xxMuahdibxx
Fleet Admiral
- Juli 2011
TP555 schrieb:Wofür stand das Tx eigentlich in der Autoexec.bat ?
Bei mir stand der immer auf T6 !
BLASTER=Axxx Iy Dz Hv Pwww Ekkk Tq
with
xxx - I/O port address in hex, typically 220, 240 or 260.
y - IRQ typically 5 or 7.
z - DMA for 8 bit transfers, typically 1, 0, 3
v - DMA for 16 bit transfers, typically 5, 7
www - port for external MPU-401 and wavetable at the waveblaster connector, typically 330, 300.
kkk - port of the EMU8000 chipset when using an SB 32/AWE32/64 card, typically 620.
q - type of Sound Blaster card
1 - Sound Blaster 1.x (8 bit mono, 22 kHz) or compatible
2 - Sound Blaster Pro (8 bit stereo, 22 kHz) or compatible
3 - Sound Blaster 2.x (8 bit mono, 44.1 kHz) or compatible
4 - Sound Blaster Pro 2
5 - Sound Blaster Pro MCA
6 - Sound Blaster 16, also SB 32, AWE32/64, ViBRA.
10- Sound Blaster MCA
Aus der Seite die weiter oben schon verlinkt ist..
Mit T gibt man die Art der SB Karte an
