HerrFornit
- Juni 2013
Hallo Experten,
habe seit einem Reset auf die Defaultwerte im UEFI gelegentliche BLuescreens of Death mit immer der gleichen Analyse.
Habe das Multi Core enhancement nun wieder aktiviert. Die VID Spannung ist von 1.000 V auf 1.100 V gestiegen. Vielleicht bringt das die Stabilität zurück.
Die Treiber sind aktuell von den Herstellern.
Was meint Ihr?
achaja, ist ein ASrock Mainboard B85m-ITX !
tanx!
System Information (local)
windows version: Windows 8 , 6.2, build: 9200
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 8505430016 total
VM: 2147352576, free: 1925804032
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Fri Freitag, 30.08.2013 18:56:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083013-3515-01.dmp
This was probably caused by the following module: hal.dll (hal+0x2D965)
Bugcheck code: 0x124 (0x0, 0xFFFFFA80075E0028, 0xBF800000, 0x124)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Was meint Ihr?
tanx!
Crash Dump Analysis
