session time: Fri Nov 26 21:12:05.699 2021 (UTC + 1:00)
System Uptime: 1 days 1:21:26.225
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff803`4c4159e0 48894c2408 mov qword ptr [rsp+8],rcx ss:ffffd600`5096d100=000000000000001e
4: kd> !analyze -v
* Bugcheck Analysis *
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common BugCheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc000001d, The exception code that was not handled
Arg2: fffff8034c28d95c, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: fffff8034a650052, Parameter 1 of the exception
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 5937
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 7330
Key : Analysis.Init.CPU.mSec
Value: 1327
Key : Analysis.Init.Elapsed.mSec
Value: 4662
Key : Analysis.Memory.CommitPeak.Mb
Value: 79
Key : WER.OS.Branch
Value: co_release
Key : WER.OS.Timestamp
Value: 2021-06-04T16:28:00Z
Key : WER.OS.Version
Value: 10.0.22000.1
FILE_IN_CAB: 112621-8421-01.dmp
BUGCHECK_CODE: 1e
BUGCHECK_P1: ffffffffc000001d
BUGCHECK_P2: fffff8034c28d95c
BUGCHECK_P3: 0
BUGCHECK_P4: fffff8034a650052
EXCEPTION_PARAMETER2: fffff8034a650052
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: Cyberpunk2077.exe
FAILED_INSTRUCTION_ADDRESS:
nt!KeAddProcessorAffinityEx+c
fffff803`4c28d95c 44 ???
STACK_TEXT:
ffffd600`5096d0f8 fffff803`4c54881a : 00000000`0000001e ffffffff`c000001d fffff803`4c28d95c 00000000`00000000 : nt!KeBugCheckEx
ffffd600`5096d100 fffff803`4c41f17f : 00000000`00000000 00000000`00000000 00000000`00000000 ffffd600`5096d1e0 : nt!HvlpVtlCallExceptionHandler+0x22
ffffd600`5096d140 fffff803`4c286347 : ffffd600`5096d6e0 fffff803`4c41d775 ffffbc05`dde67d00 ffffd600`5096d1e0 : nt!RtlpExecuteHandlerForException+0xf
ffffd600`5096d170 fffff803`4c28a291 : ffffffff`ffffffff ffffbc05`dde678d0 ffffbc05`dde678d0 ffffd600`5096d900 : nt!RtlDispatchException+0x2d7
ffffd600`5096d8d0 fffff803`4c4168f2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchException+0x1b1
ffffd600`5096dfb0 fffff803`4c4168c0 : fffff803`4c4286c7 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxExceptionDispatchOnExceptionStack+0x12
ffffbc05`dde676e8 fffff803`4c4286c7 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatchOnExceptionStackContinue
ffffbc05`dde676f0 fffff803`4c422979 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0x107
ffffbc05`dde678d0 fffff803`4c28d95c : fffff803`4c2ce564 00000000`00400a02 ffffc608`82d25b70 ffff0310`4f9e5cff : nt!KiInvalidOpcodeFault+0x2f9
ffffbc05`dde67a68 fffff803`4c2ce564 : 00000000`00400a02 ffffc608`82d25b70 ffff0310`4f9e5cff 00004bab`d24383ad : nt!KeAddProcessorAffinityEx+0xc
ffffbc05`dde67a70 fffff803`4c2cd38e : ffffd600`508fb180 ffffd600`507741b8 ffffbc05`dde67bd0 00000000`00000000 : nt!KiDeferredReadySingleThread+0x10a4
ffffbc05`dde67b60 fffff803`4c2cc506 : 00000000`00000000 ffffc608`00000001 ffffbc05`00000000 ffffd600`00000002 : nt!KiProcessThreadWaitList+0x11e
ffffbc05`dde67bd0 fffff803`4c2ca984 : ffffd600`508fb180 00000000`0000000d 000000d4`8ad47bbf fffff803`4a64e928 : nt!KiProcessExpiredTimerList+0x376
ffffbc05`dde67d00 fffff803`4c41d775 : 00000000`00000000 ffffd600`508fb180 ffffc608`82d25ac0 00000000`ffffffff : nt!KiRetireDpcList+0x714
ffffbc05`dde67fb0 fffff803`4c41d550 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxRetireDpcList+0x5
ffffbc05`e26279a0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchInterruptContinue
CHKIMG_EXTENSION: !chkimg -lo 50 -db !nt
8 errors : !nt (fffff8034c28d945-fffff8034c28d97d)
fffff8034c28d940 00 5f c3 cc cc *7f cc cc cc cc cc cc cc *20 cc cc ._........... ..
fffff8034c28d950 4c 8b c1 8b c2 *96 8d 0d 54 0c a8 00 44 *3f 0c 81 L.......T...D?..
fffff8034c28d960 41 8b c9 41 0f *7f 00 41 83 e1 3f c1 e9 *7f 3b c1 A..A...A..?...;.
fffff8034c28d970 0f 86 dc 53 20 *20 8b d1 49 8b 4c c8 08 *aa 8b c1 ...S ..I.L.....
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
MEMORY_CORRUPTOR: STRIDE
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_STRIDE
OS_VERSION: 10.0.22000.1
BUILDLAB_STR: co_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {574dbc1b-92cb-fb09-cb7a-cacc1bb2c511}
Followup: memory_corruption
