CpU & GrAkA
- Mai 2009
heute hab ich mal mal geschaut wieder 280 players online .
10+ server mit mehr als 50 leuten
Dann gibt es noch, wenn man den Singleplayermodus abgeschlossen hat zweiPriorität auf low
please try changing MaxChannels in GCEngine.ini located in
<path to my documents>\My Games\Frontlines - Fuel of War\GCGame\Config folder set:
MaxChannels=32
the value that they have 128 is inpossible for most sound cards. its for Xfi only
In the GPU Driver
scroll down to "Multi display acceleration" and set it to Single display OR Compatibility mode. (I only have one
scroll down to "Threaded Optimization" and select OFF.
disabling the maximize framerate option in advanced video also drastically reduced my stutter
The game runs much smoother if you launch it from here:
\steamapps\common\frontlines fuel of war\Binaries\FFOW_NAT_IP
Try turning off mouse smoothing, it helped a bit with me:
C:\Users\Major_Day\My Documents\My Games\Frontlines - Fuel of War\GCGame\Config\GCInput
[Engine.PlayerInput]
MoveForwardSpeed=1200
MoveStrafeSpeed=1200
LookRightScale=300
LookUpScale=-250
MouseSensitivity=45.000000
DoubleClickTime=0.250000
bEnableMouseSmoothing=false
3. Try to force the game to use DX9, instead of DX11. Try to add the dx9 switch at the end of the FFOW.exe shortcut, and see if this makes any difference or not ? Not sure if this will work properly or not. But give it a try.
e.g. "C:\Program Files\THQ\Frontlines-Fuel of War\Binaries\FFOW.exe" -dx9
GrußOnce you finish the SP, there are 2 extra maps.
At the Main Menu, choose "Bonus Content"
Enter either "sp-street" or "sp-village" in the text box.
These are SP only maps. Have fun!
