Installationsproblem mit openlogos
Hannibal77
Apr. 2004
ich bin dabei mir OpenLogos zu installieren. bin bis zu make gekommen, aber seht selbst.
tar xvvzf /home/srk/openlogos-1.0.1.tar.gz
cd /home/srk/openlogos-1.0.1
srk@linux:~/openlogos-1.0.1> ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking build system type... i686-suse-linux
checking host system type... i686-suse-linux
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/i586-suse-linux/bin/ld
checking if the linker (/usr/i586-suse-linux/bin/ld) is GNU ld... yes
checking for /usr/i586-suse-linux/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking how to run the C++ preprocessor... /lib/cpp
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... gfortran
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether gfortran accepts -g... yes
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking whether the g++ linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
libtool.m4: error: problem compiling CXX test program
checking for g++ option to produce PIC...
checking if g++ supports -c -o file.o... no
checking how to hardcode library paths into programs... unsupported
appending configuration tag "F77" to libtool
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran supports -c -o file.o... yes
checking whether the gfortran linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking whether we are using the GNU C++ compiler... (cached) no
checking whether g++ accepts -g... (cached) no
checking dependency style of g++... (cached) none
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ANSI C... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking whether make sets $(MAKE)... (cached) yes
configure: javainclude FOR i686-suse-linux is -I/lt/pkg/jdk1.5.0_02/include -I/lt/pkg/jdk1.5.0_02/include/linux
checking for jni.h... no
configure: error: No java dir
srk@linux:~/openlogos-1.0.1> make
make: *** Keine Targets angegeben und keine »make«-Steuerdatei gefunden. Schluss.
dort wo überall no steht heißt das, dass Pakete fehlen und diese nachinstalliert werden müssen?
Wichtig ist nur was in den letzen paar Zeilen steht.
Weil dort steht der Fehler, der zum Abbruch des configure-Skripts führte.
Und da steht:
Also irgendwas wegen Java!
Brauchst du vielleicht das Java SDK? -> nachinstallieren
Hast du es bereits, aber sind evtl. Umgebungsvariablen nicht richtig gesetzt? -> Umgebungsvariablen setzen; steht in einer Datei welche wie gesetzt werden müssen
also java sdk is installiert wo und wie und woher was ich wie ich die umgebungsvariablen setzen muss
in der readme steht noch das man gcc/g++ 3.2.2 or better, including gcc/g++ 4 benötigt leider hab ich das im i-net nicht gefunden dann müssten ja auch die meldungen mit no verschwinden
wenn das sdk wirklich drin is("java-1.x.x-sun" und "java-1.x.x-sun-devel") probier mal folgendes:
export JAVA_HOME="/usr/lib/jvm/java/include/linux"
./configure
habe dieses fehlende paket gefunden leider trat bei der installation wieder ein fehler auf
srk@linux:~> cd /home/srk/gcc-3.4.1/
srk@linux:~/gcc-3.4.1> ./configure
bash: ./configure: Datei oder Verzeichnis nicht gefunden
die java pakete kann man bequem per yast installieren, da brauch man nix compilieren.
und das oben genannte sollteste dann im openlogos verzeichnis ausführen..
also die java pakete sind schon installiert
und wie soll ich das ins openlogos verzeicniss ausfürhren
das heißt ja dann openlogos installieren dann das paket installieren
./configure
falls er dann immernoch über java meckert mal folgendes probieren:
./configure prefix=/usr/lib/jvm/java/include/linux
