M
Michael8549
Hallo, ich habe folgende frage jedes Mal, wenn ich Windows 11 gestartet habe und ein Ordner öffne, ist der Hintergrund weis nur nach dem Start von Windows voran kann es liegen.ist nur für 2-5 sekunden
Operating System: Windows 11 Pro 64-bit (10.0, Build 22621) (22621.ni_release.220506-1250)
System Manufacturer: ASUS
System Model: System Product Name
BIOS: 2703 (type: UEFI)
Processor: 12th Gen Intel(R) Core(TM) i7-12700KF (20 CPUs), ~3.6GHz
Memory: 65536MB RAM
Available OS Memory: 65350MB RAM
Page File: 9223MB used, 60221MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Enabled
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.4.7
DxDiag Version: 10.00.22621.0001 64bit Unicode
Card name: NVIDIA GeForce RTX 3060
Manufacturer: NVIDIA
Chip type: NVIDIA GeForce RTX 3060
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_2504&SUBSYS_39031462&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 44803 MB
Dedicated Memory: 12129 MB
Shared Memory: 32674 MB
Current Mode: 3440 x 1440 (32 bit) (100Hz)
HDR Support: Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G2084_NONE_P2020
Color Primaries: Red(0.662108,0.337891), Green(0.292969,0.641603), Blue(0.144530,0.058594), White Point(0.313478,0.329100)
Display Luminance: Min Luminance = 0.020000, Max Luminance = 880.000000, MaxFullFrameLuminance = 880.000000
Monitor Name: LG HDR WQHD(DP)
Monitor Model: LG HDR WQHD
Monitor Id: GSM7756
Native Mode: 3440 x 1440(p) (99.982Hz)
Output Type: Displayport External
Monitor Capabilities: HDR Supported (BT2020RGB BT2020YCC Eotf2084Supported )
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_NONGDI
Advanced Color: AdvancedColorSupported AdvancedColorEnabled
Mainboard TUF GAMING Z690-PLUS D4
Nvme M2 Firecuda 530 1TB
Memory: 65536MB RAM
Monitor Id: GSM7756
