Partition nicht lesbar
Okt. 2005
eine meiner Partitionen ist nicht mehr lesbar: Power Quest liefert folgendes:
PowerQuest PartitionInfo 8.0 -- Windows NT/2000 Version
Date Generated: 10/04/05 13:30:01
Copyright (c)1994-2002, PowerQuest Corporation
Permission is granted for this utility to be freely copied so long
as it is not modified in any way. All other rights are reserved.
PowerQuest, makers of PartitionMagic(r), Drive Image(tm), and DriveCopy(tm), can be reached at:
Voice: 801-437-8900
Fax: 801-226-8941
Web site: http://www.powerquest.com/support/
E-mail: magic@powerquest.com
General System Information:
Total Physical Memory (bytes): 267,894,784
Used Physical Memory: (bytes): 56,262,656
Maximum Page File Size: (bytes): 648,867,840
Current Page File Size: (bytes): 42,897,408
Disk Geometry Information for Disk 1: 2432 Cylinders, 255 Heads, 63 Sectors/Track
System PartSect # Boot BCyl Head Sect FS ECyl Head Sect StartSect NumSects
0 0 80 0 1 1 07 509 254 63 63 8,193,087
0 1 00 510 1 1 0F 1023 254 63 8,193,213 30,876,867
Info: Begin C,H,S values were large drive placeholders.
Info: End C,H,S values were large drive placeholders.
Actual values are:
0 1 00 510 1 1 0F 2431 254 63 8193213 30876867
8,193,213 0 00 510 1 3 07 1023 254 63 8,193,215 30,876,865
Actual values are:
8193213 0 00 510 1 3 07 2431 254 63 8193215 30876865
Error #106: Partition didn't begin on head boundary.
ucBeginSector expected to be 1, not 3.
Partition Information for Disk 1: 19,077.2 Megabytes
Volume PartType Status Size MB PartSect # StartSect TotalSects
C: NTFS Pri,Boot 4,000.5 0 0 63 8,193,087
ExtendedX Pri 15,076.6 0 1 8,193,213 30,876,867
EPBR Log 15,076.6 None -- 8,193,213 30,876,867
D: NTFS Log 15,076.6 8,193,213 0 8,193,215 30,876,865
Error #114: Logical starting at 8193215 is not one head away from EPBR.
Boot Record for drive C: (Drive: 1, Starting sector: 63, Type: NTFS)
1. Jump: EB 52 90
2. OEM Name: NTFS
3. Bytes per Sector: 512
4. Sectors per Cluster: 8
5. Reserved Sectors: 0
6. Number of FATs: 0
7. Root Dir Entries: 0
8. Total Sectors: 0
9. Media Descriptor: 0xF8
10. Sectors per FAT: 0
11. Sectors per Track: 63 (0x3F)
12. Number of Heads: 255 (0xFF)
13. Hidden Sectors: 63 (0x3F)
14. Total Sectors (>32MB): 0 (0x0)
15. Unused: 0x80008000
16. Total NTFS Sectors: 8193086
17. MFT Start Cluster: 4
18. MFT Mirror Start Clust: 512067
19. Clusters per FRS: 246
20. Clusters per Index Blk: 1
21. Serial Number: 0xBAC0A7C6C0A786EB
22. Checksum: 0 (0x0)
23. Boot Signature: 0xAA55
Boot Record for drive D: (Drive: 1, Starting sector: 8,193,215, Type: NTFS)
1. Jump: EB 52 90
2. OEM Name: NTFS
8. Total Sectors: 0
16. Total NTFS Sectors: 30876864
18. MFT Mirror Start Clust: 524288
21. Serial Number: 0x3EE4A0C3B6F26FA4
Wie bekomme ich das nun wieder hin?
Danke im Voraus!!!
hier der screenshot von partinfo:
Lt. dem Screen ist in der letzte Zeile obere Fenster der Startsector 8193215 - richtig lauten müsste 8193276.
Setze mal den Screen von PtEdit bitte, im Ordner Utility bei PM zu finden.
