Viele offene Fragen zu XMrig,
Chesterfield
Fleet Admiral
Sep. 2011
halloI,
kennt sich jemand mit XMrig aus ?
wann und wie findet die Auszahlung ( welcher Zeitdauer) auf das Wallet statt?
muss ich was bei meiner config beachten?
"api": {
"id": null,
"worker-id": null
"http": {
"enabled": false,
"host": "127.0.0.1",
"port": 0,
"access-token": null,
"restricted": true
"autosave": true,
"background": false,
"colors": true,
"title": true,
"randomx": {
"init": -1,
"init-avx2": -1,
"mode": "auto",
"1gb-pages": false,
"rdmsr": true,
"wrmsr": true,
"cache_qos": false,
"numa": true,
"scratchpad_prefetch_mode": 1
"cpu": {
"enabled": true,
"huge-pages": true,
"huge-pages-jit": false,
"hw-aes": null,
"priority": null,
"memory-pool": false,
"yield": true,
"asm": true,
"argon2-impl": null,
"astrobwt-max-size": 550,
"astrobwt-avx2": true,
"argon2": [0, 2, 4, 6, 5, 7],
"astrobwt": [0, 1, 2, 3, 4, 5, 6, 7],
"astrobwt/v2": [0, 1, 2, 3, 4, 5, 6, 7],
"cn": [
[1, 0],
[1, 2],
[1, 4]
"cn-heavy": [
[1, 0],
[1, 2]
"cn-lite": [
[1, 0],
[1, 2],
[1, 4],
[1, 6],
[1, 5],
[1, 7]
"cn-pico": [
[2, 0],
[2, 1],
[2, 2],
[2, 3],
[2, 4],
[2, 5],
[2, 6],
[2, 7]
"cn/upx2": [
[2, 0],
[2, 1],
[2, 2],
[2, 3],
[2, 4],
[2, 5],
[2, 6],
[2, 7]
"ghostrider": [
[8, 0],
[8, 2],
[8, 4]
"rx": [0, 2, 4, 6],
"rx/arq": [0, 1, 2, 3, 4, 5, 6, 7],
"rx/wow": [0, 2, 4, 6, 5, 7],
"cn-lite/0": false,
"cn/0": false,
"rx/keva": "rx/wow"
"opencl": {
"enabled": false,
"cache": true,
"loader": null,
"platform": "AMD",
"adl": true,
"cn-lite/0": false,
"cn/0": false
"cuda": {
"enabled": false,
"loader": null,
"nvml": true,
"cn-lite/0": false,
"cn/0": false
"log-file": null,
"donate-level": 0,
"donate-over-proxy": 0,
"pools": [
"algo": null,
"coin": null,
"url": "donate.v2.xmrig.com:3333",
"user": "HIER STEHT MEINE wallet adresse von freeWallet",
"pass": "x",
"rig-id": null,
"nicehash": false,
"keepalive": false,
"enabled": true,
"tls": false,
"wss": false,
"tls-fingerprint": null,
"daemon": false,
"socks5": null,
"self-select": null,
"submit-to-origin": false
"retries": 5,
"retry-pause": 5,
"print-time": 60,
"health-print-time": 60,
"dmi": true,
"syslog": false,
"tls": {
"enabled": false,
"protocols": null,
"cert": null,
"cert_key": null,
"ciphers": null,
"ciphersuites": null,
"dhparam": null
"dns": {
"ipv6": false,
"ttl": 30
"user-agent": null,
"verbose": 0,
"watch": true,
"pause-on-battery": false,
"pause-on-active": false
ACHTUNG: Rentabilität ist keine Diskussion, geht lediglich um einen "Versuch"
Ist XMrig nicht nur der Miner? Die Auszahlung übernimmt doch dein Pool, oder liege ich da komplett falsch? Solo mining ist heutzutage fast nicht mehr rentabel und wann du wie viele coins erhältst, hängt vom coin ab, ist aber in der Regel ein rechenleistungsabhängiges Glücksspiel.
Orientiere dich mal hier: https://www.getmonero.org/de/resources/user-guides/mine-to-pool.html. Das ist zwar explizit Monero, aber vielleicht gibt es ähnliche Pages ja für deine Zielwährung. Die haben ziemlich genau deine Fragen beantwortet.
Und pack die Config mal in einen Spoiler, es ist etwas müßig so viel scrollen zu müssen.
Reaktionen: menace_one und Chesterfield
Kommt drauf an was du machen willst. Xmrig ist nur die Software zum Minen. In der Regel schließt man sich einem miningpool an. Je nach Pool gibt es die Auszahlung meist erst ab einer bestimmten Menge an Choins.
Reaktionen: Chesterfield
XMRig bekommt vom pool Deiner Wahl Aufträge, welche Deine CPU abarbeitet.
Es ist relevant, ob Du linux benutzt oder Windows (oder was anderes). Weil es da Unterschiede gibt was "Huge pages" bzw. "1GB Pages" angeht. Zur XMRig config gibt es ein manual, wo genau das beschrieben wird inkl. Tutorial, aber das musst Du selbst suchen, ich habe das nicht gebookmarked.
Dann musst Du schauen, wie viele Threads Deine CPU hat und wie viele davon für das Minung benutzt werden sollen. Bei zu vielen wird wohl oder übel das System instabil (offensichtlich braucht Dein System minimum 1 Thread).
Dann musst Du die Schwierigkeit wählen (diff, siehe manual) bzw. Du benutzt einen genau Deiner CPU zugeschnittenem Preset.
Dann brauchst Du eine XMR Wallet Adresse xyz, wohin der pool das dann irgendwann, wenn Du den minimalen threshold erreicht hast transferiert, das kann locker einen Monat dauern, wenn nicht noch länger je nach CPU. Diese xyz gibst Du bei beispielsweise der Webpräsenz des Mining-pools an oder wie auch immer der pool mit Dir das klärt.
Weiterhin und auch ganz wichtig solltest Du die Kühlung Deiner CPU gewährleisten. Zum Beobachten kannst Du HWiNFO64 nutzen und Anfangs vielleicht auch gleich loggen.
Und Du musst stets online sein, für die Kommunikation zwischen pool und XMRig.
