Postfix + Courier und Let's encrypt
lordfritte
Juli 2006
Hallo, ich habe ein Problem:
Ich möchte einen STARTTLS E-Mail-Server mit einem Let's Encrypt Zertifikat schützen.
ABER www.checktls.com meldet bei Überprüfung: "STARTTLS command rejected". Hat jemand eine Idee was man da machen kann?
openssl s_client -connect domain:25 -starttls smtp gibt als Ergebnis:
CONNECTED(00000003)
140202956719776:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s23_clnt.c:787:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 332 bytes and written 352 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
Was hat courier da genau mit Postfix am Hut? ;) Ich rate dir courier asap gg dovecot zu tauschen, aber das nur am Rande.
main.cf und master.cf bitte bereit stellen, bei der Informationslage kann dir niemand helfen.
main.cf
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific: Specifying a file name will cause the first
# line of that file to be used as the name. The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_tls_cert_file = /etc/postfix/postfix_default.pem
smtpd_tls_key_file = $smtpd_tls_cert_file
smtpd_use_tls = yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
# See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
# information on enabling SSL in the smtp client.
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_unauth_destination
myhostname = MYDOMAIN.de
alias_maps = hash:/etc/aliases, hash:/var/spool/postfix/plesk/aliases
alias_database = hash:/etc/aliases
mydestination = localhost.rs.hosteurope.de, localhost, localhost.localdomain
relayhost =
mynetworks =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
virtual_mailbox_domains = $virtual_mailbox_maps, hash:/var/spool/postfix/plesk/virtual_domains
virtual_alias_maps = $virtual_maps, hash:/var/spool/postfix/plesk/virtual
virtual_mailbox_maps = , hash:/var/spool/postfix/plesk/vmailbox
transport_maps = , hash:/var/spool/postfix/plesk/transport
smtpd_tls_security_level = may
smtp_tls_security_level = may
smtp_use_tls = no
smtpd_timeout = 3600s
smtpd_proxy_timeout = 3600s
disable_vrfy_command = yes
smtpd_sender_restrictions = check_sender_access hash:/var/spool/postfix/plesk/blacklists, permit_sasl_authenticated
smtpd_client_restrictions = permit_mynetworks, permit_sasl_authenticated
smtp_send_xforward_command = yes
smtpd_authorized_xforward_hosts = 127.0.0.0/8 [::1]/128
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
virtual_mailbox_base = /var/qmail/mailnames
virtual_uid_maps = static:30
virtual_gid_maps = static:31
smtpd_milters = , inet:127.0.0.1:12768
sender_dependent_default_transport_maps = hash:/var/spool/postfix/plesk/sdd_transport_maps
virtual_transport = plesk_virtual
plesk_virtual_destination_recipient_limit = 1
mailman_destination_recipient_limit = 1
virtual_mailbox_limit = 0
content_filter=smtp-amavis:[127.0.0.1]:10024
master.cf
# Postfix master process configuration file. For details on the format
# of the file, see the master(5) manual page (command: "man 5 master" or
# on-line: http://www.postfix.org/master.5.html).
# Do not forget to execute "postfix reload" after editing this file.
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (yes) (never) (100)
smtp inet n - - - - smtpd
#smtp inet n - - - 1 postscreen
#smtpd pass - - - - - smtpd
#dnsblog unix - - - - 0 dnsblog
#tlsproxy unix - - - - 0 tlsproxy
#submission inet n - - - - smtpd
# -o syslog_name=postfix/submission
# -o smtpd_tls_security_level=encrypt
# -o smtpd_sasl_auth_enable=yes
# -o smtpd_reject_unlisted_recipient=no
# -o smtpd_client_restrictions=$mua_client_restrictions
# -o smtpd_helo_restrictions=$mua_helo_restrictions
# -o smtpd_sender_restrictions=$mua_sender_restrictions
# -o smtpd_recipient_restrictions=
# -o smtpd_relay_restrictions=permit_sasl_authenticated,reject
# -o milter_macro_daemon_name=ORIGINATING
#smtps inet n - - - - smtpd
# -o syslog_name=postfix/smtps
# -o smtpd_tls_wrappermode=yes
#628 inet n - - - - qmqpd
pickup unix n - - 60 1 pickup
-o content_filter=
-o receive_override_options=no_header_body_checks
cleanup unix n - - - 0 cleanup
qmgr unix n - n 300 1 qmgr
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
# -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent. See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
# lmtp cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
# mailbox_transport = lmtp:inet:localhost
# virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
# user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
# flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe flags=R user=list:list argv=/usr/lib/plesk-9.0/postfix-mailman ${nexthop} ${user} ${recipient}
plesk_virtual unix - n n - - pipe flags=DORhu user=popuser:popuser argv=/usr/lib/plesk-9.0/postfix-local -f ${sender} -d ${recipient} -p /var/qmail/mailnames
pickup fifo n - - 60 1 pickup
plesk_saslauthd unix y y y - 1 plesk_saslauthd status=5 listen=6 dbpath=/plesk/passwd.db
qmgr fifo n - n 1 1 qmgr
smtps inet n - - - - smtpd -o smtpd_tls_wrappermode=yes
plesk-*.*.*.*-2a01-488-67-1000-b01c-32ec-0-1 unix - n n - - smtp -o smtp_bind_address=*.*.*.* -o smtp_bind_address6=2a01:488:67:1000:b01c:32ec:0:1 -o smtp_address_preference=ipv4
smtp-amavis unix - - - - 2 smtp
-o smtp_data_done_timeout=1200
-o smtp_send_xforward_command=yes
-o disable_dns_lookups=yes
-o max_use=20
127.0.0.1:10025 inet n - - - - smtpd
-o content_filter=
-o local_recipient_maps=
-o relay_recipient_maps=
-o smtpd_restriction_classes=
-o smtpd_delay_reject=no
-o smtpd_client_restrictions=permit_mynetworks,reject
-o smtpd_recipient_restrictions=permit_mynetworks,reject
-o smtpd_data_restrictions=reject_unauth_pipelining
-o smtpd_end_of_data_restrictions=
-o mynetworks=127.0.0.0/8
-o smtpd_error_sleep_time=0
-o smtpd_soft_error_limit=1001
-o smtpd_hard_error_limit=1000
-o smtpd_client_connection_count_limit=0
-o smtpd_client_connection_rate_limit=0
-o receive_override_options=no_header_body_checks,no_unknown_recipient_checks
Bist Du sicher das Du die Zertifikate auch richtig eingebunden hast?
und smtp läuft dann für gewöhnlich auf Port 587.
Nach welcher Anleitung hast du denn den Server aufgesetzt?
Hier nimm diese Anleitung:
https://www.debinux.de/2015/05/mailserver-from-scratch-debian-8/
Die funktioniert bestens und Du kannst die recht leicht an das (vermutlich ) Ubuntu anpassen.
Kleiner Tipp noch: Du musst nicht alles so übernehmen wie es dort angegeben ist. Statt ViMbAdmin 3 kannst Du auch, sofern Du Deine Domains und Postfächer so verwalten willst, auch Postfixadmin nehmen.
Naja ich werde wohl ein riesen Problem haben, was ich ganz vergessen habe zu erwähnen: Der Server wird von einem Plesk verwaltet....
und "/etc/postfix/postfix_default.pem" ist zurzeit ein symlink auf die pem Datei von Let's Encrypt.
Ich überlege ob ich das ganze nochmal komplett neu aufsetze, ohne diese ganze Plesk schei.....
Guter Hinweis, aber ich gehe davon aus dass man die Zertifikate zuerst prüft =) Das naheliegendste, und sollte in den Logs auch direkt zu sehen ob da etwas klemmt.
587 ist submission und hat direkt nichts mit der grundsätzlichen Problematik zu tun. Insofern dein ISP auf 25 nichts filtert / blockiert kannst du auch dort einliefern. In der master.cf war submission nicht aktiviert.
Ich kann es Dir nur empfehlen es "händisch" zu machen. Du lernst sicher mehr über das OS. Das verlinkte HowTo ist wirklich hervorragend und sehr ausführlich. Es gibt einige Kniffe die man zwar auch zu beachten hat aber wenn Du sauber arbeitest hast Du am Ende des Tages einen gut funktionierenden Mailserver. Es wird in diesem HowTo schon großen Wert auf Sicherheit gelegt aber auch hier sind noch erhebliche Nacharbeiten angesagt.
Schau Dir später auf jeden Fall noch einige Werkzeuge zum sichern Deines Servers an. Mailserver stehen immer sehr im Fokus von zwielichtigen Gestalten!
Viel Erfolg
@Patrick888 - das ist natürlich vollkommen richtig was Du schreibst. :-)
