Zalman FX100
ak_1
Aug. 2011
hey Leute,
Ich weiß hier giebt es dutzende Beträge für den Zalman FX100 ,mich würde aber interessieren weil ich ein Gamer Pc habe ob er mir dabei wenn ich den drauf habe auf dem MOB abkackt
mein System
sorry wenn die Liste lang ist
Mein Tower: CoolerMaster Silencio 550 Midi tower
CPU-Z
Binaries
CPU-Z version 1.67.1.x64
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.436 MHz
Sys timer 1.000 KHz
BCLK timer 100.51 MHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 3770K
Codename Ivy Bridge
Specification Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1/L1
Technology 22 nm
TDP Limit 77 Watts
Tjmax 105.0 °C
Core Speed 1608.2 MHz
Multiplier x Bus Speed 16.0 x 100.5 MHz
Stock frequency 3500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 35x
Max turbo ratio 39x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins unlimited
Ratio 1 core 39x
Ratio 2 cores 39x
Ratio 3 cores 39x
Ratio 4 cores 39x
TSC 3518.3 MHz
APERF 3920.4 MHz
MPERF 3518.3 MHz
Chipset
Northbridge Intel Ivy Bridge rev. 09
Southbridge Intel Z77 rev. 04
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 8 GBytes
Channels Dual
Memory Frequency 804.1 MHz (1:6)
CAS# latency (CL) 11.0
RAS# to CAS# delay (tRCD) 11
RAS# Precharge (tRP) 11
Cycle Time (tRAS) 29
Command Rate (CR) 1T
Memory SPD
DIMM # 1
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 4096 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number CMZ8GX3M2A1600C9
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.2
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-23 @ 444 MHz
JEDEC #2 7.0-7-7-19-27 @ 518 MHz
JEDEC #3 8.0-8-8-22-30 @ 592 MHz
JEDEC #4 9.0-9-9-24-34 @ 666 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.500 Volts
Min Cycle time 1.250 ns (800 MHz)
Max CL 9.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-6-6-16-27-2T @ 533 MHz (1.500 Volts)
XMP #2 9.0-9-9-24-41-2T @ 800 MHz (1.500 Volts)
DIMM # 2
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
AMP no
Max CL 9.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
Monitoring
Mainboard Model Z77 MPower (MS-7751) (0x00000554 - 0xA5BE49F4)
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71889A
LPCIO Vendor ID 0x1934
LPCIO Chip ID 0x1005
Hardware Monitors
Hardware monitor Fintek F71889A
Voltage 0 3.28 Volts [0xCD] (+3.3V)
Voltage 1 0.86 Volts [0x6C] (CPU VCORE)
Voltage 3 1.40 Volts [0x77] (VIN3)
Voltage 4 5.68 Volts [0x87] (+5V)
Voltage 5 8.98 Volts [0x66] (+12V)
Voltage 6 2.08 Volts [0x82] (VIN6)
Voltage 7 3.31 Volts [0xCF] (VSB3V)
Voltage 8 3.30 Volts [0xCE] (VBAT)
Temperature 0 36°C (96°F) [0x24] (TMPIN0)
Temperature 2 31°C (87°F) [0x1F] (TMPIN2)
Fan 0 4451 RPM [0x151] (FANIN0)
Fan 1 540 RPM [0xAD9] (FANIN1)
Fan 2 537 RPM [0xAE9] (FANIN2)
Fan PWM 0 67 pc [0xAC] (CPU)
Fan PWM 1 65 pc [0xA6] (System Fan 1)
Fan PWM 2 65 pc [0xA6] (System Fan 2)
Hardware monitor ACPI
Temperature 0 28°C (82°F) [0xBC2] (TZ00)
Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.99 Volts [0x3DB] (VIN0)
Temperature 0 35°C (95°F) [0x23] (TMPIN0)
Fan 0 1680 RPM [0x690] (FANIN0)
Fan PWM 0 38 pc [0x26] (FANPWMIN0)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0150
Revision ID 0x09
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0151
Revision ID 0x09
Description USB Controller
Location bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1E31
Revision ID 0x04
Description Communication Device
Location bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1E3A
Revision ID 0x04
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1E2D
Revision ID 0x04
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1E20
Revision ID 0x04
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1E10
Revision ID 0xC4
Location bus 0 (0x00), device 28 (0x1C), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x1E12
Revision ID 0xC4
Location bus 0 (0x00), device 28 (0x1C), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x1E1E
Revision ID 0xC4
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1E26
Revision ID 0x04
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1E44
Revision ID 0x04
Description Serial ATA Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x1E02
Revision ID 0x04
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x1E22
Revision ID 0x04
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x1180
Revision ID 0xA1
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0E0A
Revision ID 0xA1
Description Ethernet Controller
Location bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x06
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1912
Model ID 0x0014
Revision ID 0x03
DMI
DMI BIOS
vendor American Megatrends Inc.
version V17.9
date 06/05/2013
ROM size 8192 KB
DMI System Information
manufacturer MSI
product MS-7751
version 4.0
serial To be filled by O.E.M.
UUID {AAAAAAAA-AAAA-AAAA-AAAA-D43D7E9A16C5}
SKU To be filled by O.E.M.
family To be filled by O.E.M.
DMI Baseboard
vendor MSI
model Z77 MPower (MS-7751)
revision 4.0
DMI System Enclosure
manufacturer MSI
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Port Connector
designation J1A1 (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation J2A2A (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation J3A1 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation J5A1 (internal)
designation LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation J9A1 - TPM HDR (internal)
DMI Port Connector
designation J9C1 - PCIE DOCKING CONN (internal)
DMI Port Connector
designation J2B3 - CPU FAN (internal)
DMI Port Connector
designation J9E2 - MDC INTPSR (internal)
DMI Port Connector
designation J9E4 - MDC INTPSR (internal)
DMI Port Connector
designation J9E1 - SCAN MATRIX (internal)
DMI Port Connector
designation J9G1 - LPC SIDE BAND (internal)
DMI Port Connector
designation J8F1 - UNIFIED (internal)
DMI Port Connector
designation J1G6 - AC JACK (internal)
DMI Port Connector
designation J1G7 - BATT B (internal)
DMI Port Connector
designation J1H1 - BATT A (internal)
DMI Port Connector
designation J7H2 - SATA PWR (internal)
DMI Port Connector
designation J7H1 - SATA PORT2 (internal)
DMI Port Connector
designation J7J3 - SATA PORT1 (internal)
DMI Port Connector
designation J8J1 - SATA PORT0 (internal)
DMI Port Connector
designation J4J1 - ATX PWR (internal)
DMI Extension Slot
designation J6B2
type A5
populated no
DMI Extension Slot
designation J6B1
type A5
populated yes
DMI Extension Slot
designation J6D1
type A5
populated no
DMI Extension Slot
designation J7B1
type A5
populated no
DMI Extension Slot
designation J8B4
type A5
populated no
DMI Extension Slot
designation J8D1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation J8B3
type PCI
width 32 bits
populated yes
DMI OEM Strings
string[0] To Be Filled By O.E.M.
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 32768 MBytes
max# of devices 4
DMI Processor
manufacturer Intel(R) Corporation
model Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
clock speed 3500.0 MHz
FSB speed 100.0 MHz
multiplier 35.0x
DMI Memory Device
designation ChannelA-DIMM0
format DIMM
type unknown
DMI Memory Device
designation ChannelA-DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 4096 MBytes
DMI Memory Device
designation ChannelB-DIMM0
format DIMM
type unknown
DMI Memory Device
designation ChannelB-DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 4096 MBytes
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX 680
Revision A2
Codename GK104
Technology 28 nm
Memory size 2 GB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1458)
Model ID 0x1180 (0x353C)
Performance Level 0
Core clock 324.0 MHz
Memory clock 324.0 MHz
Win32_VideoController AdapterRAM = 0x80000000 (2147483648)
Win32_VideoController DriverVersion = 9.18.13.3182
Win32_VideoController DriverDate = 11/11/2013
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit (Build 7600)
DirectX Version 11.0
MFG
Meine Frage ist es wie oben beschreiben ob ich unter Vollast mein I7 unter spiele nicht das rauchen anfängt habe hinten ein lüfter der die luft raus und vorne rein 2x
Und die helfen dir nicht weiter?
Was bitte möchtest du uns sagen oder fragen? Formulier den Satz bitte mal in anständigem Deutsch.
mein System
Aha, und du verlangst jetzt, dass wir die 583245823 Zeilen nach den wichtigen Infos durchforsten? Nene, schreib die Infos mal übersichtlich zusammen oder mach nen Screenshot.
So wird das nichts!
Du solltest dir mal echt angewöhnen vernüftgie Sätze zu schreiben die man auch versteht.
Wenn du eine ordentlich Gehäusebelüftung hast könnte der Kühler funktionieren. Wenn du ihn allerdings noch nicht hast, dann kauf dir besser:
http://geizhals.at/de/thermalright-hr-02-macho-rev-a-bw-a830474.html
oder
http://geizhals.at/de/be-quiet-dark-rock-pro-2-bk017-a770313.html
Vor allem wenn du übertakten möchtest.
edit: habe gerade dein Gehäuse gesehen. In dem würde ich diesen Kühler definitiv nicht verwenden.
Google weiß die Lösung:
1. Gehäuse: Link
Schau dir die gegebenen Daten bei der Maximalhöhe des CPU Kühlers an.
2. Kühler: Link
Schau dir die Abmessungen des Kühlers an.
3. Komme selbstständig zu einer Schlussfolgerung.
4. Schau dir deine Schreibweise an, und komme zum Schluss, dass das eindeutig besser formuliert werden kann, was du auch in Zukunft berücksichtigst. Und bitte, hier gibt es Spoiler Tags, da kannst du den ganzen Log prima reinquetschen, ohne dass er ständig nervt.
PS: einen i7 passiv zu kühlen ist in der Regel nicht sonderlich sinnvoll
ich habe ein H60
wollte bloß wissen ob es sinn macht
ok habe es kapiert passt nicht rein ,schade
