dmazurek00
- Feb. 2024
ich versuche, meine Fritzbox als Client mit einem Asus-Router über IPSec zu verbinden.Ich habe die folgende Konfiguration für die Fritzbox erstellt.
Leider gibt die Fritzbox einen Timeout-Fehler zurück, während der Asus-Router anzeigt, dass die Verbindung hergestellt wurde, aber es gibt Meldungen, die ich nicht verstehe.
Ich habe keine Ahnung, was ich in der Fritzbox-Konfiguration ändern kann...
Code:
vpncfg {
connections
enabled = yes;
editable = yes;
conn_type = conntype_lan;
name = "asus";
always_renew = yes;
reject_not_encrypted = no;
dont_filter_netbios = yes;
localip = 0.0.0.0;
local_virtualip = 10.10.10.1;
remotehostname = "xxx.asuscomm.com";
remote_virtualip = 10.10.10.1;
localid {
fqdn = "xxx.myfritz.net";
remoteid {
fqdn = "xxx.asuscomm.com";
mode = phase1_mode_idp;
phase1ss = "alt/aes/sha";
keytype = connkeytype_pre_shared;
key = "xxx";
cert_do_server_auth = no;
use_nat_t = yes;
use_xauth = yes;
xauth {
valid = yes;
username = "xxx";
passwd = "xxx";
use_cfgmode = no;
phase2localid {
ipnet {
ipaddr = 192.168.188.1;
mask = 255.255.255.0;
phase2remoteid {
ipnet {
ipaddr = 192.168.50.1;
phase2ss = "esp-all-all/ah-all/comp-all/pfs";
accesslist = "permit ip any 192.168.50.1 255.255.255.0", "permit ip any 192.168.188.1 255.255.255.0";
ike_forward_rules = "udp 0.0.0.0:500 0.0.0.0:500",
"udp 0.0.0.0:4500 0.0.0.0:4500";
// EOF
Code:
Feb 17 08:40:38 06[NET] received packet: from xxx[500] to xxx[500] (904 bytes)
Feb 17 08:40:38 06[ENC] parsed ID_PROT request 0 [ SA V V V V V V ]
Feb 17 08:40:38 06[IKE] received XAuth vendor ID
Feb 17 08:40:38 06[IKE] received DPD vendor ID
Feb 17 08:40:38 06[IKE] received NAT-T (RFC 3947) vendor ID
Feb 17 08:40:38 06[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Feb 17 08:40:38 06[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID
Feb 17 08:40:38 06[ENC] received unknown vendor ID: xxx
Feb 17 08:40:38 06[IKE] xxx is initiating a Main Mode IKE_SA
Feb 17 08:40:38 06[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
Feb 17 08:40:38 06[ENC] generating ID_PROT response 0 [ SA V V V V ]
Feb 17 08:40:38 06[NET] sending packet: from xxx[500] to xxx[500] (156 bytes)
Feb 17 08:40:39 05[NET] received packet: from xxx[500] to xxx[500] (228 bytes)
Feb 17 08:40:39 05[ENC] parsed ID_PROT request 0 [ KE No NAT-D NAT-D ]
Feb 17 08:40:39 05[ENC] generating ID_PROT response 0 [ KE No NAT-D NAT-D ]
Feb 17 08:40:39 05[NET] sending packet: from xxx[500] to xxx[500] (244 bytes)
Feb 17 08:40:39 06[NET] received packet: from xxx[500] to xxx[500] (124 bytes)
Feb 17 08:40:39 06[ENC] parsed ID_PROT request 0 [ ID HASH N(INITIAL_CONTACT) ]
Feb 17 08:40:39 06[CFG] looking for XAuthInitPSK peer configs matching xxx...xxx[xxx.myfritz.net]
Feb 17 08:40:39 06[CFG] selected peer config "Host-to-Net"
Feb 17 08:40:39 06[ENC] generating ID_PROT response 0 [ ID HASH ]
Feb 17 08:40:39 06[NET] sending packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:40:39 06[ENC] generating TRANSACTION request 3353162671 [ HASH CPRQ(X_USER X_PWD) ]
Feb 17 08:40:39 06[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:40:39 05[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:40:39 05[ENC] parsed INFORMATIONAL_V1 request 314484000 [ HASH N(INITIAL_CONTACT) ]
Feb 17 08:40:39 07[NET] received packet: from xxx[500] to xxx[500] (108 bytes)
Feb 17 08:40:39 07[ENC] parsed TRANSACTION response 3353162671 [ HASH CPRP(X_TYPE X_USER X_PWD) ]
Feb 17 08:40:39 07[IKE] XAuth authentication of 'fritzbox' successful
Feb 17 08:40:39 07[ENC] generating TRANSACTION request 3779228076 [ HASH CPS(X_STATUS) ]
Feb 17 08:40:39 07[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:40:40 08[NET] received packet: from xxx[500] to xxx[500] (60 bytes)
Feb 17 08:40:40 08[ENC] parsed TRANSACTION response 3779228076 [ HASH CP ]
Feb 17 08:40:40 08[IKE] IKE_SA Host-to-Net[1] established between xxx[xxx]...xxx[xxx.myfritz.net]
Feb 17 08:40:40 08[IKE] scheduling reauthentication in 10187s
Feb 17 08:40:40 08[IKE] maximum IKE_SA lifetime 10727s
Feb 17 08:40:40 05[NET] received packet: from xxx[500] to xxx[500] (1484 bytes)
Feb 17 08:40:40 05[ENC] parsed QUICK_MODE request 3709229530 [ HASH SA No KE ID ID ]
Feb 17 08:40:40 05[IKE] no matching CHILD_SA config found for 192.168.188.1..192.168.188.255 === 192.168.50.1..192.168.50.255
Feb 17 08:40:40 05[ENC] generating INFORMATIONAL_V1 request 1661635877 [ HASH N(INVAL_ID) ]
Feb 17 08:40:40 05[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:40:42 07[NET] received packet: from xxx[500] to xxx[500] (1484 bytes)
Feb 17 08:40:42 07[IKE] received retransmit of request with ID 3709229530, but no response to retransmit
Feb 17 08:40:46 05[NET] received packet: from xxx[500] to xxx[500] (1484 bytes)
Feb 17 08:40:46 05[IKE] received retransmit of request with ID 3709229530, but no response to retransmit
Feb 17 08:40:51 05[IKE] sending DPD request
Feb 17 08:40:51 05[ENC] generating INFORMATIONAL_V1 request 1487355878 [ HASH N(DPD) ]
Feb 17 08:40:51 05[NET] sending packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:40:51 07[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:40:51 07[ENC] parsed INFORMATIONAL_V1 response 1487355878 [ HASH N(DPD_ACK) ]
Feb 17 08:40:54 05[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:40:54 05[ENC] parsed INFORMATIONAL_V1 request 2747731623 [ HASH D ]
Feb 17 08:40:54 05[IKE] received DELETE for IKE_SA Host-to-Net[1]
Feb 17 08:40:54 05[IKE] deleting IKE_SA Host-to-Net[1] between xxx[xxx]...xxx[xxx.myfritz.net]
Feb 17 08:40:54 07[NET] received packet: from xxx[500] to xxx[500] (904 bytes)
Feb 17 08:40:54 07[ENC] parsed ID_PROT request 0 [ SA V V V V V V ]
Feb 17 08:40:54 07[IKE] received XAuth vendor ID
Feb 17 08:40:54 07[IKE] received DPD vendor ID
Feb 17 08:40:54 07[IKE] received NAT-T (RFC 3947) vendor ID
Feb 17 08:40:54 07[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Feb 17 08:40:54 07[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID
Feb 17 08:40:54 07[ENC] received unknown vendor ID: xxx
Feb 17 08:40:54 07[IKE] xxx is initiating a Main Mode IKE_SA
Feb 17 08:40:54 07[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
Feb 17 08:40:54 07[ENC] generating ID_PROT response 0 [ SA V V V V ]
Feb 17 08:40:54 07[NET] sending packet: from xxx[500] to xxx[500] (156 bytes)
Feb 17 08:40:55 05[NET] received packet: from xxx[500] to xxx[500] (228 bytes)
Feb 17 08:40:55 05[ENC] parsed ID_PROT request 0 [ KE No NAT-D NAT-D ]
Feb 17 08:40:55 05[ENC] generating ID_PROT response 0 [ KE No NAT-D NAT-D ]
Feb 17 08:40:55 05[NET] sending packet: from xxx[500] to xxx[500] (244 bytes)
Feb 17 08:40:55 07[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:40:55 07[ENC] parsed ID_PROT request 0 [ ID HASH ]
Feb 17 08:40:55 07[CFG] looking for XAuthInitPSK peer configs matching xxx...xxx[xxx.myfritz.net]
Feb 17 08:40:55 07[CFG] selected peer config "Host-to-Net"
Feb 17 08:40:55 07[ENC] generating ID_PROT response 0 [ ID HASH ]
Feb 17 08:40:55 07[NET] sending packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:40:55 07[ENC] generating TRANSACTION request 1085449259 [ HASH CPRQ(X_USER X_PWD) ]
Feb 17 08:40:55 07[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:40:55 06[NET] received packet: from xxx[500] to xxx[500] (108 bytes)
Feb 17 08:40:55 06[ENC] parsed TRANSACTION response 1085449259 [ HASH CPRP(X_TYPE X_USER X_PWD) ]
Feb 17 08:40:55 06[IKE] XAuth authentication of 'fritzbox' successful
Feb 17 08:40:55 06[ENC] generating TRANSACTION request 1568730785 [ HASH CPS(X_STATUS) ]
Feb 17 08:40:55 06[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:40:55 08[NET] received packet: from xxx[500] to xxx[500] (60 bytes)
Feb 17 08:40:55 08[ENC] parsed TRANSACTION response 1568730785 [ HASH CP ]
Feb 17 08:40:55 08[IKE] IKE_SA Host-to-Net[2] established between xxx[xxx]...xxx[xxx.myfritz.net]
Feb 17 08:40:55 08[IKE] scheduling reauthentication in 9950s
Feb 17 08:40:55 08[IKE] maximum IKE_SA lifetime 10490s
Feb 17 08:41:05 07[IKE] sending DPD request
Feb 17 08:41:05 07[ENC] generating INFORMATIONAL_V1 request 3340610179 [ HASH N(DPD) ]
Feb 17 08:41:05 07[NET] sending packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:41:05 08[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:41:05 08[ENC] parsed INFORMATIONAL_V1 response 3340610179 [ HASH N(DPD_ACK) ]
Feb 17 08:41:13 05[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:41:13 05[ENC] parsed INFORMATIONAL_V1 request 4007319260 [ HASH D ]
Feb 17 08:41:13 05[IKE] received DELETE for IKE_SA Host-to-Net[2]
Feb 17 08:41:13 05[IKE] deleting IKE_SA Host-to-Net[2] between xxx[xxx]...xxx[xxx.myfritz.net]
Feb 17 08:41:13 06[NET] received packet: from xxx[500] to xxx[500] (904 bytes)
Feb 17 08:41:13 06[ENC] parsed ID_PROT request 0 [ SA V V V V V V ]
Feb 17 08:41:13 06[IKE] received XAuth vendor ID
Feb 17 08:41:13 06[IKE] received DPD vendor ID
Feb 17 08:41:13 06[IKE] received NAT-T (RFC 3947) vendor ID
Feb 17 08:41:13 06[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Feb 17 08:41:13 06[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID
Feb 17 08:41:13 06[ENC] received unknown vendor ID: xxx
Feb 17 08:41:13 06[IKE] xxx is initiating a Main Mode IKE_SA
Feb 17 08:41:13 06[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
Feb 17 08:41:13 06[ENC] generating ID_PROT response 0 [ SA V V V V ]
Feb 17 08:41:13 06[NET] sending packet: from xxx[500] to xxx[500] (156 bytes)
Feb 17 08:41:14 07[NET] received packet: from xxx[500] to xxx[500] (228 bytes)
Feb 17 08:41:14 07[ENC] parsed ID_PROT request 0 [ KE No NAT-D NAT-D ]
Feb 17 08:41:14 07[ENC] generating ID_PROT response 0 [ KE No NAT-D NAT-D ]
Feb 17 08:41:14 07[NET] sending packet: from xxx[500] to xxx[500] (244 bytes)
Feb 17 08:41:15 08[NET] received packet: from xxx[500] to xxx[500] (124 bytes)
Feb 17 08:41:15 08[ENC] parsed ID_PROT request 0 [ ID HASH N(INITIAL_CONTACT) ]
Feb 17 08:41:15 08[CFG] looking for XAuthInitPSK peer configs matching xxx...xxx[xxx.myfritz.net]
Feb 17 08:41:15 08[CFG] selected peer config "Host-to-Net"
Feb 17 08:41:15 08[ENC] generating ID_PROT response 0 [ ID HASH ]
Feb 17 08:41:15 08[NET] sending packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:41:15 08[ENC] generating TRANSACTION request 3662103569 [ HASH CPRQ(X_USER X_PWD) ]
Feb 17 08:41:15 08[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:41:15 05[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:41:15 05[ENC] parsed INFORMATIONAL_V1 request 4185397064 [ HASH N(INITIAL_CONTACT) ]
Feb 17 08:41:15 06[NET] received packet: from xxx[500] to xxx[500] (108 bytes)
Feb 17 08:41:15 06[ENC] parsed TRANSACTION response 3662103569 [ HASH CPRP(X_TYPE X_USER X_PWD) ]
Feb 17 08:41:15 06[IKE] XAuth authentication of 'fritzbox' successful
Feb 17 08:41:15 06[ENC] generating TRANSACTION request 2739220202 [ HASH CPS(X_STATUS) ]
Feb 17 08:41:15 06[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:41:15 05[NET] received packet: from xxx[500] to xxx[500] (60 bytes)
Feb 17 08:41:15 05[ENC] parsed TRANSACTION response 2739220202 [ HASH CP ]
Feb 17 08:41:15 05[IKE] IKE_SA Host-to-Net[3] established between xxx[xxx]...xxx[xxx.myfritz.net]
Feb 17 08:41:15 05[IKE] scheduling reauthentication in 10108s
Feb 17 08:41:15 05[IKE] maximum IKE_SA lifetime 10648s
Feb 17 08:41:16 05[NET] received packet: from xxx[500] to xxx[500] (1484 bytes)
Feb 17 08:41:16 05[ENC] parsed QUICK_MODE request 1629760856 [ HASH SA No KE ID ID ]
Feb 17 08:41:16 05[IKE] no matching CHILD_SA config found for 192.168.188.0/24 === 192.168.50.1..192.168.50.255
Feb 17 08:41:16 05[ENC] generating INFORMATIONAL_V1 request 4051119710 [ HASH N(INVAL_ID) ]
Feb 17 08:41:16 05[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:41:25 06[IKE] sending DPD request
Feb 17 08:41:25 06[ENC] generating INFORMATIONAL_V1 request 2905348034 [ HASH N(DPD) ]
Feb 17 08:41:25 06[NET] sending packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:41:35 07[IKE] sending DPD request
Feb 17 08:41:35 07[ENC] generating INFORMATIONAL_V1 request 2875680137 [ HASH N(DPD) ]
Feb 17 08:41:35 07[NET] sending packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:41:45 07[JOB] DPD check timed out, enforcing DPD action
Feb 17 08:43:42 06[CFG] rereading secrets
Feb 17 08:43:42 06[CFG] loading secrets from '/etc/ipsec.secrets'
Feb 17 08:43:42 06[CFG] loaded IKE secret for %any
Feb 17 08:43:42 06[CFG] loaded EAP secret for fritzbox
Feb 17 08:43:42 06[CFG] loaded RSA private key from '/etc/ipsec.d/private/svrKey.pem'
Feb 17 08:43:42 06[CFG] rereading ca certificates from '/etc/ipsec.d/cacerts'
Feb 17 08:43:42 06[CFG] loaded ca certificate "C=TW, O=ASUS, CN=ASUS RT-AX5400-3FE8 Root CA" from '/etc/ipsec.d/cacerts/asusCert.pem'
Feb 17 08:43:42 06[CFG] rereading aa certificates from '/etc/ipsec.d/aacerts'
Feb 17 08:43:42 06[CFG] rereading ocsp signer certificates from '/etc/ipsec.d/ocspcerts'
Feb 17 08:43:42 06[CFG] rereading attribute certificates from '/etc/ipsec.d/acerts'
Feb 17 08:43:42 06[CFG] rereading crls from '/etc/ipsec.d/crls'
Feb 17 08:43:43 06[CFG] received stroke: delete connection 'Host-to-Net'
Feb 17 08:43:43 06[CFG] deleted connection 'Host-to-Net'
Feb 17 08:43:43 08[CFG] received stroke: delete connection 'Host-to-Netv2'
Feb 17 08:43:43 08[CFG] deleted connection 'Host-to-Netv2'
Feb 17 08:43:43 06[CFG] received stroke: add connection 'Host-to-Net'
Feb 17 08:43:43 06[CFG] reusing virtual IP address pool 10.10.10.0/24
Feb 17 08:43:43 06[CFG] added configuration 'Host-to-Net'
Feb 17 08:43:43 08[CFG] received stroke: add connection 'Host-to-Netv2'
Feb 17 08:43:43 08[CFG] reusing virtual IP address pool 10.10.10.0/24
Feb 17 08:43:43 08[CFG] loaded certificate "C=TW, O=ASUS, CN=xxx.asuscomm.com" from 'svrCert.pem'
Feb 17 08:43:43 08[CFG] added configuration 'Host-to-Netv2'
Feb 17 08:44:39 05[CFG] rereading secrets
Feb 17 08:44:39 05[CFG] loading secrets from '/etc/ipsec.secrets'
Feb 17 08:44:39 05[CFG] loaded IKE secret for %any
Feb 17 08:44:39 05[CFG] loaded EAP secret for fritzbox
Feb 17 08:44:39 05[CFG] rereading ca certificates from '/etc/ipsec.d/cacerts'
Feb 17 08:44:39 05[CFG] loaded ca certificate "C=TW, O=ASUS, CN=ASUS RT-AX5400-3FE8 Root CA" from '/etc/ipsec.d/cacerts/asusCert.pem'
Feb 17 08:44:39 05[CFG] rereading aa certificates from '/etc/ipsec.d/aacerts'
Feb 17 08:44:39 05[CFG] rereading ocsp signer certificates from '/etc/ipsec.d/ocspcerts'
Feb 17 08:44:39 05[CFG] rereading attribute certificates from '/etc/ipsec.d/acerts'
Feb 17 08:44:39 05[CFG] rereading crls from '/etc/ipsec.d/crls'
Feb 17 08:44:40 05[CFG] received stroke: delete connection 'Host-to-Net'
Feb 17 08:44:40 05[CFG] deleted connection 'Host-to-Net'
Feb 17 08:44:40 06[CFG] received stroke: delete connection 'Host-to-Netv2'
Feb 17 08:44:40 06[CFG] deleted connection 'Host-to-Netv2'
Feb 17 08:44:40 05[CFG] received stroke: add connection 'Host-to-Net'
Feb 17 08:44:40 05[CFG] reusing virtual IP address pool 10.10.10.0/24
Feb 17 08:44:40 05[CFG] added configuration 'Host-to-Net'
Feb 17 08:44:40 06[CFG] received stroke: add connection 'Host-to-Netv2'
Feb 17 08:44:40 06[CFG] reusing virtual IP address pool 10.10.10.0/24
Feb 17 08:44:40 06[CFG] loaded certificate "C=TW, O=ASUS, CN=xxx.asuscomm.com" from 'svrCert.pem'
Feb 17 08:44:40 06[CFG] added configuration 'Host-to-Netv2'
Feb 17 08:46:37 06[NET] received packet: from xxx[500] to xxx[500] (904 bytes)
Feb 17 08:46:37 06[ENC] parsed ID_PROT request 0 [ SA V V V V V V ]
Feb 17 08:46:37 06[IKE] received XAuth vendor ID
Feb 17 08:46:37 06[IKE] received DPD vendor ID
Feb 17 08:46:37 06[IKE] received NAT-T (RFC 3947) vendor ID
Feb 17 08:46:37 06[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Feb 17 08:46:37 06[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID
Feb 17 08:46:37 06[ENC] received unknown vendor ID: xxx
Feb 17 08:46:37 06[IKE] xxx is initiating a Main Mode IKE_SA
Feb 17 08:46:37 06[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
Feb 17 08:46:37 06[ENC] generating ID_PROT response 0 [ SA V V V V ]
Feb 17 08:46:37 06[NET] sending packet: from xxx[500] to xxx[500] (156 bytes)
Feb 17 08:46:38 05[NET] received packet: from xxx[500] to xxx[500] (228 bytes)
Feb 17 08:46:38 05[ENC] parsed ID_PROT request 0 [ KE No NAT-D NAT-D ]
Feb 17 08:46:38 05[ENC] generating ID_PROT response 0 [ KE No NAT-D NAT-D ]
Feb 17 08:46:38 05[NET] sending packet: from xxx[500] to xxx[500] (244 bytes)
Feb 17 08:46:39 06[NET] received packet: from xxx[500] to xxx[500] (124 bytes)
Feb 17 08:46:39 06[ENC] parsed ID_PROT request 0 [ ID HASH N(INITIAL_CONTACT) ]
Feb 17 08:46:39 06[CFG] looking for XAuthInitPSK peer configs matching xxx...xxx[xxx.myfritz.net]
Feb 17 08:46:39 06[CFG] selected peer config "Host-to-Net"
Feb 17 08:46:39 06[ENC] generating ID_PROT response 0 [ ID HASH ]
Feb 17 08:46:39 06[NET] sending packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:46:39 06[ENC] generating TRANSACTION request 1019943078 [ HASH CPRQ(X_USER X_PWD) ]
Feb 17 08:46:39 06[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:46:40 05[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:46:40 05[ENC] parsed INFORMATIONAL_V1 request 4176420332 [ HASH N(INITIAL_CONTACT) ]
Feb 17 08:46:40 06[NET] received packet: from xxx[500] to xxx[500] (108 bytes)
Feb 17 08:46:40 06[ENC] parsed TRANSACTION response 1019943078 [ HASH CPRP(X_TYPE X_USER X_PWD) ]
Feb 17 08:46:40 06[IKE] XAuth authentication of 'fritzbox' successful
Feb 17 08:46:40 06[ENC] generating TRANSACTION request 2969906761 [ HASH CPS(X_STATUS) ]
Feb 17 08:46:40 06[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:46:41 08[NET] received packet: from xxx[500] to xxx[500] (60 bytes)
Feb 17 08:46:41 08[ENC] parsed TRANSACTION response 2969906761 [ HASH CP ]
Feb 17 08:46:41 08[IKE] IKE_SA Host-to-Net[4] established between xxx[xxx]...xxx[xxx.myfritz.net]
Feb 17 08:46:41 08[IKE] scheduling reauthentication in 9753s
Feb 17 08:46:41 08[IKE] maximum IKE_SA lifetime 10293s
Feb 17 08:46:42 05[NET] received packet: from xxx[500] to xxx[500] (1484 bytes)
Feb 17 08:46:42 05[ENC] parsed QUICK_MODE request 1182859716 [ HASH SA No KE ID ID ]
Feb 17 08:46:42 05[IKE] no matching CHILD_SA config found for 192.168.188.0/24 === 192.168.50.1..192.168.50.255
Feb 17 08:46:42 05[ENC] generating INFORMATIONAL_V1 request 3439557106 [ HASH N(INVAL_ID) ]
Feb 17 08:46:42 05[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:46:43 05[NET] received packet: from xxx[500] to xxx[500] (1484 bytes)
Feb 17 08:46:43 05[IKE] received retransmit of request with ID 1182859716, but no response to retransmit
Feb 17 08:46:47 05[NET] received packet: from xxx[500] to xxx[500] (1484 bytes)
Feb 17 08:46:47 05[IKE] received retransmit of request with ID 1182859716, but no response to retransmit
Feb 17 08:46:55 06[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:46:55 06[ENC] parsed INFORMATIONAL_V1 request 1561383136 [ HASH D ]
Feb 17 08:46:55 06[IKE] received DELETE for IKE_SA Host-to-Net[4]
Feb 17 08:46:55 06[IKE] deleting IKE_SA Host-to-Net[4] between xxx[xxx]...xxx[xxx.myfritz.net]
Feb 17 08:46:55 07[NET] received packet: from xxx[500] to xxx[500] (904 bytes)
Feb 17 08:46:55 07[ENC] parsed ID_PROT request 0 [ SA V V V V V V ]
Feb 17 08:46:55 07[IKE] received XAuth vendor ID
Feb 17 08:46:55 07[IKE] received DPD vendor ID
Feb 17 08:46:55 07[IKE] received NAT-T (RFC 3947) vendor ID
Feb 17 08:46:55 07[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Feb 17 08:46:55 07[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID
Feb 17 08:46:55 07[ENC] received unknown vendor ID: xxx
Feb 17 08:46:55 07[IKE] xxx is initiating a Main Mode IKE_SA
Feb 17 08:46:55 07[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
Feb 17 08:46:55 07[ENC] generating ID_PROT response 0 [ SA V V V V ]
Feb 17 08:46:55 07[NET] sending packet: from xxx[500] to xxx[500] (156 bytes)
Feb 17 08:46:56 06[NET] received packet: from xxx[500] to xxx[500] (228 bytes)
Feb 17 08:46:56 06[ENC] parsed ID_PROT request 0 [ KE No NAT-D NAT-D ]
Feb 17 08:46:56 06[ENC] generating ID_PROT response 0 [ KE No NAT-D NAT-D ]
Feb 17 08:46:56 06[NET] sending packet: from xxx[500] to xxx[500] (244 bytes)
Feb 17 08:46:58 07[NET] received packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:46:58 07[ENC] parsed ID_PROT request 0 [ ID HASH ]
Feb 17 08:46:58 07[CFG] looking for XAuthInitPSK peer configs matching xxx...xxx[xxx.myfritz.net]
Feb 17 08:46:58 07[CFG] selected peer config "Host-to-Net"
Feb 17 08:46:58 07[ENC] generating ID_PROT response 0 [ ID HASH ]
Feb 17 08:46:58 07[NET] sending packet: from xxx[500] to xxx[500] (92 bytes)
Feb 17 08:46:58 07[ENC] generating TRANSACTION request 3358068321 [ HASH CPRQ(X_USER X_PWD) ]
Feb 17 08:46:58 07[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:46:58 08[NET] received packet: from xxx[500] to xxx[500] (108 bytes)
Feb 17 08:46:58 08[ENC] parsed TRANSACTION response 3358068321 [ HASH CPRP(X_TYPE X_USER X_PWD) ]
Feb 17 08:46:58 08[IKE] XAuth authentication of 'fritzbox' successful
Feb 17 08:46:58 08[ENC] generating TRANSACTION request 544349541 [ HASH CPS(X_STATUS) ]
Feb 17 08:46:58 08[NET] sending packet: from xxx[500] to xxx[500] (76 bytes)
Feb 17 08:46:58 05[NET] received packet: from xxx[500] to xxx[500] (60 bytes)
Feb 17 08:46:58 05[ENC] parsed TRANSACTION response 544349541 [ HASH CP ]
Feb 17 08:46:58 05[IKE] IKE_SA Host-to-Net[5] established between xxx[xxx]...xxx[xxx.myfritz.net]
Feb 17 08:46:58 05[IKE] scheduling reauthentication in 9904s
Feb 17 08:46:58 05[IKE] maximum IKE_SA lifetime 10444s
