3D Mark - AMD Phenom II 720
GW1nner
Nov. 2007
3D Mark 06
Windows 7 Professional 64-bit
1. Testsystem
AMD Phenom II 720 BE
Cooler:Xigmatek HDT-S1284
Heat-conductive paste:Zalman ZM-STG1
MSI GeForce 9800GT OC 512MB
Driver:195.62
Gigabyte GA-MA720-US3 nForce 720D
-----and-----
Gigabyte GA-MA720-UD3 AMD 770
OCZ DDR2 PC2-6400 SLI-Ready Edition 2x2GB
Corsair 550 Watt Netzteil
2.1 AMD 770 Chipsatz
2.1.1 CPU standard clock
------2.1.1.1 Configuration
-------------AMD Phenom II 720 BE 3x2,8 Ghz--------------------(Voltage by 4.325)
-------------MSI GeForce 9800 GT-----------------------------------(660 Core and 950 Memory bus)
-------------OCZ DDR2 PC2-6400 SLI-Ready Edition 2x2GB----(800Mhz, Timings 5-4-4)
------2.1.1.2 Result
-------------3DMarks-------------------------------12512
-------------SM 2.0 Score---------------------------5493
-------------SM 3.0 Score---------------------------5603
-------------CPU Score------------------------------3219
2.1.2 CPU overclocked
------2.1.2.1 Configuration
-------------AMD Phenom II 720 BE 3x3,6 Ghz--------------------(Voltage by 5.000)
------2.1.2.2 Result
-------------3DMarks-------------------------------13754
-------------SM 2.0 Score-------------------------- 6039
-------------SM 3.0 Score-------------------------- 5680
-------------CPU Score----------------------------- 4087
2.2 NVidia 720D Chipsatz
2.2.1 CPU standard clock
------2.2.1.1 Configuration
------2.2.1.2 Result
-------------3DMarks------------------------------------12512
-------------SM 2.0 Score--------------------------------5493
-------------SM 3.0 Score--------------------------------5603
-------------CPU Score-----------------------------------3219
2.2.2 CPU overclocked
------2.2.2.1 Configuration
-------------AMD Phenom II 720 BE 3x3,6 Ghz--------------------(Voltage by 5.250)
------2.2.2.2 Result
-------------3DMarks------------------------------------13909
-------------SM 2.0 Score--------------------------------6063
-------------SM 3.0 Score--------------------------------5690
-------------CPU Score-----------------------------------4273
und was soll das jetzt bringen ? ich schätze mal keiner will wissen wie ein dual core auf oc wirkt .
aber wende willst bekommst nen kecks
hast du gut gemacht
hatt bestimmt auch pass gemacht immer den bench anzuschaun ^^
Dass der Aussagegehalt vom 3Dmark nicht so besonders ist wurde mittlerweile ja schon öfters diskutiert.
Vielleicht hättest du einen praxisnäheren Benchmark nehmen können :)
Immerhin, die Werte sind schön aufbereitet und übersichtlich präsentiert.
Hast du den 3Dmark jeweils nur 1x durchlaufen lassen, oder Mittelwerte gebildet? Es wundert mich nämlich, dass "CPU+GPU overclocked" schneller ist als die Summe von "GPU overclocked" und "CPU overclocked ".
ich finde es gut, dass Du dich so schön engagierst. Leider haben die Vorredner völllig recht.
Da Du uns auch nicht mit irgendwelchen Schlüssen kommst, sondern nur Deine vom Prinzip bereits Millionen mal durchgekauten Ergebnisse postes ist es auch sehr schwer etwas damit anzufangen.
Wir wissen ja nichtmal worauf der Post abzielt.
Fazit: Setzen! Sechs.
Die Ergebnisse wurden anhand von zwei loops jeweils getestet und dem sich daraus ergebenden Durchschnitt. Abweichungen sind natürlich, wie zu sehen, auch da.
Die Werte sollte man niemals genau nehmen.
Ausserdem gilt dieser Test den jenigen, die eines der verbauten Teile auch kaufen wollen.
Mehr dient der test der Orientierung und vllt auch der Kaufberatung.
Keineswegs ist es etwas, was neue Erkenntisse belegen soll.
Anhand der Statistik soll ein potenzieller Käufer selbst entscheiden, für was er sich entscheidet.
Mit welcher Auflösung und AF hast du getestet?
Um so höher du diese Einstellungen und Details einstellst, umso weniger Auswirkung wird die CPU haben.
Mit dem Standard.
-1280x1024
-Kein AA
-Filtering "Optimal"
Habe mir grad überlegt den Bench zu erweitern mit mehreren Treiber Versionen von NVIDIA und etwas höheren Taktraten der CPU, ich komme dann ans Limit meiner CPU warscheinlich.
naja, an deiner stelle würd ich mir die arbeit sparen, immerhin hat deine jetzige arbeit mal eindeutig gezeigt, dass 3dmark06 in standardsettings, wie er in allen offiziellen tests verwendet wird, eindeutig cpu limitiert ist. aber da hörts dann auch schon auf.
habe mir so eben das Gegenstück zum Gigabyte GA-MA720-US3 nForce 720D gekauft, unzwar den GA-MA770 UD3 mit einem ATI Chipsatz.
Es kommt ein Vergleich beider Boards.
added
Macht den Thread auch net besser :D ;)
