Frage zu SMART-Werten einer hdd
klesi
Cadet 1st Year
Nov. 2012
hallo,
ich hab mal eine frage zu den SMART-Werten einer meiner festplatten. GSmart zeigt bei einigen "pre-failure" und 2 sind hellrot markiert (reallocated sector count und Spin-up retry count). Unterm strich scheint aber alles gut zu sein. sie läuft atm auch fehlerfrei.
hier mal der log-file
HTML:
smartctl 5.41 2011-06-09 r3365 [i686-linux-3.0.0-pmagic] (local build)
Copyright (C) 2002-11 by Bruce Allen, [url]http://smartmontools.sourceforge.net[/url]
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Barracuda 7200.11
Device Model:     ST31000333AS
Serial Number:    6TE02GY7
LU WWN Device Id: 5 000c50 00e31663f
Firmware Version: SD35
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Sat Nov 17 10:06:24 2012 UTC
==> WARNING: There are known problems with these drives,
see the following Seagate web pages:
[url]http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=207931[/url]
[url]http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=207951[/url]
[url]http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=207957[/url]
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
					Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(  617) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 ( 208) minutes.
Conveyance self-test routine
recommended polling time: 	 (   2) minutes.
SCT capabilities: 	       (0x103b)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   114   099   006    Pre-fail  Always       -       72783224
  3 Spin_Up_Time            0x0003   093   091   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   096   096   020    Old_age   Always       -       4914
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       13
  7 Seek_Error_Rate         0x000f   073   061   030    Pre-fail  Always       -       22741220
  9 Power_On_Hours          0x0032   093   093   000    Old_age   Always       -       6993
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       42
 12 Power_Cycle_Count       0x0032   099   099   020    Old_age   Always       -       1582
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   095   000    Old_age   Always       -       73015689251
189 High_Fly_Writes         0x003a   071   071   000    Old_age   Always       -       29
190 Airflow_Temperature_Cel 0x0022   063   031   045    Old_age   Always   In_the_past 37 (8 227 40 36)
194 Temperature_Celsius     0x0022   037   069   000    Old_age   Always       -       37 (0 12 0 0)
195 Hardware_ECC_Recovered  0x001a   039   029   000    Old_age   Always       -       72783224
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
meine frage ist nun, ob ich das ignorieren kann oder ob es besser währe die möglichst zeitnah auszutauschen bevor sie probleme macht.
MfG
hat sich erledigt...war etwas voreilig und hab den sammelthread übersehen.
kann also /closed oder gelöscht werden.
Mal kurz zu SMART Werten:
Perfekte SMART Werte heißen nur, dass keine Fehler festgestellt wurden. Ein Totalausfall ist trotzdem jederzeit möglich.
SMART Werte die Fehler anzeigen heißen, dass es irgend einen Grund gibt, wieso Fehler aufgetreten sind die von der HDD bemerkt und korrigiert bzw. teilweise korrigiert wurden-
Spinupretry heißt, dass die HDD aus welchen Gründen auch immer den normalen Startzyklus unterbrechen musste. Sei es weil der Rechner abgeschmiert ist, Strom weg war etc. Kann ein sich ankündigender Motorschaden oder Ähnliches sein oder ein von Außen provozierter Fehler. Wächst dieser Wert sollte die HDD möglichst bald komplett gesichert werden. Es empfiehlt sich solang die HDD noch in Betrieb ist unnötigt Starts zu vermeiden. Kurzum "HDD geht nach X Minuten schlafen" sollte deaktiviert und unnötige Neustarts vermieden werden.
Relocated Sector Count bedeutet, dass du defekte Sektoren hattest für die Reservesektoren aktiviert werden mussten. Das kann vorkommen, wenn mal ein Schlag durch den Rechner geht oder ab Werk doch mal 1-2 Sektoren hinüber sind (unschön, kommt aber vor bei zig Milliarden winzigen Magnetfeldern). Wächst dieser Wert NICHT ist es relativ* sicher. Wächst dieser Wert, wenn auch langsam bedeutet das schleichender Datenverlust. Platte schnellst möglich aussortieren. Kurz Rechner herunterfahren, HDD abklemmen und mit schnell besorgter Ersatz HDD die Daten sichern. Am Besten die alte HDD nur lesend einbinden.
*Vorsichtige Naturen würden sagen, relativ ist ein derart weiches Fundament für solche Aussagen, dass sie darauf nicht bauen würden...
