I've been working intensively on the construction of my first PC for the last week and now I'm done with the planning... Maybe someone can take a look at it and say if everything fits.
Welcome to the CB forum!
I wish you a good start and lots of fun.
For helpful tips, please share as much information as possible (being clear about your requirements helps a lot). Then “helping” works very well.
Genügen dir 30 FPS oder sollen es 60 oder gar 144 FPS sein? …
Prozessor (CPU): …
Arbeitsspeicher (RAM): …
Mainboard: …
Netzteil: …
Gehäuse: …
Grafikkarte: …
HDD / SSD: …
8. Möchtest du den PC
selbst zusammenbauen (wie schätzt du dein Vorwissen diesbezüglich ein?) oder
@duAffentier The questionnaire in German could be challenging for a non-native speaker
Please give us some specific use cases about what you're planning to do with your PC, so we can better evaluate the components based on these requirements.
For example the games you want to play, resolution, quality settings, frame rate and maybe other things like Video editing. Also a budget.
Not necessary for mentioned CPUs. I would recommend a cheaper Air cooler instead and investing your money instead where it's most needed. In your case, probably the GPU.
Welcome.
Note that the prices in Germany are different if your location is somewhere else, so recommendations may also differ, some parts may also not be available.
I've yet to see benches of the CPU (I mean it's not even released, right?) and don't remember the specs, if the performance is below a 7600 or the prices are higher, the 7600 should be prefered. The 8600g is a (with reduced cache aka slower??) 7600 with a bigger integrated GPU which you don't actually need with an extra GPU, so most likely the wrong choice (this newer CPU may or may not have additional AI acceleration features).
I am really not sure about the GPU, it has lots of RAM but the performance is probably below the old 6700xt and you, we have yet to see the launch prices.
Just a quick peek at the board, seems fine I guess? Lacks PCIe5 for the NVMe SSD M2 slot but that's unimportant (imo).
Dunno about the RAM, not sure if the clocks can be reached without fiddling.
The chosen SSD in Germany has like only 1 shop with a reasonable price, there is also the PRO model. Anyway, WD SN580/SN770 or Lexar NM790 look fine imo, there are lots of other SSDs ofc.
I personally don't recommend AIOs and suggest you get something like an Endorfy Fera 5.
Can't say anything about the case.
The PSU can deliver twice the power your configured system would need at full load, I think the picked parts would demand less than 300W from your PSU, an ATX 3.x 500W PSU should be more than enough unless you later want to swap to a fat CPU and GPU.
Lemme manually (why am I doing this ;_; ) wing the tl of:
[Bitte fülle den folgenden Fragebogen unbedingt vollständig aus, damit andere Nutzer dir effizient helfen können. Danke! ]
Welche Spiele genau? …
Welche Auflösung? Genügen Full HD (1920x1080) oder WQHD (2560x1440) oder soll es 4K Ultra HD (3840x2160) sein? …
Prozessor (CPU): …
Mainboard: …
Netzteil: …
Gehäuse: …
Grafikkarte: …
HDD / SSD: …
Please fill out the whole, complete questionnary so that other users may be able to efficienctly help ya. Thx
1. Do you want to play games on the PC?
What games exactly?
What Resolution? FHD (1920x1080) or WQHD (2560x1440) or 4K UHD (3840x2160)?
Ultra/high/medium/low graphics settings?
Are 30FPS enough, or 60FPS or do you need 144FPS?
2. Do you want to use the PC for image/music/video editing or CAD? As a hobby or as a professional (for work, durrrp o.O)? What software will you use?
3. Any requirements or wishes (OC, silent, RGB and so on)?
4. How many and what displays do you want to use? Number of displays, model/s, resolution, Hz? FreeSync or G-Sync? A link to the manufacturer or a detailed data sheet (from a price comparision engine) would or could be useful.
5. Du you have an old PC? Maybe some parts can live on in your new machine. Links to the parts could prove useful.
7. When do you wanna buy the PC? Asap or can you still wait for a few weeks/months?
8. Will you assemble the PC yourself, will a shop assemble it or will friends/acquaintances do it?
E: WIP fixing typos... E2: I mean, tbh, the CPU doesn't need much power under load, I see really no reason for an AIO or even a potent air cooler, just get something on the cheaper side like the Fera 5, gets the job done.
E3: Jerb's done I guess.
