12900K and Rtx 4090 low usage on Far Cry 6
sew333
Juli 2017
Hi. I have 12900K stock
32 GB 2x16 GB DDR4 3600mhz
Palit Gamerock Pro OC rtx 4090
1300W Seasonic Platinum Prime
Aorus Elite DDR4 Z690
Windows 11 2H22. Updated new nvidia drivers.
I swapped from 3090 Ti Gigabyte Gaming to Rtx 4090 Palit Gamerock.
I have an question about Far Cry 6. So on 3090 ti on 1440P,DXR ON i had 80-90% gpu usage.
On Rtx 4090 Palit i have now 60% usage and fps is the same like on 3090 ti.
I compare my fps with someone with 12900K and 4090 and he have 80-85% usage. So why i have 60% usage? The same cpu 12900K.
Link, look he have 80% usage.
Easy task. You were in CPU-Limit with your 3090 allready, you`re still in CPU-limit with your 4090.
To Compare with a different PC, video here, you must have exactly the same settings -in every little detail.
Reaktionen: eigsi124 und lazsniper
i have 12900k too
sew333 schrieb:
12900K stock
Did you enable XMP for the RAM?
You're in a CPU Limit. The video you linked has the CPU overclocked and much faster RAM, so their CPU can push higher framerate than yours.
GPU usage <99% means you're in a CPU Limit (or have enabled a framerate cap/limit). So look at your CPU and RAM, those are likely configured differently than the system in the video.
Reaktionen: Fuchiii
I already told you - different settings. Maybe ingame, maybe another (higher) RAM-Speed.
Also he could have less background task while you have 100 windows opened.
You could also have an framelimiter on.
There can be multiple reasons. You got the fps you want? Then theres noproblem.
(im not at home,so i cant watch the vid) but @Powl_0 told the reasons...
Reaktionen: Powl_0
What kind of framerates are you getting in the game?
Also he could have less bakcground task while you have 100 windows opened.
Hey thx for reply. Also i have VSYNC OFF,the same game settings.
90-120fps
So dont worry my pc running ok? Despite that someoone with 12900K have 80% usage on rtx 4090. I have 60% usage.
i have 12900k too
It literally doesn't matter. There are multiple possible factors at hand and there would be no benefit to figure out why he has a slightly higher GPU usage. Evidently, your FPS staying the same when switching to a better GPU means you are in a CPU Limit. You can switch to 4k and possibly have the same FPS or maybe try to increase graphical fidelity (settings/downsampling). Do you have high-res textures installed?
Reaktionen: Zwirbelkatz
But someone with DDR5 and 12900K and 4090, and 60% he have,usage like me. Weird
Oh no, DDR5 boosts Fry Cry Performance alot !
Means more workload for the 4090
The other guys 4090 Runs slower, hence the usage is higher :-)
I suggest changing to next higher Resolution Monitor (Time for 4k Display) and/or usage of DLDSR for More gpu usage, because this seems to be the Most horribly problem there Is.
You might want to consider going for a 13700k.
Plus maybe tighten the Ram timings.
I am gettin issue on TAIGA lvl on 1440P,all ultra,RT ULTRA, no DLSS. In taiga in camps i have dips to 50% gpu usage. I
It's not v-sync or any kind of throttling/bottleneck.
Someone said:"
12900 ks @ 5.4 ghz / 5.12 ring ( E cores off ! )
shuit your e cores off in bios the effcient cores they slow down alot of cpu bound games
i can pull over 250 fps in that level on ultra .
can u posta screen shot of the map and the exact spot your in wit ha scree nshot with the fps on screen and ill go the that spot and com pare show your exact video settings so i can reproduce it .
win 10 latest
12900 ks delided / relided @ 5.4 ghz all core / 5.1 ring cache
E cores off
32gb ddr4 @ 4133 mhz cl -15-15-15-35 gear 1 heavilty tightned timings
rtx 4090 gigabyte oc @ stock clocks 2790 mhz @ 0.975 v under volt
1000w psu not gen 3
1440p @ 270 hz 0.5 ms"
So is this sense to disable e cores on win11?
So, usage is a PROBLEM?
Where is the Problem again? 250 FPS is to few?
I suggest again to crank the Image-Quality up.
Its not a hardware-Problem you have.
I have it in my hands.
If you have 250 fps, and the GPU is only 50% load, than you have a CPU, which can not produce a higher framerate (CPU-Limit/Bottleneck) or you are unable to find the right settings for higher image Quality (User-Limit/Bottleneck).
If you have no bottleneck, than you should have infinite FPS.
Ups .. impossible?
So there must be a bottleneck.
Its as easy as this.
not me that 250 fps. That person who said about e cores he getting 250 fps
And you have seen this? Or is this person just telling stories?
And Enabling Legacy-Modus in Bios and Press "Scroll/Lock" to disable e-cores on the fly ingame to verify takes up to 2 Minutes.
Can you pls run the FC6-Benchmark and post a Screen.
If you want to verify your whole System because of GENERAL Faulty building please post:
Screen from GPU-Z when rendertest is running
Screen from CPU-Z Memory-Tab
Screen from HWinfo Overview-Window
i dont see this. He only told me. But i have win 11 , so disabling e cores wont help?
Takes you two Minutes to verify.
If you have a UEFI with Legacy-Modus for e-Cores. Enable it. Than you can enable/disable e-Cores INGAME by pressing Scroll/Lock.
If you do not have. Just disable ecores in Bios. Takes no time. Makes you knowing more.
I will look it up too. But takes time, I have to finish a F@H WU before.
