Krautmaster
Fleet Admiral
- Feb. 2007
http://anandtech.com/show/8910/acer-xb280hk-4k-gsync-monitor-review/2
hier ist übrigens n netter Test zum 4k Gsync Modell. Anandtech typisch gut hochgezogen.
Interessant find ich folgende Passage, leider hat ich das Problem schon bei diversen AMD GPUs von Bekannten die 1440p und höher an DP und HDMI betreiben:
Bei nem Dell U2715H der über HDMI angebunden war mussten erst über n AMD Treiber hack die Pixel refresh raten geändert werden damit 1440p +ber HDMI lief... und n Kumpel musste dasselbe bei seiner AMD GPU machen. Das geht halt garnicht =/
HDMI und 1440p ist ja nichts neues....
Zu Hause hatte ich auch anfänglich Probleme mit DP 1.2 und meinen Dualhead Displays an der HD6970. Mittlerweile gehts aber gut.
Bei diesen 4k Displays kann zudem DP 1.3 nicht schnell genug kommen.
There are some other aspects of using this display that I noticed, and while they're probably not a huge issue as most people will be using the XB280HK with NVIDIA GPUs, it’s worth noting that the behavior of my XB280HK with AMD GPUs has at times been quirky. For example, I purchased a longer DisplayPort cable because the included 2m cable can be a bit of a tight reach for my work area. The 3m cable I bought worked fine on all the NVIDIA GPUs I tested, but when I switched to an AMD GPU… no such luck. I had to drop to 4K @ 24Hz to get a stable image, so I ended up moving my PC around and going back to the original cable.
I’ve also noticed that a very large number of games with AMD GPUs don’t properly scale the resolution to fill the whole screen, so QHD with AMD GPUs often results in a lot of black borders. Perhaps even worse, every game with Mantle support that I’ve tried fails to scale the resolution to the full screen when using Mantle. So Dragon Age Inquisition at 1080p with Mantle fills the middle fourth of the display area and everything else is black. The problem would seem to lie with the drivers and/or Mantle, but it’s odd nonetheless – odd and undesirable; let's hope this gets fixed.
