S
Scriptkid
Hallo Freunde,
zum ersten Mal habe ich mit Win 10 Probleme. Bereits beim Entpacken des neusten Treibers bekomme ich einen BSOD mit folgender Auswertung:
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: ffffd000248a2000, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80055dc1d56, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000000, (reserved)
Debugging Details:
Could not read faulting driver name
READ_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPagedPoolEnd
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
ffffd000248a2000
FAULTING_IP:
klpd+1d56
fffff800`55dc1d56 488b4114 mov rax,qword ptr [rcx+14h]
MM_INTERNAL_CODE: 0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
PROCESS_NAME: 355.98-desktop
CURRENT_IRQL: 2
BAD_PAGES_DETECTED: 9d69
TRAP_FRAME: ffffd000234b0130 -- (.trap 0xffffd000234b0130)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000006cc4 rbx=0000000000000000 rcx=ffffd000248a1fec
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80055dc1d56 rsp=ffffd000234b02c0 rbp=ffffd000234b0319
r8=0000000000000014 r9=ffffd000234b0300 r10=fffff80055dc30d8
r11=ffffd000234b02b8 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na pe nc
klpd+0x1d56:
fffff800`55dc1d56 488b4114 mov rax,qword ptr [rcx+14h] ds:ffffd000`248a2000=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800c8dacf58 to fffff800c8d5d240
STACK_TEXT:
ffffd000`234afee8 fffff800`c8dacf58 : 00000000`00000050 ffffd000`248a2000 00000000`00000000 ffffd000`234b0130 : nt!KeBugCheckEx
ffffd000`234afef0 fffff800`c8c2e536 : 00000000`00000000 00000000`00000000 ffffd000`234b0130 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x41158
ffffd000`234affe0 fffff800`c8d662bd : ffffb000`6003c8b0 ffffc001`54f353f0 ffffc001`54f35530 ffffc001`54f353f0 : nt!MmAccessFault+0x696
ffffd000`234b0130 fffff800`55dc1d56 : ffffc001`5e026150 00000000`00004e9c ffffd000`00000014 ffffd000`234b0300 : nt!KiPageFault+0x13d
ffffd000`234b02c0 ffffc001`5e026150 : 00000000`00004e9c ffffd000`00000014 ffffd000`234b0300 00000000`00004e9c : klpd+0x1d56
ffffd000`234b02c8 00000000`00004e9c : ffffd000`00000014 ffffd000`234b0300 00000000`00004e9c ffffe000`99da7e70 : 0xffffc001`5e026150
ffffd000`234b02d0 ffffd000`00000014 : ffffd000`234b0300 00000000`00004e9c ffffe000`99da7e70 ffffe000`9ad0b090 : 0x4e9c
ffffd000`234b02d8 ffffd000`234b0300 : 00000000`00004e9c ffffe000`99da7e70 ffffe000`9ad0b090 00000000`00000000 : 0xffffd000`00000014
ffffd000`234b02e0 00000000`00004e9c : ffffe000`99da7e70 ffffe000`9ad0b090 00000000`00000000 ffffd000`248a1fec : 0xffffd000`234b0300
ffffd000`234b02e8 ffffe000`99da7e70 : ffffe000`9ad0b090 00000000`00000000 ffffd000`248a1fec 00000000`00000000 : 0x4e9c
ffffd000`234b02f0 ffffe000`9ad0b090 : 00000000`00000000 ffffd000`248a1fec 00000000`00000000 00000000`00000000 : 0xffffe000`99da7e70
ffffd000`234b02f8 00000000`00000000 : ffffd000`248a1fec 00000000`00000000 00000000`00000000 00000000`00000000 : 0xffffe000`9ad0b090
STACK_COMMAND: kb
SYMBOL_NAME: PAGE_NOT_ZERO
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: PAGE_NOT_ZERO
Followup: MachineOwner
*** Memory manager detected 40297 instance(s) of page corruption, target is likely to have memory corruption.
Sieht nach einem RAM-oder pagefile-Fehler aus.
Ansonsten läuft das System einwandfrei.
Habt Ihr Vorschläge zur Behebung des Fehlers?
Arguments:
address.
Debugging Details:
ffffd000248a2000
FAULTING_IP:
klpd+1d56
MM_INTERNAL_CODE: 0
BUGCHECK_STR: AV
CURRENT_IRQL: 2
klpd+0x1d56:
STACK_TEXT:
STACK_COMMAND: kb
