Physikbuddha
- Aug. 2014
Geht mit 7-Zip 15.14 einwandfrei.
Skytunnel schrieb:The problem I’ve encountered is that if the currently active cell is within the List Object, then setting the Calculation Mode to manual seems to have no effect whatsoever.
Charles Williams schrieb:To get the slowdown you seem to need 3 conditions: 1. the active cell must be within the Listobject (Table). 2. The cell(s) being updated must be on the same worksheet as the Listobject. 3. The time taken is a function of the number of formulas (but the formulas are not being recalculated).
Sub test()
Application.ScreenUpdating = False
Application.Calculation = xlCalculationManual
For Each c In Worksheets("Data").Range("C30:JZ32").Cells
If c.HasFormula Then _
If IsNumeric(c.Text) Then _
c.Value = c.Value
Next
Application.Calculation = xlCalculationAutomatic
Application.ScreenUpdating = True
End Sub
Nun umfasst der eigentliche Bereich aber etwa 80000 Zellen.
