Naru
- Juli 2010
Von der Lautheit her ist es kontraproduktiv, die auffälligeren Lüfter an die Front zu montieren, sozusagen unmittelbar zur Hörquelle.
Ich habe die Konfiguration:
Case: | be quiet! Dark Base Pro 900 w/ be quiet! PSU Shroud for Dark Base Pro 900 |
CPU Cooler: | be quiet! Dark Rock TF w/ 2x be quiet! Silent Wings 3 135mm MID-SPEED PWM [BQ SIW3 13525-MF PWM] connected per be quiet! Y-Adapter for be quiet! Dark Rock TF connected on ASUS ROG Maximus VIII Hero Alpha |
Fans Controller: | be quiet! PWM Hub for be quiet! Dark Base Pro 900 w/ STMicroelectronics STM8S003F3P6 connected on ASUS ROG Maximus VIII Hero Alpha w/ Nuvoton NCT6793D/NCT5563D w/ Wuxi U-NIKC NIKOS PA102FDG w/ Diodes AS358M |
Fans on Front: | 3x be quiet! Silent Wings 3 140mm HIGH-SPEED PWM [BQ SIW3 14025-HF PWM] connected per Noctua NA-SYC1 Y-Cables & Noctua NA-SRC7 Low-Noise Adaptors connected on ASUS ROG Maximus VIII Hero Alpha |
Fans on Heck: | 1x be quiet! Silent Wings 3 140mm HIGH-SPEED PWM [BQ SIW3 14025-HF PWM] connected per Noctua NA-SYC1 Y-Cables & Noctua NA-SRC7 Low-Noise Adaptors connected on ASUS ROG Maximus VIII Hero Alpha |
Fans on Side: | 2x be quiet! Silent Wings 3 120mm LOW-SPEED PWM [BQ SIW3 12025-LF PWM] connected per Noctua NA-SYC1 Y-Cables connected on be quiet! PWM Hub for be quiet! Dark Base Pro 900 |
Fans on Top: | 3x be quiet! Silent Wings 3 140mm LOW-SPEED PWM [BQ SIW3 14025-LF PWM] connected per Noctua Noctua NA-SYC1 Y-Cables connected on be quiet! PWM Hub for be quiet! Dark Base Pro 900 |
Fans on Bottom: | 2x be quiet! Silent Wings 3 140mm HIGH-SPEED PWM [BQ SIW3 14025-HF PWM] connected per Noctua NA-SYC1 Y-Cables & Noctua NA-SRC7 Low-Noise Adaptors connected on ASUS ROG Maximus VIII Hero Alpha 2x be quiet! Silent Wings 3 120mm LOW-SPEED PWM [BQ SIW3 12025-LF PWM] mounted on be quiet! PSU Shroud for Dark Base Pro 900 connected per Noctua NA-SYC1 Y-Cables connected on be quiet! PWM Hub for be quiet! Dark Base Pro 900 |
