Andere Minecraft Forge ,,Better Minecraft 1.19´´ startet nicht
TI_Gaming_TV
Jan. 2021
Ich habe keine Ahnung woran es liegt. Ich habe schon Configfiles gelöscht. Weiter als den Launcher komme ich nicht.
Crash Report bekomme ich nicht.
Hier sind die Logs:
[12:00:47] [main/INFO]: Loading Minecraft 1.19 with Fabric Loader 0.14.9
[12:00:47] [ForkJoinPool-1-worker-10/WARN]: Mod bcc uses the version fabric-2.0.1-build.15 which isn't compatible with Loader's extended semantic version format (Could not parse version number component 'fabric'!), SemVer is recommended for reliably evaluating dependencies and prioritizing newer version
[12:00:47] [ForkJoinPool-1-worker-8/WARN]: The mod "dungeons_arise" contains invalid entries in its mod json:
- Unsupported root entry "credits" at line 12 column 12
[12:00:48] [ForkJoinPool-1-worker-22/WARN]: Mod immersive_weathering uses the version 1.0.1-1.19_SNAPSHOT which isn't compatible with Loader's extended semantic version format (Invalid prerelease string '1.19_SNAPSHOT'!), SemVer is recommended for reliably evaluating dependencies and prioritizing newer version
[12:00:48] [ForkJoinPool-1-worker-22/WARN]: The mod "thonkutil-customization-v1" contains invalid entries in its mod json:
- Unsupported root entry "disabled:mixins" at line 11 column 20
[12:00:48] [main/WARN]: Warnings were found!
- Mod 'Custom Entity Models' (cem) 0.7.1 recommends any version of completeconfig, which is missing!
- You should install any version of completeconfig for the optimal experience.
- Mod 'Colormatic' (colormatic) 3.1.2+mc.1.19 recommends any version of quilt_loader, which is missing!
- You should install any version of quilt_loader for the optimal experience.
- Mod 'Colormatic' (colormatic) 3.1.2+mc.1.19 recommends any version between 3.0.0 (inclusive) and 4- (exclusive) of mod 'Mod Menu' (modmenu), but only the wrong version is present: 4.0.4!
- You should install any version between 3.0.0 (inclusive) and 4- (exclusive) of mod 'Mod Menu' (modmenu) for the optimal experience.
- Mod 'Debugify' (debugify) 2.3.2 conflicts with any version of mod 'ToolTip Fix' (tooltipfix), which is present with the following versions: 1.0.5-1.19!
- While this won't prevent you from starting the game, the developer(s) of mod 'Debugify' (debugify) have found that this combination may cause issues. You should remove one of the mods or check for updates that resolve the issue.
[12:00:48] [main/INFO]: Loading 340 mods:
- additionaladditions 5.0.0
- additionalstructures 4.0.0
- adorn 3.6.1+1.19
- advanced_runtime_resource_pack 0.5.5 via carrier
- advdebug 2.3.0
- adventurez 1.4.14
- ae2 12.0.2-alpha
- animatica 0.5+1.19
- another_furniture 2.0.1-1.19
- architects_palette 2.1.1
- architectury 5.10.33
- attributefix 15.1.3
- autoconfig1u 3.4.0
- auudio 1.0.3
- axolotlitemfix 1.1.3
- badpackets 0.1.2
- bcc fabric-2.0.1-build.15
- bclib 2.0.19
- betteradvancements 0.2.2.136
- betterend 2.0.11
- betterf3 1.3.2
- betternether 7.0.8
- betterthirdperson 1.8.1
- bhmenu 1.19-1.3
- biomemakeover 1.19-1.5.9
- blockus 2.5.1+1.19
- blur 2.6.0
- bookshelf 14.2.10
- bosses_of_mass_destruction 1.4.1-1.19
- byg 2.0.0.7
- caffeineconfig 1.0.0+1.17 via sodium-extra
- capybara 1.0.5
- cardinal-components 5.0.1
- cardinal-components-base 5.0.1 via cardinal-components
- cardinal-components-block 5.0.1 via cardinal-components
- cardinal-components-chunk 5.0.1 via cardinal-components
- cardinal-components-entity 5.0.1 via cardinal-components
- cardinal-components-item 5.0.1 via cardinal-components
- cardinal-components-level 5.0.1 via cardinal-components
- cardinal-components-scoreboard 5.0.1 via cardinal-components
- cardinal-components-world 5.0.1 via cardinal-components
- carrier 1.11.0
- cem 0.7.1
- charm 4.1.2
- charmofundying 6.0.0-beta.3+1.19.1
- charmonium 4.1.0
- cherishedworlds 6.0.0-beta.2+1.19
- citresewn 1.1.1+1.19
- citresewn-defaults 1.1.1+1.19 via citresewn
- cleancut 1.19-5.0-fabric
- cloth-api 4.0.65
- cloth-basic-math 0.6.1 via cloth-api
- cloth-client-events-v0 4.0.65 via cloth-api
- cloth-common-events-v1 4.0.65 via cloth-api
- cloth-config 7.0.73 via ecologics
- cloth-scissors-api-v1 4.0.65 via cloth-api
- cloth-utils-v1 4.0.65 via cloth-api
- clumps 9.0.0+7
- coat 1.0.0-beta.18+mc22w17a via wandering_collector
- collective-fabric 4.27
- colormatic 3.1.2+mc.1.19
- com_electronwill_night-config_core 3.6.5 via forgeconfigapiport
- com_electronwill_night-config_toml 3.6.5 via forgeconfigapiport
- com_eliotlash_mclib_mclib 18 via geckolib3
- com_eliotlash_molang_molang 18 via geckolib3
- com_github_llamalad7_mixinextras 0.0.11 via cull-less-leaves
- com_github_luben_zstd-jni 1.5.2-2 via dashloader
- com_logisticscraft_occlusionculling 0.0.6-SNAPSHOT via entityculling
- com_moandjiezana_toml_toml4j 0.7.2 via charm
- com_velocitypowered_velocity-native 3.1.2-SNAPSHOT via krypton
- comforts 6.0.0+1.19.1
- completeconfig-base 2.0.0-beta.3 via cem
- completeconfig-gui-cloth 2.0.0-beta.3 via cem
- conditional-mixin 0.3.0 via cull-less-leaves
- continuity 2.0.0+1.19
- controlling 10.0+3
- crawl 0.11.0
- cull-less-leaves 1.0.4
- darkpaintings 11.1.3
- dashloader 4.0.0+1.19
- dawn 3.5.0
- debugify 2.3.2
- deepslatecutting 1.4.0
- dev_isxander_settxi_settxi-core 2.4.0 via zoomify
- dev_isxander_settxi_settxi-kotlinx-serialization 2.4.0 via zoomify
- dev_quantumfusion_hyphen 0.2.2 via dashloader
- dev_quantumfusion_taski 1.1.0 via dashloader
- dragonloot 1.1.1
- drippyloadingscreen 1.6.4
- duckling 2.0.4
- dungeons_arise 2.1.51
- dustrial_decor 0.5
- dynamicfps 2.2.0
- dynamicsoundfilters 1.3.0+1.19
- earthtojavamobs 1.9.2
- easymagic 4.0.0
- ecologics 2.1.6
- edenring 0.6.3
- effective 1.2.2
- elytraslot 6.0.0+1.19.1
- enchdesc 11.1.9
- enhancedcelestials 2.1.0.0
- entity_texture_features 4.0.1
- entityculling 1.5.2-mc1.19
- equipmentcompare 1.3.1
- expandeddelight 0.2.1
- extended_armor_bars 1.2.1
- fabric 0.58.0+1.19
- fabric-api-base 0.4.9+e62f51a3a9 via fabric
- fabric-api-lookup-api-v1 1.6.7+9ff28f40a9 via fabric
- fabric-biome-api-v1 9.0.14+b2a4a624a9 via fabric
- fabric-blockrenderlayer-v1 1.1.18+9ff28f40a9 via fabric
- fabric-command-api-v1 1.2.6+f71b366fa9 via fabric
- fabric-command-api-v2 2.1.2+0d55f585a9 via fabric
- fabric-commands-v0 0.2.23+df3654b3a9 via fabric
- fabric-containers-v0 0.1.28+df3654b3a9 via fabric
- fabric-content-registries-v0 3.2.1+07df213ea9 via fabric
- fabric-convention-tags-v1 1.0.8+37622d24a9 via fabric
- fabric-crash-report-info-v1 0.2.3+bd0a0d4aa9 via fabric
- fabric-data-generation-api-v1 5.1.2+a680b9b4a9 via fabric
- fabric-dimensions-v1 2.1.28+a6d2f785a9 via fabric
- fabric-entity-events-v1 1.4.16+9ff28f40a9 via fabric
- fabric-events-interaction-v0 0.4.26+9ff28f40a9 via fabric
- fabric-events-lifecycle-v0 0.2.26+df3654b3a9 via fabric
- fabric-game-rule-api-v1 1.0.19+18990361a9 via fabric
- fabric-item-api-v1 1.5.5+35a03c43a9 via fabric
- fabric-item-groups-v0 0.3.26+9ff28f40a9 via fabric
- fabric-key-binding-api-v1 1.0.18+9ff28f40a9 via fabric
- fabric-keybindings-v0 0.2.16+df3654b3a9 via fabric
- fabric-language-kotlin 1.8.2+kotlin.1.7.10
- fabric-lifecycle-events-v1 2.1.0+33fbc738a9 via fabric
- fabric-loot-api-v2 1.1.1+03a4e568a9 via fabric
- fabric-loot-tables-v1 1.1.4+9e7660c6a9 via fabric
- fabric-message-api-v1 1.0.1+513f4a59a9 via fabric
- fabric-mining-level-api-v1 2.1.11+33fbc738a9 via fabric
- fabric-models-v0 0.3.15+9ff28f40a9 via fabric
- fabric-networking-api-v1 1.1.0+442de8b8a9 via fabric
- fabric-networking-v0 0.3.15+df3654b3a9 via fabric
- fabric-object-builder-api-v1 4.0.8+9ff28f40a9 via fabric
- fabric-particles-v1 1.0.8+dc39553aa9 via fabric
- fabric-permissions-api-v0 0.1-SNAPSHOT via spark
- fabric-registry-sync-v0 0.9.18+23c4cfefa9 via fabric
- fabric-renderer-api-v1 1.0.8+9ff28f40a9 via fabric
- fabric-renderer-indigo 0.6.10+5187d39fa9 via fabric
- fabric-renderer-registries-v1 3.2.18+df3654b3a9 via fabric
- fabric-rendering-data-attachment-v1 0.3.12+9ff28f40a9 via fabric
- fabric-rendering-fluids-v1 3.0.5+9ff28f40a9 via fabric
- fabric-rendering-v0 1.1.20+df3654b3a9 via fabric
- fabric-rendering-v1 1.10.14+9ff28f40a9 via fabric
- fabric-resource-conditions-api-v1 2.0.9+e62f51a3a9 via fabric
- fabric-resource-loader-v0 0.5.6+5f1a85e0a9 via fabric
- fabric-screen-api-v1 1.0.24+f05effafa9 via fabric
- fabric-screen-handler-api-v1 1.2.7+9ff28f40a9 via fabric
- fabric-textures-v0 1.0.18+9ff28f40a9 via fabric
- fabric-transfer-api-v1 2.0.9+e62f51a3a9 via fabric
- fabric-transitive-access-wideners-v1 1.1.1+9e7660c6a9 via fabric
- fabricloader 0.14.9
- fake-player-api 0.4.0 via the_bumblezone
- fallingleaves 1.12.1+1.19
- fallingtree 3.7.4
- fancymenu 2.12.0
- farmersdelight 1.19-0.3.0
- farmersknives 2.0
- ferritecore 4.2.1
- fiber 0.23.0-2 via collective-fabric
- forgeconfigapiport 4.0.2
- frame 0.26.0+1.19
- frame-api-base 0.2.1+906ebc04a9 via frame
- frame-blocks-v0 0.1.3+233e7428a9 via frame
- frame-config-v0 0.3.1+0fa45150a9 via frame
- frame-content-registries-v0 0.4.0+2876b511a9 via frame
- frame-enchantments-v0 0.1.0+4093105da9 via frame
- frame-game-rules-v0 0.2.4+e7ce56a6a9 via frame
- frame-items-v0 0.1.3+906ebc04a9 via frame
- frame-loot-tables-v0 0.1.4+4f7341eca9 via frame
- frame-registries-v0 0.1.1+0e0ec74ea9 via frame
- frame-rendering-v0 0.1.5+906ebc04a9 via frame
- frame-tabbed-item-groups-v0 0.2.4+0aca9b56a9 via frame
- frame-toymaker-v0 0.6.1+b13741c3a9 via frame
- frame-woods-v0 0.2.1+6a33fbada9 via frame
- friendsandfoes 1.5.5
- ftbchunks 1900.3.8-build.157
- ftblibrary 1900.3.8-build.135
- ftbteams 1900.2.8-build.59
- fwaystones 3.0.2+mc1.19
- galosphere 1.19-1.1.1
- geckolib3 3.1.6
- geodes 1.4.4
- goblintraders 1.5.2
- goodall 1.1.0
- graveyard 1.10
- guardvillagers 1.19-1.0.16
- highlighter 1.1.2
- iceberg 1.0.38
- illuminations 1.10.8
- immersive_weathering 1.0.1-1.19_SNAPSHOT
- impactfulweather 4.0.2
- imst 2.0.2
- indium 1.0.7+mc1.19
- infusion_table 1.1.0
- inmis 2.7.0-1.19
- inventoryhud 3.4.2
- iris 1.2.6
- itemmodelfix 1.0.3+1.19
- jamlib 0.4.1
- java 17
- journeymap 5.8.5
- journeymap-api-fabric 1.19-1.8-fabric-SNAPSHOT via journeymap
- just_end_anchor 1.0.2
- konkrete 1.5.0
- krypton 0.2.0
- lambdabettergrass 1.3.0+1.19
- lambdynlights 2.1.2+1.19
- lazydfu 0.1.3
- lithium 0.8.1
- maelstrom_library 1.3-1.19-pre1 via bosses_of_mass_destruction
- magnumtorch 4.0.1
- mavm 1.1.0
- maybe-data 1.3.2-1.19-rc2 via wolveswitharmor
- memoryleakfix 1.19-0.7.0
- merchantmarkers 1.2.2
- midnightlib 0.5.2
- minecraft 1.19
- mm 2.3 via crawl
- modmenu 4.0.4
- more-axolotls 1.0.2
- more_babies 0.5.3
- moremcmeta 1.19-3.0.5
- moretotems 2.11.0
- morevillagers 4.0.2
- mousetweaks 2.22
- multipart_entities 1.2-1.19-pre1 via bosses_of_mass_destruction
- naturalist 2.0.1
- naturescompass 1.19-2.0.4-fabric
- nears 1.2.3
- nochatreports 1.19-v1.2.3
- noindium 1.0.2+1.18.2 via ae2
- notenoughanimations 1.6.1
- omega-config 1.2.3-1.18.1 via inmis
- onsoulfire 1.19-2
- openloader 13.1.2
- optigui 1.1.1
- org_anarres_jcpp 1.4.14 via iris
- org_apache_commons_commons-text 1.9 via optigui
- org_jetbrains_kotlin_kotlin-reflect 1.7.10 via fabric-language-kotlin
- org_jetbrains_kotlin_kotlin-stdlib 1.7.10 via fabric-language-kotlin
- org_jetbrains_kotlin_kotlin-stdlib-jdk7 1.7.10 via fabric-language-kotlin
- org_jetbrains_kotlin_kotlin-stdlib-jdk8 1.7.10 via fabric-language-kotlin
- org_jetbrains_kotlinx_atomicfu-jvm 0.18.2 via fabric-language-kotlin
- org_jetbrains_kotlinx_kotlinx-coroutines-core-jvm 1.6.4 via fabric-language-kotlin
- org_jetbrains_kotlinx_kotlinx-coroutines-jdk8 1.6.4 via fabric-language-kotlin
- org_jetbrains_kotlinx_kotlinx-datetime-jvm 0.4.0 via fabric-language-kotlin
- org_jetbrains_kotlinx_kotlinx-serialization-cbor-jvm 1.3.3 via fabric-language-kotlin
- org_jetbrains_kotlinx_kotlinx-serialization-core-jvm 1.3.3 via fabric-language-kotlin
- org_jetbrains_kotlinx_kotlinx-serialization-json-jvm 1.3.3 via fabric-language-kotlin
- org_joml_joml 1.10.4 via sodium
- oxidized 1.7.1
- paintings 10.0.0.0
- patchouli 1.19-74-FABRIC
- pickupnotifier 4.0.0
- plushies 1.2
- pride 1.1.2+1.19 via lambdynlights
- puzzle 1.4.0-1.19
- puzzle-base 1.4.0-1.19 via puzzle
- puzzle-gui 1.4.0-1.19 via puzzle
- puzzle-models 1.4.0-1.19 via puzzle
- puzzle-splashscreen 1.4.0-1.19 via puzzle
- puzzleslib 4.0.18
- quartzelv 2.1.4+1.19
- reeses-sodium-options 1.4.4+mc1.19-build.47
- repurposed_structures 6.1.1+1.19
- rightclickharvest 2.2.2
- rocks 1.6.1
- roughlyenoughitems 9.1.520
- roughlyenoughprofessions 1.1.1
- roughlyenoughresources 2.6.0
- satin 1.8.0 via blur
- sdrp 2.0.1-build.16+mc1.19
- seasons 1.4-BETA+1.19
- settxi-gui-cloth-config 2.4.0 via zoomify
- skinlayers 1.5.1-mc1.19.1
- smoothboot 1.19-1.7.1
- sodium 0.4.2+build.16
- sodium-extra 0.4.6+mc1.19-build.47
- spark 1.9.26
- spectrelib 0.8.1+1.19 via comforts
- spruceui 4.0.0+1.19 via lambdabettergrass
- starlight 1.1.1+fabric.ae22326
- starterkit-fabric 3.3
- static-content 1.0.1-1.16.2 via wolveswitharmor
- staticdata 1.1.2 via static-content
- steves_vanilla 1.0.0+1.19
- stoneholm 1.4.4
- structory 1.0.1
- t_and_t 1.8
- team_reborn_energy 2.0.0-beta1 via ae2
- terrablender 2.0.0.120
- terraform-wood-api-v1 4.1.0 via blockus
- the_bumblezone 6.1.4+1.19
- thonkutil 2.15.4+1.19
- thonkutil-base 1.13.2+4a8c408a57 via thonkutil
- thonkutil-capes-v1 1.4.2+3eb2749857 via thonkutil
- thonkutil-coords-v1 1.1.2+8ff533c957 via thonkutil
- thonkutil-customization-v1 1.1.2+8ff533c957 via thonkutil
- thonkutil-legacy 1.1.2+5d4263f557 via thonkutil
- thonkutil-modchecker-v1 1.1.3+bd4b387957 via thonkutil
- thonkutil-potions-v0 1.5.2+8ff533c957 via thonkutil
- thonkutil-titlescreen-v1 1.2.2+8ff533c957 via thonkutil
- thonkutil-trades-v1 1.2.2+8ff533c957 via thonkutil
- tipsmod 6.1.5
- toms_storage 1.3.5
- toolstats 10.1.2
- tooltipfix 1.0.5-1.19
- tradingpost 4.0.1
- transparent 5.1.0
- trinkets 3.4.0
- tweed4_annotated 1.3.1+mc22w17a via wandering_collector
- tweed4_base 1.6.0+mc22w17a via wandering_collector
- tweed4_data 1.2.1+mc22w17a via wandering_collector
- tweed4_data_hjson 1.1.1+mc22w17a via wandering_collector
- tweed4_tailor_coat 1.1.3+mc22w17a via wandering_collector
- tweed4_tailor_screen 1.1.1+mc22w17a via wandering_collector
- twigs 2.0.0-beta.8+1.19
- universal_ores 1.4.2
- villagernames 4.0.6
- visuality 0.5.1
- visualworkbench 4.0.0
- voidtotem 2.0.0
- voidz 1.0.8
- wandering_collector 1.1.3+mc1.19
- wardentools 1.8
- windchimes 1.2.1
- wolveswitharmor 1.8.0-1.19
- worldedit 7.2.11-beta-02+315c5d0
- wthit 5.9.0
- xaerominimap 22.12.0
- xaeroworldmap 1.26.1
- xp_storage 1.4.3+1.19
- xp_storage_trinkets 0.1+1.19
- zoomify 1.7.1
[12:00:48] [main/INFO]: SpongePowered MIXIN Subsystem Version=0.8.5 Source=file:/C:/Users/tykwe/curseforge/minecraft/Install/libraries/net/fabricmc/sponge-mixin/0.11.4+mixin.0.8.5/sponge-mixin-0.11.4+mixin.0.8.5.jar Service=Knot/Fabric Env=CLIENT
[12:00:48] [main/INFO]: Compatibility level set to JAVA_16
[12:00:48] [main/INFO]: Compatibility level set to JAVA_17
[12:00:49] [main/WARN]: Reference map 'another_furniture-fabric-fabric-refmap.json' for another_furniture.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/WARN]: Reference map 'axolotl-item-fix-refmap.json' for axolotlitemfix.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/WARN]: Failed to select mixin config: charm.mixins.json
java.lang.RuntimeException: java.lang.IllegalStateException: Key is not followed by an equals sign on line 1:
at com.moandjiezana.toml.Toml.read(Toml.java:74) ~[com_moandjiezana_toml_toml4j-0.7.2-ee16bffd05e60369.jar:?]
at svenhjol.charm.helper.ConfigHelper.readConfig(ConfigHelper.java:34) ~[charm-fabric-1.19-4.1.2.jar:?]
at svenhjol.charm.mixin.BaseMixinConfigPlugin.onLoad(BaseMixinConfigPlugin.java:43) ~[charm-fabric-1.19-4.1.2.jar:?]
at org.spongepowered.asm.mixin.transformer.PluginHandle.onLoad(PluginHandle.java:119) ~[sponge-mixin-0.11.4+mixin.0.8.5.jar:0.11.4+mixin.0.8.5]
at org.spongepowered.asm.mixin.transformer.MixinConfig.onSelect(MixinConfig.java:709) ~[sponge-mixin-0.11.4+mixin.0.8.5.jar:0.11.4+mixin.0.8.5]
at org.spongepowered.asm.mixin.transformer.MixinProcessor.selectConfigs(MixinProcessor.java:498) [sponge-mixin-0.11.4+mixin.0.8.5.jar:0.11.4+mixin.0.8.5]
at org.spongepowered.asm.mixin.transformer.MixinProcessor.select(MixinProcessor.java:460) [sponge-mixin-0.11.4+mixin.0.8.5.jar:0.11.4+mixin.0.8.5]
at org.spongepowered.asm.mixin.transformer.MixinProcessor.checkSelect(MixinProcessor.java:438) [sponge-mixin-0.11.4+mixin.0.8.5.jar:0.11.4+mixin.0.8.5]
at org.spongepowered.asm.mixin.transformer.MixinProcessor.applyMixins(MixinProcessor.java:290) [sponge-mixin-0.11.4+mixin.0.8.5.jar:0.11.4+mixin.0.8.5]
at org.spongepowered.asm.mixin.transformer.MixinTransformer.transformClass(MixinTransformer.java:234) [sponge-mixin-0.11.4+mixin.0.8.5.jar:0.11.4+mixin.0.8.5]
at org.spongepowered.asm.mixin.transformer.MixinTransformer.transformClassBytes(MixinTransformer.java:202) [sponge-mixin-0.11.4+mixin.0.8.5.jar:0.11.4+mixin.0.8.5]
at net.fabricmc.loader.impl.launch.knot.KnotClassDelegate.getPostMixinClassByteArray(KnotClassDelegate.java:414) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.launch.knot.KnotClassDelegate.tryLoadClass(KnotClassDelegate.java:323) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.launch.knot.KnotClassDelegate.loadClass(KnotClassDelegate.java:218) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.launch.knot.KnotClassLoader.loadClass(KnotClassLoader.java:145) [fabric-loader-0.14.9.jar:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:520) [?:?]
at java.lang.Class.forName0(Native Method) ~[?:?]
at java.lang.Class.forName(Class.java:467) [?:?]
at net.fabricmc.loader.impl.util.DefaultLanguageAdapter.create(DefaultLanguageAdapter.java:50) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.entrypoint.EntrypointStorage$NewEntry.getOrCreate(EntrypointStorage.java:117) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.entrypoint.EntrypointContainerImpl.getEntrypoint(EntrypointContainerImpl.java:53) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.entrypoint.EntrypointUtils.invoke0(EntrypointUtils.java:47) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.entrypoint.EntrypointUtils.invoke(EntrypointUtils.java:35) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.launch.knot.Knot.init(Knot.java:162) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.launch.knot.Knot.launch(Knot.java:68) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.launch.knot.KnotClient.main(KnotClient.java:23) [fabric-loader-0.14.9.jar:?]
Caused by: java.lang.IllegalStateException: Key is not followed by an equals sign on line 1:
at com.moandjiezana.toml.Toml.read(Toml.java:140) ~[com_moandjiezana_toml_toml4j-0.7.2-ee16bffd05e60369.jar:?]
at com.moandjiezana.toml.Toml.read(Toml.java:107) ~[com_moandjiezana_toml_toml4j-0.7.2-ee16bffd05e60369.jar:?]
at com.moandjiezana.toml.Toml.read(Toml.java:72) ~[com_moandjiezana_toml_toml4j-0.7.2-ee16bffd05e60369.jar:?]
... 25 more
[12:00:49] [main/INFO]: Bootstrapping DashLoader 4.0.0+1.19.
[12:00:49] [main/WARN]: Disabled Optional Feature FAST_STATE_INIT from dashloader config. DashLoader
[12:00:49] [main/WARN]: Disabled Optional Feature CACHE_PARTICLE from dashloader config. DashLoader
[12:00:49] [main/INFO]: Preloading Debugify
[12:00:49] [main/INFO]: Done.
[12:00:49] [main/WARN]: Reference map 'dustrial-decor-fabric-refmap.json' for dustrial_decor.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/WARN]: Reference map 'goodall-fabric-refmap.json' for goodall.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/INFO]: Loaded configuration file for Lithium: 94 options available, 2 override(s) found
[12:00:49] [main/WARN]: Reference map 'morevillagers-fabric-fabric-refmap.json' for morevillagers.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/WARN]: Reference map 'nears-fabric-1.19-refmap.json' for nears.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/WARN]: Reference map 'RoughlyEnoughProfessions-fabric-1.19-refmap.json' for roughlyenoughprofessions.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/WARN]: [Satin] Sodium is present, custom block renders may not work
[12:00:49] [main/WARN]: Reference map 'SimpleDiscordRichPresence-fabric-refmap.json' for sdrp.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/WARN]: Reference map 'SimpleDiscordRichPresence-common-refmap.json' for sdrp-common.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/INFO]: Loaded configuration file for Sodium: 29 options available, 5 override(s) found
[12:00:49] [main/INFO]: Loaded configuration file for Sodium Extra: 27 options available, 0 override(s) found
[12:00:49] [main/WARN]: Reference map 'static-content-refmap.json' for static-content.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/WARN]: Reference map 'transparent-fabric-refmap.json' for transparent.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:49] [main/WARN]: Reference map 'warden-tools-refmap.json' for wardentools.mixins.json could not be read. If this is a development environment you can ignore this message
[12:00:50] [main/WARN]: Force disabled MC-228976 because it's conflicting with: lithium
[12:00:50] [main/WARN]: Error loading class: me/shedaniel/rei/impl/client/gui/fabric/ScreenOverlayImplImpl (java.lang.ClassNotFoundException: me/shedaniel/rei/impl/client/gui/fabric/ScreenOverlayImplImpl)
[12:00:50] [main/WARN]: @Mixin target me.shedaniel.rei.impl.client.gui.fabric.ScreenOverlayImplImpl was not found equipmentcompare.mixins.json:RoughlyEnoughItemsScreenOverlayImplImplMixin from mod equipmentcompare
[12:00:50] [main/WARN]: Force-disabling mixin 'alloc.blockstate.StateMixin' as rule 'mixin.alloc.blockstate' (added by mods [ferritecore]) disables it and children
[12:00:50] [main/WARN]: Force-disabling mixin 'world.player_chunk_tick.ThreadedAnvilChunkStorageMixin' as rule 'mixin.world.player_chunk_tick' (added by mods [krypton]) disables it and children
[12:00:50] [main/WARN]: Force-disabling mixin 'features.fast_biome_colors.MixinBackgroundRenderer' as rule 'mixin.features.fast_biome_colors' (added by mods [colormatic]) disables it and children
[12:00:50] [main/WARN]: Force-disabling mixin 'features.fast_biome_colors.MixinClientWorld' as rule 'mixin.features.fast_biome_colors' (added by mods [colormatic]) disables it and children
[12:00:50] [main/WARN]: Force-disabling mixin 'features.model.MixinMultipartBakedModel' as rule 'mixin.features.model' (added by mods [dashloader]) disables it and children
[12:00:50] [main/WARN]: Force-disabling mixin 'features.model.MixinWeightedBakedModel' as rule 'mixin.features.model' (added by mods [dashloader]) disables it and children
[12:00:50] [main/WARN]: Force-disabling mixin 'features.sky.MixinWorldRenderer' as rule 'mixin.features.sky' (added by mods [iris]) disables it and children
[12:00:50] [main/WARN]: Force-disabling mixin 'features.texture_updates.MixinSpriteInterpolated' as rule 'mixin.features.texture_updates' (added by mods [dashloader]) disables it and children
[12:00:50] [main/WARN]: Error loading class: net/coderbot/iris/layer/IrisRenderTypeWrapper (java.lang.ClassNotFoundException: net/coderbot/iris/layer/IrisRenderTypeWrapper)
[12:00:50] [main/WARN]: @Mixin target net.coderbot.iris.layer.IrisRenderTypeWrapper was not found mixins.satin.client.json:iris.IrisRenderLayerWrapperMixin from mod satin
[12:00:50] [main/INFO]: I used the json to destroy the json
[12:00:50] [main/INFO]: Initializing DashLoader 4.0.0+1.19.
[12:00:51] [main/INFO]: [282ms] Initialized api.
[12:00:51] [main/INFO]: Created DashLoader with KnotClassLoader.
[12:00:51] [main/INFO]: Initialized DashLoader
[12:00:51] [main/INFO]: Smooth Boot config initialized
[12:00:51] [main/WARN]: Configuration conflict: there is more than one oshi.properties file on the classpath
[12:00:52] [main/WARN]: Configuration conflict: there is more than one oshi.architecture.properties file on the classpath
[12:00:52] [main/INFO]: Mixing MixinMinecraft from nochatreports.mixins.json into net.minecraft.class_310
[12:00:52] [main/INFO]: Mixing MixinPlayer from nochatreports.mixins.json into net.minecraft.class_1657
[12:00:52] [main/INFO]: Mixing MixinLocalPlayer from nochatreports.mixins.json into net.minecraft.class_746
[12:00:52] [main/WARN]: Discarding @Unique public method getAnimatedSkin in notenoughanimations.mixins.json:DonorAbstractClientPlayerMixin from mod notenoughanimations because it already exists in net.minecraft.class_742
[12:00:52] [main/WARN]: Discarding @Unique public method getAnimatedSkin in 3dskinlayers.mixins.json:DonorAbstractClientPlayerMixin from mod skinlayers because it already exists in net.minecraft.class_742
[12:00:52] [main/WARN]: Method overwrite conflict for getEntityManager in spark.mixins.json:ClientWorldAccessor from mod spark, previously written by me.jellysquid.mods.lithium.mixin.chunk.entity_class_groups.ClientWorldMixin. Skipping method.
[12:00:52] [main/INFO]: Mixing MixinTitleScreen from nochatreports.mixins.json into net.minecraft.class_442
[12:00:53] [main/INFO]: [bclib] Added Config bclib.generator to auto sync (file hash)
[12:00:53] [main/INFO]: [bclib] Added Config bclib.main to auto sync (content diff)
[12:00:53] [main/INFO]: [bclib] Added Config bclib.recipes to auto sync (file hash)
[12:00:53] [main/INFO]: [bclib] Added Config bclib.biomes to auto sync (file hash)
[12:00:55] [main/INFO]: Building unoptimized datafixer
[12:00:56] [main/INFO]: [bclib] Make sure features are loaded from terrablender
BCLib - Nether BiomeSource (7abbc708)
biomes = 5
namespaces = minecraft
seed = 0
height = 128
config = BCLibNetherBiomeSourceConfig{mapVersion=square}
BCLib - The End BiomeSource (4f11b19)
biomes = 5
seed = 0
height = 128
deciders = 0
config = BCLEndBiomeSourceConfig{mapVersion=square, generatorVersion=paulevs, withVoidBiomes=true, innerVoidRadiusSquared=1048576, voidBiomesSize=256, centerBiomesSize=256, landBiomesSize=256, barrensBiomesSize=256}
BCLib - Nether BiomeSource (29f14e7f)
biomes = 5
seed = 0
height = 128
config = BCLibNetherBiomeSourceConfig{mapVersion=hex}
BCLib - The End BiomeSource (4df85d38)
biomes = 5
seed = 0
height = 128
deciders = 0
config = BCLEndBiomeSourceConfig{mapVersion=hex, generatorVersion=paulevs, withVoidBiomes=true, innerVoidRadiusSquared=1048576, voidBiomesSize=256, centerBiomesSize=256, landBiomesSize=256, barrensBiomesSize=256}
[12:00:57] [main/ERROR]: Failed to load config 'class com.hugman.dawn.mod.config.DawnConfig', using default!
me.shedaniel.autoconfig.serializer.ConfigSerializer$SerializationException: com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
at me.shedaniel.autoconfig.serializer.GsonConfigSerializer.deserialize(GsonConfigSerializer.java:83) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at me.shedaniel.autoconfig.serializer.PartitioningSerializer.deserialize(PartitioningSerializer.java:119) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at me.shedaniel.autoconfig.serializer.PartitioningSerializer.deserialize(PartitioningSerializer.java:40) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at me.shedaniel.autoconfig.ConfigManager.load(ConfigManager.java:92) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at me.shedaniel.autoconfig.ConfigManager.<init>(ConfigManager.java:53) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at me.shedaniel.autoconfig.AutoConfig.register(AutoConfig.java:66) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at com.hugman.dawn.Dawn.<clinit>(Dawn.java:23) ~[dawn-3.5.0.jar:?]
at net.minecraft.class_2348.localvar$cde000$dawn$fixMissingFromRegistry(class_2348.java:523) ~[client-intermediary.jar:?]
at net.minecraft.class_2348.method_10223(class_2348.java) ~[client-intermediary.jar:?]
at net.minecraft.class_1802.handler$flf000$onBlockItemRegister(class_1802.java:1331) ~[client-intermediary.jar:?]
at net.minecraft.class_1802.method_7988(class_1802.java) ~[client-intermediary.jar:?]
at net.minecraft.class_1802.<clinit>(class_1802.java:283) ~[client-intermediary.jar:?]
at net.minecraft.class_1792.method_7867(class_1792.java:74) ~[client-intermediary.jar:?]
at net.minecraft.class_2248.method_8389(class_2248.java:554) ~[client-intermediary.jar:?]
at net.minecraft.class_7143$class_7144.method_41583(class_7143.java:60) ~[client-intermediary.jar:?]
at net.minecraft.class_7143$class_7144.handler$zph000$bcl_run(class_7143.java:545) ~[client-intermediary.jar:?]
at net.minecraft.class_7143$class_7144.method_41581(class_7143.java) ~[client-intermediary.jar:?]
at net.minecraft.class_7143.method_41579(class_7143.java:199) ~[client-intermediary.jar:?]
at net.minecraft.class_5458.method_44104(class_5458.java:98) ~[client-intermediary.jar:?]
at net.minecraft.class_5458.method_30566(class_5458.java:105) ~[client-intermediary.jar:?]
at java.util.LinkedHashMap.forEach(LinkedHashMap.java:721) [?:?]
at net.minecraft.class_5458.<clinit>(class_5458.java:104) [client-intermediary.jar:?]
at net.minecraft.class_2378.<clinit>(class_2378.java:326) [client-intermediary.jar:?]
at net.minecraft.class_2966.method_12851(class_2966.java:50) [client-intermediary.jar:?]
at net.minecraft.client.main.Main.main(Main.java:154) [client-intermediary.jar:?]
at net.fabricmc.loader.impl.game.minecraft.MinecraftGameProvider.launch(MinecraftGameProvider.java:461) [fabric-loader-0.14.9.jar:?]
at net.fabricmc.loader.impl.launch.knot.Knot.launch(Knot.java:74) [fabric-loader-0.14.9.jar:?]
Caused by: com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:226) ~[gson-2.8.9.jar:?]
at com.google.gson.Gson.fromJson(Gson.java:963) ~[gson-2.8.9.jar:?]
at com.google.gson.Gson.fromJson(Gson.java:901) ~[gson-2.8.9.jar:?]
at me.shedaniel.autoconfig.serializer.GsonConfigSerializer.deserialize(GsonConfigSerializer.java:79) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
... 27 more
Caused by: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
at com.google.gson.stream.JsonReader.beginObject(JsonReader.java:384) ~[gson-2.8.9.jar:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:215) ~[gson-2.8.9.jar:?]
... 27 more
[12:00:57] [main/ERROR]: Registry 'enhancedcelestials:entity_filter' was empty after loading
[12:00:57] [main/INFO]: [bclib] Added Config betternether.main to auto sync (file hash)
[12:00:57] [main/INFO]: [bclib] Added Config betternether.generator to auto sync (file hash)
[12:00:57] [main/INFO]: [bclib] Added Config betternether.blocks to auto sync (file hash)
[12:00:57] [main/INFO]: [bclib] Added Config betternether.items to auto sync (file hash)
[12:00:57] [main/INFO]: [bclib] Added Config betternether.biomes to auto sync (file hash)
[12:00:57] [main/INFO]: [bclib] Added Config betternether.mobs to auto sync (file hash)
[12:00:57] [main/INFO]: [bclib] Added Config betternether.recipes to auto sync (file hash)
[12:00:58] [main/ERROR]: Entity goblintraders:goblin_trader has no attributes
[12:00:58] [main/ERROR]: Entity goblintraders:vein_goblin_trader has no attributes
[12:00:58] [Render thread/WARN]: Method overwrite conflict for method_22920 in sodium.mixins.json:features.buffer_builder.intrinsics.MixinBufferBuilder from mod sodium, previously written by net.coderbot.iris.mixin.vertices.block_rendering.MixinBufferBuilder_SeparateAo. Skipping method.
[12:00:58] [Render thread/INFO]: Environment: authHost='https://authserver.mojang.com', accountsHost='https://api.mojang.com', sessionHost='https://sessionserver.mojang.com', servicesHost='https://api.minecraftservices.com', name='PROD'
[12:00:58] [Render thread/INFO]: Setting user: TI_Gaming_TV
[12:00:58] [Render thread/WARN]: Method overwrite conflict for extractPools in enhancedcelestials.mixins.json:MixinLootTableManager from mod enhancedcelestials, previously written by potionstudios.byg.mixin.common.world.level.storage.loot.MixinLootTableManager. Skipping method.
[12:00:59] [Render thread/ERROR]: Failed to load config 'class net.adventurez.config.AdventureConfig', using default!
me.shedaniel.autoconfig.serializer.ConfigSerializer$SerializationException: me.shedaniel.cloth.clothconfig.shadowed.blue.endless.jankson.api.SyntaxError: Found character ' ' instead of '{' while looking for the start of an object
at me.shedaniel.autoconfig.serializer.JanksonConfigSerializer.deserialize(JanksonConfigSerializer.java:76) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at net.adventurez.init.ConfigInit.init(ConfigInit.java:11) ~[adventurez-1.4.14.jar:?]
at net.adventurez.AdventureMain.onInitialize(AdventureMain.java:12) ~[adventurez-1.4.14.jar:?]
at net.fabricmc.loader.impl.game.minecraft.Hooks.startClient(Hooks.java:52) [fabric-loader-0.14.9.jar:?]
at net.minecraft.class_310.<init>(class_310.java:443) [client-intermediary.jar:?]
at net.minecraft.client.main.Main.main(Main.java:198) [client-intermediary.jar:?]
Caused by: me.shedaniel.cloth.clothconfig.shadowed.blue.endless.jankson.api.SyntaxError: Found character ' ' instead of '{' while looking for the start of an object
at me.shedaniel.cloth.clothconfig.shadowed.blue.endless.jankson.impl.ObjectParserContext.consume(ObjectParserContext.java:58) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at me.shedaniel.cloth.clothconfig.shadowed.blue.endless.jankson.Jankson.processCodePoint(Jankson.java:316) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at me.shedaniel.cloth.clothconfig.shadowed.blue.endless.jankson.Jankson.load(Jankson.java:186) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at me.shedaniel.cloth.clothconfig.shadowed.blue.endless.jankson.Jankson.load(Jankson.java:79) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
at me.shedaniel.autoconfig.serializer.JanksonConfigSerializer.deserialize(JanksonConfigSerializer.java:74) ~[cloth-config-7.0.73-bc9504dfabb91bf1.jar:?]
... 13 more
[12:00:59] [Render thread/INFO]: Mixing MixinServerGamePacketListenerImpl from nochatreports.mixins.json into net.minecraft.class_3244
[12:01:00] [Render thread/ERROR]: Failed to load config 'class com.slomaxonical.architectspalette.compat.cloth_config.ApConfigs', using default!
at com.slomaxonical.architectspalette.ArchitectsPalette.onInitialize(ArchitectsPalette.java:29) ~[architects-palette-fabric-2.1.1.jar:?]
... 12 more
[12:01:00] [Render thread/INFO]: Initialized!
[12:01:00] [Render thread/INFO]: Loading config file
[12:01:00] [Render thread/INFO]: Config file loaded
[12:01:00] [Render thread/INFO]: [bclib] Added Config betterend.entities to auto sync (file hash)
[12:01:00] [Render thread/INFO]: [bclib] Added Config betterend.blocks to auto sync (file hash)
[12:01:00] [Render thread/INFO]: [bclib] Added Config betterend.items to auto sync (file hash)
[12:01:00] [Render thread/INFO]: [bclib] Added Config betterend.biomes to auto sync (file hash)
[12:01:00] [Render thread/INFO]: [bclib] Added Config betterend.recipes to auto sync (file hash)
[12:01:00] [Render thread/INFO]: [bclib] Added Config betterend.enchantments to auto sync (file hash)
[12:01:00] [Render thread/INFO]: [betternether] =^..^= BetterNether for 1.19 =^..^=
[12:01:01] [Render thread/INFO]: [STDERR]: org.objectweb.asm.tree.analysis.AnalyzerException: Error at instruction 140: Trying to set an inexistant local variable 9
[12:01:01] [Render thread/INFO]: [STDERR]: at org.objectweb.asm.tree.analysis.Analyzer.analyze(Analyzer.java:296)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.util.Locals.generateLocalVariableTable(Locals.java:859)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.util.Locals.getGeneratedLocalVariableTable(Locals.java:828)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.util.Locals.getLocalVariableAt(Locals.java:782)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.util.Locals.getLocalVariableAt(Locals.java:752)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.util.Locals.getLocalsAt(Locals.java:529)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.util.Locals.getLocalsAt(Locals.java:336)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.injection.callback.CallbackInjector.preInject(CallbackInjector.java:479)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.injection.code.Injector.preInject(Injector.java:258)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.injection.struct.InjectionInfo.preInject(InjectionInfo.java:436)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.transformer.MixinTargetContext.applyInjections(MixinTargetContext.java:1371)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.transformer.MixinApplicatorStandard.applyInjections(MixinApplicatorStandard.java:1052)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.transformer.MixinApplicatorStandard.applyMixin(MixinApplicatorStandard.java:400)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.transformer.MixinApplicatorStandard.apply(MixinApplicatorStandard.java:325)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.transformer.TargetClassContext.apply(TargetClassContext.java:421)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.transformer.TargetClassContext.applyMixins(TargetClassContext.java:403)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.transformer.MixinProcessor.applyMixins(MixinProcessor.java:363)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.transformer.MixinTransformer.transformClass(MixinTransformer.java:234)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.spongepowered.asm.mixin.transformer.MixinTransformer.transformClassBytes(MixinTransformer.java:202)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.launch.knot.KnotClassDelegate.getPostMixinClassByteArray(KnotClassDelegate.java:414)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.launch.knot.KnotClassDelegate.tryLoadClass(KnotClassDelegate.java:323)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.launch.knot.KnotClassDelegate.loadClass(KnotClassDelegate.java:218)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.launch.knot.KnotClassLoader.loadClass(KnotClassLoader.java:145)
[12:01:01] [Render thread/INFO]: [STDERR]: at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:520)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.minecraft.class_4668.<clinit>(class_4668.java:125)
[12:01:01] [Render thread/INFO]: [STDERR]: at party.lemons.biomemakeover.util.registry.RType.getAsRenderType(RType.java:24)
[12:01:01] [Render thread/INFO]: [STDERR]: at party.lemons.biomemakeover.init.BMBlocks.lambda$initClient$116(BMBlocks.java:209)
[12:01:01] [Render thread/INFO]: [STDERR]: at java.base/java.util.HashMap.forEach(HashMap.java:1421)
[12:01:01] [Render thread/INFO]: [STDERR]: at party.lemons.biomemakeover.init.BMBlocks.lambda$initClient$117(BMBlocks.java:209)
[12:01:01] [Render thread/INFO]: [STDERR]: at dev.architectury.utils.EnvExecutor.runInEnv(EnvExecutor.java:35)
[12:01:01] [Render thread/INFO]: [STDERR]: at party.lemons.biomemakeover.init.BMBlocks.initClient(BMBlocks.java:208)
[12:01:01] [Render thread/INFO]: [STDERR]: at party.lemons.biomemakeover.BiomeMakeoverClient.init(BiomeMakeoverClient.java:37)
[12:01:01] [Render thread/INFO]: [STDERR]: at party.lemons.biomemakeover.fabric.BMFabric.onInitialize(BMFabric.java:46)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.entrypoint.EntrypointUtils.invoke0(EntrypointUtils.java:47)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.entrypoint.EntrypointUtils.invoke(EntrypointUtils.java:35)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.game.minecraft.Hooks.startClient(Hooks.java:52)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.minecraft.class_310.<init>(class_310.java:443)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.minecraft.client.main.Main.main(Main.java:198)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.game.minecraft.MinecraftGameProvider.launch(MinecraftGameProvider.java:461)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.launch.knot.Knot.launch(Knot.java:74)
[12:01:01] [Render thread/INFO]: [STDERR]: at net.fabricmc.loader.impl.launch.knot.KnotClient.main(KnotClient.java:23)
[12:01:01] [Render thread/INFO]: [STDERR]: Caused by: java.lang.IndexOutOfBoundsException: Trying to set an inexistant local variable 9
[12:01:01] [Render thread/INFO]: [STDERR]: at org.objectweb.asm.tree.analysis.Frame.setLocal(Frame.java:208)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.objectweb.asm.tree.analysis.Frame.execute(Frame.java:337)
[12:01:01] [Render thread/INFO]: [STDERR]: at org.objectweb.asm.tree.analysis.Analyzer.analyze(Analyzer.java:188)
[12:01:01] [Render thread/INFO]: [STDERR]: ... 40 more
[12:01:01] [Render thread/WARN]: Static binding violation: PRIVATE @OverWrite method method_23182 in sodium.mixins.json:features.item.MixinItemRenderer from mod sodium cannot reduce visibiliy of PUBLIC target method, visibility will be upgraded.
[12:01:01] [Render thread/INFO]: Fixing MC-151457. Crafting remainder for minecraft:pufferfish_bucket is now minecraft:bucket.
[12:01:01] [Render thread/INFO]: Fixing MC-151457. Crafting remainder for minecraft:salmon_bucket is now minecraft:bucket.
[12:01:01] [Render thread/INFO]: Fixing MC-151457. Crafting remainder for minecraft:cod_bucket is now minecraft:bucket.
[12:01:01] [Render thread/INFO]: Fixing MC-151457. Crafting remainder for minecraft:tropical_fish_bucket is now minecraft:bucket.
[12:01:01] [Render thread/INFO]: Fixing MC-151457. Crafting remainder for minecraft:axolotl_bucket is now minecraft:bucket.
[12:01:01] [Render thread/INFO]: Fixing MC-151457. Crafting remainder for minecraft:powder_snow_bucket is now minecraft:bucket.
[12:01:01] [Render thread/INFO]: Fixing MC-151457. Crafting remainder for minecraft:tadpole_bucket is now minecraft:bucket.
[12:01:02] [Render thread/INFO]: BYG registries bootstrapped
[12:01:02] [Render thread/ERROR]: No data fixer registered for byg:boat
[12:01:02] [Render thread/ERROR]: No data fixer registered for byg:chest_boat
[12:01:02] [Render thread/INFO]: Initializing BYG network...
[12:01:02] [Render thread/INFO]: Initialized BYG network!
[12:01:02] [Render thread/INFO]: Mixing MixinClientPacketListener from nochatreports.mixins.json into net.minecraft.class_634
[12:01:02] [Render thread/INFO]: Oh The Biomes You'll Go (BYG) was initialized from "Fabric Mod Initializer"
[12:01:02] [Render thread/INFO]: Capybara is downloaded, loading now! Thanks for installing! <3
[12:01:02] [Render thread/INFO]: [STDOUT]: Loading Collective (Fabric) version 4.27.
[12:01:02] [Render thread/INFO]: Enabled 73/75 bugs!
[12:01:02] [Render thread/INFO]: Successfully Debugify'd your game!
[12:01:02] [Render thread/INFO]: Loaded Config! Regular deepslate extras are OFF
[12:01:02] [Render thread/ERROR]: Failed to load config 'class net.dragonloot.config.DragonLootConfig', using default!
at net.dragonloot.init.ConfigInit.init(ConfigInit.java:11) ~[dragonloot-1.1.1.jar:?]
at net.dragonloot.DragonLootMain.onInitialize(DragonLootMain.java:17) ~[dragonloot-1.1.1.jar:?]
... 13 more
[12:01:03] [Render thread/INFO]: [DRIPPY LOADING SCREEN] FancyMenu detected!
[12:01:03] [Render thread/ERROR]: No data fixer registered for ashen_cow
[12:01:03] [Render thread/ERROR]: No data fixer registered for albino_cow
[12:01:03] [Render thread/ERROR]: No data fixer registered for cookie_cow
[12:01:03] [Render thread/ERROR]: No data fixer registered for cream_cow
[12:01:03] [Render thread/ERROR]: No data fixer registered for dairy_cow
[12:01:03] [Render thread/ERROR]: No data fixer registered for pinto_cow
[12:01:03] [Render thread/ERROR]: No data fixer registered for sunset_cow
[12:01:03] [Render thread/ERROR]: No data fixer registered for amber_chicken
[12:01:03] [Render thread/ERROR]: No data fixer registered for bronzed_chicken
[12:01:03] [Render thread/ERROR]: No data fixer registered for gold_crested_chicken
[12:01:03] [Render thread/ERROR]: No data fixer registered for midnight_chicken
[12:01:03] [Render thread/ERROR]: No data fixer registered for skewbald_chicken
[12:01:03] [Render thread/ERROR]: No data fixer registered for stormy_chicken
[12:01:03] [Render thread/ERROR]: No data fixer registered for mottled_pig
[12:01:03] [Render thread/ERROR]: No data fixer registered for pale_pig
[12:01:03] [Render thread/ERROR]: No data fixer registered for piebald_pig
[12:01:03] [Render thread/ERROR]: No data fixer registered for pink_footed_pig
[12:01:03] [Render thread/ERROR]: No data fixer registered for sooty_pig
[12:01:03] [Render thread/ERROR]: No data fixer registered for spotted_pig
[12:01:03] [Render thread/ERROR]: No data fixer registered for bold_striped_rabbit
[12:01:03] [Render thread/ERROR]: No data fixer registered for freckled_rabbit
[12:01:03] [Render thread/ERROR]: No data fixer registered for harelequin_rabbit
[12:01:03] [Render thread/ERROR]: No data fixer registered for muddy_foot_rabbit
[12:01:03] [Render thread/ERROR]: No data fixer registered for vested_rabbit
[12:01:03] [Render thread/ERROR]: No data fixer registered for flecked_sheep
[12:01:03] [Render thread/ERROR]: No data fixer registered for fuzzy_sheep
[12:01:03] [Render thread/ERROR]: No data fixer registered for inky_sheep
[12:01:03] [Render thread/ERROR]: No data fixer registered for long_nosed_sheep
[12:01:03] [Render thread/ERROR]: No data fixer registered for patched_sheep
[12:01:03] [Render thread/ERROR]: No data fixer registered for rocky_sheep
[12:01:03] [Render thread/ERROR]: No data fixer registered for bone_shard
[12:01:03] [Render thread/ERROR]: No data fixer registered for bone_spider
[12:01:03] [Render thread/ERROR]: No data fixer registered for bouldering_zombie
[12:01:03] [Render thread/ERROR]: No data fixer registered for cluckshroom
[12:01:03] [Render thread/ERROR]: No data fixer registered for fancy_chicken
[12:01:03] [Render thread/ERROR]: No data fixer registered for furnace_golem
[12:01:03] [Render thread/ERROR]: No data fixer registered for horned_sheep
[12:01:03] [Render thread/ERROR]: No data fixer registered for jolly_llama
[12:01:03] [Render thread/ERROR]: No data fixer registered for jumbo_rabbit
[12:01:03] [Render thread/ERROR]: No data fixer registered for lobber_zombie
[12:01:03] [Render thread/ERROR]: No data fixer registered for melon_golem
[12:01:03] [Render thread/ERROR]: No data fixer registered for melon_seed_projectile
[12:01:03] [Render thread/ERROR]: No data fixer registered for moobloom
[12:01:03] [Render thread/ERROR]: No data fixer registered for moolip
[12:01:03] [Render thread/ERROR]: No data fixer registered for muddy_pig
[12:01:03] [Render thread/ERROR]: No data fixer registered for rainbow_sheep
[12:01:03] [Render thread/ERROR]: No data fixer registered for rotten_flesh_projectile
[12:01:03] [Render thread/ERROR]: No data fixer registered for skeleton_wolf
[12:01:03] [Render thread/ERROR]: No data fixer registered for tropical_slime
[12:01:03] [Render thread/ERROR]: No data fixer registered for umbra_cow
[12:01:03] [Render thread/ERROR]: No data fixer registered for viler_witch
[12:01:03] [Render thread/ERROR]: No data fixer registered for wooly_cow
[12:01:03] [Render thread/INFO]: [Earth2Java] Mod loaded! Enjoy :D
[12:01:03] [Render thread/INFO]: [bclib] Added Config edenring.blocks to auto sync (file hash)
[12:01:03] [Render thread/INFO]: [bclib] Added Config edenring.items to auto sync (file hash)
[12:01:03] [Render thread/INFO]: [bclib] Added Config edenring.entities to auto sync (file hash)
[12:01:03] [Render thread/INFO]: [bclib] Added Config edenring.recipes to auto sync (file hash)
[12:01:03] [Render thread/INFO]: [bclib] Added Config edenring.biomes to auto sync (file hash)
[12:01:03] [Render thread/ERROR]: Registry 'enhancedcelestials:lunar/event' was empty after loading
[12:01:03] [Render thread/ERROR]: Registry 'enhancedcelestials:lunar/dimension_settings' was empty after loading
[12:01:03] [Render thread/INFO]: Initializing enhancedcelestials network...
[12:01:03] [Render thread/INFO]: Initialized enhancedcelestials network!
[12:01:03] [Render thread/INFO]: Farmer's Knives loaded!
[12:01:04] [ForkJoinPool.commonPool-worker-1/INFO]: [Friends&Foes] An update is available! You're using 1.5.5 version but the latest version is 1.5.12!
[12:01:04] [Render thread/INFO]: Is initializing.
[12:01:04] [Render thread/INFO]: Has successfully been initialized.
[12:01:04] [Render thread/INFO]: If you have any issues or questions, feel free to join our Discord: https://discord.gg/vMjzgS4.
[12:01:04] [Render thread/ERROR]: No data fixer registered for silver_bomb
[12:01:04] [Render thread/ERROR]: Adding duplicate key 'ResourceKey[minecraft:worldgen/biome / galosphere:crystal_canyons]' to registry
[12:01:04] [Render thread/INFO]: Beginning More Geodes initialization
[12:01:04] [Render thread/INFO]: More Geodes initialized!
[12:01:04] [Render thread/ERROR]: com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 1 column 1 path $
[12:01:04] [Render thread/INFO]: Encountered an error while reading the-graveyard-1.19-config config, falling back to default values.
[12:01:04] [Render thread/INFO]: If this problem persists, delete the config file the-graveyard-1.19-config.json5 and try again.
[12:01:04] [Render thread/ERROR]: Failed to load config 'class com.ordana.immersive_weathering.config.ServerConfig', using default!
at com.ordana.immersive_weathering.ImmersiveWeathering.lambda$static$0(ImmersiveWeathering.java:33) ~[immersive_weathering-1.0.1-1.19.jar:?]
at net.minecraft.class_156.method_656(class_156.java:440) [client-intermediary.jar:?]
at com.ordana.immersive_weathering.ImmersiveWeathering.<clinit>(ImmersiveWeathering.java:32) [immersive_weathering-1.0.1-1.19.jar:?]
... 19 more
[12:01:04] [Render thread/ERROR]: No data fixer registered for falling_icicle
[12:01:04] [Render thread/ERROR]: No data fixer registered for falling_ash
[12:01:04] [Render thread/ERROR]: No data fixer registered for falling_sand_layer
[12:01:04] [Render thread/ERROR]: No data fixer registered for falling_leaf_layer
[12:01:04] [Render thread/ERROR]: No data fixer registered for falling_propagule
[12:01:04] [Render thread/INFO]: Mod initialized!
[12:01:04] [Render thread/INFO]: Initializing ServerSide Packet Registries
[12:01:04] [Render thread/INFO]: [KONKRETE] Successfully initialized!
[12:01:04] [Render thread/INFO]: [KONKRETE] Server-side libs ready to use!
[12:01:04] [Render thread/INFO]: Compression will use Java, encryption will use Java
[12:01:04] [Render thread/INFO]: Definitely not up to no good
[12:01:04] [Render thread/INFO]: near features initialized.
[12:01:04] [Render thread/INFO]: Let there be nears!
[12:01:04] [Render thread/INFO]: KONNICHIWA ZA WARUDO!
[12:01:04] [Render thread/INFO]: loading json file and contents for paintings.
[12:01:04] [Render thread/INFO]: Adding base paintings
[12:01:04] [Render thread/INFO]: resolving paintings.json ...
[12:01:04] [Render thread/INFO]: Loaded json painting abstract_blue , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting abstract_rainbow , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting abstract_red , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting abstract_sunset , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting arachnophobe , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting barn_owl , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting big_z , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting blue_bird , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting bluesclues , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting borgia , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting cane , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting cat_black , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting cat_gray , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting cat_orange , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting cat , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting colorful_squares , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting crest , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting danger_zone , 32 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting decorative_gun , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting exit_down , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting exit_up , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting exit_left , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting exit_right , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_bat , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_chicken , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_cow , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_creeper , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_dog , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_enderman , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_pig , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_pigman , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_silverfish , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_skeleton , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_squid , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting face_zombie , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting fishes , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting flowers , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting fruits , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting ghost , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting glowlamp , 32 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting glowstone_hourglass , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting iluvmc , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting link , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting mine_prosperity , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting no_trespassing_for_mobs , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting ocelot , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting penguin , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting pig_on_a_cliff , 32 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting pkmn_blue , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting pkmn_red , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting pkmn_green , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting plains_hut , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting portrait_2 , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting portrait , 32 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting prison , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting prosperity , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting rest , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting skeleton , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting sky , 32 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting skyblock , 32 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting snake , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting snow_landscape , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting subaraki , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting synth_city , 16 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting tapistry_a , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting tapistry_b , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting tapistry_purple , 16 x 32
[12:01:04] [Render thread/INFO]: Loaded json painting torched , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting waterfall , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting whale , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting wheat_field , 32 x 16
[12:01:04] [Render thread/INFO]: Loaded json painting wolf_in_wheat , 32 x 16
[12:01:04] [Render thread/INFO]: Reading out ResourcePacks to find painting related json files
[12:01:04] [Render thread/INFO]: Reading darkpack-v2.1.zip
[12:01:04] [Render thread/WARN]: ************************************
[12:01:04] [Render thread/ERROR]: Invalid ResourcePack darkpack-v2.1.zip
[12:01:04] [Render thread/ERROR]: Illegal character in path at index 66: file:/C:/Users/tykwe/curseforge/minecraft/Instances/Better%20MC%20[FABRIC]%201.19.2%20(1)/./resourcepacks/darkpack-v2.1.zip
[12:01:04] [Render thread/INFO]: Reading Default-Dark-Mode-1.19-v1.3.3.zip
[12:01:04] [Render thread/ERROR]: Invalid ResourcePack Default-Dark-Mode-1.19-v1.3.3.zip
[12:01:04] [Render thread/ERROR]: Illegal character in path at index 66: file:/C:/Users/tykwe/curseforge/minecraft/Instances/Better%20MC%20[FABRIC]%201.19.2%20(1)/./resourcepacks/Default-Dark-Mode-1.19-v1.3.3.zip
[12:01:04] [Render thread/INFO]: Reading Graphics
[12:01:04] [Render thread/ERROR]: Invalid ResourcePack Graphics
[12:01:04] [Render thread/ERROR]: Illegal character in path at index 66: file:/C:/Users/tykwe/curseforge/minecraft/Instances/Better%20MC%20[FABRIC]%201.19.2%20(1)/./resourcepacks/Graphics/
[12:01:04] [Render thread/INFO]: Reading NoBushyLeaves.zip
[12:01:04] [Render thread/ERROR]: Invalid ResourcePack NoBushyLeaves.zip
[12:01:04] [Render thread/ERROR]: Illegal character in path at index 66: file:/C:/Users/tykwe/curseforge/minecraft/Instances/Better%20MC%20[FABRIC]%201.19.2%20(1)/./resourcepacks/NoBushyLeaves.zip
[12:01:04] [Render thread/INFO]: Reading Ore Variants v2.4.zip
[12:01:04] [Render thread/ERROR]: Invalid ResourcePack Ore Variants v2.4.zip
[12:01:04] [Render thread/ERROR]: Illegal character in path at index 66: file:/C:/Users/tykwe/curseforge/minecraft/Instances/Better%20MC%20[FABRIC]%201.19.2%20(1)/./resourcepacks/Ore%20Variants%20v2.4.zip
[12:01:04] [Render thread/INFO]: Reading Stay_True_1.19.zip
[12:01:04] [Render thread/ERROR]: Invalid ResourcePack Stay_True_1.19.zip
[12:01:04] [Render thread/ERROR]: Illegal character in path at index 66: file:/C:/Users/tykwe/curseforge/minecraft/Instances/Better%20MC%20[FABRIC]%201.19.2%20(1)/./resourcepacks/Stay_True_1.19.zip
[12:01:04] [Render thread/INFO]: Reading Xaero's Minimap - Mod Icons.zip
[12:01:04] [Render thread/ERROR]: Invalid ResourcePack Xaero's Minimap - Mod Icons.zip
[12:01:04] [Render thread/ERROR]: Illegal character in path at index 66: file:/C:/Users/tykwe/curseforge/minecraft/Instances/Better%20MC%20[FABRIC]%201.19.2%20(1)/./resourcepacks/Xaero's%20Minimap%20-%20Mod%20Icons.zip
[12:01:04] [Render thread/INFO]: Reading xali-s-Enchanted-Books-16x-v0.10.1.zip
[12:01:04] [Render thread/ERROR]: Invalid ResourcePack xali-s-Enchanted-Books-16x-v0.10.1.zip
[12:01:04] [Render thread/ERROR]: Illegal character in path at index 66: file:/C:/Users/tykwe/curseforge/minecraft/Instances/Better%20MC%20[FABRIC]%201.19.2%20(1)/./resourcepacks/xali-s-Enchanted-Books-16x-v0.10.1.zip
[12:01:04] [Render thread/INFO]: Registered painting abstract_blue
[12:01:04] [Render thread/INFO]: Registered painting abstract_rainbow
[12:01:04] [Render thread/INFO]: Registered painting abstract_red
[12:01:04] [Render thread/INFO]: Registered painting abstract_sunset
[12:01:04] [Render thread/INFO]: Registered painting arachnophobe
[12:01:04] [Render thread/INFO]: Registered painting barn_owl
[12:01:04] [Render thread/INFO]: Registered painting big_z
[12:01:04] [Render thread/INFO]: Registered painting blue_bird
[12:01:04] [Render thread/INFO]: Registered painting bluesclues
[12:01:04] [Render thread/INFO]: Registered painting borgia
[12:01:04] [Render thread/INFO]: Registered painting cane
[12:01:04] [Render thread/INFO]: Registered painting cat_black
[12:01:04] [Render thread/INFO]: Registered painting cat_gray
[12:01:04] [Render thread/INFO]: Registered painting cat_orange
[12:01:04] [Render thread/INFO]: Registered painting colorful_squares
[12:01:04] [Render thread/INFO]: Registered painting crest
[12:01:04] [Render thread/INFO]: Registered painting danger_zone
[12:01:04] [Render thread/INFO]: Registered painting decorative_gun
[12:01:04] [Render thread/INFO]: Registered painting exit_down
[12:01:04] [Render thread/INFO]: Registered painting exit_up
[12:01:04] [Render thread/INFO]: Registered painting exit_left
[12:01:04] [Render thread/INFO]: Registered painting exit_right
[12:01:04] [Render thread/INFO]: Registered painting face_bat
[12:01:04] [Render thread/INFO]: Registered painting face_chicken
[12:01:04] [Render thread/INFO]: Registered painting face_cow
[12:01:04] [Render thread/INFO]: Registered painting face_creeper
[12:01:04] [Render thread/INFO]: Registered painting face_dog
[12:01:04] [Render thread/INFO]: Registered painting face_enderman
[12:01:04] [Render thread/INFO]: Registered painting face_pig
[12:01:04] [Render thread/INFO]: Registered painting face_pigman
[12:01:04] [Render thread/INFO]: Registered painting face_silverfish
[12:01:04] [Render thread/INFO]: Registered painting face_skeleton
[12:01:04] [Render thread/INFO]: Registered painting face_squid
[12:01:04] [Render thread/INFO]: Registered painting face_zombie
[12:01:04] [Render thread/INFO]: Registered painting fishes
[12:01:04] [Render thread/INFO]: Registered painting flowers
[12:01:04] [Render thread/INFO]: Registered painting fruits
[12:01:04] [Render thread/INFO]: Registered painting ghost
[12:01:04] [Render thread/INFO]: Registered painting glowlamp
[12:01:04] [Render thread/INFO]: Registered painting glowstone_hourglass
[12:01:04] [Render thread/INFO]: Registered painting iluvmc
[12:01:04] [Render thread/INFO]: Registered painting link
[12:01:04] [Render thread/INFO]: Registered painting mine_prosperity
[12:01:04] [Render thread/INFO]: Registered painting no_trespassing_for_mobs
[12:01:04] [Render thread/INFO]: Registered painting ocelot
[12:01:04] [Render thread/INFO]: Registered painting penguin
[12:01:04] [Render thread/INFO]: Registered painting pig_on_a_cliff
[12:01:04] [Render thread/INFO]: Registered painting pkmn_blue
[12:01:04] [Render thread/INFO]: Registered painting pkmn_red
[12:01:04] [Render thread/INFO]: Registered painting pkmn_green
[12:01:04] [Render thread/INFO]: Registered painting plains_hut
[12:01:04] [Render thread/INFO]: Registered painting portrait_2
[12:01:04] [Render thread/INFO]: Registered painting prison
[12:01:04] [Render thread/INFO]: Registered painting prosperity
[12:01:04] [Render thread/INFO]: Registered painting rest
[12:01:04] [Render thread/INFO]: Registered painting skeleton
[12:01:04] [Render thread/INFO]: Registered painting sky
[12:01:04] [Render thread/INFO]: Registered painting skyblock
[12:01:04] [Render thread/INFO]: Registered painting snake
[12:01:04] [Render thread/INFO]: Registered painting snow_landscape
[12:01:04] [Render thread/INFO]: Registered painting subaraki
[12:01:04] [Render thread/INFO]: Registered painting synth_city
[12:01:04] [Render thread/INFO]: Registered painting tapistry_a
[12:01:04] [Render thread/INFO]: Registered painting tapistry_b
[12:01:04] [Render thread/INFO]: Registered painting tapistry_purple
[12:01:04] [Render thread/INFO]: Registered painting torched
[12:01:04] [Render thread/INFO]: Registered painting waterfall
[12:01:04] [Render thread/INFO]: Registered painting whale
[12:01:04] [Render thread/INFO]: Registered painting wheat_field
[12:01:04] [Render thread/INFO]: Registered painting wolf_in_wheat
[12:01:05] [Render thread/INFO]: Initializing RightClickHarvest...
[12:01:05] [Render thread/INFO]: [jamlib] Registered config for rightclickharvest
[12:01:05] [Render thread/INFO]: [REI] Config loaded
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider AdornReiServer [adorn] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider DefaultPlugin [roughlyenoughitems] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider DefaultRuntimePlugin [roughlyenoughitems] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider AdornReiClient [adorn] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider AE2 [ae2] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider APPlugin [architects_palette] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider REIPlugin [betterend] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider CharmReiClientPlugin [charm] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider ExpandedDelightREI [expandeddelight] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider FarmersDelightModREI [farmersdelight] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider REIIntegration [ftblibrary] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider OxidizedREIPlugin [oxidized] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider DefaultClientPlugin [roughlyenoughitems] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider DefaultClientRuntimePlugin [roughlyenoughitems] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider REPClientPlugin [roughlyenoughprofessions] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider PluginEntry [roughlyenoughresources] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider REICompat [the_bumblezone] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider REIPlugin [toms_storage] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider ReiRecipeAction [wthit] for REIPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider AdornReiServer [adorn] for REIServerPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider DefaultPlugin [roughlyenoughitems] for REIServerPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider DefaultRuntimePlugin [roughlyenoughitems] for REIServerPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider FabricFluidAPISupportPlugin for REIServerPlugin
[12:01:05] [Render thread/INFO]: [REI] Registered plugin provider FabricFluidAPISupportPlugin for REIPlugin
[12:01:05] [Render thread/INFO]: [RER] RoughlyEnoughPacketSize? Possibly.
[12:01:05] [Render thread/INFO]: Setting up discord client
[12:01:05] [Render thread/INFO]: Trying to read config file...
[12:01:05] [Render thread/INFO]: A config file was found, loading it..
[12:01:05] [Render thread/INFO]: Successfully loaded config file.
[12:01:05] [pool-3-thread-1/ERROR]: Unable to connect to the discord client
com.jagrosh.discordipc.exceptions.NoDiscordClientException: null
at com.jagrosh.discordipc.entities.pipe.Pipe.openPipe(Pipe.java:113) ~[SimpleDiscordRichPresence-fabric-2.0.1-build.16+mc1.19.jar:?]
at com.jagrosh.discordipc.IPCClient.connect(IPCClient.java:118) ~[SimpleDiscordRichPresence-fabric-2.0.1-build.16+mc1.19.jar:?]
at com.sunekaer.sdrp.discord.RPClient.connectClient(RPClient.java:68) ~[SimpleDiscordRichPresence-fabric-2.0.1-build.16+mc1.19.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) [?:?]
at java.lang.Thread.run(Thread.java:833) [?:?]
[12:01:05] [Render thread/ERROR]: Failed to load config 'class net.thegrimsey.stoneholm.SHConfig', using default!
at net.thegrimsey.stoneholm.Stoneholm.onInitialize(Stoneholm.java:27) ~[stoneholm-1.4.4.jar:?]
... 12 more
[12:01:05] [Render thread/INFO]: [STDOUT]: thonkutil-capes-v1 Init
[12:01:05] [Render thread/INFO]: Config loaded
[12:01:05] [Render thread/INFO]: Tom's Storage Setup starting
[12:01:06] [Render thread/INFO]: Constructing common components for mod tradingpost
[12:01:06] [Render thread/INFO]: Initializing Twigs
[12:01:06] [Render thread/INFO]: Initialized Twigs (took 43ms)
[12:01:06] [Render thread/INFO]: Loading up Void Totem (Fabric)
[12:01:06] [Render thread/INFO]: Registering Mod Items for wardentools
[12:01:06] [Render thread/INFO]: Registering ModBlocks forwardentools
[12:01:06] [Render thread/INFO]: Loaded 5 Static Content files for wolveswitharmor:wolf_armor
[12:01:06] [Render thread/INFO]: Got request to register class com.sk89q.worldedit.fabric.FabricPlatform with WorldEdit [com.sk89q.worldedit.extension.platform.PlatformManager@3f3aac02]
[12:01:06] [Render thread/INFO]: WorldEdit for Fabric (version 7.2.11-beta-02+315c5d0) is loaded
[12:01:06] [Render thread/INFO]: [WTHIT] Registering plugin ae2:wthit at appeng.integration.modules.wthit.WthitModule
[12:01:06] [Render thread/INFO]: [WTHIT] Registering plugin betternether:global at org.betterx.betternether.integrations.wthit.WailaPlugin
[12:01:06] [Render thread/INFO]: [betternether] Registering Waila-/Wthit-Plugin.
[12:01:06] [Render thread/INFO]: [WTHIT] Registering plugin waila:core at mcp.mobius.waila.plugin.core.WailaCore
[12:01:06] [Render thread/INFO]: [WTHIT] Registering plugin waila:vanilla at mcp.mobius.waila.plugin.vanilla.WailaVanilla
[12:01:06] [Render thread/INFO]: [WTHIT] Plugin config reloaded
[12:01:06] [Render thread/ERROR]: Failed to load config 'class com.github.charlyb01.xpstorage.config.ModConfig', using default!
at com.github.charlyb01.xpstorage.Xpstorage.onInitialize(Xpstorage.java:19) ~[xp_storage-1.4.3+1.19.jar:?]
... 14 more
... 14 more
[12:01:06] [Render thread/WARN]: Configuration conflict: there is more than one oshi.architecture.properties file on the classpath
Welcher Launcher?
Im Threadtitel steht Forge aber im Log steht:
"Loading Minecraft 1.19 with Fabric Loader 0.14.9"
Bzw.
"Mod bcc uses the version fabric-2.0.1-build.15 which isn't compatible with Loader's extended semantic version format"
Über den Forge Launcher. Ist aber ein Fabric Modpack
