[FONT="Lucida Console"][SIZE="3"]
Analyzing: \\Pc10\shareddocs\Udo RAID5\HDD1.txt
===== MBR INFORMATION ===== at LBA=0
00000001FE 55AA Boot signature='55AA'... valid
. ... Partition Table entry 1 ...
00000001C2 07 Partition Type: NTFS
00000001BE 80 Boot indicator: *** ACTIVE ***
00000001BF 010100 Start CC-HH-SS: 0-001-01
00000001C3 FEFFFF End CC-HH-SS: 1023-254-63 (not CHS addressable)
00000001C6 3F000000 Start (LBA): 63 0-1-1
00000001CA 82597074 Size (Blocks): 1953520002 121600-254-0 953867MiB 931.51GiB
. ... Partition Table entry 2 ...
00000001D2 00 Partition Type: unused partition entry
. ... Partition Table entry 3 ...
00000001E2 00 Partition Type: unused partition entry
. ... Partition Table entry 4 ...
00000001F2 00 Partition Type: unused partition entry
Analyzer Version: 2009072701
===== RAID MPB INFORMATION ===== when MaxLBA=976773168 then from Sector==>976773166 downwards
7470C05C00 496E74656C205261 . RAID
7470C05C08 69642049534D2043 .. Controller
7470C05C10 6667205369672E20 ... Signature: Intel Raid ISM Cfg Sig.
7470C05C18 312E322E3032 .... Version: 1.2.02
7470C05C1E 0000 <reserved>
7470C05C20 811B1B66 MPB checksum: unknown type
7470C05C24 14020000 MPB size: 532
7470C05C28 F316DA69 family ID <first time checksum>
7470C05C2C 363F6C00 Generation <# MPB updates>: 7094070
7470C05C30 F00F0000 Error Log Size: 4080
7470C05C34 00000080 MPB Attributes: checksum verify
7470C05C38 03 # configured disks: 3
7470C05C39 01 # configured volumes: 1
7470C05C3A 02 error log position: 2
7470C05C3B 00 <reserved>
7470C05C3C 00000000 <cache size>
7470C05C40 F316DA69 original family ID: -0
7470C05C44 00000000... <148 Bytes unused>
. --- HDD [0] ---
7470C05CD8 39514D304A5A3635 .
7470C05CE0 0000000000000000 .. Serial: "9QM0JZ65"
7470C05CE8 3060383A Sectors total: 976773168
7470C05CEC 00000200 SCSI ID: Port 0 Path 0 Target 2 Lun 0
7470C05CF0 3A Status Flags: Disk is: Member, Usable, Detected, Claimed,
7470C05CF1 01 Status Flags: contains metadata,
7470C05CF2 00 Status Flags:
7470C05CF3 00 Status Flags: <unused>
7470C05CF4 00000000 owner config number.
7470C05CF8 0000000000000000 .
7470C05D00 0000000000000000 .. <16 bytes unused>
. --- HDD [1] ---
7470C05D08 39514D304A324C42 .
7470C05D10 0000000000000000 .. Serial: "9QM0J2LB"
7470C05D18 3060383A Sectors total: 976773168
7470C05D1C 00000000 SCSI ID: Port 0 Path 0 Target 0 Lun 0
7470C05D20 3A Status Flags: Disk is: Member, Usable, Detected, Claimed,
7470C05D21 01 Status Flags: contains metadata,
7470C05D22 00 Status Flags:
7470C05D23 00 Status Flags: <unused>
7470C05D24 00000000 owner config number.
7470C05D28 0000000000000000 .
7470C05D30 0000000000000000 .. <16 bytes unused>
. --- HDD [2] ---
7470C05D38 39514D304A5A564C .
7470C05D40 0000000000000000 .. Serial: "9QM0JZVL"
7470C05D48 3060383A Sectors total: 976773168
7470C05D4C 00000100 SCSI ID: Port 0 Path 0 Target 1 Lun 0
7470C05D50 3E Status Flags: Disk is: Member, *** Failed ***, Usable, Detected, Claimed,
7470C05D51 01 Status Flags: contains metadata,
7470C05D52 00 Status Flags:
7470C05D53 00 Status Flags: <unused>
7470C05D54 00000000 owner config number.
7470C05D58 0000000000000000 .
7470C05D60 0000000000000000 .. <16 bytes unused>
. --- Volume [0] ---
7470C05D68 7261696435000000 .
7470C05D70 0000000000000000 .. Map Name: "raid5"
7470C05D78 0098707400000000 Sectors: 1953536000
7470C05D80 8C Status Flags: read coalescing, write coalescing, verify and fix
7470C05D81 00 Status Flags:
7470C05D82 0000 <reserved>
7470C05D84 00000000 Reserved Sectors: 0
7470C05D88 00000100 <migration priority,# subvolumes,target id,cng master disk>
7470C05D8C 01010000 <cache policy[2],cng state,cng substate>
7470C05D90 00000000... <40 Bytes unused>
7470C05DB8 98707400 <curr migr unit>
7470C05DBC 00000000 <check point ID>
7470C05DC0 00 Volume migration state: 0 <normal or migrating>
7470C05DC1 02 Volume migration type: 2 <initializing, rebuilding,...>
7470C05DC2 03 Volume dirty: 3
7470C05DC3 FF Volume fs state: 0xFF
7470C05DC4 0000 <verify errors>
7470C05DC6 0000 <verify bad blocks>
7470C05DC8 00000000... <16 Bytes unused>
7470C05DD8 00000000 volume LBA0 offset(LBAs or stripes? - LBAs will run in >2TiB bug): 0
7470C05DDC 084D383A # Sectors/member: 976768264
7470C05DE0 98707400 # Stripes/member: 7631000
7470C05DE4 8000 # Sectors/Stripe: 128 ==> stripesize=64KB
7470C05DE6 02 Volume status: DEGRADED
7470C05DE7 05 RAID Level: RAID-5 Array
7470C05DE8 03 # member disks: 3
7470C05DE9 01 # domains: 1
7470C05DEA 02 failed disk: HDD[2]
7470C05DEB 01 <unused, always 01>
7470C05DEC 00000000... <28 Bytes unused>
7470C05A08 00000000 member order 1: HDD[0] <Serial=9QM0JZ65>
7470C05A0C 01000000 member order 2: HDD[1] <Serial=9QM0J2LB>
7470C05A10 02000001 member order 3: HDD[2] <Serial=9QM0JZVL> *** BAD ***
7470C05A14 === end of metadata ===
Analyzing: \\Pc10\shareddocs\Udo RAID5\HDD2.txt
7470C05C20 7C1B1466 MPB checksum: unknown type
7470C05C2C 353F6C00 Generation <# MPB updates>: 7094069
. --- HDD [0] ---
. --- HDD [1] ---
. --- HDD [2] ---
7470C05D50 3A Status Flags: Disk is: Member, Usable, Detected, Claimed,
7470C05DC2 01 Volume dirty: 1
7470C05DE6 00 Volume status: NORMAL
7470C05DEA FF failed disk: - NONE -
7470C05A10 02000000 member order 3: HDD[2] <Serial=9QM0JZVL>
Analyzing: \\Pc10\shareddocs\Udo RAID5\HDD3.txt
7470C05C20 8B791767 MPB checksum: unknown type
7470C05C2C 3A3F6C00 Generation <# MPB updates>: 7094074
. --- HDD [0] ---
7470C05CE0 3A30000000000000 .. Serial: "9QM0JZ65:0"
7470C05CEC FFFFFFFF MISSING!
7470C05CF0 06 Status Flags: Disk is: Member, *** Failed ***, *** Unusable ***, *** Undetected ***,
7470C05CF1 00 Status Flags:
. --- HDD [1] ---
. --- HDD [2] ---
7470C05D40 3A30000000000000 .. Serial: "9QM0JZVL:0"
7470C05D4C FFFFFFFF MISSING!
7470C05D50 06 Status Flags: Disk is: Member, *** Failed ***, *** Unusable ***, *** Undetected ***,
7470C05D51 00 Status Flags:
7470C05DE6 03 Volume status: FAILED
7470C05A08 00000001 member order 1: HDD[0] <Serial=9QM0JZ65:0> *** BAD ***
7470C05A10 02000001 member order 3: HDD[2] <Serial=9QM0JZVL:0> *** BAD ***
7470C05A14 === end of metadata ===[/SIZE][/FONT]
