Max Payne 1 & 2 wieder zum laufen bringen
  • Ersteller Ersteller Tyler654
  • Erstellt am Erstellt am
T
Tyler654
Vielleicht kennt der ein oder andere das Problem, das Max Payne 1 & 2 (Steamversion) zwar starten, sich aber ums verrecken nichts tut. In Steam wird zwar angezeigt, dass das Spiel läuft, was man auch im Taskmanager nachlesen kann, aber das bringt ja herzlich wenig. Das Problem tritt meines Erachtens am häufigsten mit Grafikkarten aus dem Hause AMD auf. Eine wirksame Lösung stellt der User Kusaros im Steamforum bereit.
I've got the same issue and Radeon 7850 & Catalyst 12.8, when I run MP2 nothing happens - though it's listed in processess.
If you've got AMD GPU you can try this solution:
Place older version of following files into [steam directory]\Steamapps\common\Max Payne 2 The Fall Of Max Payne"
atidxx32.dll
atidxx64.dll
atiumd64.dll
atiumdag.dll
These files handles Direct3D API. I've tried those from Catalyst 12.6 and it works.
1) If you installed older AMD drivers there should be some sort of temporary directory, usually it's located on system drive. It's typically C:\AMD\Support
-If you haven't installed older version of catalyst then you might want to download it somewhere and run installer to unpack files, then just cancel the process. And it must support your GPU - ie. catalyst 12.6 for HD7000 series.
-locate this directory:
C:\AMD\Support\12-6_vista_win7_64_dd_ccc_whql\Packages\Drivers\Display\W76A_INF\B140419
-there might be slight variations in names of few folders, but the last directory is always B###### and contains a lot of *.dl_ files.
2)*.dl_ files are compressed so you need to use "expand" command to unpack files(simply renaming them won't work). Create new text file inside B###### directory and copy & paste following lines:
expand atidxx32.dl_ atidxx32.dll
expand atidxx64.dl_ atidxx64.dll
expand atiumd64.dl_ atiumd64.dll
expand atiumdag.dl_ atiumdag.dll
-save it, rename text file extension to ".bat" and run it. This should unpack dl_ files.
3) Copy aforementioned dll files to max payne 2 directory:
Now it should work.
Compatibility mode is not necessary.
Something similar should work for nVidia users.
Ich habe die Anleitung befolgt - und es klappt wunderbar. Ich habe mit den DLLs sogar 3DMark 2001 SE wieder zum laufen bekommen(einfach in den Ordner ziehen). Wenn man ganz faul ist, kann man auch einfach den Catalyst 12.6 installieren, wenn man jedoch auf die Leistungssteigerungen / Bugfixes der neuen Versionen nicht verzichten möchte, ist es ideal.
Die Anleitung wurde bereits erwähnt, ich hoffe aber das es Personen mit dem selben Problem es so noch einfacher haben (habe die DLLs hochgeladen)
Grüße
Tyler
Es funktioniert. Danke.
Ich hatte es seinerzeit in dem anderen Thread auch so versucht. Ohne Erfolg. Heute klappt es. Vielleicht durch den Trick, den ich aus nicht verständlichen Gründen auch bei anderen alten Spielen anwenden muss, einmal das Spiel gestartet, es hängt im Taskmanager fest. Dann den Task im Manager beenden und ein zweites mal das betreffende Spiel starten. Dann geht es. Bei NOLF 1 zB muss ich das machen. Und jetzt eben auch bei MP 1+2.
Aber es läuft wieder :)
Ich habs mit dem Catalyst 13.11 Beta 8 und Windows 8.1 x64 jetzt endlich zum laufen gebracht.
Ich musste allerdings die CPU Nutzung auf 1 CPU festlegen sonst startet es nicht. http://steamcommunity.com/app/12140/discussions/0/864976115440393806/
Max Payne 1 startet dann ohne Kompatibilitätsmodus.
Max Payne 2 musste ich Win 98/ME einstellen und noch dazu die Leerzeichen aus dem Ordnernamen entfernen sonst kam der Fehler dass es den Data Ordner nicht findet.
Die Spiele muss man dann halt über die Exe Datei selbst starten in Steam direkt funktioniert es nicht.
