[Bitte fülle den folgenden Fragebogen unbedingt vollständig aus, damit andere Nutzer dir effizient helfen können. Danke!
Ich habe mir vor Kurzem einen neuen Pc zusammengebaut. Installiert ist Windows 10 Home. Gestern wollte ich mit einem Freund Gta V Online spielen. Zunächst hat alles geklappt, doch nach ca. 5 Minuten hat sich das Spiel beendet. Das Problem hatte ich dann noch zweimal. Heute hab ich es nochmal versucht und es ist wieder passiert.
Das sind die Fehlerprotokolle vom Epic Games Launcher:
Gestern 1:
[0916/000330.635:ERROR:gpu_init.cc(426)] Passthrough is not supported, GL is disabled
[0916/004336.828:ERROR:angle_platform_impl.cc(43)] Renderer11.cpp:2135 (testDeviceLost): The D3D11 device was removed, HRESULT: 0x887A0005
[0916/004336.828:ERROR:shared_context_state.cc(826)] SharedContextState context lost via ARB/EXT_robustness. Reset status = GL_UNKNOWN_CONTEXT_RESET_KHR
[0916/004336.828:ERROR:gpu_service_impl.cc(1187)] Exiting GPU process because some drivers can't recover from errors. GPU process will restart shortly.
[0916/004336.832:WARNING:gpu_process_host.cc(1296)] The GPU process has crashed 1 time(s)
[0916/004337.221:ERROR:viz_main_impl.cc(150)] Exiting GPU process due to errors during initialization
[0916/004339.240:ERROR:viz_main_impl.cc(150)] Exiting GPU process due to errors during initialization
[0916/004347.275:WARNING:spdy_session.cc(3431)] Received HEADERS for invalid stream 45
[0916/004540.590:ERROR:gpu_init.cc(426)] Passthrough is not supported, GL is disabled
[0916/013522.706:WARNING:spdy_session.cc(3431)] Received HEADERS for invalid stream 3
[0916/013720.399:ERROR:gpu_init.cc(426)] Passthrough is not supported, GL is disabled
[0916/015526.088:WARNING:gpu_process_host.cc(1296)] The GPU process has crashed 1 time(s)
[0916/015526.108:ERROR:network_service_instance_impl.cc(330)] Network service crashed, restarting service.
Gestern 2:
[0916/024939.609:ERROR:gpu_init.cc(426)] Passthrough is not supported, GL is disabled
Gestern 3:
[0916/025401.214:ERROR:backend_impl.cc(1041)] Critical error found -8
[0916/025401.215:ERROR:entry_impl.cc(1075)] No file for b30200e0
[0916/025401.215:WARNING:storage_block-inl.h(146)] Failed data load.
[0916/025401.225:WARNING:storage_block-inl.h(146)] Failed data load.
[0916/025555.745:ERROR:gpu_init.cc(426)] Passthrough is not supported, GL is disabled
[0916/030108.680:ERROR:network_service_instance_impl.cc(330)] Network service crashed, restarting service.
[0916/030108.703:WARNING:gpu_process_host.cc(1296)] The GPU process has crashed 1 time(s)
[0916/030108.726:ERROR:network_service_instance_impl.cc(330)] Network service crashed, restarting service.
[0916/030108.739:WARNING:gpu_process_host.cc(1296)] The GPU process has crashed 2 time(s)
[0916/030108.774:ERROR:network_service_instance_impl.cc(330)] Network service crashed, restarting service.
[0916/030108.785:WARNING:gpu_process_host.cc(1296)] The GPU process has crashed 3 time(s)
[0916/030108.822:ERROR:network_service_instance_impl.cc(330)] Network service crashed, restarting service.
Heute:
[0917/011108.940:ERROR:gpu_init.cc(426)] Passthrough is not supported, GL is disabled
Windows Dateien überprüft und Fehler behoben (mittels cmd) hat nichts gebracht
P.S.: Beachte auch die verschiedenen angepinnten Themen und die Forensuche. Möglicherweise findest du da bereits die Lösung zu deinem Problem.
Wie kann ich diese Fehler beheben und was ist eigentlich los?
Danke im Voraus
![Lächeln :) :)](/forum/styles/smilies/smile.gif)
- Prozessor (CPU): Intel Core i7-13700K
- Arbeitsspeicher (RAM): GSKILL Trident Z5 DDR5 32Gb
- Mainboard: Z790 AORUS ELITE AX
- Netzteil: beQuiet! Pure Power 12 850 W
- Gehäuse: Nzxt H7 Flow
- Grafikkarte: Nvidia RTX 4070 Gaming Oc
- HDD / SSD: Samsung M2 Pro 2TB
- Weitere Hardware, die offensichtlich mit dem Problem zu tun hat(Monitormodell, Kühlung usw.): nein
- Wird ein sog. "PCIe Riserkabel" genutzt? nein
Gestern 1:
Gestern 2:
Gestern 3:
Heute:
Danke im Voraus
