Andi07
Banned
- Aug. 2013
Hallo ihr Lieben, Hallo liebe SSD-Erfahrenen!
Vorsichts halber oder Interessen halber möchte ich mich bzgl. meiner Samsung SSD 840 Pro (512GB) informieren, ab welchem Wert ich mir Sorgen machen muss und an Ersatz denken sollte? Aktuell steht der Wert bei 139. Vielen Dank!
Gruß Andi
smartctl:
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-4.2.0-34-generic] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Samsung based SSDs
Device Model: Samsung SSD 840 PRO Series
Serial Number: XXXXXXXXXXXXXXX
LU WWN Device Id: 5 002538 5503ffea2
Firmware Version: DXM06B0Q
User Capacity: 512,110,190,592 bytes [512 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4c
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Mar 16 12:16:26 2016 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (53956) seconds.
capabilities: (0x53) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 35) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 8113
12 Power_Cycle_Count 0x0032 093 093 000 Old_age Always - 6870
177 Wear_Leveling_Count 0x0013 096 096 000 Pre-fail Always - 139
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0
181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 080 054 000 Old_age Always - 20
195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0
199 CRC_Error_Count 0x003e 097 097 000 Old_age Always - 2323
235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 2167
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 73515838350
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 5083 -
# 2 Short offline Completed without error 00% 5083 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
255 0 65535 Read_scanning was never started
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Zitat aus: http://blog.ip-projects.de/rootserver-festplatte-auf-fehler-pruefen/Wear_Leveling_Count
Dies ist ein Wert, der nur bei SSD Festplatten vorkommt. Er definiert die Anzahl der Löschvorgänge auf einem einzelnen Speicherblock. Ist dieser Wert sehr hoch, sollte ebenfalls ein Tausch der Festplatte vorgenommen werden.
Gruß Andi
smartctl:
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
