CyanogenMod-7.1 Released!
Pritti
Aug. 2005
Juten Tag,
da ja genug Leute die CyanogenMod nutzen wollte ich nur mal darauf aufmerksam machen,
dass es nun eine 7.1 stable Version zum Download gibt...ich werde diese gleich auch mal testen und bin echt sehr gespannt ;)
CHANGELOG (notable new features)
7.1.0
Common: Android 2.3.7 (Google)
Common: Bluetooth mouse support - Scott Brady
Common: Improve notification swipe-to-clear - Evan Charlton
Common: Improve album-artist support in media scanner - Paul Crovella
Common: Profile improvements and bugfixes - Martin Long, Danny Baumann, Robert Burns
Common: RTL text improvements - Eyad Aboulouz, Eran Mizrahi
Common: Wake on volume key option - Sven Dawitz
Common: Support for revoking application permissions - Plamen K. Kosseff
Common: Latest Superuser app - ChainsDD
Common: Control brightness by sliding on statusbar - Danesh M
Common: Add "copy all" to context menu - Danesh M
Common: Lockscreen haptic and statusbar indicators toggle - Danesh M
Common: Nicer timepicker/datepicker - Jiri Tyr
Common: Configuration 0/90/180/270 rotation - Jonas Larsson, Scott Brady
Common: DSP Manager bugfixes and improvements - Antti S Lankila
Common: Support for launching apps via gestures in the background - Jiri Tyr
Common: Option to hide hold button during call - Roberto Leinardi
Common: Allow using wildcards for call blacklisting - Nihanth Subramanya
Common: Option to allow in-call lockscreen to match main lockscren - Sven Dawitz
Common: Option to notify about incoming call only in background when screen is on - Pavel Kucera
Common: ADWLauncher- Transitions, catalog improvements, bugfixes - John Van Etten
Common: Optional GMT correction for SMS/MMS timestamps - Terry Hau
Common: Add FM Seek for TI devices - KalimochoAz
Common: Add FM support for SI4708 devices (Blade, V9, Racer) - Stéphane Konstantaropoulos
Common: Add FM seek implementation to FM application - Tom Giordano
Common: Show current FM status on lockscreen - Tom Giordano
Common: Camera touch-to-focus - cyanogen, arcee, m0viefreak, Danny Baumann
Common: Screenshot feature via power menu - arcee
Common: WEBP backport - Vikas Arora
Common: Add CM copyright noticies - arcee
Common: Skia/Zlib/libcore ARM optimizations - 0xlab
Common: Bluetooth tethering - Stéphane Konstantaropoulos
Common: Lockscreen widget alignment - Danesh Mondegarian
Common: Lockscreen calendar - David Morgan
Common: AVRCP 1.3 support - Qualcomm (bugfix by Danny Baumann)
Common: LED notification overhaul - Danny Baumann
Common: System-wide DNS cache - Google, SEMC
Common: Headset icon toggle - Cameron Pickett
Common: FM seek support - Emilio López, Tom Giordano
Common: Editable event fields in Contacts app - Danny Baumann
Common: Remove compromised CA from system certs - Guardian Project
Common: Mute camera shutter option - George Maizel
Common: Camera timer - Danesh Mondegarian
Common: "Mark all read" option in MMS - Vinod Surendran
Common: "eat" pushes fresh brunch/breakfast to device - Ricardo Cerqueira
Common: Customizable account color chip in Email - copolii
Common: "Rings" lockscreen - Valera Trubachev
Click, Motorola: Speed up photo recording - Emilio López
Click, Motorola: Add Geolocation to photo app - KalimochoAz
Click: Upgraded kernel from HTC 2.6.29 to 2.6.35
HTC msm7x30: 2.6.35 kernel and updated userspace
Buzz: 2.6.35 kernel - Arne Coucheron
Bravo(c)/Vivo(w)/Ace/Liberty: On charge notification led - Richard Antony Burton
Crespo/Crespo4G: Kernel update 2.6.35.14 and more, voodoo implementation, BLN, BLX...
Encore: Update kernel from 2.6.29 to 2.6.32 - Dalingrin,Fattire,Verygreen
Encore: New GPU drivers and userspace libs
Encore: Adjustable clockspeed and voltage - Dalingrin
Encore: Backport 2.6.35 Bluetooth - Fattire
Encore: Working mem sleep
Encore: USB host support - Verygreen
Bias schrieb:
hab ich schon seid gestern drauf handy-faq.de
ist da immer platz 1 ;)
Ja ich weiss, gibts schon seit 2 Tagen...aber ich habe öfter nur direkt auf der CM-Seite geguckt und wollte halt nur andere hier informieren...falls sie es auch noch nicht mitbekommen haben ;)
ist ja auch nett
aber hier im forum haben se sich immer son bissel doof =)
MIuI ist auch schon da in Deutsch =) für das optimus speed weiß ja nicht was du hast (handy)
Meint ihr CM kommt auch noch mal fürs Defy+ raus? Das steht da ja nun nich in der Liste drin, sondern nur das Defy.
Wäre nett wenn Du nach deinem Test etwas dazu Berichten könntest.......habe auch das Optimus Speed und kein Bock mehr auf das lang ersehnte LG-Update 2.3.4 Gingerbraed zu warten
also ich habs ja auch drauf und du kannst dir die raufen machen akku hält länger und läuft alles super
geh auf handy-faq.de
und da findest alles ;)
;)OK...Danke werd mich dann mal rantasten....
ich hatte gestern abend auch noch CM drauf.
Allerdings wollte er meine interne SD-Karte einfach nicht ansprechen.
Heute bin ich wieder auf Stock und sie läuft ohne Probleme.
Hatte als Kernel Hardcore Speedmod.
Weiß jemand da was?
@ AngryAngel
beim Galaxy S i9000 musst du von nem Froyo Rom auf CM7 updaten!
Wenn du von Gingerbread kommst hast du dein beschriebenes Problem!
Einfach Froyo installen, damit der Bootloader stimmt! Dann CM7 und alles passt :-)
gruß
Alex
Funktioniert die Bluetooth-Mouse mittlerweile einwandfrei? Ich habe das SGS2.
Ich möchte den Screen des SGS2 gerne per Klick wieder einschalten. Ist das möglich?
Für das Galaxy S ist Cyanogen die Befreiung, die ich mir immer gewünscht habe. Alle Lagfixes und Tweaks für Samsung ROMs liefern nicht mal einen schwacher Abklatsch von der Performance, die ich jetzt habe. BTW: ich hatte vorher (custom) Gingerbread drauf - man muss nicht über Froyo gehen.
Es fühlt sich fast so an als hätte ich ein neues Gerät! Danke, Cyanogen-Team! :]
Das einzige, was ich vermisse, ist der Video Player.
Im Changelog steht "Common: Bluetooth mouse support - Scott Brady"
Kann soetwas leider nicht testen, sry.
@doom666:
kalter Kaffee
CM7 läuft auf dem SGS auch mit Gingerbread bootloadern, sonst gibt es einen stündlichen Akkudrain von 1-3% - mit GB bootloadern reduziert sich das ganze auf 1% auf alle 8h
@AngryAngel:
einfach 7.1.0 oder eines der nightlies um 140 herum nehmen:
http://cm-nightlies.appspot.com/?device=galaxysmtd
dann sollte es keine Probleme geben
@PlanetJumble
Ich hatte Vorher Goa und habe dann die JVT installiert.
Aber ich lese gerade:
This guide assumes the Samsung Galaxy S already has Android 2.2 installed on it.
Denke ich probiere es nochmal mit der 2.2
Allerdings hätte ich ja schon gerne die 2.3.5 gehabt :(
@freak01
thx, ich gucke mir das mal an
Ähm... Cyanogen ist 2.3.7! :)
Du musst wirklich nicht vorher downgraden - ich habe auch direkt von Goatrip mit Speedmod-Kernel aus geflasht. Aber es empfiehlt sich wirklich - wenn man die Installationsdatei auf der internen Speicher"karte" hat, ein Format System unter Mounts & Storage durchzuführen - bei mir gab es beim ersten mal (trotz Factory Reset) einen Bootloop, den ich aber einfach mit zweiter Installation (inklusive Format System) beheben konnte.
Ja keine Ahnung, scheinbar ist mir das zu kompliziert.
Habe gestern nochmal die JVT drauf gemacht, dann Werkseinstellung, danach den Darkcore Kernel (wie bei Goa) und anschließend auf die interne SD Karte die Cyanogen Datei:
http://download.cyanogenmod.com/?type=stable&device=galaxysmtd
Danach noch doppel wipe und dann die zip ausgewählt.
Funzt auch alles perfekt. Nur kein Zugriff auf die externe SD Karte.
Bzw, Zugriff mehr oder weniger schon. Kann die sogar Formartieren.
Aber ich bekomme keinen Zugriff auf die Dateien.
Ich formatiere die übers Handy.
Schliesse es an den PC an. Kopiere Daten drauf.
Aber im Dateiverzeichnis zeigt er einfach nichts an.
