Ich bin leider komplett ratlos, warum meine pppoe verbindung nicht mehr geht. Sie ging gestern abend noch - jedoch seit dem nächtlichen neu einwählen kommt folgender Fehler beim Verbindungsaufbau:
Hat einer von euch ne Idee was das sein könnte - bzw wie man den Fehler finden kann?
Code:
May 7 17:20:18 localhost pppd[2310]: Serial connection established.
May 7 17:20:18 localhost pppd[2310]: Couldn't get channel number: Input/output error
May 7 17:20:48 localhost pppd[2310]: Serial connection established.
May 7 17:20:48 localhost pppd[2310]: Couldn't get channel number: Input/output error
May 7 17:21:18 localhost pppd[2310]: Serial connection established.
May 7 17:21:18 localhost pppd[2310]: Couldn't get channel number: Input/output error
May 7 17:21:48 localhost pppd[2310]: Serial connection established.
May 7 17:21:48 localhost pppd[2310]: Using interface ppp0
May 7 17:21:48 localhost pppd[2310]: Connect: ppp0 <--> /dev/pts/0
May 7 17:22:19 localhost pppd[2310]: LCP: timeout sending Config-Requests
May 7 17:22:19 localhost pppd[2310]: Connection terminated.
May 7 17:22:19 localhost pppd[2310]: tcflush failed: Input/output error
May 7 17:22:19 localhost pppd[2310]: Serial connection established.
May 7 17:22:19 localhost pppd[2310]: Couldn't get channel number: Input/output error
May 7 17:22:19 localhost pppd[2310]: Modem hangup
