OK... Danke
Ich hab noch nicht im Abgesicherten Modus geguckt.
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini041110-04.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
WARNING: Whitespace at start of path element
Symbol search path is: SRV*c:\symbols*
http://msdl.microsoft.com/download/symbols
Executable search path is: c:\windows\System32; c:\windows\system\System32;
http://www.alexander.com/SymServe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 2600.xpsp_sp2_rtm.040803-2158
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805531a0
Debug session time: Sun Apr 11 20:52:59.828 2010 (GMT+2)
System Uptime: 0 days 3:41:03.441
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000007E, {c0000005, 804eddf5, b89d9c0c, b89d9908}
*** ERROR: Module load completed but symbols could not be loaded for SynMini.sys
Probably caused by : SynCamd.sys ( SynCamd!USBCAMD_CallUSBD+95 )
Followup: MachineOwner
kd> imv
^ Syntax error in 'imv'
kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 804eddf5, The address that the exception occurred at
Arg3: b89d9c0c, Exception Record Address
Arg4: b89d9908, Context Record Address
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in "0x%08lx" verweist auf Speicher in "0x%08lx". Der Vorgang "%s" konnte nicht auf dem Speicher durchgef hrt werden.
FAULTING_IP:
nt!IopfCallDriver+2d
804eddf5 ff548638 call dword ptr [esi+eax*4+38h]
EXCEPTION_RECORD: b89d9c0c -- (.exr 0xffffffffb89d9c0c)
ExceptionAddress: 804eddf5 (nt!IopfCallDriver+0x0000002d)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 00000000
Parameter[1]: 00000074
Attempt to read from address 00000074
CONTEXT: b89d9908 -- (.cxr 0xffffffffb89d9908)
eax=0000000f ebx=8623c848 ecx=849f62e0 edx=8623c848 esi=00000000 edi=00000000
eip=804eddf5 esp=b89d9cd4 ebp=b89d9d0c iopl=0 nv up ei ng nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010286
nt!IopfCallDriver+0x2d:
804eddf5 ff548638 call dword ptr [esi+eax*4+38h] ds:0023:00000074=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 4
PROCESS_NAME: System
ERROR_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in "0x%08lx" verweist auf Speicher in "0x%08lx". Der Vorgang "%s" konnte nicht auf dem Speicher durchgef hrt werden.
EXCEPTION_PARAMETER1: 00000000
EXCEPTION_PARAMETER2: 00000074
READ_ADDRESS: 00000074
FOLLOWUP_IP:
SynCamd!USBCAMD_CallUSBD+95 [C:\Work\DC-1125 Build 2005-02-17 PureSensor\DC-1125_SourceCode\Driver\Sys\SynCamd\StkCamd.c @ 429]
f7906c7b 894508 mov dword ptr [ebp+8],eax
BUGCHECK_STR: 0x7E
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_DEREFERENCE
LAST_CONTROL_TRANSFER: from f7906c7b to 804eddf5
STACK_TEXT:
b89d9cdc f7906c7b b89d9d88 00000001 864e2af1 nt!IopfCallDriver+0x2d
b89d9d0c f7907eeb 853e4324 864e2af1 00000000 SynCamd!USBCAMD_CallUSBD+0x95 [C:\Work\DC-1125 Build 2005-02-17 PureSensor\DC-1125_SourceCode\Driver\Sys\SynCamd\StkCamd.c @ 429]
b89d9d34 f7907f5f 864e2af0 00000000 00000000 SynCamd!USBCAMD_ControlVendorCommandWorker+0xc4 [C:\Work\DC-1125 Build 2005-02-17 PureSensor\DC-1125_SourceCode\Driver\Sys\SynCamd\StkCamd.c @ 2720]
b89d9d5c ee4886dc 853e453b 00000000 00000000 SynCamd!USBCAMD_ControlVendorCommand+0x28 [C:\Work\DC-1125 Build 2005-02-17 PureSensor\DC-1125_SourceCode\Driver\Sys\SynCamd\StkCamd.c @ 2809]
WARNING: Stack unwind information not available. Following frames may be wrong.
b89d9d90 ee4a71e1 853e453b 00000001 00000000 SynMini+0x56dc
b89d9ddc 80540fa2 ee4a71ac 853e453b 00000000 SynMini+0x241e1
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: SynCamd!USBCAMD_CallUSBD+95
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: SynCamd
IMAGE_NAME: SynCamd.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4264b060
STACK_COMMAND: .cxr 0xffffffffb89d9908 ; kb
FAILURE_BUCKET_ID: 0x7E_SynCamd!USBCAMD_CallUSBD+95
kd> imv
kd> lmv
start end module name
804d7000 806cdb80 nt (pdb symbols) c:\symbols\ntkrnlpa.pdb\BD8F451F3E754ED8A34B50560CEB08E31\ntkrnlpa.pdb
Loaded symbol image file: ntkrnlpa.exe
Mapped memory image file: c:\windows\System32\ntkrnlpa.exe
Image path: ntkrnlpa.exe
Image name: ntkrnlpa.exe
Timestamp: Wed Aug 04 07:58:36 2004 (41107B0C)
CheckSum: 002002A6
ImageSize: 001F6B80
File version: 5.1.2600.2180
Product version: 5.1.2600.2180
File flags: 0 (Mask 3F)
File OS: 40004 NT Win32
File type: 1.0 App
File date: 00000000.00000000
Translations: 0407.04b0
CompanyName: Microsoft Corporation
ProductName: Betriebssystem Microsoft® Windows®
InternalName: ntkrnlpa.exe
OriginalFilename: ntkrnlpa.exe
ProductVersion: 5.1.2600.2180
FileVersion: 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
FileDescription: NT-Kernel und -System
LegalCopyright: © Microsoft Corporation. Alle Rechte vorbehalten.
806ce000 806ee380 hal (deferred)
Mapped memory image file: c:\windows\System32\hal.dll
Image path: halaacpi.dll
Image name: halaacpi.dll
Timestamp: Wed Aug 04 07:59:05 2004 (41107B29)
CheckSum: 0002CFD1
ImageSize: 00020380
File type: 2.0 Dll
Translations: 0409.04b0
ProductName: Microsoft® Windows® Operating System
InternalName: halaacpi.dll
OriginalFilename: halaacpi.dll
FileDescription: Hardware Abstraction Layer DLL
LegalCopyright: © Microsoft Corporation. All rights reserved.
b8369000 b836c800 asyncmac (deferred)
Mapped memory image file: c:\windows\System32\drivers\asyncmac.sys
Image path: asyncmac.sys
Image name: asyncmac.sys
Timestamp: Wed Aug 04 08:05:02 2004 (41107C8E)
CheckSum: 0000BB8C
ImageSize: 00003800
File type: 3.6 Driver
InternalName: ASYNCMAC.SYS
OriginalFilename: ASYNCMAC.SYS
FileDescription: MS Remote Access serial network driver
b8475000 b84b5380 HTTP (deferred)
Mapped memory image file: C:\Programme\Debugging Tools for Windows (x86)\sym\HTTP.sys\41107B6940380\HTTP.sys
Image path: HTTP.sys
Image name: HTTP.sys
Timestamp: Wed Aug 04 08:00:09 2004 (41107B69)
CheckSum: 00043E6A
ImageSize: 00040380
File type: 3.7 Driver
InternalName: http.sys
OriginalFilename: http.sys
FileDescription: HTTP Protocol Stack
b8825000 b8839400 wdmaud (deferred)
Mapped memory image file: c:\windows\System32\drivers\wdmaud.sys
Image path: wdmaud.sys
Image name: wdmaud.sys
Timestamp: Wed Aug 04 08:15:03 2004 (41107EE7)
CheckSum: 00023A1D
ImageSize: 00014400
File type: 2.0 Dll
InternalName: WDMAUD
OriginalFilename: WDMAUD.SYS
FileDescription: MMSYSTEM Wave/Midi API mapper
b894a000 b8958d80 sysaudio (deferred)
Mapped memory image file: c:\windows\System32\drivers\sysaudio.sys
Image path: sysaudio.sys
Image name: sysaudio.sys
Timestamp: Wed Aug 04 08:15:54 2004 (41107F1A)
CheckSum: 00013320
ImageSize: 0000ED80
File type: 2.0 Dll
InternalName: sysaudio.sys
OriginalFilename: sysaudio.sys
FileDescription: System Audio WDM Filter
b8ae2000 b8b34180 srv (deferred)
Mapped memory image file: c:\windows\System32\drivers\srv.sys
Image path: srv.sys
Image name: srv.sys
Timestamp: Wed Aug 04 08:14:44 2004 (41107ED4)
CheckSum: 000603B5
ImageSize: 00052180
InternalName: SRV.SYS
OriginalFilename: SRV.SYS
FileDescription: Server driver
b8b85000 b8bb1400 mrxdav (deferred)
Mapped memory image file: c:\windows\System32\drivers\mrxdav.sys
Image path: mrxdav.sys
Image name: mrxdav.sys
Timestamp: Wed Aug 04 08:00:49 2004 (41107B91)
CheckSum: 000398F1
ImageSize: 0002C400
InternalName: MRxDav.sys
OriginalFilename: MRxDAV.Sys
FileDescription: Windows NT WebDav Minirdr
b8c9a000 b8c9ce40 mdmxsdk (deferred)
Mapped memory image file: c:\windows\System32\drivers\mdmxsdk.sys
Image path: mdmxsdk.sys
Image name: mdmxsdk.sys
Timestamp: Wed Mar 17 20:04:10 2004 (4058A12A)
CheckSum: 000043F6
ImageSize: 00002E40
File version: 1.0.2.6
Product version: 1.0.2.6
File flags: 3 (Mask 3F) Debug Pre-release
File OS: 10004 DOS Win32
File type: 5.0 VXD
Translations: 0409.04e4
CompanyName: Conexant
ProductName: Diagnostic Interface
InternalName: MDMXSDK
OriginalFilename: MDMXSDK.SYS
ProductVersion: 1.0.2.006
FileVersion: 1.0.2.006
FileDescription: Diagnostic Interface DRIVER
LegalCopyright: Copyright© Conexant Systems, Inc. 2004
b8d3a000 b8d49000 DgiVecp (deferred)
Mapped memory image file: c:\windows\System32\drivers\DGIVECP.SYS
Image path: DgiVecp.sys
Image name: DgiVecp.sys
Timestamp: Wed Aug 11 08:39:36 2004 (4119BF28)
CheckSum: 00010366
ImageSize: 0000F000
File version: 1.1.2.40
Product version: 1.1.2.40
File OS: 40000 NT Base
File type: 3.1 Driver
CompanyName: Samsung Electronics Co., Ltd.
ProductName: Samsung Electronics Co., Ltd. VECP for Windows 2000, XP
InternalName: NT VECP Driver
OriginalFilename: DgivEcp.sys
ProductVersion: 1.1.2.40
FileVersion: 1.1.2.40
PrivateBuild: 1.1.2.40
SpecialBuild: 1.1.2.40
FileDescription: Windows 2k,XP IEEE-1284 parallel class driver for ECP, Byte, and Nibble modes
LegalCopyright: Copyright © 1998, 1999 by Samsung Electronics Co., Ltd.
LegalTrademarks: Copyright © 1998, 1999 by Samsung Electronics Co., Ltd.
Comments: VECP Device Driver
b8e5a000 b8e6f580 irda (deferred)
Mapped memory image file: c:\windows\System32\drivers\irda.sys
Image path: irda.sys
Image name: irda.sys
Timestamp: Wed Aug 04 08:00:50 2004 (41107B92)
CheckSum: 0001C028
ImageSize: 00015580
InternalName: irda.sys
OriginalFilename: irda.sys
FileDescription: IRDA Protocol Driver
b8ed4000 b8ed7280 ndisuio (deferred)
Mapped memory image file: c:\windows\System32\drivers\ndisuio.sys
Image path: ndisuio.sys
Image name: ndisuio.sys
Timestamp: Wed Aug 04 08:03:10 2004 (41107C1E)
CheckSum: 00003A23
ImageSize: 00003280
InternalName: NDISUIO.SYS
OriginalFilename: NDISUIO.SYS
FileDescription: NDIS User mode I/O Driver
b8f04000 b8f068c0 s24trans (deferred)
Mapped memory image file: c:\windows\System32\drivers\s24trans.sys
Image path: s24trans.sys
Image name: s24trans.sys
Timestamp: Fri Oct 15 20:20:02 2004 (417014D2)
CheckSum: 00010433
ImageSize: 000028C0
File version: 9.0.1.3
Product version: 9.0.0.0
File OS: 0 Unknown Base
CompanyName: Intel Corporation
ProductName: Intel Wireless LAN Packet Driver
InternalName: S24TRANS.SYS
OriginalFilename: S24TRANS.SYS
ProductVersion: 9, 0, 0, 0
FileVersion: 9, 0, 1, 3
PrivateBuild: 9, 0, 1, 3
SpecialBuild: 9, 0, 1, 3
FileDescription: Intel WLAN Packet Driver
LegalCopyright: Copyright © Intel Corporation, Inc. 2002-2004 Copyright © Symbol Technologies, Inc. 1995-1998
LegalTrademarks: Copyright © Intel Corporation, Inc. 2002-2004 Copyright © Symbol Technologies, Inc. 1995-1998
Comments: Copyright © Intel Corporation, Inc. 2002-2004 Copyright © Symbol Technologies, Inc. 1995-1998
b8f10000 b8f13be0 AegisP (deferred)
f7904000 f790b520 SynCamd (codeview symbols) SynCamd.sys
Loaded symbol image file: SynCamd.sys
Mapped memory image file: c:\windows\System32\drivers\SynCamd.sys
Image path: SynCamd.sys
Image name: SynCamd.sys
Timestamp: Tue Apr 19 09:16:48 2005 (4264B060)
CheckSum: 0003A8FC
ImageSize: 00007520
File version: 1.0.0.2
Product version: 1.0.0.2
File type: 3.0 Driver
CompanyName: Syntek America Inc.
ProductName: Syntek Universal Serial Bus 2.0 Video Driver
InternalName: SynCamd.sys
OriginalFilename: SynCamd.sys
ProductVersion: 1.0.0.2
FileVersion: 1.0.0.2
PrivateBuild: 1.0.0.2
SpecialBuild: 1.0.0.2
FileDescription: Syntek Universal Serial Bus 2.0 Video Driver
LegalCopyright: Copyright (C) Syntek America Inc. 2003-2004
LegalTrademarks: SynCamd is a registered trademark of Syntek America Inc. SynCamd (TM) is a trademark of Syntek America Inc.
Comments: SynCamd is a registered trademark of Syntek America Inc. SynCamd (TM) is a trademark of Syntek America Inc.
Und das heißt jetzt was?
