ok betriebssystem windows xp sp3
meine cpu auslastung is ohne das ich nur Firefox anhabe bei von 0-1% prozesse laufen 31
zugesicherter speicher 311MB weis nicht ob das genügend informationen sind hier nochmal die Dxdiag infos
Was nur komisch ist das sauviele ram controller da sind
System Information
Time of this report: 2/16/2009, 17:00:25
Machine name: BIE
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: German (Regional Setting: German)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Genuine Intel(R) CPU 2140 @ 1.60GHz (2 CPUs)
Memory: 3070MB RAM
Page File: 316MB used, 4639MB available
Windows Dir: C:\WINXP
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GT
Manufacturer: NVIDIA
Chip type: GeForce 8800 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0611&SUBSYS_200E107D&REV_A2
Display Memory: 512.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug und Play-Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.8120 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 12/25/2008 20:38:00, 6168960 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: nv4_mini.sys
Mini VDD Date: 12/25/2008 20:38:00, 6301344 bytes
Device Identifier: {D7B71E3E-4551-11CF-756C-050003C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0611
SubSys ID: 0x200E107D
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: C-Media Wave Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_13F6&DEV_0111&SUBSYS_A6501681&REV_10
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: cmaudio.sys
Driver Version: 5.12.0001.0643 (English)
Driver Attributes: Final Debug
WHQL Logo'd: Yes
Date and Size: 11/18/2002 12:21:40, 377358 bytes
Other Files:
Driver Provider: C-Media
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 17, 16
Static/Strm HW 3D Bufs: 17, 16
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINXP\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
C-Media Wave Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-Mapper [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401 [Emuliert], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Wireless Optical Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046A, 0x0053
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x10DE, 0x026D
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 13:00:00, 59520 bytes
| Driver: usbd.sys, 4/14/2008 13:00:00, 4736 bytes
+-+ USB-HID (Human Interface Device)
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidusb.sys, 4/14/2008 13:00:00, 10368 bytes
| | Driver: hidclass.sys, 4/14/2008 13:00:00, 36864 bytes
| | Driver: hidparse.sys, 4/14/2008 13:00:00, 24960 bytes
| | Driver: hid.dll, 4/14/2008 13:00:00, 20992 bytes
| +-+ HID-konformes Benutzersteuergerät
| | | Matching Device ID: hid_device_up:000c_u:0001
| | | Driver: hidserv.dll, 4/14/2008 07:52:12, 21504 bytes
| +-+ HID-konforme Maus
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 4/14/2008 13:00:00, 23552 bytes
| | | Driver: mouhid.sys, 4/14/2008 13:00:00, 12288 bytes
Gameport Devices
+ CMI8738/C3DX PCI Audio Device
| Matching Device ID: pci\ven_13f6&dev_0111&subsys_a6501681
| Service: cmpci
+-+ Standardgameport
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 4/13/2008 20:45:30, 10624 bytes
PS/2 Devices
+ Standardtastatur (101/102 Tasten) oder Microsoft Natural Keyboard (PS/2)
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 13:00:00, 52992 bytes
| Driver: kbdclass.sys, 4/14/2008 13:00:00, 25216 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 07:53:28, 40840 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: LAN-Verbindung 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 KBit/s
Voxware SC06 6,4 KBit/s
Voxware SC03 3,2 KBit/s
MS-PCM 64 KBit/s
MS-ADPCM 32,8 KBit/s
Microsoft GSM 6.10 13 KBit/s
TrueSpeech(TM) 8,6 KBit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 85.3 GB
Total Space: 150.0 GB
File System: NTFS
Model: WDC WD2000JS-00MHB0
Drive: D:
Free Space: 36.2 GB
Total Space: 40.8 GB
File System: NTFS
Drive: E:
Model: _NEC DVD_RW ND-4550A
Driver: c:\winxp\system32\drivers\cdrom.sys, 5.01.2600.5512 (German), 4/14/2008 13:00:00, 62976 bytes
Drive: F:
Model: ELBY CLONEDRIVE SCSI CdRom Device
System Devices
Name: JMicron JMB36X Controller
Device ID: PCI\VEN_197B&DEV_2360&SUBSYS_82081043&REV_02\4&268339C6&0&0038
Driver: C:\WINXP\system32\DRIVERS\jraid.sys, 1.17.0006.0003 (English), 10/30/2006 04:31:58, 43648 bytes
Driver: C:\WINXP\system32\DRIVERS\JGOGO.sys, 5.00.3790.0001 (English), 2/7/2006 12:52:58, 6912 bytes
Name: CMI8738/C3DX PCI Audio Device
Device ID: PCI\VEN_13F6&DEV_0111&SUBSYS_A6501681&REV_10\4&DC268A3&0&3080
Driver: n/a
Name: NVIDIA GeForce 8800 GT
Device ID: PCI\VEN_10DE&DEV_0611&SUBSYS_200E107D&REV_A2\4&63F8C69&0&0018
Driver: C:\WINXP\system32\DRIVERS\nv4_mini.sys, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 6301344 bytes
Driver: C:\WINXP\system32\nv4_disp.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 6168960 bytes
Driver: C:\WINXP\system32\nvsvc32.exe, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 163908 bytes
Driver: C:\WINXP\system32\nvapi.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 663552 bytes
Driver: C:\WINXP\system32\nvcuda.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 1560576 bytes
Driver: C:\WINXP\system32\nvoglnt.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 9412608 bytes
Driver: C:\WINXP\system32\nvcpl.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 13680640 bytes
Driver: C:\WINXP\system32\nvmctray.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 86016 bytes
Driver: C:\WINXP\system32\nvwddi.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 81920 bytes
Driver: C:\WINXP\system32\nvmccs.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 229376 bytes
Driver: C:\WINXP\system32\nvmccsrs.dll, 6.14.0011.8120 (German), 12/25/2008 20:38:00, 45056 bytes
Driver: C:\WINXP\system32\nvdisps.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 4710400 bytes
Driver: C:\WINXP\system32\nvdispsr.dll, 6.14.0011.8120 (German), 12/25/2008 20:38:00, 6594560 bytes
Driver: C:\WINXP\system32\nvgames.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 3489792 bytes
Driver: C:\WINXP\system32\nvgamesr.dll, 6.14.0011.8120 (German), 12/25/2008 20:38:00, 4280320 bytes
Driver: C:\WINXP\system32\nvmccss.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 188416 bytes
Driver: C:\WINXP\system32\nvmccssr.dll, 6.14.0011.8120 (German), 12/25/2008 20:38:00, 458752 bytes
Driver: C:\WINXP\system32\nvmobls.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 1286144 bytes
Driver: C:\WINXP\system32\nvmoblsr.dll, 6.14.0011.8120 (German), 12/25/2008 20:38:00, 2854912 bytes
Driver: C:\WINXP\system32\nvvitvs.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 3796992 bytes
Driver: C:\WINXP\system32\nvvitvsr.dll, 6.14.0011.8120 (German), 12/25/2008 20:38:00, 4280320 bytes
Driver: C:\WINXP\system32\nvwss.dll, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 2744320 bytes
Driver: C:\WINXP\system32\nvwssr.dll, 6.14.0011.8120 (German), 12/25/2008 20:38:00, 3026944 bytes
Driver: C:\WINXP\system32\NvPVEnc.ax, 6.14.0011.8120 (English), 12/25/2008 20:38:00, 1253376 bytes
Driver: C:\WINXP\help\nvcpl.hlp, 12/25/2008 20:38:00, 177897 bytes
Driver: C:\WINXP\help\nvwcplen.hlp, 12/25/2008 20:38:00, 55444 bytes
Driver: C:\WINXP\system32\nvcod.dll, 1.03.0006.0029 (English), 12/25/2008 20:38:00, 135168 bytes
Driver: C:\WINXP\system32\nvcodins.dll, 1.03.0006.0029 (English), 12/25/2008 20:38:00, 135168 bytes
Name: PCI Standard-RAM-Controller
Device ID: PCI\VEN_10DE&DEV_03BC&SUBSYS_00000000&REV_A1\3&2411E6FE&0&11
Driver: n/a
Name: PCI Standard-PCI-zu-PCI-Brücke
Device ID: PCI\VEN_10DE&DEV_03BB&SUBSYS_00000000&REV_A1\3&2411E6FE&0&38
Driver: C:\WINXP\system32\DRIVERS\pci.sys, 5.01.2600.5512 (German), 4/14/2008 13:00:00, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_03BA&SUBSYS_00000000&REV_A1\3&2411E6FE&0&12
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B7&SUBSYS_00000000&REV_A1\3&2411E6FE&0&18
Device ID: PCI\VEN_10DE&DEV_03B6&SUBSYS_00000000&REV_A1\3&2411E6FE&0&10
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B5&SUBSYS_00000000&REV_A1\3&2411E6FE&0&06
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B4&SUBSYS_00000000&REV_A1\3&2411E6FE&0&07
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B3&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0E
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B2&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0D
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B1&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0C
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B0&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0B
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AF&SUBSYS_00000000&REV_A1\3&2411E6FE&0&0A
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AE&SUBSYS_00000000&REV_A1\3&2411E6FE&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AD&SUBSYS_00000000&REV_A1\3&2411E6FE&0&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AC&SUBSYS_00000000&REV_A1\3&2411E6FE&0&01
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AB&SUBSYS_00000000&REV_A1\3&2411E6FE&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AA&SUBSYS_00000000&REV_A1\3&2411E6FE&0&02
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A9&SUBSYS_00000000&REV_A1\3&2411E6FE&0&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A8&SUBSYS_00000000&REV_A2\3&2411E6FE&0&05
Driver: n/a
Name: PCI Standard-Host-CPU-Brücke
Device ID: PCI\VEN_10DE&DEV_03A3&SUBSYS_00000000&REV_A2\3&2411E6FE&0&00
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0272&SUBSYS_81BC1043&REV_A3\3&2411E6FE&0&52
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0270&SUBSYS_81BC1043&REV_A2\3&2411E6FE&0&48
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_026F&SUBSYS_00000000&REV_A2\3&2411E6FE&0&80
Name: Standard erweiterter PCI-zu-USB universeller Hostcontroller
Device ID: PCI\VEN_10DE&DEV_026E&SUBSYS_81BC1043&REV_A3\3&2411E6FE&0&59
Driver: C:\WINXP\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 13:00:00, 30208 bytes
Driver: C:\WINXP\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 13:00:00, 143872 bytes
Driver: C:\WINXP\system32\usbui.dll, 5.01.2600.5512 (German), 4/14/2008 07:52:32, 77312 bytes
Driver: C:\WINXP\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 13:00:00, 59520 bytes
Driver: C:\WINXP\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 13:00:00, 7168 bytes
Name: Standard OpenHCD USB-Hostcontroller
Device ID: PCI\VEN_10DE&DEV_026D&SUBSYS_81BC1043&REV_A3\3&2411E6FE&0&58
Driver: C:\WINXP\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/14/2008 13:00:00, 17152 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0269&SUBSYS_82211043&REV_A3\3&2411E6FE&0&A0
Driver: C:\WINXP\system32\DRIVERS\nvnetbus.sys, 1.00.0000.5023 (English), 2/17/2006 12:28:32, 13056 bytes
Driver: C:\WINXP\system32\DRIVERS\nvnrm.sys, 1.00.0002.5023 (English), 2/17/2006 12:28:14, 305152 bytes
Driver: C:\WINXP\system32\DRIVERS\nvsnpu.sys, 1.00.0000.5023 (English), 2/17/2006 12:28:02, 222592 bytes
Driver: C:\WINXP\system32\bdco1.dll, 1.00.0000.0000 (English), 2/17/2006 12:26:58, 9728 bytes
Driver: C:\WINXP\system32\bdco1ins.dll, 1.00.0000.0000 (English), 2/17/2006 12:26:58, 9728 bytes
Driver: C:\WINXP\system32\nvconrm.dll, 1.00.0000.0035 (English), 12/21/2005 02:23:30, 35840 bytes
Name: NVIDIA nForce 430/410 Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_0267&SUBSYS_81BC1043&REV_A1\3&2411E6FE&0&78
Driver: C:\WINXP\system32\DRIVERS\nvata.sys, 5.10.2600.0666 (English), 4/24/2006 18:52:28, 100736 bytes
Driver: C:\WINXP\system32\idecoi.dll, 1.00.0000.0001 (English), 4/24/2006 18:52:30, 289792 bytes
Driver: C:\WINXP\system32\idecoiins.dll, 1.00.0000.0001 (English), 4/24/2006 18:52:30, 289792 bytes
Driver: C:\WINXP\system32\NVCOI.DLL, 1.00.0000.0035 (English), 4/14/2006 15:01:20, 35840 bytes
Device ID: PCI\VEN_10DE&DEV_0266&SUBSYS_81BC1043&REV_A1\3&2411E6FE&0&70
Device ID: PCI\VEN_10DE&DEV_0265&SUBSYS_81BC1043&REV_A1\3&2411E6FE&0&68
Driver: C:\WINXP\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (German), 4/14/2008 13:00:00, 24960 bytes
Driver: C:\WINXP\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 13:00:00, 96512 bytes
Driver: C:\WINXP\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (German), 4/14/2008 13:00:00, 3328 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0264&SUBSYS_81BC1043&REV_A3\3&2411E6FE&0&51
Driver: n/a
Name: PCI Standard-ISA-Brücke
Device ID: PCI\VEN_10DE&DEV_0260&SUBSYS_00000000&REV_A3\3&2411E6FE&0&50
Driver: C:\WINXP\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (German), 4/14/2008 13:00:00, 37632 bytes
