[Auswahl] 140 mm Gehäuselüfter
Cov
März 2009
Hi, hier ist eine aktuelle Auswahl an 140 mm Gehäuselüfter.
Wo möglich habe ich die PWM Versionen herausgesucht.
» Akasa - Apache Black - 140 mm
Akasa Apache Black
Fan speed: 600 - 1300 rpm
Max airflow: 89.55 CFM
Noise level: 12.5 - 22.19 dB(A)
Bearing: HDB (Hydro Dynamic Bearing)
Fan life expectancy: 50,000 hours
Connector: 4-pin PWM
» Akansa - Viper - 140 mm
Akasa Viper
Fan speed: 600 -1600 rpm
Max airflow: 110.61 CFM
Noise level: 12.5 - 26.01 dB(A)
» Alpenföhn - Wingboost - 140 mm
Alpenföhn Wingboost
Fan speed: 7V = 600 (adaptor included) / 12V = 1100 rpm
Max airflow: ? CFM
Noise level: 19.4 dB(A)
Bearing: HD
Fan life expectancy: ?
» Cougar - Vortex HDB - CF-V14H - 140 mm
Cougar Vortex CF-V14H
Fan speed: 700 (with adaptor) / 1200
Max airflow: 55.5 / 70.5 CFM
Noise level: 16.4 / 19.2 dB(A)
Bearing: HDB (Hydro-Dynamic Bearing)
Fan life expectancy: 300.000
Connector: 3-pin
» Deepcool - UF140 - 140 mm
Deepcool UF140
Fan speed: 700 ±200 ~ 1200 ±10% rpm
Max airflow: 71.8 CFM
Noise level: 17.6 ~ 26.7dB(A)
Bearing: 2 Ball Bearing
» Noctua - NF-P14 FLX - 140 mm
Noctua NF-P14 FLX
Fan speed: ULNA = 750 / LNA = 900 / 1200 rpm *
Max airflow: ?
Noise level: ULNA = 10.1 / LNA = 13.2 / 19.6 dB(A)
Bearing: SSO Bearing
Fan life expectancy (MTBF): 150,000 hours
Connector: ?
* ULNA = Ultra Low Noise Adaptor / LNA = Low Noise Adaptor
» NZXT - FX-140LB - 140 mm
NZXT FX-140LB
Fan speed: Low = 1000 / medium = 1.500 / high = 2000 rpm *
Max airflow: 49.1 - 98.3 CFM
Noise level: 22.1 - 37 dBA
Bearing: Fluid Dynamic Bearing
Fan life expectancy: 35.000 hours
Connector: 4-pin Molex and 3-pin Mainboard
* [FONT=arial,helvetica,sans-serif]has a three position fan speed switch built in[/FONT]
» Scythe - Kaze Maru - 140 mm
Scythe Kasa Maru
Fan speed: 500 / 1200 / 1900 rpm (depending on model)
Max airflow: 29,39 / 61,30 / 104,54 CFM
Noise level: 10,80 / 26,58 / 41,13 dB(A)
Bearing: Sleeve Bearing
Fan life expectancy (MTBF): 30.000 hours
Connector: 3-pin
» Scythe - Kama Flex - 135 mm
Scythe Kama Flex 135
Fan speed: 800 / 1200 / 1600 rpm (depending on model)
Max airflow: 49,8 / 75,6 / 100,5 CFM
Noise level: 16 / 23,2 / 33,1 dBA
Bearing: S-FDB
Fan life expectancy (MTBF): 120.000 hours
Connector: 3-pin
» Scythe - Slip Stream - 140 mm
Scythe Slip Stream 140
Fan speed: 500 / 800 / 1200 / 1700 rpm (depending on model)
Max airflow: 27,2 / 43,5 / 65,2 / 92,4 CFM
Noise level: 9,6 / 14,3 / 23,2 / 36,4 dBA
Fan life expectancy (MTBF): 20.000 hours
Connector: 3-pin
» Be Quiet - Silent Wings USC - 140 mm
Be Quiet Silen Wings USC
Fan speed: 12V = 1000 rpm
Max airflow: 12V = 60.4 CFM
Noise level: 12V = 16.5 dBA
Bearing: FDB
Fan life expectancy: 300.000 hours
Connector: 3-pin Molex
» Silverstone - AP 141 - 140 mm
Silverstone AP141
Fan speed: 5V = 700 rpm / 7V = 1000 / 12V = 1500
Max airflow: 5V = 28.26 / 7V = 41.09 / 12V = 64.34 CFM
Noise level: 5V = 18 / 7V = 20.9 / 12V = 30.1 dB(A)
Bearing: Fluid Dynamic Bearing (FDB)
Fan life expectancy (MTBF): 50.000 hours
Connector: 4-pin Power Connector
» Thermalright - TY140 - 140 mm
Thermalright TY140*
Fan speed: 900 ~ 1300 RPM
Max airflow: 28.3 ~ 74CFM
Noise level: 17 ~ 21dBA
Bearing: Enhanced Hyper-Flow Bearing (EHFB)
* 12 cm mounting hole
» Titan - Kukri - TFD-14025H12ZP/KU(RB) - 140 mm
Titan Kukri TFD-14025H12ZP/KU(RB)
Fan speed: 700 ~ 1800 RPM
Max airflow: 34.78 ~ 89.43 CFM
Noise level: <8.3 ~ <28.8 dBA
Bearing: Z-AXIS
Fan life expectancy: 60.000 hours
Connector: 4-pin PWM function
» Titan - DC Fan - TFD-14025 xxxx - 140 mm
Titan DC Fan TFD-14025 xxxx
Fan speed: 600 / 900 / 1200 / 1500 / 1800 (depending on model)
Max airflow: 38.58 / 56.74 / 68.23 / 94.89 / 113.87 CFM
Noise level: 7 / 15.8 / 22.1 / 26.9 / 30.9
Bearing: ?
Connector: 3-pin
» Xigmatek - XAF-F1452 - 140 mm
Xigmatek XAF-F1452
Fan speed: 800 ~ 1300 R.P.M.
Max airflow: max 90.3 CFM
Noise level: <18 dBA
Bearing: Aeronautical Oil System Bearing
Fan life expectancy: 150.000 hours
» Xilence - 2CF (2 component fan) - 140 mm
Xilence 2CF
Fan speed: 700 - 1200 rpm
Max airflow: 70.79 CFM
Noise level:
17,6 - 26,7 db(A)
Bearing: Ball Bearing
Connector: ?
» Zaward - ZG2-140B - 140 mm
Zaward - ZG2-140B
Fan speed: 300 - 1.200 RPM
Noise level: 10,1 - 20,3 dB(A)
Die herausgesuchten Angaben also Herstellerwerte sagen bei vielen Modellen nichts aus. Viele Angaben werden geschönt oder beziehen sich nur auf die unterste Drehzahl.
Und was bezweckst du damit?
Die Bilder und Herstellerdaten kann sich jeder selbst im Netz zusammen klabustern.
Subjektive Urteile oder ein Round Up/ Test / Review wären sinnvoller.
Spock55000
Wenn man gegen die Schleifgeräusche der doch nicht günstigen Lüfter unempfindlich ist - dann ja
Ansonsten - NOPE - kann die Dinger nicht SILENT nennen.
2x den PK-1 gekauft - beide schleifen wie sau - scheiß Dinger
Habe ich mich gerade auch gefragt.
Wie es aussieht wolltest du einfach uns mal mitteilen welche 140mm Lüfter aktuell auf dem Markt sind. Oder?
Aber warum? Hast du zu viel Zeit oder ist dir langweilig?
Bitte versteh mich nicht falsch, ist nicht böse gemeint oder so. Ich versuch nur nachzuvollziehen warum du das machst, wenn jeder z.B. beim caseking noch viel besseres Auswahl hat und wo sogar die Preise angegeben werden?
:confused_alt::confused_alt::confused_alt:
Finde ich nicht schlecht, den Thread. Zwar nix halbes und nix ganzes (Alle brauchbaren Lüfter mal reinpacken?), aber doch recht hilfreich. ^^
Bin dank dir jetzt bspw. auf den neuen (?) Cougar Lüfter gestoßen. Geiles Ding. <:
Shalva schrieb:
Soweit ich weiß, gibt es keine Übersich über 140 mm Gehäuselüfter mit PWM.
Ja, bei Caseking kann man sich sämtliche Lüfter nach den Maßen schön auflisten lassen, aber erstens habe ich hier die für mich in Frage kommenden zusammengestellt und zweitens gefallen mir die Bilder besser. Also ich brauche hier nicht zwischen unzähligen nicht in Frage kommenden Lüfter hin- und herzuspringen..
fr3sh schrieb:
... Zwar nix halbes und nix ganzes ...
Schick mir doch mal bitte jemand alle Lüfter nach Hause, dann mache ich einen ausführlichen, gewissenhaften Vergleichstest :D
Ein Test is ja nich unbedingt nötig, aber als übersichtliche Zusammenfassung mit eben zur Zeit allen brauchbaren Lüftern - wieso nicht? ^^
Wäre schön zu wissen warum gerade diese Lüfter für dich in Frage kommen. Solche Infos könnten für den einen oder den anderen möglicherweise hilfreich sein. Nichts gegen eine übersichtliche Zusammenfassung aber ohne Begründung sind es nur Bilder.
Oder findest du die Lüfter nur optisch hübsch?
Hmm, gute Frage. Also ich suche irgendwie alle Dinge besonders nach optischen Gesichtspunkten aus.
Ich versuche darauf zu achten, daß sie mir sowohl praktisch als auch optisch gefallen, aber es ist schon eine echte Macke von mir, daß mir die Optik so wichtig ist. Dessen bin ich mir bewußt.
@Cov
Hahahaha..... :daumen:
Da haben wir wohl mehr gemeinsam als du denkst. Mein Mainboard Asus Rampage III Formula habe ich fast nur wegen Optok gekauft. Naja nicht ganz aber Optik hat da eine sehr grosse Rolle gespielt. Ich habe es beim Alternate für 240€ gekauft obwohl der Rampage III Extreme für 299€ verfügbar war und theoretisch die bessere Wahl gewesen wäre.
Das Rampage III Formula hat meiner Meinung nach das schönste und beste Layout überhaupt. Am liebsten würde ich es in einem Bilderrahmen auf dem Wand hängen.
Also wenn ich genauer nachdenke dann habe ich schon so einiges zu 60%-70% wegen Optik gekauft. Die Funktionalität ist da ein sehr wilkommenes Nebeneffekt:D:D
Ich würde sagen die Optik ist mir, genau so wie dir enorm wichtig, auch bei einem Maindoard oder RAM obwohl man nicht mehr viel davon sieht aber man will ja auch etwas für Auge.:cool_alt:
Und die Vernunft.....na ja..... was war das noch mal......:confused_alt::confused_alt::confused_alt:
Shalva schrieb:
... Mein Mainboard Asus Rampage III Formula habe ich fast nur wegen der Optik gekauft.
Asus Rampage? Habe gerade mal nach Bilder gegoogelt, und jetzt verstehe ich genau was Du meinst :daumen:
Haha
, da bin ich aber froh daß ich nicht alleine so denke!
Die Funktionalität ist da ein ̶s̶̶e̶̶h̶̶r̶ willkommener Nebeneffekt.
Ja, muß nicht unbedingt sein, aber wenn es schon darüber hinaus auch noch praktisch ist, ok :D
Shalva schrieb:
... etwas genauer untersuchen.
Ach so, Du machst Dir jetzt sorgen wegen einer möglichen Infektion oder so?
Oder wolltest Du nur wissen, wohin das Tattoo so weiterführt? :D
Sechs der hier aufgelisteten Lüfter werde ich bald testen, den Xilence 2CF und den EKL Wingboost habe ich bereits hier getestet.
Der EKL Wingboost ist recht gut, der Xilence ist schlechter aber günstiger und das gesamte Zubehör des Xilence ist gesleevt, was für den ein oder anderen wichtig sein könnte.
Die Cougar HDB Lüfter sind sehr gut, aber ich finde, dass das 140mm Modell für 20€ etwas zu wenig bietet. (Low Noise Adapter ohne Schrumpfschlauch, Molex Adapter nicht gesleevt, Lager schlechter als beim Silent Wings).
Die Prolimatech Vortex sollst du auch aufnehmen, die sind gut und günstig.
Bilder des Cougar HDB:
mfg dorndi
Wegen der Noiseblocker:
Ich verwende den Noiseblocker NB-BlackSilentPRO PK-2 im Boden meines Fractal R3.
Ein Lagerschleifen ist definitiv nicht wahrnehmbar. Auf maximaler Umdrehung ist ein dezentes Rauschen zu hören, ab 950 abwärts ist absolut Ruhe :)
Der Lüfter ist zwar nicht billig, aber mit Abstand der Beste bisher.
http://geizhals.at/deutschland/476867
