X.Org X Server 1.6.5
Release Date: 2009-10-11
X Protocol Version 11, Revision 0
Build Operating System: Linux_2.6.32.4-pclos2 PCLinuxOS
Current Operating System: Linux localhost.localdomain 2.6.33.5-pclos1.bfs #1 SMP PREEMPT Sun May 30 02:37:14 CDT 2010 i686
Build Date: 22 January 2010 05:01:40AM
Before reporting problems, check
http://pclinuxos.com
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 14 10:35:58 2010
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "layout1"
(**) |-->Screen "screen1" (0)
(**) | |-->Monitor "monitor1"
(**) | |-->Device "device1"
(**) Option "DontZap" "False"
(**) Option "AllowMouseOpenFail"
(==) Automatically adding devices
(==) Automatically enabling devices
(==) FontPath set to:
catalogue:/etc/X11/fontpath.d
(==) ModulePath set to "/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
(**) Extension "Composite" is disabled
(II) Cannot locate a core pointer device.
(II) Cannot locate a core keyboard device.
(II) The server relies on HAL to provide the list of input devices.
If no devices become available, reconfigure HAL or disable AllowEmptyInput.
(II) Loader magic: 0x1fbc0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 5.0
X.Org XInput driver : 4.0
X.Org Server Extension : 2.0
(II) Loader running on linux
(++) using VT number 8
(--) PCI:*(0:1:0:0) 1002:68be:1787:2287 ATI Technologies Inc rev 0, Mem @ 0xd0000000/268435456, 0xfdfc0000/131072, I/O @ 0x0000ee00/256, BIOS @ 0x????????/131072
(II) Open ACPI successful (/var/run/acpid.socket)
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "record" will be loaded by default.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri2" will be loaded by default.
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "v4l"
(II) Loading /usr/lib/xorg/modules/drivers//v4l_drv.so
(II) Module v4l: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 0.1.1
ABI class: X.Org Video Driver, version 5.0
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension Multi-Buffering
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/extra-modules//libglx.so
(II) Module glx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.4.0, module version = 1.0.0
(II) Loading extension GLX
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
dlopen: /usr/lib/xorg/modules/extensions//libdri.so: cannot open shared object file: No such file or directory
(EE) Failed to load /usr/lib/xorg/modules/extensions//libdri.so
(II) UnloadModule: "dri"
(EE) Failed to load module "dri" (loader failed, 7)
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions//libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 1.4.99.906, module version = 8.77.5
Module class: X.Org Video Driver
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(II) v4l driver for Video4Linux
(II) ATI Proprietary Linux Driver Version Identifier:8.77.5
(II) ATI Proprietary Linux Driver Release Identifier: 8.771
(II) ATI Proprietary Linux Driver Build Date: Aug 25 2010 21:37:50
(II) Primary Device is: PCI 01@00:00:0
(WW) Falling back to old probe method for v4l
(WW) Falling back to old probe method for fglrx
(II) Loading PCS database from /etc/ati/amdpcsdb
(--) Assigning device section with no busID to primary device
(--) Chipset Supported AMD Graphics Processor (0x68BE) found
(WW) fglrx: No matching Device section for instance (BusID PCI:0@0:17:0) found
(WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found
(II) AMD Video driver is running on a device belonging to a group targeted for this release
(II) AMD Video driver is signed
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x8f8ae58
(II) resource ranges after probing:
(II) fglrx(0): === [atiddxPreInit] === begin
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 0.1.0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "DPMS"
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB
(==) fglrx(0): Buffer Tiling is ON
(II) Reloading /usr/lib/xorg/modules/linux//libfglrxdrm.so
ukiDynamicMajor: found major device number 250
ukiOpenByBusid: Searching for BusID PCI:1:0:0
ukiOpenDevice: node name is /dev/ati/card0
ukiOpenDevice: open result is 10, (OK)
ukiOpenByBusid: ukiOpenMinor returns 10
ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
(==) fglrx(0): NoAccel = NO
(==) fglrx(0): ATI 2D Acceleration Architecture enabled
(--) fglrx(0): Chipset: "ATI Radeon HD 5700 Series " (Chipset = 0x68be)
(--) fglrx(0): (PciSubVendor = 0x1787, PciSubDevice = 0x2287)
(==) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xd0000000
(--) fglrx(0): MMIO registers at 0xfdfc0000
(--) fglrx(0): I/O port at 0x0000ee00
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) fglrx(0): AC Adapter is used
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 3.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
(II) fglrx(0): VESA VBE OEM Software Rev: 12.14
(II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: JUNIPER
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) fglrx(0): ATI Video BIOS revision 9 or later detected
(--) fglrx(0): Video RAM: 1048576 kByte, Type: GDDR5
(II) fglrx(0): PCIE card detected
(--) fglrx(0): Using per-process page tables (PPPT) as GART.
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) fglrx(0): Using adapter: 1:0.0.
(II) fglrx(0): [FB] MC range(MCFBBase = 0xf00000000, MCFBSize = 0x40000000)
(II) fglrx(0): Interrupt handler installed at IRQ 27.
(II) fglrx(0): RandR 1.2 support is enabled!
(II) fglrx(0): RandR 1.2 rotation support is enabled!
(==) fglrx(0): Center Mode is disabled
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(==) fglrx(0): Active stereo disabled
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) fglrx(0): Finished Initialize PPLIB!
(II) fglrx(0): Output DFP1 using monitor section monitor1
(II) fglrx(0): Output DFP2 has no monitor section
(II) fglrx(0): Output DFP3 has no monitor section
(II) fglrx(0): Output DFP4 has no monitor section
(II) fglrx(0): Output CRT1 has no monitor section
(II) fglrx(0): Output CRT2 has no monitor section
(II) fglrx(0): Connected Display0: DFP3
(II) fglrx(0): Display0 EDID data ---------------------------
(II) fglrx(0): Manufacturer: HSD Model: 2275 Serial#: 16843009
(II) fglrx(0): Year: 2010 Week: 13
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Digital Display Input
(II) fglrx(0): Max Image Size [cm]: horiz.: 52 vert.: 29
(II) fglrx(0): Gamma: 2.20
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off
(II) fglrx(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.647 redY: 0.334 greenX: 0.284 greenY: 0.607
(II) fglrx(0): blueX: 0.151 blueY: 0.071 whiteX: 0.313 whiteY: 0.329
(II) fglrx(0): Supported established timings:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): 1152x870@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported standard timings:
(II) fglrx(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) fglrx(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
(II) fglrx(0): Supported detailed timing:
(II) fglrx(0): clock: 148.5 MHz Image Size: 521 x 293 mm
(II) fglrx(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
(II) fglrx(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
(II) fglrx(0): Monitor name: Hanns.G HH241
(II) fglrx(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 82 kHz, PixClock max 170 MHz
(II) fglrx(0): Serial No: 013RL3XY03172
(II) fglrx(0): EDID (in hex):
(II) fglrx(0): 00ffffffffffff0022...
(II) fglrx(0): End of Display0 EDID data --------------------
(II) fglrx(0): Connected Display1: DFP4
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: BNQ Model: 76ac Serial#: 1745
(II) fglrx(0): Year: 2006 Week: 7
(II) fglrx(0): Max Image Size [cm]: horiz.: 38 vert.: 30
(II) fglrx(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
(II) fglrx(0): blueX: 0.149 blueY: 0.060 whiteX: 0.312 whiteY: 0.328
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) fglrx(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) fglrx(0): #2: hsize: 1280 vsize 1024 refresh: 72 vid: 35969
(II) fglrx(0): clock: 108.0 MHz Image Size: 376 x 301 mm
(II) fglrx(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
(II) fglrx(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
(II) fglrx(0): clock: 25.2 MHz Image Size: 376 x 301 mm
(II) fglrx(0): h_active: 640 h_sync: 656 h_sync_end 752 h_blank_end 800 h_border: 0
(II) fglrx(0): v_active: 350 v_sync: 387 v_sync_end 389 v_blanking: 449 v_border: 0
(II) fglrx(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 140 MHz
(II) fglrx(0): Monitor name: BenQ FP91V
(II) fglrx(0): 00ffffffffffff000...
(II) fglrx(0): End of Display1 EDID data --------------------
(II) fglrx(0): Output DFP1 disconnected
(II) fglrx(0): Output DFP2 disconnected
(II) fglrx(0): Output DFP3 connected
(II) fglrx(0): Output DFP4 connected
(II) fglrx(0): Output CRT1 disconnected
(II) fglrx(0): Output CRT2 disconnected
(II) fglrx(0): Using user preference for initial modes
(II) fglrx(0): Output DFP3 using initial mode 1920x1080
(II) fglrx(0): Output DFP4 using initial mode 1280x1024
(II) fglrx(0): DPI set to (96, 96)
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(II) fglrx(0): Eyefinity capable adapter detected.
(II) fglrx(0): Adapter ATI Radeon HD 5700 Series has 3 configurable heads and 2 displays connected.
(==) fglrx(0): PseudoColor visuals disabled
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(==) fglrx(0): NoDRI = NO
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing swlDriScreenInit
(II) fglrx(0): swlDriScreenInit for fglrx driver
ukiOpenDevice: open result is 16, (OK)
ukiOpenByBusid: ukiOpenMinor returns 16
(II) fglrx(0): [uki] DRM interface version 1.0
(II) fglrx(0): [uki] created "fglrx" driver at busid "PCI:1:0:0"
(II) fglrx(0): [uki] added 8192 byte SAREA at 0x2000
(II) fglrx(0): [uki] mapped SAREA 0x2000 to 0xb676b000
(II) fglrx(0): [uki] framebuffer handle = 0x3000
(II) fglrx(0): [uki] added 1 reserved context for kernel
(II) fglrx(0): swlDriScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0): Name: fglrx
(II) fglrx(0): Version: 8.77.5
(II) fglrx(0): Date: Aug 25 2010
(II) fglrx(0): Desc: ATI FireGL DRM kernel module
(II) fglrx(0): Kernel Module version matches driver.
(II) fglrx(0): Kernel Module Build Time Information:
(II) fglrx(0): Build-Kernel UTS_RELEASE: 2.6.33.5-pclos1.bfs
(II) fglrx(0): Build-Kernel MODVERSIONS: yes
(II) fglrx(0): Build-Kernel __SMP__: yes
(II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000
(II) fglrx(0): [uki] register handle = 0x00004000
(II) fglrx(0): DRI initialization successfull
(II) fglrx(0): FBADPhys: 0xf00000000 FBMappedSize: 0x010e0000
(II) fglrx(0): FBMM initialized for area (0,0)-(1920,2304)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1920,1920) (front color buffer - assumption)
(II) fglrx(0): Largest offscreen area available: 1920 x 384
(==) fglrx(0): Backing store disabled
(II) Loading extension FGLRXEXTENSION
(**) fglrx(0): DPMS enabled
(II) fglrx(0): Initialized in-driver Xinerama extension
(**) fglrx(0): Textured Video is enabled.
(II) LoadModule: "glesx"
(II) Loading /usr/lib/xorg/modules//glesx.so
(II) Module glesx: vendor="X.Org Foundation"
compiled for 1.4.99.906, module version = 1.0.0
(II) Loading extension GLESX
(II) fglrx(0): GLESX enableFlags = 592
(II) fglrx(0): GLESX is enabled
(II) fglrx(0): Acceleration enabled
(II) LoadModule: "amdxmm"
(II) Loading /usr/lib/xorg/modules//amdxmm.so
(II) Module amdxmm: vendor="X.Org Foundation"
(II) Loading extension AMDXVOPL
(II) fglrx(0): UVD2 feature is available
(II) fglrx(0): Composite extension is not loaded
(II) fglrx(0): X context handle = 0x1
(II) fglrx(0): [DRI] installation complete
(==) fglrx(0): Silken mouse enabled
(==) fglrx(0): Using HW cursor of display infrastructure!
(II) fglrx(0): Disabling in-server RandR and enabling in-driver RandR 1.2.
(--) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
ukiOpenDevice: open result is 17, (OK)
ukiOpenByBusid: ukiOpenMinor returns 17
(II) AIGLX: Loaded and initialized /usr/lib/dri/fglrx_dri.so
(II) GLX: Initialized DRI GL provider for screen 0
(II) fglrx(0): Enable the clock gating!
(II) fglrx(0): Setting screen physical size to 507 x 285
(II) config/hal: Adding input device Power Button
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input//evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 2.2.5
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 4.0
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event4"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "us"
(**) Option "xkb_options" "compose:rwin"
(II) config/hal: Adding input device HID 046a:0023
(**) HID 046a:0023: always reports core events
(**) HID 046a:0023: Device: "/dev/input/event2"
(II) HID 046a:0023: Found 1 mouse buttons
(II) HID 046a:0023: Found scroll wheel(s)
(II) HID 046a:0023: Found keys
(II) HID 046a:0023: Configuring as keyboard
(II) HID 046a:0023: Adding scrollwheel support
(**) HID 046a:0023: YAxisMapping: buttons 4 and 5
(**) HID 046a:0023: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "HID 046a:0023" (type: KEYBOARD)
(EE) HID 046a:0023: failed to initialize for relative axes.
(**) HID 046a:0023: Device: "/dev/input/event1"
(**) Power Button: Device: "/dev/input/event3"
(II) config/hal: Adding input device Logitech USB-PS/2 Optical Mouse
(**) Logitech USB-PS/2 Optical Mouse: always reports core events
(**) Logitech USB-PS/2 Optical Mouse: Device: "/dev/input/event0"
(II) Logitech USB-PS/2 Optical Mouse: Found 12 mouse buttons
(II) Logitech USB-PS/2 Optical Mouse: Found x and y relative axes
(II) Logitech USB-PS/2 Optical Mouse: Found scroll wheel(s)
(II) Logitech USB-PS/2 Optical Mouse: Configuring as mouse
(**) Logitech USB-PS/2 Optical Mouse: YAxisMapping: buttons 4 and 5
(**) Logitech USB-PS/2 Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "Logitech USB-PS/2 Optical Mouse" (type: MOUSE)
(**) Logitech USB-PS/2 Optical Mouse: (accel) keeping acceleration scheme 1
(**) Logitech USB-PS/2 Optical Mouse: (accel) filter chain progression: 2.00
(**) Logitech USB-PS/2 Optical Mouse: (accel) filter stage 0: 20.00 ms
(**) Logitech USB-PS/2 Optical Mouse: (accel) set acceleration profile 0
(II) Logitech USB-PS/2 Optical Mouse: initialized for relative axes.
(II) fglrx(0): Restoring Recent Mode via PCS is not supported in RANDR 1.2 capable environments
FreeType: couldn't find encoding 'iso8859-14' for '/etc/X11/fontpath.d/../../../usr/share/fonts/TTF/liberation/LiberationMono-Regular.ttf'
(II) fglrx(0): EDID vendor "BNQ", prod id 30380
(II) fglrx(0): Using hsync ranges from config file
(II) fglrx(0): Using vrefresh ranges from config file
(II) fglrx(0): Printing DDC gathered Modelines:
(II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) fglrx(0): Modeline "640x350"x0.0 25.17 640 656 752 800 350 387 389 449 +hsync -vsync (31.5 kHz)
(II) fglrx(0): Modeline "1280x1024"x72.0 132.75 1280 1368 1504 1728 1024 1025 1028 1067 -hsync +vsync (76.8 kHz)
