GREENBARN
- Okt. 2019
Was bedeutet das b hinter der 1.2.03 ? Ist das nun eine Beta oder was bedeutet das?Boombastic schrieb:MSI MAG B550 Tomahawk Final BIOS
Version
7C91vA7
Erscheinungsdatum
2021-07-07
Beschreibung
- Update to AMD ComboAM4PIV2 1.2.0.3b
Model | Version | Date | Description | Download |
L1.45 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L1.65 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L1.82 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L1.62 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L1.75 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS defaul | Download | |
L5.02 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L4.11 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L5.21 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L2.82 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L2.71 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L2.06 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L2.14 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS defaul | Download | |
L2.06 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS defaul | Download | |
L1.85 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS defaul | Download | |
L4.51 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
3.80 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
3.80 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default *To support Renoir/ Ryzen™ 5000 processors, it requires to update the BIOS with Matisse CPU. | Download | |
L1.75 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
4.20 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default *To support Renoir/ Ryzen™ 5000 processors, it requires to update the BIOS with Matisse CPU. | Download | |
4.60 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
3.14 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default | Download | |
L3.52 | 8/5/2021 | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.3 Patch C 2. Enable AMD CPU fTPM in BIOS default *To support Renoir/ Ryzen™ 5000 processors, it requires to update the BIOS with Matisse CPU. | Download |
ist anscheinend kein beta mehr, mein b450 gaming-itx/ac hat jetzt 4.60 statt der 4.51VelleX schrieb:Patch C jetzt auch bei ASRock
