phpbbhomer
- Sep. 2005
Hallo Leute,
brauche ein gutes Mainboard, wo ich sowohl S-ATA als auch P-ATA Platten anhängen an. Habe momentan nur P-ATA Platten, aber habe vor eine gute 500gb S-ATA Festplatte zuzulegen.
Poste hier die Daten zu meinem PC. Danke schon mal im Voraus!
lg Homy
Code:
CPU-Z version 1.39
Processors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1
Number of threads 1 (max 1)
Name Intel Pentium 4
Codename Northwood
Specification Intel(R) Pentium(R) 4 CPU 2.66GHz
Package Socket 478 mPGA (platform ID = 2h)
CPUID F.2.7
Extended CPUID F.2
Brand ID 9
Core Stepping C1
Technology 0.13 um
Core Speed 2672.6 MHz (20.0 x 133.6 MHz)
Rated Bus speed 534.5 MHz
Stock frequency 2666 MHz
Instructions sets MMX, SSE, SSE2
L1 Data cache 8 KBytes, 4-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 512 KBytes, 8-way set associative, 64-byte line size
FID/VID Control no
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001001h
Max CPUID level 00000002h
Max CPUID ext. level 80000004h
Function eax ebx ecx edx
0x00000000 0x00000002 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F27 0x00010809 0x00004400 0xBFEBFBFF
0x00000002 0x665B5101 0x00000000 0x00000000 0x007B7040
0x80000000 0x80000004 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
0x80000002 0x20202020 0x20202020 0x20202020 0x6E492020
0x80000003 0x286C6574 0x50202952 0x69746E65 0x52286D75
0x80000004 0x20342029 0x20555043 0x36362E32 0x007A4847
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x00000017 edx = 0x000A0000 eax = 0x00000000
MSR 0x0000002C edx = 0x00000000 eax = 0x14110014
MSR 0x000001A0 edx = 0x00000000 eax = 0x00000081
Chipset
Northbridge SiS 648 rev. 02
Southbridge SiS LPC Bridge rev. 04
Memory Type DDR
Memory Size 1024 MBytes
Memory Frequency 167.0 MHz (4:5)
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 7
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) SpecTek Incorporated (7F7FB5FFFFFFFFFF)
Size 1024 MBytes
Max bandwidth PC2700 (166 MHz)
Part number
Serial number 14022F1F
Manufacturing date Week 29/Year 03
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
Frequency (MHz) 133 166
CAS# 2.0 2.5
RAS# to CAS# delay 3 3
RAS# Precharge 3 3
TRAS 6 7
Monitoring
Sensor Chip Winbond W83697HF
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x0648
Revision ID 0x02
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x20
Header 0x80
PCI header
Address 0 (memory) 0xD0000000
Subvendor ID 0x1039
Subsystem ID 0x0648
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Offset C0h
Version 3.0
Status disabled
Max transfer 8x
Queue lenght 3 (max 32)
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x0001
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI to ISA Bridge
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x0008
Revision ID 0x04
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
OHCI FireWire Controller
bus 0 (0x00), device 2 (0x02), function 3 (0x03)
Common header
Vendor ID 0x1039
Model ID 0x7007
Revision ID 0x00
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xE2426000
Subvendor ID 0x1462
Subsystem ID 0x701D
Int. Line 0x11
Int. Pin 0x02
Capabilities
Power Management Capability
Offset 64h
Version 1.1
IDE Controller
bus 0 (0x00), device 2 (0x02), function 5 (0x05)
Common header
Vendor ID 0x1039
Model ID 0x5513
Revision ID 0x00
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x80
Header 0x00
PCI header
Address 0 (port) 0x000001F0
Address 1 (port) 0x000003F4
Address 2 (port) 0x00000170
Address 3 (port) 0x00000374
Address 4 (port) 0x00004000
Subvendor ID 0x1462
Subsystem ID 0x7010
Int. Line 0x0B
Int. Pin 0x01
Capabilities
Offset 58h
Version 1.1
Audio device
bus 0 (0x00), device 2 (0x02), function 7 (0x07)
Common header
Vendor ID 0x1039
Model ID 0x7012
Revision ID 0xA0
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000E400
Address 1 (port) 0x0000E800
Subvendor ID 0x1462
Subsystem ID 0x7010
Int. Line 0x12
Int. Pin 0x03
Capabilities
Offset 48h
Version 1.1
USB Controller (OHCI)
bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x7001
Revision ID 0x0F
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x80
PCI header
Address 0 (memory) 0xE2420000
Subvendor ID 0x1462
Subsystem ID 0x7010
Int. Line 0x14
Int. Pin 0x01
bus 0 (0x00), device 3 (0x03), function 1 (0x01)
Common header
Vendor ID 0x1039
Model ID 0x7001
Revision ID 0x0F
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xE2421000
Subvendor ID 0x1462
Subsystem ID 0x7010
Int. Line 0x15
Int. Pin 0x02
bus 0 (0x00), device 3 (0x03), function 2 (0x02)
Common header
Vendor ID 0x1039
Model ID 0x7001
Revision ID 0x0F
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xE2422000
Subvendor ID 0x1462
Subsystem ID 0x7010
Int. Line 0x16
Int. Pin 0x03
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 3 (0x03), function 3 (0x03)
Common header
Vendor ID 0x1039
Model ID 0x7002
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xE2423000
Subvendor ID 0x1462
Subsystem ID 0x7010
Int. Line 0x17
Int. Pin 0x04
Capabilities
Offset 50h
Version 1.1
Ethernet Controller
bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x0900
Revision ID 0x91
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000EC00
Address 1 (memory) 0xE2424000
Subvendor ID 0x1462
Subsystem ID 0x0900
Int. Line 0x13
Int. Pin 0x01
Capabilities
Offset 40h
Version 1.1
Multimedia device
bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x1131
Model ID 0x7134
Revision ID 0x01
PI 0x00
SubClass 0x80
BaseClass 0x04
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xE2425000
Subvendor ID 0x16BE
Subsystem ID 0x0003
Int. Line 0x0C
Int. Pin 0x01
Capabilities
Offset 40h
Version 1.0
Communication Device
bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1040
Revision ID 0x00
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xE2000000
Subvendor ID 0x16BE
Subsystem ID 0x1040
Int. Line 0x03
Int. Pin 0x01
Capabilities
Offset E0h
Version 1.1
VGA Controller
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0281
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0xF8
Header 0x00
PCI header
Address 0 (memory) 0xE0000000
Address 1 (memory) 0xD8000000
Subvendor ID 0x1462
Subsystem ID 0x8890
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 60h
Version 1.1
AGP Capability
Offset 44h
Version 3.0
Status disabled
Max transfer 8x
Queue lenght 1 (max 32)
SMBus Controller
bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x1039
Model ID 0x0016
Revision ID 0x00
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x000010C0
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x02
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version 6.00 PG
date 09/11/2002
DMI System Information
manufacturer MEDIONPC
product unknown
version unknown
serial unknown
UUID 88028D25-321EB211-80006445-6E4E6973
DMI Baseboard
vendor MICRO-STAR INTERNATIONAL CO., LTD
model MS-6701
revision unknown
serial unknown
DMI System Enclosure
manufacturer unknown
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel Pentium(R) 4
clock speed 2666.0MHz
FSB speed 133.0MHz
multiplier 20.0x
DMI Memory Controller
correction unknown
Max module size 1024MBytes
DMI Memory Module
designation A0
size 1024MBytes (double bank)
DMI Memory Module
designation A1
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (external)
port type USB
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation AGP
type AGP
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 2048MBytes
max# of devices 2
DMI Memory Device
designation A0
format DIMM
type SDRAM
total width 64bits
data width 64bits
size 1024MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
lg Homy
