Skudrinka
Fleet Admiral
- Sep. 2008
Huhu,
ich komme hier mit den Smart-Werten nicht klar.. Wegen den RAW-Werten..
Hier die Werte:
Hier der gesamte Log:
Kann mir wer das entschlüssenl und was dazu sagen?
Vielen Dank!
Hier die Werte:
Code:
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 100 064 006 - 2212144
3 Spin_Up_Time PO---- 092 091 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 301
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 076 060 045 - 39696811
9 Power_On_Hours -O--CK 099 099 000 - 1015h+07m+16.581s
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 100 100 020 - 63
183 Runtime_Bad_Block -O--CK 100 100 000 - 0
184 End-to-End_Error -O--CK 100 100 099 - 0
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 100 000 - 0 0 0
189 High_Fly_Writes -O-RCK 100 100 000 - 0
190 Airflow_Temperature_Cel -O---K 072 049 040 - 28 (Min/Max 15/39)
191 G-Sense_Error_Rate -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 100 100 000 - 10
193 Load_Cycle_Count -O--CK 100 100 000 - 348
194 Temperature_Celsius -O---K 028 051 000 - 28 (0 15 0 0 0)
195 Hardware_ECC_Recovered -O-RC- 100 064 000 - 2212144
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
240 Head_Flying_Hours ------ 100 253 000 - 222h+35m+09.457s
241 Total_LBAs_Written ------ 100 253 000 - 39625846027
242 Total_LBAs_Read ------ 100 253 000 - 65610521543
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
Code:
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.0-28-amd64] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate BarraCuda 3.5 (SMR)
Device Model: ST8000DM004-2CX188
Serial Number: ZR1185R4
LU WWN Device Id: 5 000c50 0dbaa36a6
Firmware Version: 0001
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5425 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5625
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Dec 31 14:50:41 2024 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Unavailable
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x73) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: (1037) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x30a5) SCT Status supported.
SCT Data Table supported.
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x0c GPL R/O 2048 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x24 GPL R/O 512 Current Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 24 Device vendor specific log
0xa2 GPL VS 8160 Device vendor specific log
0xa6 GPL VS 192 Device vendor specific log
0xa8-0xa9 GPL,SL VS 136 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xb0 GPL VS 9048 Device vendor specific log
0xbd GPL VS 8 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL,SL VS 16 Device vendor specific log
0xc3 GPL,SL VS 8 Device vendor specific log
0xc4 GPL,SL VS 24 Device vendor specific log
0xd1 GPL VS 264 Device vendor specific log
0xd3 GPL VS 1920 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 3
SCT Version (vendor specific): 522 (0x020a)
Device State: Active (0)
Current Temperature: 27 Celsius
Power Cycle Min/Max Temperature: 15/39 Celsius
Lifetime Min/Max Temperature: 15/50 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 3 minutes
Temperature Logging Interval: 59 minutes
Min/Max recommended Temperature: 14/55 Celsius
Min/Max Temperature Limit: 10/60 Celsius
Temperature History Size (Index): 128 (42)
Index Estimated Time Temperature Celsius
43 2024-12-26 09:30 32 *************
44 2024-12-26 10:29 33 **************
45 2024-12-26 11:28 32 *************
46 2024-12-26 12:27 29 **********
47 2024-12-26 13:26 28 *********
48 2024-12-26 14:25 27 ********
49 2024-12-26 15:24 25 ******
50 2024-12-26 16:23 25 ******
51 2024-12-26 17:22 25 ******
52 2024-12-26 18:21 24 *****
53 2024-12-26 19:20 24 *****
54 2024-12-26 20:19 23 ****
55 2024-12-26 21:18 23 ****
56 2024-12-26 22:17 24 *****
... ..( 2 skipped). .. *****
59 2024-12-27 01:14 24 *****
60 2024-12-27 02:13 25 ******
61 2024-12-27 03:12 34 ***************
62 2024-12-27 04:11 ? -
63 2024-12-27 05:10 30 ***********
64 2024-12-27 06:09 37 ******************
65 2024-12-27 07:08 38 *******************
66 2024-12-27 08:07 39 ********************
67 2024-12-27 09:06 38 *******************
68 2024-12-27 10:05 38 *******************
69 2024-12-27 11:04 39 ********************
70 2024-12-27 12:03 39 ********************
71 2024-12-27 13:02 39 ********************
72 2024-12-27 14:01 ? -
73 2024-12-27 15:00 15 -
74 2024-12-27 15:59 35 ****************
75 2024-12-27 16:58 37 ******************
76 2024-12-27 17:57 38 *******************
77 2024-12-27 18:56 38 *******************
78 2024-12-27 19:55 38 *******************
79 2024-12-27 20:54 34 ***************
80 2024-12-27 21:53 31 ************
81 2024-12-27 22:52 31 ************
82 2024-12-27 23:51 32 *************
83 2024-12-28 00:50 29 **********
84 2024-12-28 01:49 26 *******
85 2024-12-28 02:48 24 *****
86 2024-12-28 03:47 24 *****
87 2024-12-28 04:46 23 ****
88 2024-12-28 05:45 22 ***
89 2024-12-28 06:44 22 ***
90 2024-12-28 07:43 22 ***
91 2024-12-28 08:42 23 ****
92 2024-12-28 09:41 23 ****
93 2024-12-28 10:40 23 ****
94 2024-12-28 11:39 22 ***
95 2024-12-28 12:38 23 ****
96 2024-12-28 13:37 34 ***************
97 2024-12-28 14:36 37 ******************
98 2024-12-28 15:35 38 *******************
... ..( 7 skipped). .. *******************
106 2024-12-28 23:27 38 *******************
107 2024-12-29 00:26 35 ****************
108 2024-12-29 01:25 38 *******************
109 2024-12-29 02:24 36 *****************
110 2024-12-29 03:23 35 ****************
111 2024-12-29 04:22 34 ***************
112 2024-12-29 05:21 28 *********
113 2024-12-29 06:20 34 ***************
114 2024-12-29 07:19 27 ********
115 2024-12-29 08:18 23 ****
116 2024-12-29 09:17 21 **
117 2024-12-29 10:16 21 **
118 2024-12-29 11:15 21 **
119 2024-12-29 12:14 23 ****
120 2024-12-29 13:13 26 *******
121 2024-12-29 14:12 27 ********
122 2024-12-29 15:11 28 *********
123 2024-12-29 16:10 27 ********
... ..( 6 skipped). .. ********
2 2024-12-29 23:03 27 ********
3 2024-12-30 00:02 26 *******
4 2024-12-30 01:01 25 ******
5 2024-12-30 02:00 24 *****
6 2024-12-30 02:59 23 ****
7 2024-12-30 03:58 22 ***
8 2024-12-30 04:57 20 *
9 2024-12-30 05:56 20 *
10 2024-12-30 06:55 20 *
11 2024-12-30 07:54 19 -
... ..( 3 skipped). .. -
15 2024-12-30 11:50 19 -
16 2024-12-30 12:49 20 *
17 2024-12-30 13:48 21 **
18 2024-12-30 14:47 22 ***
19 2024-12-30 15:46 23 ****
20 2024-12-30 16:45 25 ******
21 2024-12-30 17:44 26 *******
... ..( 2 skipped). .. *******
24 2024-12-30 20:41 26 *******
25 2024-12-30 21:40 27 ********
26 2024-12-30 22:39 28 *********
27 2024-12-30 23:38 27 ********
28 2024-12-31 00:37 24 *****
29 2024-12-31 01:36 22 ***
30 2024-12-31 02:35 22 ***
31 2024-12-31 03:34 21 **
32 2024-12-31 04:33 21 **
33 2024-12-31 05:32 20 *
40 2024-12-31 12:25 20 *
41 2024-12-31 13:24 24 *****
42 2024-12-31 14:23 26 *******
SCT Error Recovery Control command not supported
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 63 --- Lifetime Power-On Resets
0x01 0x010 4 1015 --- Power-on Hours
0x01 0x018 6 39625845963 --- Logical Sectors Written
0x01 0x020 6 47067070 --- Number of Write Commands
0x01 0x028 6 65610044337 --- Logical Sectors Read
0x01 0x030 6 93887269 --- Number of Read Commands
0x01 0x038 6 - --- Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 230 --- Spindle Motor Power-on Hours
0x03 0x010 4 221 --- Head Flying Hours
0x03 0x018 4 348 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 10 --- Number of High Priority Unload Events
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 27 --- Current Temperature
0x05 0x010 1 22 --- Average Short Term Temperature
0x05 0x018 1 30 --- Average Long Term Temperature
0x05 0x020 1 48 --- Highest Temperature
0x05 0x028 1 0 --- Lowest Temperature
0x05 0x030 1 42 --- Highest Average Short Term Temperature
0x05 0x038 1 22 --- Lowest Average Short Term Temperature
0x05 0x040 1 31 --- Highest Average Long Term Temperature
0x05 0x048 1 30 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 60 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 205 --- Number of Hardware Resets
0x06 0x010 4 74 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 3 Device-to-host register FISes sent due to a COMRESET
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
Vielen Dank!
