smartctl 5.43 2012-06-30 r3573 [i686-w64-mingw32-win7(64)-sp1] (sf-5.43-1)
Copyright (C) 2002-12 by Bruce Allen,
http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model: HGST HDS724040ALE640
Serial Number: PK1334PBG3K7NP
LU WWN Device Id: 5 000cca 23dc19ddb
Firmware Version: MJAOA580
User Capacity: 4.000.787.030.016 bytes [4,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Sun Mar 01 16:49:43 2015 MZ
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 24) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 565) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 137 137 054 Pre-fail Offline - 77
3 Spin_Up_Time 0x0007 126 126 024 Pre-fail Always - 613 (Average 610)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 1227
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 119 119 020 Pre-fail Offline - 35
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 1418
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1211
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 1251
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 1251
194 Temperature_Celsius 0x0002 206 206 000 Old_age Always - 29 (Min/Max 15/52)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 397280
SMART Error Log Version: 1
ATA Error Count: 65535 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 65535 occurred at disk power-on lifetime: 1364 hours (56 days + 20 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
84 51 00 00 00 00 00
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
ec 00 00 00 00 00 00 00 00:00:07.630 IDENTIFY DEVICE
60 00 70 f2 73 e2 48 ff 00:00:07.598 READ FPDMA QUEUED
60 00 00 62 73 e2 40 00 00:00:07.560 READ FPDMA QUEUED
60 00 00 62 75 e2 40 00 00:00:07.557 READ FPDMA QUEUED
ec 00 00 00 00 00 00 00 00:00:07.534 IDENTIFY DEVICE
Error 65534 occurred at disk power-on lifetime: 1364 hours (56 days + 20 hours)
ec 00 00 00 00 00 00 00 00:00:06.638 IDENTIFY DEVICE
60 00 80 e2 76 e2 48 ff 00:00:06.605 READ FPDMA QUEUED
60 00 00 62 76 e2 40 00 00:00:06.566 READ FPDMA QUEUED
ec 00 00 00 00 00 00 00 00:00:06.543 IDENTIFY DEVICE
ef 10 02 00 00 00 00 00 00:00:06.532 SET FEATURES [Reserved for Serial ATA]
Error 65533 occurred at disk power-on lifetime: 1364 hours (56 days + 20 hours)
ec 00 00 00 00 00 00 00 00:00:02.613 IDENTIFY DEVICE
60 00 f0 72 65 e2 48 ff 00:00:02.580 READ FPDMA QUEUED
60 00 00 62 65 e2 40 00 00:00:02.546 READ FPDMA QUEUED
ec 00 00 00 00 00 00 00 00:00:02.534 IDENTIFY DEVICE
ef 10 02 00 00 00 00 00 00:00:02.523 SET FEATURES [Reserved for Serial ATA]
Error 65532 occurred at disk power-on lifetime: 1356 hours (56 days + 12 hours)
ec 00 00 00 00 00 00 00 00:00:11.611 IDENTIFY DEVICE
ef 10 02 00 00 00 00 00 00:00:11.600 SET FEATURES [Reserved for Serial ATA]
ec 00 00 00 00 00 00 00 00:00:11.567 IDENTIFY DEVICE
60 00 00 61 92 e2 48 ff 00:00:11.535 READ FPDMA QUEUED
60 00 00 62 91 e2 40 00 00:00:11.496 READ FPDMA QUEUED
Error 65531 occurred at disk power-on lifetime: 1356 hours (56 days + 12 hours)
ec 00 00 00 00 00 00 00 00:00:01.731 IDENTIFY DEVICE
ef 10 02 00 00 00 00 00 00:00:01.720 SET FEATURES [Reserved for Serial ATA]
ec 00 00 00 00 00 00 00 00:00:01.687 IDENTIFY DEVICE
60 22 02 20 00 00 40 ff 00:00:01.654 READ FPDMA QUEUED
60 22 00 00 00 00 40 00 00:00:01.598 READ FPDMA QUEUED
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 1418 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
