Jemand eine idee? *help*
Fehler:
Der folgende Fehler wurde generiert, als "$error.Clear();
$maxWait = New-TimeSpan -Minutes 8
$timeout = Get-Date;
$timeout = $timeout.Add($maxWait);
$currTime = Get-Date;
$successfullySetConfigDC = $false;
while($currTime -le $timeout)
$setSharedCDCErrors = @();
try
Set-SharedConfigDC -DomainController $RoleDomainController -ErrorVariable setSharedCDCErrors -ErrorAction SilentlyContinue;
$successfullySetConfigDC = ($setSharedCDCErrors.Count -eq 0);
if($successfullySetConfigDC)
break;
Write-ExchangeSetupLog -Info ("An error ocurred while setting shared config DC. Error: " + $setSharedCDCErrors[0]);
catch
Write-ExchangeSetupLog -Info ("An exception ocurred while setting shared config DC. Exception: " + $_.Exception.Message);
Write-ExchangeSetupLog -Info ("Waiting 30 seconds before attempting again.");
Start-Sleep -Seconds 30;
if( -not $successfullySetConfigDC)
Write-ExchangeSetupLog -Error "Unable to set shared config DC.";
" ausgeführt wurde: "System.Exception: Unable to set shared config DC.
bei Microsoft.Exchange.Configuration.Tasks.Task.ThrowError(Exception exception, ErrorCategory errorCategory, Object target, String helpUrl)
bei Microsoft.Exchange.Configuration.Tasks.Task.WriteError(Exception exception, ErrorCategory category, Object target)
bei Microsoft.Exchange.Management.Deployment.WriteExchangeSetupLog.InternalProcessRecord()
bei Microsoft.Exchange.Configuration.Tasks.Task.<ProcessRecord>b__b()
bei Microsoft.Exchange.Configuration.Tasks.Task.InvokeRetryableFunc(String funcName, Action func, Boolean terminatePipelineIfFailed)".
Fehler:
try
break;
catch
