Pornomafia
- Juni 2008
mein PC friert seit ca. einer Woche immer mal wieder ein, so maximal 2 mal am Tag bisher ... alle 3 - 5 Stunden mal ...
jetzt kam das erste mal nachdem ich den PC wieder anmachen wollte ein Bluescreen samt Minidump :
On Tue 22.07.2014 21:04:27 GMT your computer crashed
crash dump file: C:\Windows\Minidump\072214-10108-01.dmp
This was probably caused by the following module: wdf01000.sys (Wdf01000+0xA9E3)
Bugcheck code: 0xD1 (0xFFFFEF7FDA97C45F, 0x2, 0x1, 0xFFFFF88000E0A9E3)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\wdf01000.sys
product: Betriebssystem Microsoft® Windows®
company: Microsoft Corporation
description: Kernelmodustreiber-Frameworklaufzeit
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Kann irgendjemand was damit anfangen ?
MfG
MfG
