unser 2t PC stürzt schon seit Monaten ab.
Habe bis jetzt nur probiert das Betriebssystem neu zu installieren ( von XP auf Win8) doch auch dies hat keine Besserung gebracht.
Habe jetzt mit dem WinDebugger mal den Fehler probiert auszulesen, doch aus dies sagt mir nichts:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
THIS DUMP FILE IS PARTIALLY CORRUPT.
KdDebuggerDataBlock is not present or unreadable.
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to read PsLoadedModuleList
KdDebuggerData.KernBase < SystemRangeStart
Windows 8 Kernel Version 9200 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0x00000000`00000000 PsLoadedModuleList = 0xfffff802`280e7b00
Debug session time: Thu May 23 15:44:19.879 2013 (UTC + 2:00)
System Uptime: 1 days 21:30:27.588
Loading Kernel Symbols
GetContextState failed, 0xD0000147
CS descriptor lookup failed
Unable to get program counter
Unable to get current machine context, NTSTATUS 0xC0000147
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck EF, {fffffa80021d0940, 0, 0, 0}
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
| NT symbols are not available |
| reduced functionality |
unable to get nt!KiCurrentEtwBufferOffset
unable to get nt!KiCurrentEtwBufferBase
ReadControl failed - kernel symbols must be loaded first
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
Was kann ich nun tun? Was sagt der Fehler aus?
Machine Name:
