CodingIstToll
- Nov. 2023
Folgender Code:
public enum Main {
public static void main(final String[] args) {
final int boxsize = 3;
final int anzahlshapes = 6;
final int rotation = 1;
final String[][][] box = new String[boxsize][boxsize][boxsize]; // 3D-Array für die Box
box[boxsize / 2][boxsize / 2][boxsize / 2] = "G";
final Form[] formes = new Form[anzahlshapes];
formes[0] = new Form(1, 3, 3);
formes[1] = new Form(1, 3, 3);
formes[2] = new Form(1, 1, 3);
formes[3] = new Form(1, 1, 2);
formes[4] = new Form(1, 1, 2);
formes[5] = new Form(1, 1, 1);
Main.solve(box, formes, 0);
public static void solve(final String[][][] box, final Form[] formes, final int currentIndex) {
// Basisfall: Wenn alle Formen platziert wurden, drucken Sie die Lösung oder tun Sie etwas damit
if (boxisfull(box)) {
Main.print(box);
return;
// Versuchen Sie, die aktuelle Form an verschiedenen Positionen und Rotationen zu platzieren
for (int x = 0; x < box.length; x++) {
for (int y = 0; y < box[0].length; y++) {
for (int z = 0; z < box[0][0].length; z++) {
for (int rotation = 1; rotation <= 6; rotation++) {
if (formes[currentIndex].canbeplaced(x, y, z, box)) {
formes[currentIndex].place(x, y, z, box, currentIndex + 1);
solve(box, formes, currentIndex + 1);
formes[currentIndex].remove(x, y, z, box);
private static void print(final String[][][] box) {
System.out.print(box[x][y][z] + "\t");
System.out.println();
System.out.println("----------");
public static boolean boxisfull(String[][][] box) {
if (box[x][y][z] == null) {
return false; // Es gibt mindestens eine leere Stelle
return true;
class Form {
int xpos, ypos, zpos;
int xlength, ylength, zlength;
int ix, iy, iz;
char type;
int rotation = 1;
public Form(final int xlength, final int ylength, final int zlength) {
this.xlength = xlength;
this.ylength = ylength;
this.zlength = zlength;
ix = xlength;
iy = ylength;
iz = zlength;
if (xlength == ylength && ylength == zlength)
type = 'w';
else
type = 'q';
public void place(final int x, final int y, final int z, final String[][][] box, final int index) {
// Platzieren Sie die Form basierend auf den aktuellen Abmessungen
for (int i = 0; i < this.xlength; i++) {
for (int j = 0; j < this.ylength; j++) {
for (int k = 0; k < this.zlength; k++) {
// box[x + i][y + j][z + k] = Integer.toString(index);
public void remove(final int x, final int y, final int z, final String[][][] box) {
box[x + i][y + j][z + k] = null;
public void rotate() {
if (7 > this.rotation && 0 < this.rotation) {
switch (rotation) {
case 1:
xlength = this.ix;
ylength = this.iy;
zlength = this.iz;
break;
case 2:
xlength = this.iy;
ylength = this.iz;
zlength = this.ix;
break;
case 3:
xlength = this.iz;
ylength = this.ix;
zlength = this.iy;
break;
case 4:
xlength = this.ix;
ylength = this.iz;
zlength = this.iy;
break;
case 5:
xlength = this.iy;
ylength = this.ix;
zlength = this.iz;
break;
case 6:
xlength = this.iz;
ylength = this.iy;
zlength = this.ix;
break;
rotation++;
} else {
rotation = 1; // Zurücksetzen auf den Anfang, wenn rotation 6 erreicht.
this.rotate();
public boolean canbeplaced(final int x, final int y, final int z, final String[][][] box) {
if (i + x >= box.length) {
return false;
if (j + y >= box[0].length) {
return false;
if (z + k >= box[0][0].length || null != box[x + i][y + j][z + k]) {
return false;
return true;
er soll eine box per backtrackign mit den gegebenen steinen füllen udn die lösung ausgeben. Seht ihr meinen Fehler?
public enum Main {
Main.print(box);
return;
return true;
class Form {
int ix, iy, iz;
char type;
int rotation = 1;
ix = xlength;
iy = ylength;
iz = zlength;
type = 'w';
else
type = 'q';
switch (rotation) {
case 1:
xlength = this.ix;
ylength = this.iy;
zlength = this.iz;
break;
case 2:
xlength = this.iy;
ylength = this.iz;
zlength = this.ix;
break;
case 3:
xlength = this.iz;
ylength = this.ix;
zlength = this.iy;
break;
case 4:
xlength = this.ix;
ylength = this.iz;
zlength = this.iy;
break;
case 5:
xlength = this.iy;
ylength = this.ix;
zlength = this.iz;
break;
case 6:
xlength = this.iz;
ylength = this.iy;
zlength = this.ix;
break;
rotation++;
} else {
this.rotate();
return false;
return false;
return false;
return true;
