Hi, I have a trekstore surfbook w1 and it does not see a keyboard or a mouse. Boots into windows 10 but cannot use anything, no keyboard or mouse working. How to get into bios and how to reinstall windows 10?
Power On and Press F2: Turn it on and press F2 repeatedly to enter the BIOS.
Reinstall Windows 10:
Create a Bootable USB:
Use another computer to download the Windows 10 Media Creation Tool from Microsoft.
Create a bootable USB drive.
Boot from USB:
Insert the USB into your Surfbook.
Enter BIOS (F2) and set USB as the primary boot device.
Save and exit BIOS.
Install Windows:
Follow on-screen instructions to install Windows 10.
Additional Tips:
External Keyboard/Mouse: Try using an external USB keyboard/mouse.
Reset BIOS: In BIOS, reset to default settings.
Additionally, you can test your keyboard and mouse functionality on keyboardkeytest.com. This website is a great resource to ensure your input devices are working correctly.
