[29.07.2011 09:21:07 30c] INFO: Beginning execution from folder: X:\sources
[29.07.2011 09:21:07 30c] Failed to wait for PnP devices some drives and devices may not be visibile
[29.07.2011 09:21:07 30c] INFO: Found Configuration File E:\cfg.ini
[29.07.2011 09:21:07 30c] INFO: Setup Running in Unnatended Mode from cfg file
[29.07.2011 09:21:07 30c] starting unattend mode
[29.07.2011 09:21:07 30c] INFO: Setup Collecting User Data -------------------------------------------
[29.07.2011 09:21:07 30c] INFO: Getting configuration for DefaultLanguage
[29.07.2011 09:21:07 30c] INFO: Getting configuration for DefaultKeyboard
[29.07.2011 09:21:07 30c] INFO: Skipping optional configuration, no value specified
[29.07.2011 09:21:07 30c] INFO: Getting configuration for DefaultLocale
[29.07.2011 09:21:07 30c] INFO: Getting configuration for DefaultTimeZone
[29.07.2011 09:21:07 30c] INFO: Getting configuration for DefaultServerName
[29.07.2011 09:21:07 30c] WARNING: Unable to verify computer name availability due to network error 2136
[29.07.2011 09:21:07 30c] INFO: Getting configuration for Drivers
[29.07.2011 09:21:07 30c] INFO: Getting configuration for InstallDisk
[29.07.2011 09:21:24 30c] Disk 849c5a64-8257-409e-a239-413973ea2579
[29.07.2011 09:21:24 30c] Name: \\?\PhysicalDrive0
[29.07.2011 09:21:24 30c] Friendly Name:
[29.07.2011 09:21:24 30c] Address: Port0Path0Target1Lun0
[29.07.2011 09:21:24 30c] Device path: \\?\ide#diskintel_ssdsa2m040g2gc____________________2cv102m3#5&24b7107&0&0.1.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
[29.07.2011 09:21:24 30c] Adaptor: ATA Channel 0
[29.07.2011 09:21:24 30c] Status: ONLINE
[29.07.2011 09:21:24 30c] Health: HEALTHY
[29.07.2011 09:21:24 30c] Device type: DISK
[29.07.2011 09:21:24 30c] Media type: 0x0000000c
[29.07.2011 09:21:24 30c] Size: 40020664320
[29.07.2011 09:21:24 30c] Bytes per sector: 512
[29.07.2011 09:21:24 30c] Sectors per track: 63
[29.07.2011 09:21:24 30c] Tracks per cylinder: 255
[29.07.2011 09:21:24 30c] Flags: 0x00005000
[29.07.2011 09:21:24 30c] Bus type: VDSBusTypeAta
[29.07.2011 09:21:24 30c] Partition style: MBR
[29.07.2011 09:21:24 30c] Signature: 0xf0260044
[29.07.2011 09:21:24 30c] Extent 0 type 0x00007fff size 32256 offset 0
[29.07.2011 09:21:24 30c] Extent 1 type 0x00000001 size 1016320 offset 32256
[29.07.2011 09:21:24 30c] Extent 2 type 0x00000002 size 104857600 offset 1048576
[29.07.2011 09:21:24 30c] Extent 3 type 0x00000002 size 39912996864 offset 105906176
[29.07.2011 09:21:24 30c] Extent 4 type 0x00000001 size 712704 offset 40018903040
[29.07.2011 09:21:24 30c] Pack (null) status 0x00000001 flags 0x00000000
[29.07.2011 09:21:24 30c] [Online]
[29.07.2011 09:21:24 30c] Disk 276ad8f2-9b86-4312-a0c3-c6dab4733b59
[29.07.2011 09:21:24 30c] Name: \\?\PhysicalDrive1
[29.07.2011 09:21:24 30c] Device path: \\?\usbstor#disk&ven_&prod_usb_disk_3.0&rev_pmap#07ba0f077ced114b&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
[29.07.2011 09:21:24 30c] Adaptor: USB DISK 3.0
[29.07.2011 09:21:24 30c] Media type: 0x0000000b
[29.07.2011 09:21:24 30c] Size: 7914651648
[29.07.2011 09:21:24 30c] Flags: 0x00001000
[29.07.2011 09:21:24 30c] Bus type: VDSBusTypeUsb
[29.07.2011 09:21:24 30c] Signature: 0x00000000
[29.07.2011 09:21:24 30c] Extent 1 type 0x00007fff size 1016320 offset 32256
[29.07.2011 09:21:24 30c] Extent 2 type 0x00000002 size 7913603072 offset 1048576
[29.07.2011 09:21:24 30c] INFO: BIOS requested boot disk is \Device\Harddisk0\Partition0
[29.07.2011 09:21:24 30c] INFO: Getting configuration for SystemPartitionType
[29.07.2011 09:21:24 30c] INFO: Populating internal setting from existing data
[29.07.2011 09:21:24 30c] INFO: MBR firmware detected
[29.07.2011 09:21:24 30c] INFO: GetFirmwareEnvironmentVariableW indicated required partition type 1 (Status: 1)
[29.07.2011 09:21:24 30c] INFO: Getting configuration for SystemPartitionActive
[29.07.2011 09:21:24 30c] INFO: Getting configuration for SystemPartitionFormat
[29.07.2011 09:21:24 30c] INFO: Getting configuration for MSRPartitionType
[29.07.2011 09:21:24 30c] INFO: Getting configuration for WindowsPartitionID
[29.07.2011 09:21:24 30c] INFO: Getting configuration for WindowsPartitionSize
[29.07.2011 09:21:24 30c] INFO: Calculated pre system partition remaining space as: 39914758144
[29.07.2011 09:21:24 30c] ERROR: Specified partition size is too large to support a data partition, maximum possible is: 27825 MB (Alternatively, use MAX to span the whole disk)
[29.07.2011 09:21:24 30c] ERROR: The value chosen for this setting is invalid
[TRACE] UIBackend::Launch : Exited (0x80004005)
[29.07.2011 09:21:24 30c] There was an error launching unattended setup.
[29.07.2011 09:21:24 30c] Getting the reason for the failure.
[29.07.2011 09:21:24 30c] Failed gathering data provided via the unattend file
[29.07.2011 09:21:24 30c] starting the ui mode to show the error page since there was a failed attempt to run in unattended mode
[29.07.2011 09:21:24 30c] Initializing common controls
[29.07.2011 09:21:24 30c] Done initializing common controls
[29.07.2011 09:21:24 30c] Displaying the wizard
