Laut Videocarz wurden zum ersten mal die genauen Spezifikationen von Coffeelake geleaked.
https://videocardz.com/71307/intel-core-i7-8700k-i7-8700-i5-8600k-i5-8400-specs-emerge
"There are in total four 6-core Coffee Lake processors. Intel is supposedly planning to compete in multi-core mid-range market, currently occupied by AMD. The CPUs have 5 different clock speeds, which go up as fewer cores are in use. The highest boost clock for single-threaded operations is 4.7 GHz.
According to the leak, there are at least two parts with TDP at 95W and two parts with 65W."
Mit insgesamt 12 Threads und diesen hohen Taktraten, würden dann auch alle Ryzen 8 Kerner was Anwendungen angeht, leistungsmäßig angegriffen, wenn nicht überholt.
