Crash analyse Bluescreen
tobi83
Nov. 2004
Bräuchte mal eine Erklärung für folgende Crash Analyse....
Wenn möglich mit einem Tip was ich dagegen machen kann....
Vielen Dank
Tobias
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 16.06.2015 13:53:44 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061615-18642-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x6C7C5)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF80002E7A7C5, 0xFFFFF88003308368, 0xFFFFF88003307BC0)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0x7E (0xFFFFFFFFC0000005, 0xFFFFF80002E7A7C5, 0xFFFFF88003308368, 0xFFFFF88003307BC0)
Bug check description: This bug check indicates that a system thread generated an exception that the error handler did not catch.
On Sun 14.06.2015 17:53:41 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061415-20482-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x748C0)
Bugcheck code: 0x7A (0xFFFFF6FB40000168, 0xFFFFFFFFC000009D, 0x13C6D3884, 0xFFFFF6800002D470)
Error: KERNEL_DATA_INPAGE_ERROR
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
On Thu 14.05.2015 05:19:50 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051415-18470-01.dmp
Bugcheck code: 0x7A (0x20, 0xFFFFFFFFC000009D, 0xFFFFFA80082F6488, 0x0)
On Mon 20.04.2015 14:06:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042015-20966-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x72A40)
Bugcheck code: 0x7A (0xFFFFF6FC8060DFB8, 0xFFFFFFFFC0000010, 0x7F2B5880, 0xFFFFF900C1BF79F0)
Hik,
hast Du irgendwas in letzter Zeit an der Hardware gemacht (Speicher, neue Platte, etc.)
eingebaut od. Software/Treiber (Grafikkarte ?) installiert/optimiert ?
Ne läuft so seit längerem (letztes Jahr)
eben hat sich der pc wieder verabschiedet.
Keine Reaktion mehr und schwarze und weiße dünne striche aufm Bildschirm...
Keiner eine Idee??
Aus den ersten beiden Stopfehlercodes kann man (ohne nähere Analyse der Dumps) erst mal nur eine Speicherzugriffsverletzung herauslesen:
0x7E (0xFFFFFFFFC0000005,....)
Speicher i.d.S. kann allerdings so ziemlich alles sein.
Die nächsten beiden Stopfehlercodes geben schon etwas nähere Hinweise welcher Speicher das sein könnte:
Bugcheck code: 0x7A (0xFFFFF6FB40000168, 0xFFFFFFFFC000009D,....)
Das zweite Argument in der Klammer ist ein NT Statuscode (C000009D), dieser beschreibt, dass das System nicht mehr auf die Systemplatte zugreifen konnte.
Der letzte Stopfehlercode, bzw. dessen NT Status Code:
0x7A (0xFFFFF6FC8060DFB8, 0xFFFFFFFFC0000010,....) beschreibt eine ungültige Anfrage auf die Systemplatte (ggf. weil diese selbst fehlerhaft ist).
Dem würde ich erst mal nachgehen. Poste bitte mal ein paar Screenshots von CrystalDiskInfo, damit wir die SMART Werte (aller) Laufwerke prüfen können.
Da Laufwerk 3 angeschlagen ist würde es ja passen das es mehrmals bei einem Programm von dessen Platte Probleme gab?!
Anderes Smart Tool zeigte keine Warnung an für die Platten .....
Auch wenn dort bereits 6 wiederzugewiesene Sektoren zu sehen sind (und damit die Ausfallwahrscheinlichkeit erhöht ist -> Austausch wäre empfehlenswert), so ist diese Platte kaum für die Stop 0x7A Fehler verantwortlich (sofern nicht die Auslagerungsdatei auf der Platte ist).
Bei deiner Samsung SSD sind 23 UDMA CRC Fehler protokolliert (C7 - Hex Wert 17). Dies könnte vielmehr der Grund für die Stop 0x7A Fehler sein. Die CRC Fehler treten insbes. bei lockeren oder defekten Datenkabel (SATA Kabel) auf. Ich würde daher dringend empfehlen das Datenkabel auszutauschen (und gleich auch noch den korrekten Sitz des Stromkabels an der SSD prüfen).
Der CRC Wert darf nach dem Kabeltausch nicht weiter ansteigen (falls doch liegt möglicherweise ein Controllerproblem vor).
Die 1,5 TB WDC (Laufwerk D, E, F) zeigt übrigens 353 CRC Fehler! (Hex Wert 161)
Auch hier solltest du schnellstens das SATA Kabel tauschen und den Wert regelmäßig kontrollieren.
Also mal einen komplett neuen Satz Kabel besorgen.
wie können die Kabel denn Verschleißen?
nu ja, wenn es "preiswerte"' Kabel sind, dann können die Stecker / Buchsen "ausleiern",
sprich, bei wärme "dehnen" sie sich, zwar minimal, aber es reicht, damit der kontakt nicht
dauerhaft ist.
Im schlimmsten Falls haben die SATA Anschlüsse auf dem Board ein Problem "kalte Lötstelle",
d.h. bei erwärmung gibt es keinen 100% Kontakt vom Board zu den "lötstellen", ergo.
"wackekontakt" und dadurch teilweise kein Kontakt.
Schwierig...
Die Probleme könnten auch von Anfang an da gewesen sein, nur hast du sie nicht gemerkt. Billige Kabel sind oft schlecht abgeschirmt, was auch zu CRC-Fehlern führen kann. Achte beim Neukauf darauf, dass diese Sata3-Kompatibel sind (für die Zukunft).
