limoni@linux-x23800:~> [B]su[/B]
Passwort:
linux-x23800:/home/limoni # [B]fdisk -l[/B]
Platte /dev/sda: 160.0 GByte, 160041885696 Byte
255 heads, 63 sectors/track, 19457 cylinders
Units = Zylinder of 16065 * 512 = 8225280 bytes
Disk identifier: 0x000de2fe
Gerät boot. Anfang Ende Blöcke Id System
/dev/sda1 1 3060 24579418+ 7 HPFS/NTFS
/dev/sda2 * 3061 6119 24571417+ 83 Linux
/dev/sda3 6120 9179 24579450 83 Linux
/dev/sda4 9180 17898 70035367+ 5 Erweiterte
/dev/sda5 9180 9309 1044193+ 82 Linux Swap / Solaris
/dev/sda6 9310 12369 24579418+ 83 Linux
/dev/sda7 12370 14980 20972826 83 Linux
/dev/sda8 14981 16286 10490413+ 83 Linux
/dev/sda9 16287 17898 12948358+ 83 Linux
Platte /dev/sdb: 250.0 GByte, 250059350016 Byte
255 heads, 63 sectors/track, 30401 cylinders
Disk identifier: 0x000eb28b
/dev/sdb1 1 2611 20972826 83 Linux
/dev/sdb2 2612 5222 20972857+ 83 Linux
/dev/sdb3 5223 30401 202250317+ f W95 Erw. (LBA)
/dev/sdb5 5223 5745 4200966 82 Linux Swap / Solaris
/dev/sdb6 5746 18800 104864256 83 Linux
linux-x23800:/home/limoni # [B]hwinfo --short[/B]
cpu:
AMD Athlon(tm) 64 X2 Dual Core Processor 3800+, 1000 MHz
keyboard:
/dev/input/event0 AT Translated Set 2 keyboard
mouse:
/dev/input/mice Microsoft IntelliEye Mouse
printer:
/dev/usb/lp0 Brother HL-5040 series
monitor:
Generic Monitor
graphics card:
ASUSTeK GeForce 6200
sound:
Creative SB Audigy LS
storage:
Floppy disk controller
ASRock In ASRock 939Dual-SATA2 Motherboard IDE (PATA)
ASRock In JMicron 20360/20363 AHCI Controller
network:
eth1 ASRock In ULi 1689,1573 integrated ethernet.
eth0 Realtek RT8139
network interface:
lo Loopback network interface
eth1 Ethernet network interface
eth0 Ethernet network interface
disk:
/dev/sda SAMSUNG SP1604N
/dev/sdb SAMSUNG SP2504C
partition:
/dev/sda1 Partition
/dev/sda2 Partition
/dev/sda3 Partition
/dev/sda4 Partition
/dev/sda5 Partition
/dev/sda6 Partition
/dev/sda7 Partition
/dev/sda8 Partition
/dev/sda9 Partition
/dev/sdb1 Partition
/dev/sdb2 Partition
/dev/sdb3 Partition
/dev/sdb5 Partition
/dev/sdb6 Partition
cdrom:
/dev/sr0 HL-DT-ST DVDRAM GSA-4082B
usb controller:
ASRock In USB 2.0 Controller
bios:
BIOS
bridge:
ALi M1695 K8 Northbridge [PCI Express and HyperTransport]
ALi PCI Express Root Port
ALi M1689 K8 Northbridge [Super K8 Single Chip]
ALi AGP8X Controller
ALi M5249 HTT to PCI Bridge
ASRock In M7101 Power Management Controller [PMU]
AMD K8 [Athlon64/Opteron] HyperTransport Technology Configuration
AMD K8 [Athlon64/Opteron] Address Map
AMD K8 [Athlon64/Opteron] DRAM Controller
AMD K8 [Athlon64/Opteron] Miscellaneous Control
hub:
Linux 2.6.22.5-31-default ohci_hcd OHCI Host Controller
Linux 2.6.22.5-31-default ehci_hcd EHCI Host Controller
memory:
Main Memory
unknown:
FPU
DMA controller
PIC
Timer
RTC
Keyboard controller
/dev/lp0 Parallel controller
PS/2 Controller
PnP Unclassified device
/dev/ttyS0 16550A
