Suche nach arbeitsspeicher
Deep_House
Cadet 1st Year
Okt. 2012
Guten Tag,
Mein System
<http://www.cpuid.com>
Code:
*CPU-Z*
*Binaries*
CPU-Z version	1.60.1
*Processors*
Number of processors	1
Number of threads	4
*APICs*
Processor 0
     -- Core 0
         -- Thread 0	0
     -- Core 1
         -- Thread 0	1
     -- Core 2
         -- Thread 0	2
     -- Core 3
         -- Thread 0	3
*Processors Information*
Processor 1	ID = 0
     Number of cores	4 (max 4)
     Number of threads	4 (max 4)
     Name	AMD Phenom II X4 955
     Codename	Deneb
     Specification	AMD Phenom(tm) II X4 955 Processor
     Package 	Socket AM3 (938)
     CPUID	F.4.2
     Extended CPUID	10.4
     Brand ID	13
     Core Stepping	RB-C2
     Technology	45 nm
     TDP Limit	125 Watts
     Core Speed	800.0 MHz
     Multiplier x FSB	4.0 x 200.0 MHz
     HT Link speed	2000.0 MHz
     Stock frequency	3200 MHz
     Instructions sets	MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A,
x86-64, AMD-V
     L1 Data cache	4 x 64 KBytes, 2-way set associative, 64-byte line size
     L1 Instruction cache	4 x 64 KBytes, 2-way set associative, 64-byte
line size
     L2 cache	4 x 512 KBytes, 16-way set associative, 64-byte line size
     L3 cache	6 MBytes, 48-way set associative, 64-byte line size
     FID/VID Control	yes
     Min FID	4.0x
     # of P-States	4
     P-State	FID 0x10 - VID 0x10 - IDD 21 (16.00x - 1.350 V)
     P-State	FID 0x9 - VID 0x18 - IDD 15 (12.50x - 1.250 V)
     P-State	FID 0x5 - VID 0x20 - IDD 11 (10.50x - 1.150 V)
     P-State	FID 0x100 - VID 0x2E - IDD 5 (4.00x - 0.975 V)
     Package Type	0x1
     Model	55
     String 1	0x3
     String 2	0x6
     Page	0x0
     CmpCap	4
     ApicIdCoreSize	4
     TDC Limit	84 Amps
     Boosted P-States	0
     Max non-turbo ratio	16.00x
     Attached device	PCI device at bus 0, device 24, function 0
     Attached device	PCI device at bus 0, device 24, function 1
     Attached device	PCI device at bus 0, device 24, function 2
     Attached device	PCI device at bus 0, device 24, function 3
     Attached device	PCI device at bus 0, device 24, function 4
*Chipset*
Northbridge	AMD 785G rev. 00
Southbridge	AMD SB700 rev. 00
Graphic Interface	PCI-Express
PCI-E Link Width	x16
PCI-E Max Link Width	x16
Memory Type	DDR3
Memory Size	4096 MBytes
Channels	Dual, (Unganged)
Memory Frequency	666.7 MHz (3:10)
CAS# latency (CL)	9.0
RAS# to CAS# delay (tRCD)	9
RAS# Precharge (tRP)	9
Cycle Time (tRAS)	24
Bank Cycle Time (tRC)	33
Command Rate (CR)	1T
Uncore Frequency	2000.0 MHz
*Memory SPD*
DIMM #	1
     SMBus address	0x50
     Memory type	DDR3
     Module format	UDIMM
     Manufacturer (ID)	A-Data Technology (7F7F7F7FCB000000)
     Size	2048 MBytes
     Max bandwidth	PC3-10700 (667 MHz)
     Part number	DDR3 1333G
     Number of banks	8
     Nominal Voltage	1.50 Volts
     EPP	no
     XMP	no
JEDEC timings table	CL-tRCD-tRP-tRAS-tRC @ frequency
     JEDEC #1	6.0-6-6-17-23 @ 457 MHz
     JEDEC #2	7.0-7-7-20-27 @ 533 MHz
     JEDEC #3	8.0-8-8-22-30 @ 609 MHz
     JEDEC #4	9.0-9-9-25-34 @ 685 MHz
DIMM #	2
     SMBus address	0x51
     Memory type	DDR3
     Module format	UDIMM
     Size	2048 MBytes
     Number of banks	8
     EPP	no
     XMP	no
*Monitoring*
Mainboard Model	M4A785TD-V EVO (0x0000038B - 0xA759D28A)
*LPCIO*
LPCIO Vendor	ITE
LPCIO Model	IT8712
LPCIO Vendor ID	0x90
LPCIO Chip ID	0x8712
LPCIO Revision ID	0x8
*Hardware Monitors*
Hardware monitor	ITE IT87
     Voltage 0	1.31 Volts [0x52] (CPU VCORE)
     Voltage 2	3.33 Volts [0xD0] (+3.3V)
     Voltage 4	12.61 Volts [0xC5] (+12V)
     Voltage 5	-6.14 Volts [0x60] (-12V)
     Voltage 8	3.33 Volts [0xD0] (VBAT)
     Temperature 0	37°C (98°F) [0x25] (TMPIN0)
     Temperature 1	37°C (98°F) [0x25] (TMPIN1)
     Fan 0	1032 RPM [0x28E] (FANIN0)
     Fan 1	1291 RPM [0x20B] (FANIN1)
     Fan PWM 0	0 pc [0x0] (FANPWM0)
     Fan PWM 1	0 pc [0x0] (FANPWM1)
     Fan PWM 2	0 pc [0x0] (FANPWM2)
Hardware monitor	ATI I/O
     Temperature 0	53°C (127°F) [0x35] (TMPIN0)
Hardware monitor	AMD ADL
     Voltage 0	0.92 Volts [0x39A] (VIN0)
     Temperature 0	54°C (129°F) [0x36] (TMPIN0)
*PCI Devices*
Description	Host Bridge
Location	bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID	0x1022
     Model ID	0x9601
     Revision ID	0x00
Description	PCI to PCI Bridge
Location	bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
     Vendor ID	0x1022
     Model ID	0x9603
     Revision ID	0x00
Location	bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
     Vendor ID	0x1022
     Model ID	0x9609
     Revision ID	0x00
Description	IDE Controller
Location	bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
     Vendor ID	0x1002
     Model ID	0x4390
     Revision ID	0x00
Description	USB Controller (OHCI)
Location	bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
     Vendor ID	0x1002
     Model ID	0x4397
     Revision ID	0x00
Location	bus 0 (0x00), device 18 (0x12), function 1 (0x01)
Common header
     Vendor ID	0x1002
     Model ID	0x4398
     Revision ID	0x00
Description	USB 2.0 Controller (EHCI)
Location	bus 0 (0x00), device 18 (0x12), function 2 (0x02)
Common header
     Vendor ID	0x1002
     Model ID	0x4396
     Revision ID	0x00
Location	bus 0 (0x00), device 19 (0x13), function 0 (0x00)
Common header
     Vendor ID	0x1002
     Model ID	0x4397
     Revision ID	0x00
Location	bus 0 (0x00), device 19 (0x13), function 1 (0x01)
Common header
     Vendor ID	0x1002
     Model ID	0x4398
     Revision ID	0x00
Location	bus 0 (0x00), device 19 (0x13), function 2 (0x02)
Common header
     Vendor ID	0x1002
     Model ID	0x4396
     Revision ID	0x00
Description	SMBus Controller
Location	bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
     Vendor ID	0x1002
     Model ID	0x4385
     Revision ID	0x3C
Location	bus 0 (0x00), device 20 (0x14), function 1 (0x01)
Common header
     Vendor ID	0x1002
     Model ID	0x439C
     Revision ID	0x00
Description	Multimedia device
Location	bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
     Vendor ID	0x1002
     Model ID	0x4383
     Revision ID	0x00
Description	PCI to ISA Bridge
Location	bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
     Vendor ID	0x1002
     Model ID	0x439D
     Revision ID	0x00
Location	bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
     Vendor ID	0x1002
     Model ID	0x4384
     Revision ID	0x00
Location	bus 0 (0x00), device 20 (0x14), function 5 (0x05)
Common header
     Vendor ID	0x1002
     Model ID	0x4399
     Revision ID	0x00
Location	bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
     Vendor ID	0x1022
     Model ID	0x1200
     Revision ID	0x00
Location	bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
     Vendor ID	0x1022
     Model ID	0x1201
     Revision ID	0x00
Location	bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
     Vendor ID	0x1022
     Model ID	0x1202
     Revision ID	0x00
Location	bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
     Vendor ID	0x1022
     Model ID	0x1203
     Revision ID	0x00
Location	bus 0 (0x00), device 24 (0x18), function 4 (0x04)
Common header
     Vendor ID	0x1022
     Model ID	0x1204
     Revision ID	0x00
Description	VGA Controller
Location	bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID	0x1002
     Model ID	0x9460
     Revision ID	0x00
Location	bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
     Vendor ID	0x1002
     Model ID	0xAA30
     Revision ID	0x00
Description	Ethernet Controller
Location	bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID	0x10EC
     Model ID	0x8168
     Revision ID	0x03
Description	OHCI FireWire Controller
Location	bus 3 (0x03), device 8 (0x08), function 0 (0x00)
Common header
     Vendor ID	0x1106
     Model ID	0x3044
     Revision ID	0xC0
*DMI*
DMI BIOS
     vendor	American Megatrends Inc.
     version	0410
     date	09/10/2009
DMI System Information
     manufacturer	System manufacturer
     product	System Product Name
     version	System Version
     serial	System Serial Number
     UUID	{1E00C160-008C-2800-A5B5-002618D3F860}
DMI Baseboard
     vendor	ASUSTeK Computer INC.
     model	M4A785TD-V EVO
     revision	Rev X.0x
     serial	MT7097K04001573
DMI System Enclosure
     manufacturer	Chassis Manufacture
     chassis type	Desktop
     chassis serial	Chassis Serial Number
DMI Processor
     manufacturer	AMD
     model	AMD Phenom(tm) II X4 955 Processor
     clock speed	3200.0 MHz
     FSB speed	200.0 MHz
     multiplier	16.0x
DMI Port Connector
     designation	PS/2 KeyBoard (internal)
     designation	Keyboard (external)
     port type	Keyboard Port
     connector	PS/2
DMI Port Connector
     designation	USB12 (internal)
     designation	USB12 (external)
     port type	USB
     connector	Access Bus (USB)
DMI Port Connector
     designation	USB34 (internal)
     designation	USB34 (external)
     port type	USB
DMI Port Connector
     designation	LPT 1 (internal)
     designation	LPT 1 (external)
     port type	Parallel Port ECP/EPP
     connector	DB-25 male
DMI Port Connector
     designation	COM 1 (internal)
     designation	COM 1 (external)
     port type	Serial Port 16550A
     connector	DB-9 male
DMI Port Connector
     designation	LAN (internal)
     designation	LAN (external)
     port type	Network Port
     connector	RJ-45
DMI Port Connector
     designation	Audio_Line_In (internal)
     designation	Audio_Line_In (external)
     port type	Audio Port
     connector	Mini Jack (headphones)
DMI Port Connector
     designation	Audio_Line_Out (internal)
     designation	Audio_Line_Out (external)
DMI Port Connector
     designation	Audio_Mic_In (internal)
     designation	Audio_Mic_In (external)
DMI Port Connector
     designation	Audio_Center/Sub (internal)
     designation	Audio_Center/Sub (external)
DMI Port Connector
     designation	Audio_Rear (internal)
     designation	Audio_Rear (external)
DMI Port Connector
     designation	Audio_Side (internal)
     designation	Audio_Side (external)
DMI Port Connector
     designation	HDMI (internal)
     designation	HDMI port (external)
DMI Port Connector
     designation	DVI (internal)
     designation	DVI port (external)
DMI Port Connector
     designation	SPDIFO (internal)
     designation	SPDIFO (external)
DMI Port Connector
     designation	PRI IDE (internal)
     connector	On Board IDE
DMI Port Connector
     designation	SB_SATA1 (internal)
DMI Port Connector
     designation	SB_SATA2 (internal)
DMI Port Connector
     designation	SB_SATA3 (internal)
DMI Port Connector
     designation	ESATA (internal)
DMI Port Connector
     designation	SB_SATA5 (internal)
DMI Port Connector
     designation	SB_SATA6 (internal)
DMI Port Connector
     designation	CPU FAN (internal)
DMI Port Connector
     designation	CHA FAN (internal)
DMI Port Connector
     designation	PWR FAN (internal)
DMI Port Connector
     designation	USB56 (internal)
     port type	USB
DMI Port Connector
     designation	USB78 (internal)
     port type	USB
DMI Port Connector
     designation	USB910 (internal)
     port type	USB
DMI Port Connector
     designation	USB1112 (internal)
     port type	USB
DMI Port Connector
     designation	PANEL (internal)
DMI Port Connector
     designation	SPDIF OUT (internal)
DMI Port Connector
     designation	AAFP (internal)
DMI Port Connector
     designation	CD (internal)
     connector	On Board Sound Input From CD-ROM
DMI Port Connector
     designation	IE1394_1 (internal)
     port type	Firewire (IEEE P1394)
     connector	IEEE 1394
DMI Extension Slot
     designation	PCIE1X_1
     type	A5
     width	32 bits
     populated	no
DMI Extension Slot
     designation	PCIE16X_1
     type	A5
     width	32 bits
     populated	yes
DMI Extension Slot
     designation	PCI1
     type	PCI
     width	32 bits
     populated	no
DMI Extension Slot
     designation	PCI2
     type	PCI
     width	32 bits
     populated	no
DMI Extension Slot
     designation	PCI3
     type	PCI
     width	32 bits
     populated	no
DMI Extension Slot
     designation	PCIE16X_2
     type	A5
     width	32 bits
     populated	no
DMI OEM Strings
     string[0]	002618D3F860
     string[1]	To Be Filled By O.E.M.
     string[2]	To Be Filled By O.E.M.
     string[3]	To Be Filled By O.E.M.
DMI Physical Memory Array
     location	Motherboard
     usage	System Memory
     correction	None
     max capacity	16384 MBytes
     max# of devices	4
DMI Memory Device
     designation	DIMM0
     format	DIMM
     type	unknown
     total width	64 bits
     data width	64 bits
     size	2048 MBytes
DMI Memory Device
     designation	DIMM1
     format	DIMM
     type	unknown
     total width	64 bits
     data width	64 bits
     size	2048 MBytes
DMI Memory Device
     designation	DIMM2
     format	DIMM
     type	unknown
DMI Memory Device
     designation	DIMM3
     format	DIMM
     type	unknown
*Graphics*
Number of adapters	1
*Graphic APIs*
API	ATI I/O
API	ADL SDK
*Display Adapters*
Display adapter 0
     Name	Radeon HD 4890
     Codename	RV790
     Technology	55 nm
     Memory size	1024 MB
     Memory bus width	256 bits
     GPU ref clock	100000
     PCI device	bus 1 (0x1), device 0 (0x0), function 0 (0x0)
     Vendor ID	0x1002 (0x1787)
     Model ID	0x9460 (0x2282)
     Performance Level	0
*Software*
Windows Version	Microsoft Windows 7 (6.1) Ultimate Edition 64-bit
Service Pack 1 (Build 7601)
DirectX Version	11.0
Ich habe folgenden Arbeitsspeicher eingebaut:
4 GB DDR-RAM A-DATA XPG-G Kit PC-1333,CL8-8-8-24,1.65-1.85V, XPG-G Heatspreader,2x2GB (Gaming Series)
Wo finde ich exakt den selben? Könnt ihr mir ein Link geben? Wieviel mehr macht Sinn
2 oder 4 GB?
Beste Grüße !
hol dir einfach ein 8gb kit für unter 30 eur und verkauf deine alten wenn du keine weitere verwendung dafür hast
du könntest einfach 2x2 GB Ram eines anderen Herstellers reinstecken, natürlich mit den gleichen Spezifikationen
aber ich würd auch sagen, dass du dir am besten irendwelche billigen 8GB Teile kaufst
@XxIcemanxX
Warum sollte beim Aufrüsten bitte kein Dualchannel mehr gehen?
@Deep_House
Günstigen Kingston oder ähnliches rein, die laufen fast immer solange die Daten möglichst gleich sind, wobei du auch 1333MHz CL9 kaufen kannst, musst nur schauen ob das dein Speicher bei 1,5V packt.
Eine Möglichkeit wären auch 2x2GB drin lassen und noch mal 2x4GB oder ähnliches einbauen, je nach dem wie viel Speicher du brauchst, wie viel du brauchst musst du aber schon selber wissen.
Kauf dir ein 4GB Modul oder gleich ein 2x4B Kit und steck das oder den einfach dazu.
Irgendeines mit 1333MHz CL9 1.5V
Das kann dein ja RAM auch.
da du 2x2 GB verbaut hast... wenn du nachrüstest läuft dein RAM nicht mehr im Dual-Channel Modus
Aha?
Wenn man ein sagen wir 2x4 GB DDR3 RAM Kit eingebaut hat in den dafür vorgesehenden Slots laufen die ja im Dual Channel Modus aber wenn man noch sagen wir mal 2 GB dazupackt dann nicht mehr ? Oder liege ich hier gerade völlig falsch ?
Was hat dein Beispiel mit deiner Aussage von vorhin zu tun?
Da ging es doch um 4x2GB, oder?
Aber auch 4GB+4GB+2GB laufen im Dual-Channel.
Bei AMD reicht es aus daß beide Kanäle bestückt sind. Egal wie.
Hab hier erst 1GB+2GB+4GB+8GB gestestet. Läuft im Dual-Channel.
Ich meinte das zweite Beispiel von dir, wurde wohl falsch verstanden, das das erste Beispiel im Dual Channel Modus läuft ist klar.
Das zweite Beispiel von dir wäre mir neu ??? Unterstützt dein Mainboard zufällig den sogenannten Flex Modus ? Dann kann es schon sein das es funktioniert ?
Flex Mod ist von Intel, bei AMD gibt es ganged/unganged, einfach mal in die Suche tippen.
Geht übrigens schon seit ziemlich langer Zeit egal ob Intel oder AMD, gibt eigentlich schon seit Jahren keine Bretter mehr wo das nicht können, den TE sein Kombi kann es auf jeden Fall.
Wirklich ? Ist wohl komplett an mir vorbei gegangen . . . . Danke für die Aufklärung. Man lernt eben nie aus. :)
