surf canyon ad-on läuft nur unter yahoo,obwohl beide eingestellt sind.bei der erstinstallation
ist es noch gegangen,beim 2 .mal nicht mehr,geht nur noch unter yahoo.was kann man da tun?
I apologize for not speaking German, but today we're having a temporary problem with Google. We'll be rolling out an update (v1.1.3) very shortly that fixes the issue. If you leave your current version installed, you'll be prompted to update and then everything should be back to functioning normally. Thank you for your understanding!
thank you very much ,with the version 1.1.3 of surf canyon he run under google hipppiiiipppiiii.
thanks,thanks,thanks,the automatic option on firefox is now on by me.thanks.
